- engine took a poop
- Fp red car acting weird.
- can the excedy triple plate overhaul kit fits the twin plate system
- Exedy Tripple "SR" vs "HR"?
- Low boost? This might be your problem!
- what are the negatives about stiffer motor mounts??
- Browsing for a descent turbo kit
- Engine build questions.
- Mivec Cams
- stock 4g64 (2.4) bottom how much power?
- Vaccum indication at idle
- breaking up at 31lbs....plugs?
- Stronger torque tube?
- How far should you push the MR 6spd
- hks 272 camshafts questions
- Highest horsepower stock block evo
- what type of gasket do you use with your o2 housing or dump?
- Evo8 serpentine belt size
- Need Help with Alt 100amp fuse?
- Benefits of a Flywheel?
- Eneos Gear oil.......anybody? Amsoil?
- HTA Green on 93, 450whp capable?
- The right config
- exhaust cutout.
- 850R guy chime in I need you thought...
- Evo 8 lifter or valve tick
- Let's talk Throttle bodies
- valve cover thread pattern
- help plzzz
- Megan O2 Housing "Doughnut"
- running a gsc 280 intake cam 272 exhaust cam??
- soon-to-be evo 8 e85 fpgreenHTA
- Exhasut manifold studs
- How to make a clutch job more difficult ....
- non acd evo and diff info
- Stock exhaust
- boosting low
- rod bearings
- ACD Lights Turned On After Installing New Battery
- benifits of pcv delete
- tips for removing primary o2 sensor
- Bad Gas
- best flowing true 3" 02 & downpipe
- Tcase leak
- o2 housing dump questions
- 2.0L 11:1 compression Vs 2.1L 10:1 Compression
- arp head stud install torque specs???
- EGR.... is it needed?
- Need some Cheese for my Tcase Whine
- Exdy stage 1 issues?
- All clutches wear similar on Evos?
- Custom Built Cluth 50/50 Ceramic Kevlar
- Map gasket problem w/fp red
- Ran out of gas :/
- compression question regarding new motors
- rev hard manifold
- Building block questions
- My evo build (comment/input)
- Where should my in/HG be at?
- How do I remove Mivec Head from Block ?
- 4g63
- Interesting (??) Downpipe.... heh.
- turbo feed coolant hose size?
- FpBlack spool
- What springs to run w Kelford 272's?
- Oem Clutch w/ aftermarket flywheel?
- Part numbers for seals between trans and t-case
- Need help with double pumper wiring
- Fluid Amounts
- Problems with my clutch
- Need Help!!
- Nisei Engineering Mini Battery Kit Review
- Anyone else idle like garbage?
- James's STM tuned Evo 8
- starter problem
- Stock to t3 60-1 @ 450 crank?
- Car appears to stutter/sputter over 30 psi
- Coil pack and spark plug wires test
- Seafoam'd my Evo
- partial throttle issues,only when hot!
- Idle issue
- carbonetics throwout bearing HELP!!!!!!!
- boost problem , searched
- anybody know?
- what oil for breaking in a motor?
- Lower Front Motor Mount
- Possible clutch slip (but doesn't feel like it)NEED HELP!
- Input Shaft Seal
- Breaking in Motor Question.
- Squealing sounds??
- will No cat make a big difference??
- which bov should i use
- What is the best BOV and Wastegate ?????
- Clutch Noise? SEARCHED
- brian crower valvesprings?
- When is light to light?
- Combustion Chamber Porting
- wierd AFR reading
- HKS Hi Power Fitment....
- Popping sound when I turn...
- CAD drawing of a torque plate?
- FP 4R cams and a stock turbo
- Drop in piston discussion
- Problem with Fidanza 3.2 Clutch
- what do you guys think
- Wrong oil in transfer case
- Exedy Twin PEEPS
- Need some help with a cluth problem
- Done a few timing belts on DSMs, how much more difficult on an Evo IX?
- FP Black owners, what intake are you running?
- Balance Shaft Removal / Replacement - Engine in Situ?
- what do i need to swap a 4g64 in to my evo
- noobish flywheel question
- EGR removal and sputtering...
- Engagement issues and maybe a slip?
- excedy twin plate clutch Q
- Flashing CEL, No code?
- Best Cams for Me???:::
- clutch no launching
- Forge WGA: What spring do I need?
- BC titanium retainers: available a piece?
- Eo8 ecu
- What DP to go with Borla Cat-Back?
- I found this info on another site about Garrett Turbo's.....NAGTROC ..GTR site
- EVO IX wont start after cosworth 272 cam install..HELP!!
- getting tuned on e85.
- For those with forward facing turbos.
- Grinding Issues
- Injectors?
- Evo 5-Speed Custom final drive??
- Supertech springs install questions
- p0011 help....???
- exedy twin install
- High mileage drop-in piston/rod
- check engine light..????
- Injector Dynamics injectors and EMS setup
- Spiking?
- ebrake handle tension question...
- Stalling Issue
- Missing?
- Missing?
- 2.3l 4g63 vs 2.4l 4g64
- EVO VIII 2.3l shortblock from AMS
- About to break 400, what now.
- School me on spark plugs
- ACT 6 Puck Sprung Setups
- Resistor Pack question - Mitsu and honda the same?
- evo 8 non acd in evo 9 how too
- *5th gear grind help PLEASE*
- Serious Backfiring
- Attempt at a quiet 3" exhaust
- What is the stock fuel rail pressure?
- Stalls when clutch is disengaged..
- Need quick help with part please
- T-case Installed Now leaking between trans and tcase
- What do I need for E85?
- Mileage when doing a turbo swap
- weird sound
- Please Help! Violent Jerking in 1st, 2nd & 3rd.
- Evosick2332 quest for a low 10 sec pass on Stock Motor
- Damaged compressor blades cause knock? (pics)
- need input from guys running double pumpers!
- External o2 Dump?
- evap box?
- Car will start intermittently.
- How does my power look for my mod list?
- *2010 Tial QR* Vid
- arp head studs?
- Ported Ex Manifold using a stock turbo
- BOV flutter?
- INLINE RACING -2.0l MOTOR BUILD w/ PICS
- FP Black
- 9.8cm turbine housing on IX, Green or Red turbo?
- Car almost stalls when dropping hood + P0170
- which 2-step to get
- 3 bovs/recirc which one?
- 05 Evo 8 Ticking Lifters?
- whining noise .
- sheptrans/transfer case?????
- What is this?
- FIC 2150cc going lean after spool then settles to target?
- exhaust cam sensor cracked
- Need help removing con rod bearings!!!!
- What would you do next?
- Oil Pump...Which one?
- RS/BadBish Video for the start of 2010
- BBK Full comp upgrade
- heat wrap
- A few quick questions...
- Full-Race, need advice
- AWD Motorsports " Bastard " Round 3.. FP HTA 86 up NEXT!!!
- Stock air filter box question
- help finding lifters
- TOB clip question
- Wheel bearing problem?!?!
- Evo 9 mr --> fp black??
- how hot does a exhaust manifold get?
- Another,... BLOWN motor!
- Spool difference between GT4094r vs Precision's Billet BB 6765
- snapped exhaust manifold bolt that attaches to head, need help
- need some help my cars possessed
- Clutch Help - Evo 7 (same as 8/9)
- installed MBC now low boost
- p0106 and a p0096 DTC codes
- running non water cooled turbo on evo8- how do i block the stock lines?
- Evo 8/9 Starter
- Reading my spark plug
- acd lights all 3 on after my car got broken into
- Opinions on Fuel rail/AMS Feed line...
- Occasional Low Idle When Warm
- Fidanza 3.2 vs. 4.3?
- TOB Problem! Help!
- Siezed driveshaft in front hub assembly
- SP III goes down quick? need support
- High Idle
- Finally figured out the noise!
- evo 8/9 piston rings, where to buy/how much?
- Need help asap
- wht turbo will fit to my full race manifold
- Idle issues: Help- VIDEO inside
- Greddy Profec B Spec II - Multiple beeps on start up then reset??
- ACD fluid lowering when hot?
- GT35RL whats diff??
- hard line under brake booster
- Need Help : INJEN UICP OEM Intake pipe
- Cracking open a 5spd
- thoughts on a top mount forward facing manifold
- How much HP from Porting FP Red
- Muse Intercooler pipe review!
- Help Please: Dilemma on Spark Plugs for 03 VIII
- How long before insulation(?) starts burning up?
- Problem after cam install
- Is this the right gasket for IM?
- Ebay Oil cooler????
- 60K maintenance, replace rods and pistions or wait to build???
- Whinning/hissing noise???
- Is this ok spot for boost soruce
- building block evo 8 advice plz???
- Extrude Hone turbo parts. does it help?
- anyone running a muffler on their dump tubes?
- drip drop
- *HELP, do i need This?
- tial spring pressure: making more boost than rated for?
- evo mr trans....
- Flanges for dummies please...
- SS slave cylinder line
- Lifter tick only when warm??
- Surprise...Surprise (spark plug content)
- Valve spring replacement
- Need advice on what to do next...
