- Anybody have an overlay of a BBK-B and an FP Red?????
- timing belt replacement-bay area
- were do i buy a hobb switch?
- Max power on stock IX fuel pump and injectors?
- Iridium Spark Plug Gaping
- Received FP BB Black today....
- Low compression on cylinder #4
- can stock evo 8 injectors be resized
- Koyo full size rad and aftermarket turbo help...
- slight noise from drivetrain??
- trying to find a evo 8 transmission
- Recommendations for engine build
- Injector dynamics 2000cc injectors noisy?
- Torque Solutions underhood shift bushings
- Serious help needed
- Question about lifters, are there two different height sizes?
- Driven Innovations NEW designed manifold for 2012
- build or not to build???
- clunking in 2nd gear and idle..
- Spark tech non cdi cop fuses?
- Shot Starter???
- Quarter Marter harmonics problem/fix
- need AEM EMS BASE MAP
- HTA Green transient response
- where to mount oil temp sensor.
- clutch question
- HKS 7460R or FP Green/BBK Full
- 0.001" oversize valve guides
- timing belt question help!
- name this electrical connector!
- New clutch
- Exhaust theory and my IX MR. Tapered exhaust. Fujitsubo / Supersprint.
- please delete.
- exedy twin disk help
- How daily driveable is a LR 2.4
- 03 evo 8 misfire/bad idle/low boost
- nasty oil leak any ideas im out of ideas
- Fuel pump wont stop priming with key ON
- Rear Diff gear ration difference
- Fp black proven whp?
- Hanging RPM's at WOT
- Any first hand experience with PRM Racing intakes?
- Surge or turbo dying or something else!!??~
- Carbon Exedy Triple Clutch
- boost surge??
- 06 Evo 9 clutch advice
- Sloshing noise inside the car after cooland flush
- passenger side axle play? How much is tolerable?
- quick head gasket question
- AMS 3076 in Evo VII
- Help me figure out what Im doing wrong, front case doesnt want to come off.
- Best Turbo for 4g64 2.4l
- Brian Crower Cams Stage3+ stock springs ¿?
- Delay in fan turning off.
- QM 8 Leg
- check engine light
- Best spark for the buck??????
- Rear Diff Bushings
- Castrol 10w60 for build engine?
- During idle car random dies
- Opinions on comp clutches
- Spun bearings, now i need to rebuild...QUESTIONS!
- OS Giken Rebuild kit needed
- Power Enterprise F1 Bearings?
- What's this part?
- Multiple clicks after roll start in 1st or reverse
- evo9 compressor housing on 8 turbo ?
- Problem after installation of COP
- HKS EVC-S displaying weird error
- External or internal??
- evo ix makes a whineing sound on start up?
- Tensioner broken bolt removal help
- Quartermaster clutch users - What to use to plug slave cylinder boot hole?
- Noise after timing belt change
- Which turbo kit is the best
- Evo idles but wont drive
- We're to mount flex fuel sensor?
- Need a hand in jacksonville FL
- Anyone using NGK Iridium R7437-8
- Helpppp...Is This Death Whine?
- Only 10 psi evo ix???
- Wideband formula help. Innovate MTX-L ---> EvoScan
- fp3794 ex housing sizes
- I hope this an't a dumb question springs/cams
- clutch newb question
- BBK Full BB turbo...or not?
- cam suggestions?
- Front wheel spin (video)
- clutch to floor, replaced TOB
- Engine dies when I press clutch
- short shifters
- engine specs doubts
- Power drops when upshifting...
- W/G Screamer Pipe
- Is it worth upgrading ?
- How long for bled lifters to quiet?
- MAP H11 Head Studs Install no instructions included of course
- Kelford tx284hl cams
- Cam Position Sensor gasket
- Help with boost issue after tuning
- ACT 6 pucks ultimate holding power ?
- Rpm???
- tial flutter normal? VIDEO INSIDE
- Wtb 272 cams
- Which oil to get from Royal Purple
- 2.3 owners, need your suggestions - rod to block clearence
- 70mm TB and first rebuild start
- Engine Oil - Different Brand Mixing
- Necessary to notch block in a 2.4 L LR setup?
- Car Cranks, Doesn't Fire
- Multiple cylinder misfires
- 6262 CEA or HTA86
- Synapse dv-Boost leak test
- Bov
- Sand In Block From Factory? Strange and Scary
- timing belt decisions
- supertech duals question
- MIVEC Head on non Mivec Block Question
- Bad Bish, the next generation-introducing the clutchless 4 speed.
- Old technology Turbo Kit, help me what to do next!
- ACDtuning track review
- Exhaust rubbing question
- Need help identifying these cams
- 2.3 Stroker kit/ turbo combo
- weightmatching rods ? *Maney H beams*
- Need help with bearing clearances and ring gap clearances?
- Oil Light coming on at idle
- Replacemant knock sensor
- Evo 8 VS 9 Turbo Questions..I searched :)
- Garrett 3.5 vs 3.8 core
- Throwout bearing removal
- Timing belt help
- the 11th billion which turbo thread
- Oil Leak issue
- NGK BR8EIX against BPR8ES review
- Stock turbo info wanted
- A few injector questions
- A3N exhaust housing material, what is D2B Material?
- wtf? feels like Vtec!
- E85 Safe Fuel Filter??
- New cam angle sensor no fire.
- Clutch pedal adjustment
- cams and tranny
- evo 9 piston 7 bolt rod combo
- problem with a 2.4 in evo
- New MAFS on evo IV
- Stock Turbo Speed Density 4" intake
- Stock Turbo vs Bigger Turbo...
- car not boosting more than 19psi
- AMS/ Vibrant Rear O2 Spacer
- Walbro 400's in Buschur Double Pumper
- j-pipe to turbo gasket leak!
- Evo 4 rear o2 sensor question
- Slight AYC Oil leak...
- Hbeam rods
- manley h beam failure
- Timing belt is loose and slapping
- Competition Clutch Stage 3.5
- s3's with stock valves/pistons
- 2 plugs behind intercooler?
- Need Help! Idle Speed Control Motor
- *****y LICP Install?
- Oil light flicker issue HELP.
- Spark plug check?
- gear ratio RS and Evo8
- Evo IX turbo and other mods put in, but feels only slightly faster
- Interesting situation happened and now a problem
- clutch wont engage,hard to push in
- Best aftermarket turbo for torque?
- BOV/BPV Question
- bb fp black or T3 kit
- Transfercase seal leaking
- Br fmic
- Br fmic
- Flywheeldamage question / Clutch Identification
- Boost Drop/Taper
- PTE Turbo options, opinions?
- S3 Cams and Stock Block valve clearance Input needed ASAP!
- Size of intake for SD
- "eClutchmaster.com" Knock-off clutch?
- ebc to mbc
- Which pump? Walbro 255 HP, or non HP?
- Spark plugs causing blow by??? Anyone have this problem before???
- Built Bottom End?
- Need HELP!!!! ASAP
- Really strange stuff concerning driving in the snowHELP!
- Picked up 05 evo 8 and a few concerns
- 6 Speed stuck in 5th gear.. any ideas??
- Oil leak places to look help.
- Mystery Rattle...Video included
- 12 second bet
- Koyo Evo half radiator fitment and daily driving?
- Cams with or with cam gears
- evo tranny parts
- Lot of pressurized air from valve cover.
- Stock Except HKS 272 cams
- Help:Fuse for ECU?
- strength of t-case and rear
- Exedy Twin Loose Bolts
- Clutch restrictor pill removal long term update anyone?
- Looking For Insight And Advice
- Who make the best UPGRADE oil cooler for a Evo 9
- p0011 code HELP please
- what is the best turbo for 630hp to 700hp? 6262 6765 or 6766?
- Tail QR BOV stock battery
- Help with my build!
- cleaning iac & tb?
- Shep Trans 3rd-4th gear
- question on wiring zeitronix ethanol content analyzer
- Clutch/gear shifting issues
- Hp gains with the Greddy Comp Ti-C Turboback exhaust
- shifting issues after clutch install
- Transmission and T-Case Pulled! Now for some questions
- does anyone make a variable vane turbo for our car yet????
- Clutch problem
- Decel Rattle/Grind: Solution
- Is this the right part?
- Replacement throwout bearing broken 63 days
- Not getting a Spark on 05 Evo 8.
- Noob needs help on a evo8
- TiAL V-Band Turbine Housings
- What Is This Sound?
- low sputtering idle after driving through puddle.
- can you run stock cam gears on a 2.4 ?
- do evo 8 and 9 have same intake mani,throttlebody??
- idle problems
- Map ef3
- QTP electric cutout cable solution
- Black swirls (residue) on stock ix turbo compressor housing inlet
- redline notchiness?
- Evo 9 turbo or Fp white?
- Total seal piston rings on 4g63
- My rant
- What mods for a reliable 350 - 370 hp on a IX
- Running on 3 cylinders on evo 8 :((
- Fuel surge tank return to fuel tank
- Which turbo?
- ETS FF Turbo Kit Filter
- Compressor Surge Problem!
- 03 evo VIII revs way too much
- Oil scrapers
- Realy need help
- coolant pushing to overflow
- +.5mm valves needed??
- unusual squeal?
- Active Differential Question/Issue
- Jm fab drag manifold and aem 5 bar????
- Issue with drivetrain
- External Wastegate O2 Housing
