- Help! (MR 6th gear wont engage)
- Help with TO bearing popping out
- Question about 5 and 6 Speed Transmissions
- Timing belt skipped tooth fix...
- Question about HP capabilities / Power Goal
- Throttle hanging up between full throttle shifts
- Need Help!!!!! P0170!!
- 05 evo mr wont start
- Help w/ Cam Angle Senor Orientation
- Your opinion on this OBD-II / ABS / SRS airbag code scanner please..
- Headgasket? :(
- Valve Cover Oil Leak
- Do Evo IX have intercooler sprayers?
- Burning smell Help.
- 2.0 long rod
- Exhaust Smell
- aluminum rods
- Idle Concern
- 4 channel C.O.P. on a standalone ECU
- What Turbo Manifold/Kit does this look like?
- Larger hotside for Stock, Green, Red???
- Please help me diagnose my problems.
- Stroker or not?? Whats best on an evo 9
- Stock 2.0L EVO IX with GT35R turbo kits come in..
- ABS light on...
- anyone got IAT logs for perrin (or any non stock) intake
- Should I make my own Intermediate pipe?
- What is a safe boost # on stock 4g63?
- Motor Mount?
- Which camshafts?
- FP turbo setup for stock manifold and downpipe
- 1200CC injectors, Dual-Fuel pumps, 93-octane - Stock ECU
- Are these the correct NGK Spark Plugs for Evo 8 ?
- What causes High RPM lockout on ACT clutches?
- 1G DSM cam gears into my Evo 8 ???
- Spark Plugs for HTA35R!!!
- Help with wb02 !!!
- Recommended Oil Weights for Evo 8
- Exedy clutch bolts?
- Help with fuel door release
- Slowboy racing engine?
- all around turbo.
- Exedy bolt Help!
- WORKS Pistons
- Upgrading Evo 9 trans to Evo 8 4th and 5th gearing
- Issue with blown tubo * i need your help*
- Clutch
- Car Wont Start any suggestions
- Atp Gt35r
- Exedy Triple Cerametallic Questions
- Will a standard OBD-II scan tool pull ABS codes?
- cams installation
- Exedy twin disc clutch noise.
- peakboost mani.. which rad hose? need ASAP!!!
- ams compatibl with greddy
- Shepherd Transmission Options
- Upgrade path, hows it lookin?
- Please Help, Power steering little wire.
- 2006 EVO IX ACD/Transfer case fluids?
- 2.2L & 2.3L Strokers Passing Emissions
- Are Brian Crowers Really that good?
- Pump Gas Records...
- car hesitates/backfires under acceleration
- GT-A transmission oil change
- Redline Heavy ShockProof Gear Oil or Amsoil SEVERE GEAR SVG?
- Drivetrain question
- Who has heard of CXRacing FMIC's?
- Clocking the turbo WTF?
- Evo + Honda = boosty goodness
- Is 30psi on stock turbo 2 much???
- Straight Pipe Exhaust!
- Shifting problems..
- problem after clutch install HELP
- My Tranny Is Leaking
- Destroyed 1st to 2nd shift fork
- noise when turbo starts to spool
- Is it OK to use Amsoil SVG on EVO 8 TC and Diff?
- evo VIII intake fit on IX??
- No easy way to say this but I put a rod through my block
- idle problem with evo
- White smoke issued
- SES P0031 issue
- What should my spark plug gap be?
- 4.11 final drive
- When/why do I need a fuel pressure regulator?
- Carrillo pro-H beam rods
- Exedy MM022HD installed
- Exeddy mm022HBL clutch
- t-case post
- Upper I/C piping
- rear diff oil change= huge mess/picts :mad:
- Stroker with higher final drive, explain please
- Stock MR drain plug.
- Biggest Cams...?
- "Easiest" way to make 500whp...
- High Mileage Meth Cars
- clutch delay valve?
- FPRed on 91 Octane
- Fp Red
- Car Idles then dies
- What Is my best option in my Situation.
- how much hp with 9 turbo making with no meth
- Buschur Shifter Bushings VS AMS Underhood Shifter Bushings?
- Buschur Racing Mass Air pipe & Filter!?! The Good and the Bad?!?
- Power cut at 6000rpm
- OBD-II scanner
- Longitudinal Engine/Gearbox
- Chromoly Flywheel
- Throttle Body Bypass-Mod
- AEM EMS and my starter
- Need advice on ignition
- SBC (South Bend Clutch) Anyone using one?
- valve train noise issue/or not?
- removed aircon, broke power steering-newbe plz help
- My car is shooting flames
- 1st Mod...What would you do?
- Is my valvetrain screwed?
- anybody heard of this turbo??
- Help!! No 1st & 2nd gear in my 5 month old Evo 9!
- tranny fluid change
- 50 trim dyno results question
- question about meth. inject
- How much boost can you run on FP RED
- O2 sensor - SOS
- Need an education: Swapping 05 ACD Tcase internals into 03-04 non acd Tcase
- Can a diff controller be rebuilt
- Help! Broken bolt!
- Hks T51r
- Good news for LBM evo 9 owners.
- Time Attack Engine
- Full Race manifold question
- Do I have the quickest/fastest stock ecu/mas EVO?
- Help! Timing belt came loose while driving!
- NEED HELP (Very Specific) !!!
- 2006 new eco ix oem tranny-do u still feel the notch?
- FP Green or FP Red?!?!
- 450 whp street monster!!
- Removing sand from inside of MIVEC valve cover???
- Modifying Intake to work with HKS 280
- acd transfer on non acd evo
- clutch install
- Exhaust Manifold ?'s
- fuel press question..
- Strange Problem
- whats the diff betwee rs lsd and aftermarket lsd
- I keep adding fuel and my car still runs lean. Ideas?
- Anyone know where to get Spring clamps locally?
- EvoIII Head
- Radaitor Removal
- Boost Consistancy - Greddy Profec B-Spec II
- Engine not Starting, Help required!
- Competition Clutch Stg 2 for Evo IX MR opinions
- Full Blown's old EVO
- problem shifting 2-3, 4-5
- Help: Boost issues after clutch install
- Can head flow numbers be????
- Fp Hta Dsm88?
- Drop In's
- best exhaust system for the ix
- Cold Start W/ Cams
- How many cam seals do I need?
- electrical problem?
- FP Red w/ Stock Wastegate
- Intercooler kit for evo IX
- video request: kelfords
- ENGINE VIBRATES when clutch engages???
- EVO IX repair manual
- Jdm exhausts
- Best clutch for the AMS 850R turbo kit
- aftermarket crank pully worth it?
- My car seems to be stuck in warm up mode!!!!
- My car is stuck in warm up mode!!!
- Oil leak or Busted CV Joint
- Evo 9, 6 speed
- What would you do? 10.5 vs 50trim turbo
- Clutch Rattle. Need help!
- Comp Cams holding me back?
- Plugs on oil filter housing
- Evo 9 Turbo TME 20G Reviews!!!
- t case and or trans question
- Notchy 3rd gear on low rpm slow shifting but not on high power shifting
- Brief whine in first gear... what could it be?
- 2 fuel tanks; 1 for pump, 1 for race gas
- Oil Return lines
- Correct specs for the GSC S1 Evo 8 Cams?
- wb 02 installation tips?
- Transmission Fluids - 5-Speed - The BEST, and a Mix
- Hole in intake manifold?
- FPRed or BBK or Meth
- Building a motor: How would you go about this!?!
- Evo VIII Factory/Dealership replaced transfer case poll
- Evo IX Factory/Dealership replaced trasfer case poll
- Factory/Dealership replaced Transfer Case poll
- part throttle/high boost
- 03 Evo8 Driveshaft bearings bad, replace whole driveshaft?
- 2.1l strocker
- Boost Creep Help
- walbro fuel pump mods?
- Spark Plug Recommendation??
- Solution for the Trasfer Case issue...
- EVO 7 HRA 16G 9.8 turbo good for 400flywheel hp ?
- Stroke now, Stroke later
- 14MM Hex on mivec Intake cam (2)
- starter electrical problem
- hallman pro question
- Where's the best place to buy a new genesis battery?
- Wanting to take to the next step
- What Turbo Timer Do I Have?
- vacuum at idle
- coolant leak, need help ID source.. pics inside.
- To heat treat or not!!!!!!!!!
- strong vibration sound
- help!! routing of belt
- Evo9 Head Gasket
- Stroking to 2.3L, what mods are needed?
- FP Green VS stock 9 turbo. Looking for feedback
- P0301...help.
- dumptube?
- Which axle sub shaft goes on the drivers side?
- I need help please!!
- 5 spd. vs. 6 spd.
- Tarmac/Gravel/Snow lights are all on!!!! what's the issue?
- Grinding on fifth !!! Synchros ???
- ic piping tought
- Just for curiosity, how 162 rods on a 102 crank?
- Loud Exhaust
- RC vs Clinic
- Forge RS Atmospheric
- I hope this Intake Manifold will bring me to 10's!(pics)
- Stock Head?
- Who is running 4g64 motors? Chime in!
- BOV Flutter?
- Battery that Fits AMS Intercooler piping set up...problems...
- could a evo8 TRANSFER CASE work on a evo9
- Switch to E85 or Kelford 272s?
- Dogbox or something else?
- Help: Spun A Rod bearing
- What FP Green is that?????
- anyone with high HP with balance shafts?
- battery relocation
- 3rd Gear Wont Go In Easy, Why?
- clutch locking me out of gears pressed in
- Clutch Question..(very specific)
- radiator install. No more heater??
- Sparkplug questions???
- TOB will not engage!
- Gsc S3's VS Tomei 280s???
- something wrong?
- Water pump location question
- Perrin Intake kit installed (pics)
