- Bad vibration and shaking!
- clutch assistance
- fp black no wastegate?
- Seriously Frustrated. Tranny problems
- Restacking the diff. Right now. Need your EXPERT input
- STM forward facing turbo kit.
- Evo VIII water pump on a ix
- Cam seal install not going so well.
- How to break in a brand new 4g63 evo 8
- Serpentine Tensioner
- New build suggestions
- Clutch noise, possible TOB? Video inside
- will a stock fuel pump handle........?
- Intake/TB Exhaust/BOV recommendations..??
- Can you bypass a faulty rad fan control box?
- Is this a slipping clutch or something else?
- If you wanted 500whp on pump....
- aem short ram intake install problem
- Driveshaft part numbers
- Bov sound
- Evo noises?
- Pic Request: EGR Port
- What size is the block water drain plug that is near the knock sensor?
- BR 3065 on 2.3 - what to expect ?
- ARP +625 rod bolts
- Clear fluid leaking out of hose...Pic inside
- Evo v randomly pulling to either side
- Rough power figures
- Like to trade my fp hta green for a black
- Really looking for some help on what turbo to run with my setup?
- Choppy at WOT.
- Oil jets hitting Wiseco pistons?
- Trouble Holding Base Idle (Dips Below 850) When Going From 1st or 2nd Gear to Neutral
- troubleshooting, car wont start
- Megan racing downpipe.
- lifting head??
- What happened to my 4th gear?
- Transmission help!
- Water in a tale pipe and coolant 1/2 missing after Hgasket change
- Time to upgrade!!
- Engine Removal
- Leaking Transfer Case
- EGR vacuum hose loose
- HELP! need to identify these connectors
- DriveShaftShop drive shaft users need help please
- Rotella synthec t6 5w40 oil analysis
- Please help!!
- kelford 272 ?
- Evo owners with P0365
- GSC S2 Vs. Tomei PROCAM 270
- Will PTE ever put out a stock frame 58 or 62 turbo?
- USDM rear diff part number?
- FP black - 2.0
- Ignition help!!!!
- Manley piston ring gap
- 2.4L timing with 4G64 gears????
- Which 3582r is this?
- What is the best BOV to get?
- Which is the best turbo for my goal? Need help.
- Brian Crower springs and titanium plates
- Boost Gauge Issues....
- Garrett V-band TwinScroll GTX35r Topmount Experiment
- Question on Competition Clutch Kit Stage 4 Wave Clip Included or needed?
- rod choices
- weird problem
- I havent seen my rad fan come on in a while.....
- Vi-PEC v44 plugin ECU evo 8 evo 4-7
- coolant level rise in coolant reservoir tank
- Car isn't staying running, randomly
- differance between evo 9 and 8 turbo
- Won't start after a run
- which turbo td05 or td06?
- could use a little help!
- AYC -> RS swap? Driveshaft?
- Engine dies @~5500 rpm wot
- Fuel Pump Loud Noise
- Rough Idle
- How much power will i gain from my fp black??
- HKS gt2 vs green 73
- Valve stem seal install?
- 65mm TB install 3k Idle
- Possible Fuel Pump problem!
- Low Vacuum While Cruising Caused by?
- Tial leaking at idle
- Need some evo 3 engine info please
- brake booster check valve
- differences in 2.3 stroker & 2.4 LR??
- Air in the Fuel Rail?
- Will this clutch disc be ok?
- HELP! went from 4th to 3rd
- 1st and 2nd, Clutch? Tranny? Help!
- kelford 264in and 272ex, anyone tried??
- 6266 twin scroll
- Visual difference between Evo 7 / 8 engine
- SD cold start issue?
- Kaaz
- Engine Harness Differences or Wiring Gurus
- t case leak need help please!
- Sleeving a 4G63 block
- Comp stage 4 ordered-Do I need a lighter flywheel?
- What year 5-speed trans will fit into an '03
- Driver side headlight wont turn on
- Clutch part question?
- Evo 8 Upgrading to 9 Turbo
- Evo 8 Clutch, Wheel, Cams
- Exhaust question
- Continuing Contamination Issue! Engine Builders NEEDED
- Over-filled oil
- evo 5 turbo help
- Milling evo8 head
- X rear rotors on 8/9
- Reconnecting battery terminal = rough idle???
- HKS Super Turbo Muffler
- Anyone know what manifold this is
- lower timing belt cover removal?
- Quick Mivec to non Mivec swap
- Exedy Wave Clip or Master/Slave Cylinder?
- What weight engine oil?
- Very bizzare issue
- Exploding sparkplug / coil on a stock car under half throttle?
- Blue smoke from exhaust, what to check?
- Fuel injectors next?
- DIY COP blows 10a,15a, and 20a fuse?
- What blow off to get
- 10. hotside vs 11.5 hotside
- Engine build on a brand new block, Hone it or not to hone it !
- How much can a stock 8 block put down n hold reliably?
- Thoughts on what clutch to get?????
- Weird high RPM shifting issue, feels like gearbox is moving?
- 3 port boost controller not working?
- Which Cams???
- Question on VIN numbers on drivetrain parts
- hi guys
- overfilled tcase
- ACD pump orientation
- Need input on cams for a 2.3L w/ a 62mm turbo.
- ACT's solution to the most common pull-type clutch issue..
- Solution to TOB clip failures?
- Is my oil pressure too high???
- curious question, what would happen if we drove around without a driveshaft?
- oem slave cylinder
- 3-B + S3's on VIII?
- Exhaust set up help/guidance needed
- need radiator!
- EVO rear axle cross-compatibility?
- EVO 9 MR - is low mileage a good thing?
- Dead CPS?
- Evo 8 Next Upgrades
- Water Pump Fell OFF!
- 2.4 blown head gasket question
- Motor mount insight plz!!!!
- So whats new for more power?
- Cooling problems
- Interesting cold start issues
- Any Alternatives? - Aftermarket Upper IC Pipe W/Stock Air box fitment (Stock Route)
- What is pinout for stock boost solenoid?
- 05 Evo VIII 60k 5spd - 1st gear problem?
- Is my Injen intake hampering my 84mm FP cover?
- 20g Turbo Question
- Logging turbo speed with the Garrett kit.
- My 35R Kit for your ...?
- Need more power :-)
- Evo 8MR Cams & GT3076R...What do you think?
- Making Your QM Clutch Street Friendly..
- Transfer Case O-Ring Part Numbers?
- 430 WHP Turbo
- No start issue
- Spark plug -> Coil ring rubber seal part #?
- Competition Clutch stage 2 or stage 3.5????
- in depth look of the ac delco 252-891 vs oem water pump
- Evo 9 downpipe on evo 8
- Oil leak?
- No 4th in new tranny
- Acd removal or restore
- Tomei vs HKS Turbo?
- Will Evo 4 Rocker cover fit on Evo 8
- IAC issue?
- Agp fmic
- Fan upgrades....thoughts?
- 6262 vs 6266 vs 6466
- Blitz EBC gain setting
- In need of definitive info regarding building a Mivec 2.1L 4G64...
- Good Exhaust for EVO IX
- How do you test the boost control solenoid?
- EXEDY/CUSCO Twin Carbon min disc thickess?
- 05 EVO VIII 60k great condition but clicking? FML
- Play in rear axles. Diff bearings?
- Boost gauge installed...a few things not working...
- HG vs Comp Ratio
- Full blown 70mm tb issue
- Nisei ICP
- Koyo vs CBRD vs Mishimoto vs OEM Radiator?
- gt 3071r hotside A/R
- UICP blows off when boosting (search already)
- Evolution Cranks but doesnt start
- Question about rewired fuel pump
- Map o2 dump install Ac removal?
- 260f oil temp too hot?
- Are any air box mods recommended for a car with SD and 400hp ATW?
- Nominal size to gauge size? Harness Wire
- Exedy Triple Carbon Clutch noise help...
- Going into Gear issue
- Timing belt skipped
- Ignition Coil Relay
- FP Red vs FP Black vs CBRD BBK Full (ported)
- How to rebuild my trans
- Knock sensor question
- Gsc S2 or Evo 8MR Cams for Lower End Response?
- evo viii engine harrness
- GT30R Questions.
- Quartermaster 6 Leg
- hybrid boost controller configuration???
- Ebay resonator
- Engine Break in
- Extra fun day, version: Oil pump failure
- Evo 9 MR cranks but won't start
- Need advice on my setup!
- Stripped head stud threads
- Boost leak at throttle body
- Misfire on idle
- Gasket Picking help needed
- Putting together new setup, Oil pump sprocket seal question
- Issues after Timing Belt Job
- Timing belt help????
- Help Please! FP Green Only Making 10 PSI Boost EBCS
- Radiator under the frame exist?
- Best cams that don't negatively influence bottom/mid and response
- Clutch help
- Air to water cooler on coolant feed to turbo ?
- Coolant temp raising on idle
- need input 2.4l 4g64
- ACD System Issues (constant stand-by mode after number of attempts)
- Help: Upgrade to Twin or even bigger oil cooler?
- Dumb 4g64 cheap Build Idea
- What to check/do prior to tune
- 6 speed transmission issue ( bearings ) + Pic ??
- Cosworth m3 cams on ix
- Having Boost Issue
- QTP Downpipe Wideband Location?
- GSC CNC Head
- Question about power with s3 cams?
- Coolant in the aprk plug well?
- ATP GTX3076R and stock bottom
- Lets play name that sound!!!!!????
- grinding noise when steering EVO 4 IV
- **Need Help with Intake Cam** Tech Plz
- Help!!
- Cam install prep ?
- Crankshaft, nitrate or billet?
- flywheel keeps coming loose
