- Redline Mt-85 Trans Fluid
- How should I rebuild?
- Afi forward facing turbo kit
- Best Mivec Cams?
- Evo cams timing
- help evo 7 o2 sensor
- Opinions on Ethamax injectors?
- water pipe ID
- Help with 2nd Gear issue
- Who's running the valve cover nipple to the turbo inlet?
- Video from RRE using a Fluke Ti32 Digital Imaging Video on our Front Mount.
- Cams becoming a bottle neck?
- catch can fluid
- CBRD Half, Koyo Half, Mishimoto Half
- When is a bigger fuel rail needed?
- Axle shaft length
- Pls help me to choose WG spring rate?
- Upgrading the fuel lines...but dont know right length
- CR calculation help
- Ferrea valve face hardness
- Stock Evo 6 ECU Reflash - Pls Share...
- Balance Shaft Sprocket Eliminator ?
- Best compressor wheel choice for GT30 turbine?
- Garrett V-Band Twinscroll Housings at SEMA
- Please help. Car is broke and need ideas to get it moving so I'm not stuck...
- ARP L19 and oringed head questions (high boost)
- Quick Question: What to gap plugs at after installing SpoolinUp COP?
- Does FP still offer rebuild for JB ? Or can the kit be purchased?
- Using Fuel Feed Line As The Return line when upgrading Fuel lines
- car wont crank! fuel pump turns on but no crank. helpe asap
- Why my knocking register suddenly so high???
- 2.3 or 2.4 price
- Evo VII back to the road! Time for a tune
- Partial Throttle Misfire When On Track
- Drivetrain Fluids
- Noise coming from tranny HELP
- 2.3 build questions
- DriveTrain calculations
- SES light help?
- valve seals? smoke..
- ToxicFab Stock Frame Forward Facing Manifold...
- Building heads for standard size valves, keep OEM or go aftermarket?
- Boost leak help?
- AC Pulley making noise? (video)
- possible to upgrade fuel lines in engine compartment without a tune?
- High idle after IAC replacement please help.
- low boost 14psi max (((((
- Tial 50mm BOV and Tial Q BOV springs interchangable?
- New 2.3 build, with massive mystery oil leak.
- intake install went wrong
- At wits end with spark plugs and P0300
- Rods for a 2.3
- are 5speed and 6speed gearbox casings the same?
- No2
- exedy triple issue i think?
- spots on cylinder walls evo 8**PICS**??
- Please advise...
- SEMA video with some new Garrett turbo stuff
- Getting a fair amount of lag out of the stock turbo (more then I should be)
- need some help deciding weather or not to get 280 cams
- Megan o2 vs Open dump o2 housings
- Clutch issue
- theory behind test pipe cutouts/dump gains
- Kelford 280s Stock Motor
- for those running large turbos - gains from gsc s2 to s3 cams?
- Rear diff fluid change
- Aerocharger turbos
- Which timing belt to choose?
- Project 4G69
- Low speed clicking from left front wheel/trans ( not hub bearing or axle related)
- EVO9 MR having major issues
- Transmission guru's chime in please.
- About to set my car ablaze.
- Need help swap evo 8 to 9 motor
- Ignition Coil Booster! Is this Safe???
- Vacuum question for those running GSC S2s
- ACL Bearings, intergrated Thrust washer?
- Only will boost to 11psi
- do i have an aftermarket rear diff?
- quick going 2.4l question
- where to buy...
- TREPerformance TRE-342 Fuel Pump
- Helicoil strength?
- pie cut 11.5 housing vs genuine 10.5
- engine misfire code solution?
- Issue with ETS Intake hitting lower Radiator hose, alternative fix worked great!
- Is this a genuine full race T3 manifold
- best turbo set up for rebuild eng build
- Need a step by step engine removal guide for evo 5
- Need advice on selecting the turbo for my evo9
- Can you tell me why this happens? and did some testing
- 6262 boost level
- loud knocking car died!! helpp
- What is Engine Blue Print mean?
- jmfab vs cbrd intercooler
- Anyone ever try mixing BG sycnromesh and MT90?
- ef3 vs new fp red bb
- What turbo is best for e85?
- Trans Help.
- Please help. What to do next?
- 06 evo 9 upgrades
- new PTE DBB 6765 turbo whining after shut off !
- Need some input
- What does a stock Evo rod look like before it breaks?
- White smoke from exhaust?
- Tuning after a o2 dump install?
- No spark or injector firing after engine swap.
- Stock injector o ring replacement with ,OEM, FIC ....ect.
- QM Twin Installed Loud Noise
- EF3, BB Green or BB BBK?
- i need your afr's please!!!!
- Severe backfire and engine power cut - WOT, full boost @ 5.5k RPM
- VIII gsr engine/ fuel trouble
- Tomeii Expreme Ti Exhaust Owners
- Shearer o2 dump vs JMFab o2 dump
- direct injection, way of the future
- T4 .84 TS Question
- E85, 2.3L... decisions decisions
- Double acting WGA
- MAP EF turbos
- IAC Motor Problem?
- Installing Wire O-Rings?
- Clutch travel and engage/disengage
- balance shaft removed, what should my oil level be?
- Evo 4 clutch
- Help, please, i can't decide between 2.1, 2.2 or 2.25
- need front struts asap!
- Alternative to HKS final drive 4.11 gear?
- does anyone in fl have a RRE stealth exhaust
- Compression Test Results and questions
- Any website selling optic scope???
- Ebay Test pipes any long term use issues?
- Port and polish or aftermarket?
- Injectors for running e-85
- Problem with the car after re tune
- E85+Stock Turbo OR Pump Gas+FP Green?
- Can I run the MAF sensor upside down?
- Car dies and wont start
- Car not stalling VTA
- Burnt AMS coil
- BBK-B, FP Black, EF3 for 2.3L pump only
- to keep or not: balance shafts with 2.3 build?
- FP Green Turbo Oil Line Crushed
- O-ringing substitute
- Intercooler pipe work size
- Ralliart center differential identification
- Injen uicp and intake with stock BOV question
- Why do some people remove their oil cooler?
- EFR manifold options
- Coolant Leak but where
- 03' Evo Won't Start After Cam Install
- new high lift Kelford Cams?
- 6 speed mr transmission... Problems to look for?
- Low Oil Pressure
- Help me make a shopping list for easy power from my stock IX
- bent FMIC fins
- HKS intake
- Rebuild fp ball bearing turbos(not stock frame)
- my craptastic catch can full of..... crap?
- stock turbo+cams vs. torque limited HTA green?
- Tranny Popping into gear
- what exhaust to get??
- Going for the drop-in build at English Racing
- Fp BB Green Info (poll)
- Percision vband housing, anyone use one yet?
- Help me find a EVO stock Diverter/BOV :)
- Fp oil return fitting question
- Misfire in all cylinders!!!!!!!!
- Help me get more power out of FP black buschur setup ;)
- WTB Evo 8 Oem Ecu
- FP HTA 3582r compressor housing query
- Bad leak down test. 3 different responses
- Knock sensor replacement
- Check my timing (pics)
- Fitting bigger turbo then driving before being mapped
- Road racing with a FF turbo setup, Can it be done?
- Evo 8 GTX35R w/ 1.06 A/R Twin Scroll Housing.
- 5.0 throttle bodies
- Turbo Upgrade
- Short Runner T4 TS GTX3076R Experiment
- Will an Evo 8 rad fan bolt to Evo 6 rad
- Stupid cam position sensor!
- 3 inch test pipe with 02 bung
- Off-idle/low speed drivability with large cams (BF272, S2, S1, 280s, etc)
- What bov to get for my 1g dsm flange?
- Warped block, head gasket issue? Please help!!
- evo ix BOV help! plz!!!!
- Mivec or cam noise?
- evo 6 engine fit in my 5?
- Back for more advice....
- any one daily drive a Quartermaster twin
- Exhaust design question
- boost leak or BOV problem?
- Fp red e85 build help
- 3 ACD and anti lock light. Help?!
- Open Dump O2 Question
- Evo 8 stock cams part number(s)
- Lancer Question - engine vibriation under load
- setting fuel trims help!
- NOZZS parts any good?
- New exhaust with o2 bang welded off.....
- Need input on cams for my setup, come in.
- Oil filter comparisions
- Dual topic thread: JB 6262 vs HTA3586 and stock ecu vs AEM EMS
- Pic request of OEM pistons
- O-Ringed gead, MAP H11 headstuds
- Oil in cylinder 3, please advise.
- forge pistons or not
- Evolution Evolved- English Racing presents the USDM Auto Evo
- Blown head gasket
- idle air control valve location..vid inside!
- Hks 7460 + gsc s1
- Fortifying the ole 2.0
- Rpm hang, help!
- Tell me what you think of these timing values
- transfercase leak after a hard pull
- FP red turbo vs Precision 6262?
- Belt For Power Steering and AC Delete
- GSC S1 cams in stock in/ex evo 8
- Phantom Vacuum Leak
- Compression test
- HTA86 leaking badly....
- Enough fuel?
- Smoky oil catch can
- What is broken (trans/axle area) Vid
- EVO 9 will not go at all, missing L/F axle
- 6766 turbo ,, go with 2.1L or 2.4L
- AYC checklight on after clutch replacement.
- BBK full turbo
- GT30 turbo questions
- Clutch is letting go...How long???
- Gears Stuck
- Oil loss solution :Is anybody running Kracka Crankcase Vacuum Kit
- MIVEC Noise
- shift problem
- idle issue!..video inside
- New DBB FP Green Installed and Initial Tune
- Exedy tripple owners please step in....
- High Idle when stopped
- can you fix this?
- High HP guys (650+) what Head Gasket are you using?
- Buschur 2.1L water pump question
- Oil changing interval question?
- My Transfer case leaking? (pics)
- PCV fitting thread size?
- runs for about an hour...
- AMS Under Hood Shifter Bushings How To Help!!
- Possible Injector problem please help :)
- Compressor surge with Tial?
