PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Lancer Evo 7 drivetrain
  2. Help with twin disc
  3. Clutch Lockout - Gearbox shifting theories
  4. Evo 8 Overboosting - Need advice
  5. Freeze Plug Heater Location
  6. Timing belt
  7. Oh no, is this the beginning of the end?
  8. Can the power steering pump be rebuilt?
  9. Sudden power loss at wot
  10. titanium pistons
  11. Clutch pedal stuck in UP position
  12. Getting Rid of drone with APR PREMIUM HELMHOLTZ RESONATOR - 76MM (3")
  13. Evo dies when I push the clutch in. Crank walk??
  14. cv axles install question
  15. HELP coolant in blowby!
  16. Exhaust manifold problem
  17. Timing
  18. Billet Blocks and heads
  19. I know.. another oil leak thread..
  20. Request: Lifter Tick
  21. Evo V - Opinions on condition of stock crankshaft
  22. Evo 4 Gearbox internals
  23. Jdm Evo GTA COOLANT RADIATOR UPGRADE
  24. Boost test
  25. Evo 8 vs Evo 9 OEM muffler
  26. Helppp !!! W/ my evo 8 engine
  27. Opinions on what to get
  28. Is my turbo dead?
  29. ETS T4 1.06 A/R G30-660 vs G30-770
  30. Exedy twin usable service thickness
  31. New Joiner - Garrett GTX3071R / Vi-Pec ECU
  32. No idea what to do next...
  33. Starting Engine for First Time
  34. Car won’t go into gear while running
  35. Weird clutch issue
  36. 3d printed intake manifolds!?
  37. Front hub assemblies
  38. Non ACD JDM Transfer case into Non ACD USDM Evo 8
  39. Lower rad hose hitting slave cylinder boot.
  40. Gearbox code
  41. Building a 2.2 Strocker 4g63 Whats the best piston options
  42. Coolant leak
  43. Any ideas on this noise?
  44. Need validation on TBE components
  45. Transmission/T-case question.
  46. Valve train Failures - Plural
  47. Drivetrain Issue EVO 9
  48. ACD Reservoir Always Low
  49. pte 6466 vs 6870
  50. Switching from PTE to Garrett
  51. Evo 7 turbo hose diagram and bypass options
  52. Evo 7 turbo hose diagram and bypass options
  53. Does anyone have any exp regarding the new FP 57s red/green turbos?
  54. Evo 7 broken clutch, gearbox or transfer case???
  55. General Help Evo IX MR
  56. Coolant air bleeder valve
  57. Brand New Block, High Power Build. Any issues?
  58. Hks 272/264 vs 272/272
  59. Evo 8 short block with JDM Evo 4 head bolted into JDM Evo 4
  60. Where should I start with my mods ?
  61. ‘05 Evolution Burning Oil; Low Compression & Leakdown PSI escaping from Exhaust
  62. Evo Anti Lag Steering Wheel Button
  63. Crank case pressure oil leak
  64. XClutch Twin Disk Sprung Organic Clutch: Unboxing, First Impressions, and Review
  65. What model is my engine evo 5,6,7 or 8
  66. evo makes less boost
  67. Catch can drain line
  68. Anyone bought from copart
  69. Evo 9 head is the same as Kia’s head
  70. Diamond Racing Rear Subframe and TRE Rear Diff with MAX lock
  71. Ayc to Rs diff (should i disable the ayc electronics?)
  72. Evo 8 wont move 🤷‍♀️
  73. Chasing Gremlins with 8.5AFR
  74. 6-spd lost 4th gear question
  75. Rod side clearance
  76. Evo 8 Block O rings
  77. anyone else also done this?
  78. Evo IX Whine
  79. can you change rod bearing without taking the engine apart?
  80. again evo overboosts
  81. Help! Have drivetrain whine under deceleration.
  82. Any help appreciated
  83. Supertech valve seals
  84. Evo 4 starter
  85. FP Red with stock injectors on pump gas?
  86. Grimspeed EBC Malfunctioning?
  87. How to install a 3-port solenoid to EVO 5???
  88. Evo driveshaft hoop evo 4/5/6
  89. Evo 8 clutch pedal assembly
  90. Eagle 94mm crank limit
  91. Any tips for removing midpipe to stock cat bolts?
  92. Tensioner Bolt Broke Off in Oil Filter Bracket
  93. 4G63 weird engine seizure issues
  94. evo 9 turbo markings
  95. evo 8 AYC mustache bar removal advice needed
  96. 4g69 vs 4g64 crankshaft no real info out there
  97. STM o2 downpipe install issue
  98. 05 Lancer Evo 8 - Whining Noise
  99. Choosing clutch for 500 HP Evo IX
  100. Cannot start new build PLEASE HELP
  101. Tapping Valve Cover
  102. system running to rich
  103. RacingDiffs clutch plate repair set
  104. Manley platinum sport Stroker piston Oil support failure
  105. Went for a data logging run
  106. Timing belt setup for Evo6 stroker engine
  107. White smoke out of exhaust when shifting gears
  108. Turbosmart Electric Wastegate
  109. Battery relocation question.
  110. from 3.5 inch exhaust to 3 inch
  111. Is my engine in trouble?
  112. Late Model 4G63 swap into 1990 Galant VR-4
  113. Evo IX MR DD Clutch/Flywheel recommendations?
  114. Need Help With this error code P0108
  115. '96 Evo IV GSR, temporary FWD conversion?
  116. Compression Test Results 65k miles
  117. Fuel pump for 1000whp
  118. Evo x ayc diff into Evo viii
  119. Randomly going rich
  120. Sticky shifter - 6 speed control housing removal help?
  121. Anyone able to get ahold of TRE?
  122. Boost Leak issue
  123. Evo 9 mr slips in 1st gear but not in 2nd or 3rd?
  124. Cat-Delete 02 Sensor
  125. E85 turbo spool AFR!!
  126. Exhaust manifold external waste gate issue
  127. Evo 8 compression ratio! 10.5 vs 9.0
  128. Evo 8 weird whine after about 40 kph
  129. ACD transfer case bleeding
  130. Transfer - transmission oil mixed with gear oil, leaking through breather
  131. need help with AYC lights
  132. E8 starts, runs like garbage, troubleshooting inside
  133. Manley H-Tuff rods
  134. Spark Plugs / Sputtering / Oil Found
  135. Transmission Bearing Shims
  136. Oil pressure Tap location on back of block 8 vs 9
  137. Diff pump solenoid rebuild (acd-ayc)
  138. Stock Evo8 vs Evo9 muffler - they are different
  139. Experience with X-Force/Varex Catback Exhaust for Evo8?
  140. Help wanted! P0011 code and Loud mivec clack
  141. New intense turbo won't go above 23 psi.
  142. Exedy twin disc
  143. Fuel pump rewire won't prime.
  144. Extremely laggy turbo
  145. Block Breathing - Reducing oil in the Catch Can
  146. Who is running 1/2 concrete filled block?
  147. Knocking noise and low oil pressure after WOT
  148. Engine cranks but doesn’t start
  149. Sudden drop in power - what the heck
  150. Banjo Bolt
  151. 3AN line length for Rife Triple Pressure Sensor
  152. Anyone use an outlander diff to replace an evo viii/ix diff?
  153. Stupid Question About Open Dump vs Recirculating
  154. Best Street Turbo for 2.0
  155. Constant Power Steering Pump whine
  156. How long did you starter motor last?
  157. Ultimate Trans Build
  158. Need part number for Aeromotive 340lph Fuel Pump for Evolution 4g63.
  159. Evo 9 AYC rear diff problem
  160. sequential shifter! sqs or s1? or others?
  161. Evo 8 6spd Gearset Options
  162. Center Diff Bearings
  163. Help identifying ETS SS Garrett model with Tial hosusing
  164. Walbro fuel pump, should I buy Fuel Pump Cartridge and Acc or Fuel Tank Assembly?
  165. Evo RS rear diff internals ?
  166. Evo 1-3 Specific Kit. 4G64 wide block to EVO 1-3 Gearbox
  167. A Question compression ratio
  168. unknown engine bay items or wrong intercooler/intake piping
  169. Tcase diff
  170. Front balance shaft out of phase questions
  171. Cracked Head?
  172. 18k spoolup surge/flutter under WOT
  173. Transmission Parts
  174. Oem Airbox max hp ?
  175. 334whp on bone stock Evo 9 on 91 octane?!
  176. Evo 4 Transmission on Evo 8?
  177. Evo 4/5/6 downpipes
  178. ACD problem or Pump maybe the Oil ?
  179. Built Evo 2.0 Oil pressure?
  180. Kelford280 vs S2 question
  181. Egr vacuum regulator solenoid valve
  182. JDM engine swap
  183. Dog Box vs Straight Cut Synchro Gears vs Other
  184. Having trouble getting tcase rebuilt
  185. Scratching metal noise
  186. Varying radiator fan speed when cold.
  187. Aluminum Fluidamper 610702
  188. Magnus V5 vs Skunk2 for Street2Strip car
  189. hicup after lowering fuel pressure
  190. Identifying the turbo
  191. Anyone know how to de-pin the oem crank sensor?
  192. ACD/S-AYC problem
  193. Borgwarner s257sxe on 2.1 liter
  194. fuel level gauge
  195. BISS and aem v2
  196. complete exhaust system
  197. Oil pressure drops at high RPM?
  198. what tune adjustment do I need after cams change from 272 to 280cams(double posting)
  199. dual injector set-up and wiring harness
  200. Evo 4 turbo with 10.5 exhaust housing
  201. horrible idle/staling with GSC S2 cams
  202. running out of fuel, please help!!!
  203. Evo 8 and 9 oil filter housing options?
  204. Exedy tripple issue
  205. 5spd Transmission Rebuild Kit
  206. Water/oil heat exchanger?
  207. Drivetrain Question(s)
  208. Evo 8 Correct Tial Q BOV spring?
  209. wix oil filter help
  210. possible wideband failure?
  211. anyone heard of this ''easy stroker kit''?
  212. boost solenoid/FPR vacuum line question
  213. Quarter Master HRB holes not matching
  214. evo 8 non acd transfer case weld
  215. mac boost solenoid help!!!
  216. fp red 550whp possible??
  217. Turbo hot side removal
  218. turbo elbow pro's and con's?
  219. Rough Idle and Rich AFR
  220. top mount intake options
  221. ARP Mainstuds for 4g63 - can't find anywhere!
  222. Evo 8 overboosting
  223. bleeding my clutch and suddenly lost pressure
  224. Evo 2 Spark Plugs
  225. P0011 MIVEC Code
  226. Bowl Bend/Pocket Port vs Race Port
  227. Oil wont warm up
  228. Drivability - ? EXEDY Triple Cerametallic Clutch Kit for Evo 9
  229. Blown transfer case?
  230. Transfer Case Rebuild - Is that right?
  231. How is your engine doing?
  232. Tomei 85.5mm piston ring gap
  233. 4g63 timing belt
  234. Evo 8 tinny rattle sound.
  235. Running ID2600-XDS
  236. evo map sensor problem
  237. Evo 9 MR Clutch Replacement Recommendation for 2022
  238. Oh crud, what is that sound?
  239. Noobie Question
  240. Third gear scrunching
  241. Quarter master clutch issues
  242. overboost even after a brand new wg(no vac leaks)
  243. Heater hose popped off, how do I fix it?
  244. so how does oil get to the rings?
  245. Fuel Temperature sensor code P0181- FIXED
  246. Noise from the back
  247. balance shaft delete
  248. 2005 evo viii acd problem
  249. Loud Spool and No Boost
  250. ACT Clutch lifespan
