- JDM EVO7 swapped USDM EVO8
- Norris Designs Supercharger for Evo 4-9
- 1/2 filled block streetable????
- how to fix leaky v-band flange ?
- Evo 9 transmission swap problems
- SS clutch line and restrictor delete
- MIVEC clacking on load, disessembled pics & video
- Evo 7 retainer
- No turn signals - random..
- What mounting hardware for FP Manifold
- Converting Evo trans back from Push Style
- stroker kits rods and crank length enquiries, please help
- evo 8 loss of power/bogging down after shift help please
- road racing a 2.3L?
- O2 housing issue
- Rebuild Clutch or upgrade?
- Recirc Hose
- Crankwalk solutiion Evo 4
- Wiseco 2.3L Piston Ring Gap - Need Advise
- Precision DSM Injectors - Very Affordable!
- WTB: 3" Down Pipe for my EVO IX Vendors Welcomed looking for something cheap
- quick question on splitting the tcase trans
- ETS 4inch intercooler pressure drop
- Evo 9 2WD Mode (FWD/RWD?)
- Shep Stage 3 ACD Transfer Case
- Excedy Twin Vs. Triple Q's
- Help!!!
- FP Green 73HTA Compressor wheel needed
- Help please. Trans/shifting.
- What EVO engine fit in my 06 Outlander Turbo
- hta 3794 or gtx3582
- Did I buy the wrong pistons?
- Part needed
- Benefits of oil catch can?
- Transmission install issue
- Will Invidia O2 housing work with QTP downpipe?
- Rough idle post CAM installtion
- Lumpy idle
- Eagle rods in 2.3
- 4G64's, pushing water common?
- Will the Evo 8 starter fit on the Evo 9?
- Help! Strange Ringing at idle fresh 2.4LR
- GSC S2 Cams - What is your Cams Setting Spec?
- Tolerance on Plastigage for Main & Rod Bearings Clearance
- 700+ fuel systems
- Just installed Quartermaster 8-Leg Street Clutch Kit
- Car Revs up after pushing clutch pedal in
- 4th gear problems
- clutch question
- Bolt size for oil return line to block
- Wire loom plugs/clips?
- First tune ever (Dual Map) What Happened with my Tune? Please help :(
- Opinion on Comp Clutches?
- Anyone Tried Using an 4G64 Crank on their Rebuilt without doing Balancing?
- Can you disable the ACD on a ACD Tcase?
- i just drained the oil and....
- weird key/starting problem
- Weird ticking
- Excessive Engine Oil flow Onto Oil Catch Tank
- Engine guru help needed, Compression good leak down terrible? Mivec, HG, Oil pump?
- 2.5" or 3" pipings
- Full Blown vs stock bolt pattern
- Exhaust setup?
- do i need an engine oil with zinc for the turbo?
- Small Screw on Valve cover
- Running 91 octane pump gas on E85 map
- FP WGA came apart
- What is the different of High & Low Impedance Injectors for Evo?
- How much torque can the 6-speed Transmission handle
- NEED help here, can't figure it out, even dealership.
- Where is the MPI relay/fuse
- Oil Seal In Transmission
- Anyone besides map making dp for the new FP Zero
- New FP Black Turbo option! 100% stock appearing.
- Advice in buying
- Bully Clutch
- Please help radiator leak
- Boost source for hobbs switch
- 2.3 Stroker Rebuild - Advice / Suggestions
- Damn you AMS! Exhaust issues.
- Block heater for 4??
- 3.5 vband downpipe wanted
- Built Evo 8 bad break-up
- How long is your dipstick? Evo 4-6.5 - Help
- Got a flywheel with no spacers that go inbetween the clutch and flywheel
- Evo 9 Cosworth Head
- What diff oil I should be running ?
- Wheel Hub Fell Apart....Hmm
- attempting to do acd and ayc swap .
- evo 4 water pump - same as later evos ?
- DSS carbon fiber driveshaft on a evo for those interested in install pictures
- Precision 6870 is now available.
- 2.3 Stroker with 5858, better spool???
- Which transmission fluid?
- STM FF 6466 Complete Turbo kit CHEAP!!!
- Clutch Choices: QuarterMaster 8 Leg or Comp Triple
- Anyone have an exploded 6 speed diagram?
- ISO turbo manifold
- Bigger turbo / P0234 turbo overboost + cutting off.
- P0171 Lean Code Keeps popping up!!
- oil filter housing/cooler question
- no oil pressure!!!!!!!!!!
- Timing Belt Noise after Service
- Is Evo 7 Rear Wheel Bearing & Hub Compatible with Evo 5?
- oil on hood vent
- Excedy Hyper Single or Ogura Super Single?
- IM.is it ported or not.
- back ward pistons?
- uhm......are my pistons in backwards?
- Getting 16 to 25 counts of knock car was tuned recently
- Forward facing, top mount or normal placement
- Boost leak or boost problem
- Cylinder head o-ring protrusion height
- lockout problems can not figure it out
- Can a td06sl2-20g turbo produce 400whp on 93 octane?
- Bypass AC with shorter belt
- Evo 8 Timing Belt Auto tensioner Pulley HELP!
- 2.3 stroker with 6466???
- Evo 8 shifter spring
- Knock Knock... Whos there.. Evo Knock ...
- OEM Coils Replacement
- evo 8 starting, idling problems
- 400hp??
- Brand New motor, low compression numbers
- Valves hang open intermittently?
- Wastegate missing from evo
- HELP! Lean under load. tried everything.
- HKS cams
- Lean idle ever since UICP install
- Is an upper intercooler pipe upgrade really needed?
- QM 8 leg and new trans, possible clutch dragging?
- Evo 9 starting issues
- Turn down tip on down pipe
- Fp green Vacuum
- OEM Pressure plate clamping load??
- Has anyone ran the NEW FP RED with SS housing?
- new build oil pressure concern
- Possible stripped plug?
- topmount manifolds
- Amsoil in the 6 speed
- Turbo life expectancy using factory ALS/SAS
- Evo 8 Injen filter size?
- 740hp evo with boost spike issue HELP
- Moore Berg Warner 7670 kit
- Balancer shaft removal why remove tranfert case
- Modified axle for an RWD Evo
- MBC, 3 Port, 4 Port, Hybrid Boost
- timing marks
- Forge BOV not holding boost?
- Choosing a turbo manifold!!! Please HELP!!!
- Ajusa Lifters=JAM lifters?
- Wastegate,boost controller.???
- Clunk and then metal to metal noise
- PTE 6262 vs PTE 6266
- Rebuild 2.3L - Guide Needed
- Different spool T3 vs T4
- The next evolution of the Bad Bish
- Precision 67 JB failure
- Rust building up inside turbo.... Normal?
- which turbo - FP green FP red DBB or BBK 3B
- Help! Starting issue.
- Ets or mil spec hfc?
- random shut off
- Strange lean fuel issue.... I'm STUMPED
- Best turbo for for 600whp pump gas
- Transfer Case.
- Lean at start
- AMSOIL long term use switch back to Mobile 1 question
- FP RED arrived.... Few Questions!!
- Is it ok to decat a stock Evo 8 FQ300?
- GFB bov problems
- Are my motor mounts out?
- trans cooler for IX 6spd
- 2006 Evolution MR stuck in fourth gear
- Measured performance gains with turbo blankets
- When to upgrade fuel system?
- No Start Help, Replaced Crank Position Sensor
- 2.3 TS what turbo?
- double pumper + dual 044s
- GTX35 stock engine directions
- Wastegate problems?
- Who is using manley turbo tuff? What power are you making?
- Transmission Issues
- 4g63 swap question
- OFH port question
- ACD Code 82 - No Noise From Pump - Should i Rebuild?
- Ebay Fmic?
- 03 Evo cv shaft popping out.
- low oil pressure readings?
- Wiseco ring gap
- Oil catch can question
- Stock Evo 9 trans question
- recommended repair.
- Need advice
- evo6 boost control mystery
- fp race manifold. should i buy?? ALSO NEED ADVICE ON CAMS
- Misfiring
- knock sensor and timing not working or logging correctly
- Can Oil check valves be used for vacuum?
- Idle not consistent 2004 Evo8
- Help: Car shut off during 2nd gear pull/boost cut
- WTB Evo 8 cylinder head
- Idle air control valve (IACV, ISCV) part # ?
- Why am I burning so much oil?!?
- Valvetrain noise.. Video inside
- Black inspection panel/ Evo 8 Transmission
- GTX3076R 0.82a/r versus 0.63a/r
- IN need of a transfer case Housing and Tranny housing evo 9 ACD
- Did I get the wrong pistons again?
- weird idle and stalling.
- high compression/high boost, what to run for timing?
- hx35 questions
- AMS DP or ETS TP ???
- Stock 05 E8 clutch slipping, need advices guys.
- 2003 evo passenger axle not fitting
- Evo IX Cylinder Head Replacement Cost
- Seal valve with dual buschur spring?
- blown motor woes. finding replacement?
- Road Racing Application, which built motor?
- Is fp red direct bolt on?
- AMS F1 intake manifold install with boomba TB lost 50WHP wt****
- P0442 after tb install
- IAC Test: Good or Bad Video
- stage 1 transfer case
- #Fluidampr question# DO I REALLY NEED IT @847WHP/578TQ???
- Front Inner axles
- need help with evo 9 mr
- Not building boost past 13-15 psi
- RPMS are acting weird.
- Evo 9 - porting of the head.
- Evo 1-3 / Dsm FP RED / BLACK or BB76Hta
- reason for high oil temps ?
- Where to buy Exedy 4 puck disc?
- Spoolin up and new Denso plugs?
- T3 S200SX: GSC S1 or S2?
- Physical dimensions engine+tranny
- price of new motor?
- Noob Check // Oil, Trans, Diff fluid change
- Shaft Play in BB turbos
- Any one know the price on a new PTE billet comp wheel?
- Best way to get 450hp evo 9?
- 06rs Pulling engine/cleaning up bay
- exhaust manifold and vacuum reading ?
- Damaged camshaft repair?
- Car wont free rev past 3k
- Stutter/missing at WOT
- What cams do i have here?
- 2006 Evo IX Shifter position
- Apexi Isamu exhaust manifold cracked
- A/C LINE/HOSE - Condenser to Compresor
