PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 [133] 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. ARP flywheel bolts
  2. rod bearing
  3. Transmission Fluid Mystery
  4. What Cams
  5. Bad Motor Mounts?
  6. Bearings....
  7. why is this here???
  8. Anti-seize on spark plug threads
  9. ACD/Brake/idle issue. Please help!
  10. Extreme Turbo Systems Does it again! 45r working with a Stock Radiator and more...
  11. Ebay IC Piping vs ETS IC Piping
  12. Boost Problems
  13. INTAKE/EXHAUST stock vs. custom; PLEASE HELP
  14. Engine Light w/ Test Pipe?
  15. valve cover
  16. Ported manifold and 02 housingPorted manifold and 02 housing question..
  17. grind into 5th gear when fully stpping on clutch
  18. Bypass the Hot H2O in throttle body ?
  19. Where is your friction point set on your Exedy?
  20. stock turbo 26PSI
  21. possible clutch problem
  22. What do you think about SeaFoam?
  23. rev limit (help)
  24. Need Pics of Installed Stock Intake Manifold
  25. 403whp Mustang Dyno FPgreen
  26. who has a cosi m2 evo 8 dyno chart?
  27. Forge WGA Issues (I think)
  28. Mishimoto intake
  29. 2,3 EVO GREEN & GSC.2. cams.
  30. backwards motor mounts
  31. Cam... Help
  32. 100% Meth burning up IAC Valve
  33. Help With Meth
  34. help! asap!!
  35. Evo 60 trim?
  36. Mitsubishi TSB on "Coolant / Oil Revisions" to the 7-Bolt Engines ?
  37. Converting WR8 to TME turbo
  38. Misfire Issue, plugs not gapped correctly?
  39. engine dyno
  40. Mitsubish Evo Green Turbo
  41. Tanabe Downpipe 03-07 EVO
  42. Torco Accelerator Fuel, answer to unleaded race gas??
  43. Boost Leak at Throttle Body??
  44. MR 6-Speed Transmission Drain/Fill Plugs
  45. Suddenly Super Rich
  46. 57trim 100oct pump
  47. bearing noise
  48. Turbos: #80 vs #71. Cams??
  49. All headgaskets are not created equal
  50. Where to get injectors flow balanced & cleaned?
  51. Does the ETS Stock Battery UICP work with Buschur MAF Intake?
  52. What this sound makes you think its the problem?
  53. cosworth 2.2L?
  54. Necessary tools for degreeing cams
  55. jun cams
  56. Loud pop?
  57. Who makes the better turbo? Precision or Garrett??
  58. non chromed out pipes
  59. most reliable and consistant injectors?
  60. anyone running fp-grn w/gsc s2 cams?
  61. Precision turbo to AMS...for real!!
  62. boost spike?? or what
  63. another random misfire thread! P0300
  64. Just went large at GRUPPE-S
  65. Valve Spring Compressor
  66. What is oem valve retainer to stem seal clearance?
  67. Finally got my FP green installed
  68. MBC or EBC?
  69. need help...very advanced timing!
  70. Transmission Question Evo ix
  71. Idle issues and the vent control
  72. Pulstar spark plugs.. Anyone tried them?
  73. ACT MB7-HDSS Clutch Kit: EVO 03-06 any good?
  74. Upgrades questions HKS 2835 Evo VIII
  75. how-to 2003 clutch install?
  76. Evo IX Stock piston, 2 or 3 piston rings??
  77. ACT HDSS and 6-speed??
  78. After Market Clutch Reliability!!!
  79. Have problem
  80. Gt45r
  81. EVO8 Flange "Full Race" Manny?
  82. Little help please PCV valve.
  83. MR Transmission Swap
  84. Which evo is faster in 1/4 mile evo 8 or evo 9 with evo 8 4th gear, and if they bo ?
  85. Another Evo 9 cam thread
  86. Evo IX 20g
  87. Best Turbo Back, under $1,000???
  88. BR cast mani turbo kit with ETS fmic
  89. Little Project: Porting & Polishing Evo IX Stock Intake Manifold
  90. evo ix oem catback ?
  91. clearance questions
  92. 500 to 550 WHP on stock engine?
  93. Sticky Throttle...HELP
  94. Honestly... what the crap
  95. Normal PTE880 fitment?
  96. Amsoil gear oil
  97. windage tray / crank scraper?
  98. HELP - what OIL? in carbonetic LSD's
  99. Which HFC?
  100. Green 20G 9LT Ball Bearing conversion ?
  101. Cosworth Cam Users on Stock Valvetrain? Need feedback please?
  102. Ball style tip injectors vs Pintle tip injectors?.....
  103. Code came on, VSS
  104. 35r anti surge compressor housings.
  105. do i need to gap oem stock plugs for the ix?
  106. FP evogreen SS race pipe fitment issue (PIC)
  107. Ralliart Super Direct Twin Clutch
  108. Well I got questions i hope you got answers
  109. Thoughts? Evo 9 setup.........
  110. 10.5 hotside?
  111. IX Turbo issues
  112. GSC 272 or GSC S1 series cams?
  113. Tial Valve Seat problem
  114. Need help deciding on next mod
  115. Need help deciding on next mod
  116. Intake manifold testing.
  117. Evo 9 Spark Plug List, Also how to read plugs.
  118. AMS Lexan Window kit... Any Interest?
  119. GM Maf install
  120. Tcase Blown!!!??? help
  121. Crank Pulleys
  122. Problem with Hotside Read plz
  123. Advice on Test Pipe
  124. How much top end in hp would a full race twin scroll gt30r lose compered to a ams kit
  125. Arp Head Studs
  126. Inectors and ARP head studs
  127. your mod list~help
  128. Big turbo with stock intercooler
  129. Bleeding lash adjusters???
  130. Oil in intake manifold...what is the cause?
  131. rubbing noise from engine....
  132. GSC S2 Camshafts
  133. Source for Evo 16G compressor housing?
  134. Any front LSD solutions for 03 VIII without having to disconnet ABS?
  135. Who has the EVO 9 Brian Crower 272 Mivec Cams on their car Worth it for $350 Shipped?
  136. Seperating Spindle and Knuckle...
  137. How do you know when the plates in you exedy twin need replacing?
  138. whining noise shift...
  139. EGR valve
  140. ARP Headstuds
  141. Is the Buschur MAF Intake a 3" pipe?
  142. meth injection
  143. AEM O2 Wideband Bung Material
  144. GSC 2.2L stroker??
  145. So I got my AMS 2.3RR motor today..and some ETS parts...sneak peek inside
  146. transmission help .
  147. HELP! Fuel cut cause it's too cold
  148. Balance Shaft Help
  149. Water pump suggestions
  150. Cam Gears
  151. Boost controllers
  152. TRE 3.73 or Simalar Help.
  153. PICS of my new turbo from Buschur Racing!!
  154. SRS light is on
  155. Launching a twin disk
  156. AMS Teams up to build a Standing mile EVO
  157. 3 inch DP recommendations
  158. WTF is up with this
  159. Bypass valve not working
  160. What Clutch Fo My 9
  161. Evo 9 and cams
  162. Building a trans to handle 5-600hp
  163. Are head studs Necessary for cams?
  164. Manual Boost Controllers
  165. Bov Decision
  166. cam question
  167. help please
  168. Buschur Racing 3" Exhaust Test Pipe
  169. Rough idle problem car dies at stops
  170. Boost Problem?
  171. Need help deciding what turbo will work best?
  172. Accel issues
  173. Exedy install question?
  174. Need help!!!!!!!!!
  175. Some exciting new builds at AMS!
  176. Coolant Smell BUT no coolant loss
  177. No Top End Power
  178. TTP-Engineering proactive Cosworth Announcement
  179. Anyone know the Correct Length of RS BELT.
  180. 02 sensor install help!
  181. Buying Buschur 3065 Setup, Question about what size injectors?
  182. PCV Valve setup
  183. Considering removing clutch restrictor
  184. Normal Oil Pressure?
  185. Exhaust Manifold????
  186. Cosworth Springs on FH35R and GSC S2 cams
  187. Crower 280s and Springs/Retainers
  188. Aftermarket Alternators
  189. EVO 6.5 RS TME Turbo ???
  190. EGR Question
  191. Cosworth M3 Race Cams - Results Anyone?
  192. A friend wants to know how he can get ayc and acd into his usdm 03 evo?
  193. HP advice
  194. boost controller/wastegate/spiking problems. please help
  195. weird noise!?!?!
  196. 2.3l stroker or 2.1l destroker
  197. Cam Help
  198. Camshafts
  199. GT40/94R vs FPHTA35R
  200. my plans.. what do you think
  201. clutch prob. please help
  202. Snow performance water/meth injection
  203. Turbo advice and other mods
  204. Mini battery is dying on me..
  205. cams...are they all the same?
  206. Intercoolers that are over 600 hp rating
  207. Shortest Available 5th gear?
  208. Intercooler Piping Materials
  209. Buschur Air Intake vs. Stock Box
  210. jolting problem
  211. My new Full Race GT42 Twin Scroll Manifold
  212. What Clutch should I get
  213. Car dies sometimes when going to neutral and slowing down to a stop?
  214. is it possible with this setup to hit 400!?
  215. Need Help ASAP.. anyone please help
  216. wreaking my drive train
  217. Engine problem: in need of diagnosis
  218. My engine seized.
  219. t case question?
  220. wtb oil cooler and evo 8 or 9 front
  221. Twin Scroll Candidate
  222. How much torque for o-ringed heads?
  223. Nitrous for spool???
  224. Question EBC Solenoid installation?
  225. scary noises please help
  226. fp green suggestions:
  227. Would it be possible to use a 4b11 engine head on a 4g63?
  228. CDI coils?
  229. just got altered Exhaust ticket !
  230. I NEED HELP...Car shut off suddenly...
  231. Spool: Evo 9 stock turbo vs FPgreen
  232. Butt Dyno
  233. Evo IX VIN# on Transmission?
  234. air temp?
  235. car is stalling all the time please help
  236. 11's on stock turbo?
  237. Forge WGA
  238. 272 vs 268 cams on 16G
  239. Need advice on flywheels
  240. Need advice on flywheels
  241. Spark Plug question
  242. threw 2 codes after cam install (rich idle)
  243. Sleeper EVO exhaust
  244. After cam install....
  245. GSC Power Division CNC Cylinder Head! Dyno and track #s soon to come
  246. EvoM & Ebay = 500WHP for less than $4000 with built engine!
  247. Which LICP will work with stock turbo and 3065 kit?
  248. Okada and HKS?
  249. SC6152 dynop results
  250. cam tuning on stock cams
