- HKS Twin Power DLI-II CDI Ignition System
- Installed Tomei Poncams 260, but no improvements
- About ACT MonoLock?
- Breaking up
- First gear slap/knock
- Evo IV ayc delete verification
- Evo IX starting issues
- building 2.0 long rod
- Car dies when i push the clutch in!!!
- Weird noise when downshifting from 3rd to 2nd gear
- Walbro 255 install
- Carbonetic twin carbon clutch
- Evo 4 to 8 swap, oil cooler issues
- Help Carbon Fouling
- Help! Turbo boost dropped after new manifold and O2 housing was installed
- building my 2.4 have a few questions
- turbo wont hold boost
- Greddy LS intercooler kit?
- Pros/cons of O-ringing a 4g64 block?
- anybody still using a Tomei M7960?
- Radiator slim fan
- Can transmission fluid leak into the center diff?
- questions on fluids on drivetrain
- Breaking up under high boost after cam install
- Which cams to buy..(brand wise)
- Internal Surge Tank Concept - Test car wanted Detroit area
- Evo 9 over rev issues
- Tial Q 50 Mill Mounting Question
- ETS Short Route I/C Pipe With Perrin Intake
- evo 9 MR not boosting over 10 psi
- Those of you with built motors...I got some pricing questions
- Transmission Issue
- clutch pedal collapsed
- Evo down!
- Diagnosing My Transmission Issue
- Oil Cooler Banjo Bolt Torque
- Exedy twin disk slipping already?
- Serpentine Belt Squeal?
- Really stiff clutch pedal
- 2002 oz rally engine swap
- Excedy Clutch + Cusco Diff's - Issues
- 4G64 harmonic /crank balancer info
- Evo 9 3rd gear whine.
- Gates serpentine belt wont fit
- Random No start
- SD conversion by English Racing – Stock Turbo
- Oil change after cam break in
- Clutch fork issue
- Need advice!
- Trans case swap
- Trouble re-installing transmission HELP!!!
- Walbro 400 e85 type install help?
- Help....what grade oil do you guys use in your evo's?
- Crower Cams
- oil restrictor size??
- boost gauge sensor
- 4 to 8 swap, the exhaust will not fit!
- Awkward boost cut problem? HELP appreciated
- rear o2 sensor hitting drive shaft
- Another rough/lean idle and CEL
- Trans life for guys making 750+hp?
- BR hta3582r lower intercooler pipe
- Just got my pte injectors, how to verify size??
- Common failures?
- thrust bearings
- Oil overfill
- QM 8 Leg Street Version Weight???
- Intermittent CEL for O2 sensor
- engine bearing need help
- Evo 6 hard intercooler piping
- evo 8 misfire
- stock final drive ( maximum speed )
- EVO 8 2003 US Spec
- Safe rpm limiter
- Pon cam type R upgrade
- Precision JB- feed from head or oil housing?
- harmonic balancer missing...
- Exedy twin wont go in gear & ACT monoloc vs stock clip
- Wiseco 1400HD piston to wall clearance
- Car wont go in gear when stationary?
- Oil consumption on new built engine. Checklist.
- delrin solid mount
- Need help to built a better evo 8 transmission to handle 700hp+
- first time engine build
- Ams oil pan with forward facing setup
- 2nd gear issue?
- Quick question for those of you that are running dumptubes out of the hood vent
- How much power standar OEM axle , transfer , gearboks evo8 MR Can hold
- ACD Problem - 3 lights on right away
- Evo 9 stock ic pipe and bov
- Clutch going..
- Help locating a thermostat
- Stripped spark plug hole
- Oil change an new plugs on the 9 with a twist
- cop setup users
- Go 5 speed or build 6 speed for my evo 9 MR??
- injen intake with pipes
- Wiring in some 5v sensors evo 9
- Streetable 6266 Setup - Which Turbine?
- Possible hydrolock pleaseeeeee help!
- evo 8 rod nock plz help>>>
- Help. Tranny noise.
- BOV question
- Bolt/stud size request intake manifold to head
- Evo 6 radiator into an Evo 9 MR
- Oil Filter Housing Oil Flow Direction
- Hard to shift when not in motion
- Paddleshift your Evo 8 or 9......
- Evolution 7 JDM Rear Differential (AYC) Rebuild!?
- Quarter Master/Evo6 5 speed noises.
- modifying stock engine mounts
- Clutch questions
- EVO 6 build, 2.4 Block / Evo 8 head
- Aeromotive Double Pumper w/ pump #1 dead as of now
- Difficulting shifting into gears
- Rough Idle/lean idle
- Cam Sensors Failing.....??
- Evo 5 serious issue!
- Mivec/Non-Mivec
- Engine Bay Temp Comparison Help
- Balance shaft question
- Are VIII and IX throttle bodies the same?
- fuel pump not turnning on
- OEM Main bolts
- Best Location for a Wideband
- Evo 6 LHD steering Rack
- Need help!!!
- Quaife front diff fluid reccomendation.
- 9500rpm in 4th gear mph?
- new build...spun bearing, need suggestion to diagnose problem!
- tranny/rear dif problem
- Turbo laggg
- 3586 TS 1.15 AR turbine housing
- o2 dump and manifold after install issues
- Cant boost past 13psi!!
- 4g63 N stroker kit
- How much power is the evo IX turbo cable of?
- deatschwerks fuel pump failure?
- Help!!
- any ideas on severiity of damage?
- 10.5mm Hotside
- 6466 only bb ???
- Evo 7 Head on Evo 8
- fuel injector questions
- Lower intercooler pipe question evo 8 turbo to hafe HTA3586R
- small 16g
- 5spd difference between 05 and 06?
- 2.4l build help with tolerance??!
- ETS or VRSF 3.5" intercooler
- ? AMS wet slump pan ?
- Evo 5 font diff
- evo 8 clutch fork mounting point broke off, what trans case fits?
- 422whp/365tq Stock block PTE6262
- Help in stroker kit options?
- Gt35r real garret or fake
- help drove through a puddle n think i drown it
- ACT mb7-XTSS VS exedy twin SD
- how to get to 30psi?
- Need to build new motor ( spun bearing ) opinions needed
- Garrett gtx3076r; opinions? housing and manifold options?
- Starting problems.
- cotter pin for axle nut
- Front facing turbo and mini radiator
- Evo 8 cylinder head oil regulator
- Loud exhaust??
- harmonic damper
- Need Evo stage 3 transfer case ACD / AYC type
- manual boost controller leak
- turbo oil in comp side
- Quaife QDH12B in Evo 5 T Case
- Thrust bearing question for turbo nerds
- Build transmission ?
- Building Evo Transmission
- Evo 8-9 non ACD transfer case LSD bearing
- GT3076 rebuild kit
- Turbo?
- Valve stem seals with gsc stage 3 valve springs?
- cometic hg leaks after 1500 miles
- mustang 75mm tb..mustang tps or evo tps
- Evo 7 Boost cut! HELP!
- 05 MR EVO 8 transmission problems.
- Randomly running rich
- stud need for 25psi???
- Concrete method to determine if bov leaks under driving wot condition?
- Retune for different exhaust
- Fuel tank leaking!
- Carbonetics clutch failure rate
- Valve cover gaskets - part numbers and a few lessons
- MIVEC oil line to head
- Built engine ~10% compression difference in 1 cylinder
- Spark plug wont thread in.
- Evo 8/9 on road course - fuel starvation common?
- Pls help on my 2.3L Build
- Low compression test
- Evo going lean stumped
- Balance shaft bearings cracked on install
- Car heating/cooling issues: Educated opinions welcomed
- Evo 4-5-6 gearbox internals to evo 8 swap
- A/C Blower Motor
- Sleeve block to repair damage?
- FP Black DBB - oil in compressor housing question??
- Fuel Pump Relay 3 Colors and Shematics
- Best way to make a 4g64 2.3LR?
- Car Keeps Dying...Help!!!
- Getting oil on my windshield
- 7-10k to spend on evo 8 build
- GSC R2 11:1 2.3L Idle video!
- Help me reach my goal of 140+ trap speeds (which turbo)
- Oil in Radiator & Coolant Reserviour Tank
- Help on cam selection. Evo 8
- Bogging under WOT after tune
- invidia exhaust parts
- trying to save some $$$
- opions on bushwacker trans upgrade
- Stock 2.0L with GT3076R
- Evo ix overheating
- Someone verify BISS adjustment
- camshaft question
- Battery Relocation OEM EvoX (Part Numbers)
- Price for an evo 9 mr six speed transmission
- driveshaft issues
- Evo IV is only boosting 8 pound??
- Installed a mbc then took it off and now my evos running like poop!
- $4,000 to put into my evo 8
- HKS GTII 7460R wastegate question......
- 159mm ROD options best strength weight combo!?
- MR 6-speed W6MAA - what's more important when filling tranny?
- cam markings. Greddy Easy cam vs Stock
- Best evo 9 mivec cnc head options.
- GSC R2s
- GSC 5039 cam springs with stock seats?
- Evo 9 turbo install
- thread pattern on fp black hot side stud???
- clutch slave cylinder
- fuel in oil
- Exhaust questions
- Oil leak, stock motor...quick fix?
- 4g64 questions/compression ratio questions
- Idle issue after driving long distances
- Painting over Swain Tech
- Fp green oil leak? Turbo expert needed!
- 2.4LR FP Black vs 6266 vs ?
- Car wont go into gear again! But on a brand new build!?
- clutch
- Evo 9 gearbox
- Cbrd bbk-c
- Skunk2 intake mani and 74mm tb
- 4'' Intercooler Install HELP
- cam identification
- Will an invidia downpipe bolt up to a Muse motorsports o2 dump?
