- Forge Adjustable Wastgate correct adjustment
- Output channel on ECU flash, EMS etc.
- Need oppinion on how to get longest life on stock internals when upgrading turbo.
- JMFab Drag I/M.. TB and UICP options
- How can you tell a IX RS T-case from a different model's?
- 4.6 or 5.0 tb on ams vsr
- Any experience with JAM lifters?
- Anyone running RC 1600cc injectors..
- FP Evo Flow Advancement Port Cover
- Exhaust Manifold Heat Shield
- Diff, T-case, Trans upgrade re-builds?
- boost issue
- Need some help please
- Alternative Filters to Replace ARC Filter
- Evo 8 or Evo 9 first gear for drag?
- what can i do to make more power
- Strange High Pitched sound
- Bearing housing on my turbo cracked?
- Grimmspeed MBC
- Confirm that this is a 2.4L for an Evo build
- BOV installation. Before or after the tune
- Stock Cat Length
- Infamous p0300 fix?
- putting the tranny back in place
- Exedy rebuild q's (looking for concrete answers)
- Upgrade intake pipe?
- 3" Straight Pipe - Good or Bad?
- Using stock DV, still get BOV Noise
- 65mm tb on stock manifold?
- using stock retainers on upgraded springs???
- 35R Install Question
- Running a half width radiator
- Evo 8 - 10.5 Hotside on an Evo 9 turbo?
- Intercooler Pipe Blowing off
- slave cylinder / clutch issues
- S90 70mm throttle vs OEM in my V RS
- Rebuilding Transmission?
- Wtf bovvv
- OS Giken 1.5 Fitment
- DW300 and Aeromotive 340 fuel pumps
- tranny :(
- Buschur Double Pumper output nipple size???
- OBX Turbo Manifold
- Berk Technology HFC???
- Spring build project
- About clutch kit push style?...
- It's Alive!! ETS Custom Borg Warner Top Mount (S400sx) For Force-Fed Performance!
- Headers and Turbos questions.
- Which 02 housing for better spool?
- Used act pressure plate still good?
- surge port + AEM intake?
- Help with a buschur cast hta kit
- Boost on stock tune only 0.7 to 0.8bar
- FP Turbo Users: Gen 2 Intall Kit required?
- Post up the most mileage you have on the exedy twin/triple
- Crank Question-HELP!
- Built engine oil consumtion
- Carbonetics Blade clutch
- HKS Ti Question
- Aftermarket airbox cover
- Throttle body shaft seals and proper plate sealing
- Simple way to get valve out of head
- Just decapitated my motor...LOTS of Pics!!
- Fluttering noise
- oil cooler lines
- OEM Mitsu Oil
- Odd color Oil In Oil Catch Can
- Engine Mount kit reviews
- Spring tune up? Ideas.
- 2.4L Water Pump Spacer Needed?
- Gaskets Needed when doing cams???
- Is it a time to replace Exedy Twin Plate Clutch?
- anyone have info on the fs635 turbo?
- ACT extreme or hd vs. Spec twin p-trim for 400hp daily driver evo?
- PTE 6262 Journal - proper oiling?
- Stupid Walbro!
- New QM clutch shims installation
- mystery oil leak
- 2.2LR FP Black Build some questions
- plastic piece in transfer case?
- DIY Intake for EVO
- P138?
- New TBE opinions needed
- Overboosting after turbo install
- 5 speed trans with use 6 speed shift
- How to log boost using a Gauge with Datalogging (like AEM WIDEBAND)
- Looking for info on the TD05HRA-15GK2 TME Turbo .
- perrin intake tube + stock UICP = Synapse BOV not fitting!
- Mini Battery kit keeps dying
- Best Intake Manifold for 2.0l with large turbo
- Need help with Greddy Type-S BOV install
- How can I tell what clutch is in the car?
- Clutch Engagement Changes
- no start bad crank sensor?
- Where does this plug go?
- Buschur Fabricated Intake Manifold vs Driven Innovation Intake Manifold
- NEW battery DEAD wtf.. 0.14amps draw??
- small oil leak...help please!!!
- 2.3 Stroker Re-build...?
- Can I pull JUST the shortblock and leave trans/tc in place? (head off)
- Wierd clutch behavior, please help.
- what better GT35R BB or Fp black?
- Valve Cover Rubber Washers
- Exhaust leak?
- i am ordering intercooler ams or ets
- MAP Stock Turbo Tubular Manifold
- Can oem Transfer Case be strengthened...?
- EVO rear diff fluid change
- bov for fp black
- Axle problems!
- E85 E98 - Will fuel tank rust?
- Help with first mods please.
- Replace flywheel with new clutch?
- not building boost during boost leak test
- AEM no weld bung Question
- Exhaust/Muffler testing
- Engine Removal
- GSC Beehive Kit Install height specs needed
- Why can't I achive high boost?
- Smallest 4" air cleaner for 600-650whp
- buschur ported manifold
- My 2.0L FPBlack 2011 Build thread
- Cam Specs Thread - Updated
- Garret 60 trim.... few questions to ask???
- Joe Gibbs XP3 oil
- Looking to upgrade Valve spring.
- Evo 3 info/suggestions
- FIC 1050 cc injector
- Which header
- Time for a new clutch disk!!!
- Help.. What turbo is this??!?!?
- Upgrading from my HKS 272's
- Boost leak tested my car and im getting alot of crank pressure?
- Ams?
- mbc/boost pill questions
- Compression results
- Power Steering Question
- Differentials Setup
- OCV replacement
- shut off, no start
- Head gasket options for 2.4L Mivec
- Cold start poblem
- Draining fuel tank...?
- Pulling Evo 8 motor out from top DIY needed...
- is 93 octane really that much better than 91 octane
- porting exhaust housing on a red
- what else do i need?
- forgot what order the TOB goes in.
- Manual boost controller or Electronic/ECU boost control? Which one?
- engine noise
- Best Ethanol Analyser for Closed Loop Feedback?
- exhaust even the dealers get confused about
- buschur racing mini battery question
- P0011 - cam sensor out of phase 180*???
- just switched to ACT street disc from QUARTERMASTER TWIN
- axel seal replacement?
- Will lowering & adjusting Boost Controller affect the Map?
- Intake for evo 9
- JIC muffler rattles
- Before and After CAMS Opinion
- Axle boot leaking diaqueen instead of grease?!
- On-Boost Compressor Surge Issues
- can the stock turbo be upgraded?
- Please opinion on ignition system
- Turbo ques
- Thickness of Exedy Disk on Clutches
- Which T-Case o go for????
- Question about HTA turbos..
- built 2.4 block with a manley 2.4 crank
- Bullseye Power s362 Billet awesomeness
- A/F problems
- ACD lights on, starter noise after new clutch evo viii
- Clutch rebuild kits?
- Idk what's happening?
- put new clutch in now question about slave cylinder\clutch fork!
- Like new 5 speed trans!!!
- On rev pin ball game.
- Ignition
- <$50 ebay o2 housings
- Buschur 2.1
- MAP Manifold: ported stocker vs tubular
- Built Motor Break in Oil?
- Can a 6 speed clutch work in a 5 speed ???
- Magnus V5 vs AMS F1 Intake
- Flush the tranny/T-case/diff
- un-bend intercooler inlet?
- Evo VIII valve train limit
- miss above 6lbs
- o2 sensor won't fit Megan o2 housing
- Quieter exhaust system for an 07' IX
- Help With Compressor Surge?
- Design your own turbocharger
- Determining if master or slave cylinder is bad
- Whats best in adding octane to 92/93
- clutch
- Help! Identify these GSC cams.
- transfer case
- Build Jacks Transmission,TeamRip OR Shep????Help!
- About ACT clutch kit F1 racing xtreme???
- idle problem with hks272 and rc1000
- Full Race Turbo kit
- evo 5 gearbox vs 1996 legnum gearbox (4.111 final drive)
- Bov Question??
- evo8 upgrade to evo9 turbo
- New clutch slipping in 1st and 2nd gear only?
- Rear Diff upgrade in europe
- ATP'S GARRETT GTX3582R product review
- How to know when too much boost Is Too Much
- New whistle sound
- 84mm surge port with aem intake
- what radiators fit evo 8
- Tons of Knock
- Holding more boost at redline
- is flywheel necessary??
- 44mm wastegate dump tube clamp???
- Cam identification?
- Can I use a VIII O2 sensor on my VII?
- aftermarket intake manifold and pcv system?
- Lightest Clutch/Flywheel Combo?
- hks bov how to install?
- Exedy Twin Hyper HD or SD ?
- E85 gas mileage with GT35R??????
- BBK Full compressor surge at only 27 psi?
- blow-by oil
- Where's this *&%$ thing go?
- Varex Mufflers for us guys that want quiet exhaust.
- Fuel leak advice
- Transfercase/Lsd Questions! help
- Tanabe Touring Medallion, sticks out
- How much time to repair steering wheel being off?
- megan racing type 2 exhuast
- Factory ICS (waterspray) and roadracing
- Can being low on manual transmission fluid mimic a slipping clutch?
- Transfercase click or knock
- Main bearing question
- Opinions on good replacement clutches (~400whp)
- Coolant Pouring out of Water Pump
- Is it okay??? ( AEM Wideband)
- clutch issue..please chime in
- block decking
- full blown dual pump
- AYC - ACD Pump Removal from the evo
- Question about my injectors
- HKS GTII, doing it backwards...
- Gm ait
- system lean code and stalling
- evo 8 3rd gear grinds
- Car stalls, why??? (video)
- Over-Revving Between Gears???
