- Is it possible to kill a clutch in 4 days
- Transfer Case carrier removal ?
- Anyone have a link for the Evo IX USDM & JDM Service Manual
- why do honda engines make so much more power with less boost
- Weekend Fun
- Buschur HFC?
- Quaife?
- stock clutch
- To coat or Not ??
- Centerforce vs. ACT which do you choose?
- 05 LSD in a 03 t-case?
- Boost problem after a couple of runs at the track
- Compressor Surge???
- Just recieved my ss o2 housing/dumppipe.
- Ams Gt37r Kit Or Buschur Gt37r Kit?
- Exedy Twin Disk Clutch Problems
- Fair rebate for transmission, transfer case cores
- Whats next?
- driveshaft play
- Injen SES exhaust
- Evo Block Donor Cars
- individual cylinder knock retard
- Tanabe Ultra Medallion
- 100oct in tank and afr's are LEAN
- Simple question... why aren't any 3" O2 housings available for the stock turbo?
- Finally, wicked affordable camshafts....
- PO 304 code?
- What intake manifold, exhaust manifold, and sgould i use a igniton amplifer with meth
- what whp with stock turbo.
- ebay manifolds what is the difference in size.
- Please Post 280 cam, 16g, Gas dyno chart
- Buschur parts ftw
- Three holes in the firewall
- 16g with headers?
- Which cables do you use when hooking up aftermarket rad fans?
- Jerky with BOV
- What is your favorite Diff. fluid for your Evo?
- Possibly Clutch/Syncro Problem
- hks cams
- Evo IX spark plug cover
- Random Misfires 030X SES: Need updated information
- Clutch advise needed please
- Going with a hard pipe kit, got one question about the install
- Just got a Carbonetics twin carbon installed and it sounds bad
- Evo IX Cams
- For those who run staight race gas
- Running the car without o2 simulator
- ebay o2 housing on which downpipe...
- 20g or evo 9 turbo???
- gutted cat or test pipe
- BOV issue...causing car to die..
- Boost creep problem
- Cams, Meth or Evo 9 turbo?
- spring setting
- What meth kit ?
- mobil 1 oil for evo?
- Injector Options
- gt35r owners?
- spring height
- My BR GT35R
- Boost problem
- engine upgrade
- Those of you with Helix 02 housings???
- Water and oil pump flow, l/min?
- Need upgraded Intercooler with uncut undertray?
- What is the highest PSI you can run on a stock evo9 motor?
- Forge UNOS + Cold Weather = Boost Creep?
- anyone run a gt3082r? (gt3040r)
- What is the exact purpose for a fuel rail
- Need Help with Trany/ACD Fluids, MR
- gt35r vs. 50trim (debate!)
- Forge Unos stiff spring min. boost?
- Tranny problem I think????
- If space were not an Issue How would you build a Header?
- The best LICP for stock turbo?
- Drivetrain problem...I think.
- changed spark plugs, made puttering sound
- Precision PT67R, where please?
- ARP head stud install. 1by1 the right way
- Rear Diff???
- Exhaust Install Questions
- help walbro whine
- APEXi GT Hybrid intercooler
- MAF connection
- Boost Characteristics of A Large Turbo
- Bad Fuel Pump?!?!?
- Help - Need New Clutch
- WR Intake Manifold
- clutchmaster fx700 opinions
- Big Problem
- Ghost exhaust.
- help me pick a turbo kit
- APS BOV Question
- Any risks if boosting up to 25 psi
- Synchronic BOV eliminates turbo restriction
- no oil cooler
- tranny problem
- act hdss or xtss for 500whp
- No acceleration (sometimes)...
- The Perfect Exhaust?
- Back to the drawing board.
- Where Do You Get Service
- Buschur's 3065 tuned by Al
- Can I run the MBC from the driver seat.
- Installed Boost Control, now problems ??
- ACD failsafe mode??
- Tranny issue
- just picked upngk ilfr7h, gapped at .024
- ECUtek. HP gains???
- Evo 8 20g
- misfire under heavy load
- popping out of 1st
- TRE Transfer Case
- GSC S1 cams
- Will a 2.3 Stroker outflow the stock turbo and any other uprade be4 TUNE!!!!!
- Go Fast Bits Bov ????
- Exedy HD
- Evo 9 w/ 20G-LT, S1 GSC cam + bolt on round 2
- Whats better 1g DSM BOV or Evo 9 BOV?
- some questions
- apex'i vs arc or others intake comparison
- help me pls.
- Help!
- IX o2 wire colors?
- General IX questions
- Well my clutch is going out...
- Help Evo 9 Plug Gap ILFR7H Urgent
- Is it bad if my downpipe hits my ACD?
- Why my water temp gauge wend dead ??
- Looking for bolt-on selection advice.
- Anyone running the PeakBoost GT30R w/ .63 AR
- Is this my transfer case or what
- Radiator which one ?
- finally got on the dyno
- What are the differences between a 5-speed or 6-speed clutch?
- 922whp for the Danimal!
- who's running "precision" injectors?
- Buschur Custom Flash vs. full custom tune?
- 20g turbo
- The competitions coming..so AMS and Buschur Racing teamed up....
- Best Clutch for street and 400 HP?
- What do you think.
- Stroker Build: Eagle Crank or 4G64 crank
- can evo 8 head be converted to mivec to work with an evo 9?
- Wont go into gears :(
- 375whp attainable?
- problem with acd
- 20g ?
- bad BOV cause a SES light?
- Is this a complete set of IC pipes?
- Bov
- Buschur 20G-9LT Results
- oxygen sensor plug answer
- what BOV is AMS using?? *vid inside*
- Is this a good boost leak tester for evo9?
- Installed exhaust...should I reset ECU?
- is peak boost suppose to announce their group buy today?
- 5th gear vibration
- Evo 5 Tranny + transfer Case Same as Evo 8?
- How to install a front CV Boot?
- Clutch install
- Triple Intank Walbro??
- another 500whp evo
- intercooler delete pipe
- Go for HKS 2.3 stroker or stick with my JUN 2.2?
- 02 sensor plug size???
- Ebay exhaust..My dealings with the vendor
- hks 264/272 to hks 280s?
- EVO 9 J Pipe?
- Exedy Stage 1
- Fuel Filter
- Need Help
- Suggestions on a good resonator?
- Would this be a boost leak?
- Megan testpipe to stock dp
- Rod Bearings
- Ideal AFR Map for 93
- service manual
- FP Green water/coolant line
- air temperature - right before IC and right after IC, on a stockish turbo
- Clutch install time ? which paint?
- IC pipe rattling sound?
- Need Help!!! Emergency!!
- Factory Cam Specs.
- Intercooler Hose Diameter
- switch transmissions??
- t/c question. does the whine get louder?
- unburnt fuel on floor at start up?
- Megan catback fitment on 05 EVO VIII MR
- Boost problems?!!!
- Which exhaust is the quietest
- Bosch LSU4.2 Wideband Sensor?
- throtle body
- Warning for anyone who cares about their transmission...
- P011? Anyone else having this problem?
- What Coolant?????
- EVO 8 MR 5 or 6 speed tranny
- Which turbo kit to get?
- HKS Evo IX cams and MIVEC controller
- Looking for Rod Bearings
- lets talk 2.2 liters
- stock IC - bottleneck for a green turbo?
- thinking about changing my goals...
- Larger Oil Cooler: Pros and Cons!
- Evo Turbo for 400 AWHP club Buschur vs. Turbochargers.com
- Pruven Evolution 9 480awhp / Street Video
- Turbo Timers - Needed ?
- The Buschur 20GLT/AMS 2.3/280's/Meth. My writeup.
- 16G boost puke-n-die help for high rpm
- t-bolt clamps
- titanium gear replacement for MR 4th gear problem?
- Not another BOV thread - stock IX BOV part throttle bucking
- Shepherd Racing options???
- Will the Invidia O2 Housing fit with the Ultimate-Racing 3inch TBE
- Bad ASS EVO on E85..........
- Injector or valve ticking?
- Tilton or Quarter Master
- dv clicking??
- New Clutch
- Lets's narrow down to IX MR w/ Jdm bumper and Ti or blue exhaust/muffler
- Intercooler pipes and prices
- evo owners be aware...
- I Just Blew My Motor!
- oem intake tube/Airbox/MAF is $HIT
- New sound from the engine....
- Buschur Racing 20G-LT DYNO results review
- Turbo housing ?
- Need help w/HKS EVC
- Idle troubles w/ my IX (video)
- Best way to set boost spike? roll-on gas from low rpm or stomp @ 4k?
- sudden OCCATIONAL rough idle
- oil was overfilled
- Engine Bearing Tolerances
- Spark plug cover cracks
- Ball joint pop/knock already?
- Walbro pump?
- Blown Motor
- Backfire problem at peak boost
- Best injectors?
- Exhaust data
- Dejon EBC?
- 2.3L stroker, Good Deal or not?
- Transmission
- Swap whole t-case or just LSD?
- Cam Question
- Turbo XS TBE?
- Post Turbo EGT Numbers?
- Anyone have pics of ported hotside??
- The "magnet" test for your "stainess steel" exhuast
- HELP!!! Wastegate question
