PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 [187] 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. A little help
  2. Tranny and tranfer case oil
  3. clunking sound coming from the side of the motor!!
  4. Got back from TurboTrix...great numbers.
  5. too much boost now?
  6. question
  7. Show your interest in a dry sump kit here
  8. Best clutch for my Evo
  9. help turbo install question
  10. Just ordered RMR catback....
  11. Open Downpipe and MBC Runing @ 312HP
  12. Say no to ARP.
  13. Tial BOV and Stock Turbo
  14. turbo or wastegate?
  15. Safe Boost?
  16. WeaponR Catch Can = Perfect Fit on IX
  17. Anybody have the Full-Race GT3037 or GT3567 on a 2.3L, I can't decide!
  18. need quick help, BIG possible motor problem
  19. Did a compression test ~117psi after 720mi
  20. Blue Evo 8 gets all "Trixxed" out. 363.61 AWHP, 391.95 TQ with major boost leak!!!!
  21. EVO IX - HKS 272 Exh Cam Fits!!
  22. Oil leak, help :(
  23. Anyone No anything about the SSautochrome turbo back exhaust
  24. Buschur ported & coated parts install (pics)
  25. Car wont start, what to do now???
  26. Neisop dsmloggers chat
  27. HP changes ?
  28. Ralliart diff
  29. Confirmed? 05 dp fit 06?
  30. Picture of chassis
  31. Anyone made o2 sim?
  32. Horrible Friday the 13th
  33. Wrong firing order? any damage?
  34. master clinder? or clutch?
  35. Exedy Hyper Single Clutch
  36. Bizarre - Boost Leak Fixed Itself??
  37. Buschur Racing 20G-9 Dyno charts. Pump gas and race gas.
  38. How do I check for a 10.5?
  39. 10.5 hotside flapper question
  40. Works Drop In Filter
  41. Limit of 880cc inj and Walbro 255?
  42. Finally!!
  43. Think i found my boost problem....WARR?
  44. How to I make my car go pssshhht!?
  45. How fast should i be going?
  46. exedy single disc clutch
  47. plz What is the best piggy back for the Evo 8
  48. HKS Cams for the EVO IX
  49. flywheel question
  50. water pump went out AGAIN
  51. Valve springs and retainers guide
  52. Alcohol injection with nitrous
  53. Stock Motor. 8.7k RPM, no problem
  54. 3" High Flow Cat
  55. Tuner's path to 300whp in the Evo IX
  56. Strange timing belt problem
  57. I need some help
  58. ATS Single Carbon TQ Capacity
  59. Intake after tune?
  60. Car almost stalls when...
  61. Electronic or Manual Boost controller???
  62. perrin sound clip
  63. Best 02 housing for the price
  64. removal/venting PCV valve to catch can - I searched!
  65. Full TB review on Evo 9 , please read
  66. Tips for QTP Electronic cut-out (Dump)
  67. Maybe big prob, might be small hehe
  68. APS Exhaust ?
  69. Tial BOV with a flash
  70. Good Clutch?
  71. Another Tilton Install
  72. Evo 8 help
  73. EVO8 turbos converted to EVO9's and 20G's!!
  74. For those running the Forge RS adj. Rec.
  75. Vishnu Xede Or Works/ecutek P2e
  76. Which One Would U Go For??????????
  77. Painted Intercooler?
  78. 6th gear is out
  79. EVO IV Stock Injectors and Fuel pump rated at? ...
  80. New Tilton Clutch/Pics/Install
  81. evo 8 16g question..?
  82. 24psi???????
  83. aem ems and stock box
  84. ok wtf are people always talking sh*t about DSM drive trains
  85. Engine Build Advice
  86. Turbo XS MBC-- Good R Bad
  87. more power mid to top end 264i 272e or 272in 264e
  88. how to improve power in 2k-4k rpm area?
  89. Quick 20g question
  90. evo9 20g, injectors, utec, wideband, o2 housing, all going in!
  91. my twin turbo or turbo electric turbo set up
  92. Best downpipe for the IX?
  93. Rear o2 sensor question
  94. Shop doesn't know...need help
  95. HKS or Buddy Club
  96. Stock Vacuum at idle
  97. Safe to drive 35R untuned?
  98. boost problem
  99. Ever recieved alcohol kit..
  100. HKS 9 Cams at Sema...
  101. Electronic Gauge (PLX R-500)
  102. Shepherd or TRE?
  103. Invidia Cast Stainless 02 housing
  104. stiff/soft spring
  105. Good news!!
  106. sputtering problem
  107. Tanabe concept G blue TBE ?
  108. PO234 code throwing
  109. How much boost?
  110. Yaw Control Feature On Jdm And Uk Evo's ?
  111. runing down pipe only
  112. Eliminating Low Frequency Sounds from the Exhaust
  113. Help: Boost leak on the exhaust side.
  114. CEL comes on even though I have a CEL fix, 5000 miles later???
  115. Maximum boost on stock turbo
  116. Gt37r Turbo
  117. 20G-9 Install Can't get boost under 1.7 bar?
  118. 2nd gear
  119. Touchy Clutch?
  120. service engine soon light
  121. How much hp can the 6.5 tme hold?
  122. Exhaust performance?
  123. Vent Paint Stripped.
  124. TRE trans experience?
  125. 05 EVO, 6500 miles, resurface OEM flywheel or not?
  126. Tech info on fuel line sizing and fuel pump flow
  127. pre-oiler
  128. BR EVO 8 20G TME close inspection
  129. Stiffer spring for APS BOV
  130. what should be my next mod (powerwise)
  131. Fuel Cut?
  132. EVO IX Dyno Thread
  133. 10.5 hotside questions
  134. HKS suction intake????
  135. Timing is being pulled at anything above 17psi/1.2bar!?!
  136. Clutch Prolem?
  137. How does a lightened flywheel feel?
  138. Hose ID for MBC, please help
  139. please help - boost leak/test ?'s
  140. Clutch Opinion?
  141. EVO Engine Diagram
  142. What we know about the EVO IX MIVEC?
  143. The Great Dyno Tune Battle...
  144. My IX's first oil change....
  145. P0300 fix, TSB-05-13-003, what are the updates?
  146. Is this turbo manifold any good?
  147. 30K service soon....
  148. My recent visit to Mitsu aka "Satan"
  149. Looking for a flange
  150. new photoshoot
  151. Sound clips for BR exhausts....poll attached.
  152. Power increase
  153. 400 whp on a IX?
  154. serious problem with Injen intake
  155. Where can I get Hose clamps that are strong ?
  156. 280's vs 272 race results...
  157. 10 Hp+
  158. My New Setup COMING MARCH
  159. 2 problems after FMIC install
  160. More Forge reviews (preliminary results)
  161. BOV Position - Up or Down? Does it matter?
  162. car shakes then CEL
  163. comp cams
  164. Short shifter kit comparison to Honda S2000
  165. MBC gone crazy??
  166. Is this average cost for changing a clutch?
  167. 2.3 engine rebuild
  168. Authority cat-back
  169. po234 almost 0 mods and 75F outside temp
  170. Which cams do I have??
  171. Fujitsubo exhaust question
  172. Evo 9 aftermarket FMIC in disavantage
  173. question about spinning bearings?
  174. Anyone running a GT3076r w/ .82 A/r?
  175. 2.3L engine weight
  176. Exhaust question..
  177. Compression results help
  178. 2.3l Stroker...Daily Driver?
  179. New DP necessary?
  180. Ported Shroud for a 35R
  181. Need advice
  182. Troubleshooting: Clunking Sound in Rear
  183. Buschur 20G install kit question?
  184. 378whp/385tq - 93oct/stock turbo NO alcy/race gas
  185. drivetrain noise normal?
  186. noise when downshifting..any ideas?
  187. Break in period for New EVO IX
  188. instal balance shaft removal kit?
  189. Short Shifter for MR tranny?
  190. Possible exhaust leak?
  191. Injen LICP
  192. Mods Mods Mods
  193. Need Help Added O2 housing and 10.5 Hotside
  194. 42R Boost Levels
  195. Anyone make their exhaust/ic piping?
  196. Better off to just read it......
  197. And now the problems start..
  198. Weird problem with Forge MBC
  199. Help with whining nise, don't think it's a boost leak.
  200. Ported Throttlebody explanation
  201. Carbon, Twin, or Other?
  202. exedy tripple
  203. Nitto Radials
  204. Evo Engine Management / Tuning Help!
  205. What would you do? "building motor"
  206. clutch noises
  207. 5 Speed vs 6 Speed?
  208. Strange sound, loss of boost, BOV or wastegate?
  209. evo cold air intake
  210. engine shut down
  211. Combustion discussion
  212. Help.. car not starting!!!
  213. How To: Powerfelx Motor Mount Bushing Install
  214. Changing Gear Ratios on IX MR
  215. oil temp
  216. type RS stalling problem!!!!
  217. question about rpm converter
  218. Evo9 20g
  219. Who makes 3"dp's w/Flex joint?
  220. powerflex or buschur motor mount/bushing?
  221. idle problems
  222. what fluid to use in 05 x-fer case?
  223. EVO IX MR Flutter?
  224. Sticking Emergency Break?
  225. help me understand stalling with intake!!!
  226. best inlet manifold
  227. stupid intake box!
  228. RPS Clutch. Who so far is running fast with this clutch?
  229. problem maybe
  230. More bad news
  231. 10.5 hotside question
  232. Forged Motorsports Mbc Question
  233. Would a group 26R battery be a good substitute for a Mini-bat
  234. Removing A/C Compressor good for how much WHP???
  235. Anyone using 280 comp cams?
  236. HP, timing vs boost
  237. Who can size these turbos in the correct order??
  238. Anyone broken a Ralliart FLSD?
  239. Car is stalling for some reason...cold weather maybe?
  240. crush washer for oil drain plug = crush washer for spark plug
  241. specific question for modded evo veterans and tuners
  242. HK$ 30th cat-back broken hanger
  243. RPS Carbon too grabby?
  244. underheating--Fan wont shut off
  245. Happy Holidays...thanks to Z-1 Auto!
  246. EVO VIII and IX injectors
  247. Clutch pedal adjustment.....when?
  248. new Spec stg 3+ clutch!
  249. gt35r with ported shroud...?
  250. Tial BOV question
