- EGT Guage/Probe
- Newbie BOV question
- Stock FMIC and Buschur's comments..
- BLITZ Turbo timer with VIPER alarm bypass
- Intake questions
- evo 1 elctrical drawing
- Where to find EVOIII engine??
- Sunroof or NO sunroof on the EVO??
- 3" turbo back exhaust
- Water sprayer
- RMR Intake?
- Tranny noise
- Wastegate/boost control question
- wheel vibration/shake
- boost controller install
- Synthetic oil in the engine? Watch out!!!
- Fuel cut-off
- Can someone explain mods to me?
- Fuel Cut Defenser / Boost Cut Controller
- 2.5 mph bumper removal
- The Hardest Question for Upgrade
- Stock Turbo, Stock Tranny
- EVO VIII transmission update
- funny smell
- Electronic Boost Controllers ?????
- Clutch?? Flywheel??
- The Best Re-circulating BOV
- Exedy Twin Disc?
- Easy power fix?
- Buschur 3
- What are thin walled headers?
- K&N Oil Filters for 4G63?
- HELP! Need brake pad info for Evo 8.
- ARP Rod Bolts
- Going for the Greddy cat back
- Has anyone purchasesd RMR's ...?
- ECU Pin 11, Turbo Wastegate Solenoid
- Max Turbo output
- Pulling ECU fuse - resets ECU?
- Track...
- Loud 'thunk' under hard shifting
- Best Launches?
- Cruse controll for 2003 Evo
- S-AFC installed and working...
- Mitsubishi rear strut brace
- $500 for mods..what to get?
- Stock Internals
- Emanage and Evo
- Evolution needs
- EVO 8 internals
- Racing Harnesses for Stock Seats
- ic pipe keeps blowing off!!
- What do you guys think of...
- Clutch restrictor removal on Evo 8
- Evo differential...what is the split??
- Evo turbo timer...any NON-SPLICE harnesses??
- Dyno Tuners in San Diego?
- Accuracy of HKS TT measurements?
- ECU Upgrades?
- boost gauge mechanical install help!!
- Electronic Boost Gauge install
- trouble shifting........
- The Right Engine Oil
- Evo 8, 91 octane: Should I worry about knock?
- Evo gas tank questions
- anyone with ideas of mods to an evo 7
- WICKED EVO VII, HKS proven
- anyone with a apexi s-afc in their evo
- 4WD Dyno in New England area?
- SAFC Harness for the Evo??
- HKS catback's intransit from JP
- How long should i wait to install any mods on my car??
- Just installed Buschur Intake and 3" exhaust suction sound in cabin?
- Black Box behind cooling fan???....???
- 4G63 forged Stroker kit
- Aftermarket exhaust question ...
- I vented the stock bypass valve to atomsphere today
- VAFC on Evo
- ECU Location on EVO VIII
- Just installed GFB Boost Controller
- Cure for Passanger side Rattle
- Manual Boost Controller Installation
- Active Valve System
- 500hp 11.22@126mph
- EVOVIII 5th gear syncros messing up already!
- Earthing kit
- Solenoid grommet mod
- Buschur Air Filter Kit...
- Mandrel bent or not?
- Buschur Racing
- What the hell is wrong?
- Test pipe and CEL
- Autronic
- Blitz Dual Turbo Timer-digital Compact Ii...
- DSM 2G flange bolt on to USDM EVO?
- Mechanical boost gauge install question
- EVO VIII JDM vs USDM engines...
- Wastegate boost question?
- Drag strip tonight....
- Intercooler spray
- Battery in US Evo8
- Any rattle so far on your Evo?
- Power FC
- hks ssq blow off valve
- HKS electronic
- HKS Type-1 Turbo Timer
- Should I change oil after 600 mile break in
- DSM Link?
- where is the 'key switch connector'?
- Nitrous IC kits
- downpipe
- dyno comparison in turbo mag
- Warm-up Noise
- O2 sensor Simulator?
- How high can we boost on the stock fuel system?
- I need some info about oil filter
- What Kind of MAF Does The EVO Use
- Downpipe?
- Turbo setting
- How compression effects the turbo.
- Weatherstripping blocking air duct on intake?
- T.M.E. Evo VII, or save $10000?
- Evo 8 rods
- best intake
- Turbo....... Psi........????????
- HKS titanium exhaust
- HIGH PSI.... How much Hp per PSI?
- 100 octane question...
- E-Boost Electronic Gauge/Controller
- turbo velocity tube. where to get it. picture inside
- turbo upgrade
- which downpipe 2.5"or 3"
- Gauge Light wiring..
- Crush washers
- Transmission and transfer case fluids (maybe even rear LSD)
- Magnetic Drain Plug
- Shifting into 3rd gear?
- Connector next to OBD-II Diag port..
- Evo Clutch Gone READ NEED AFTERMARET
- Which exhaust kit would you purchase?
- Over Rev and burning smell??!?
- Ultimate Racing EVO 8 goes 12.57 @ 107 MPH!
- hks ssqv
- downpipe price
- Calling Claudius
- What is a good gas mix for the EVO?
- Power Enterprise Air Impulse install on Evo 8
- Max HP
- 19psi to redline safe??
- Fuel maps for S-afc on Evo?
- Boost!
- Donwpipe install!
- Dealer must change oil?
- EVO tranny looks BUILT to me!!!
- 2nd Gen Eclipse Turbo Timer Harness
- Has the SAFC been proven not to work on the new EVO?
- Please Help Me
- SRS warning light
- ANYONE WITH THE GREDDY PROFEC E-01 pleeeeease help!!!
- front lsd on ebay
- Synthetic gear oil?
- Apexi BOV and S-AFC
- Drop in filters?
- Evo VIII front LSD
- High-revving
- HKS camp system install
- G-Tech results & downpipe ?
- Just installed Vishniu Stage O Mods!
- Thermal Exhaust for EVO is READY
- After reding the EVO's brochure got some ?'s
- ecu wire charts
- Safe boost setting
- Dave Buschur says get back 30hp easy..
- Regards Bov to Air
- Octane math formula anyone.
- Foglights Usage with Only Parking Lights
- Remote locking - how to remove the horn
- Engine Idle at 1300 rpm on EVO
- Bulb types
- Samco turbo hoses - fit 100% great stuff
- Mitsubishi backed performance mods
- Blitz DTT Turbo Timer
- First Oil Change?
- Warrenty
- will this bov work
- Is it possible???
- Oil overfilled...
- Finally past break in, mod time...
- just installed mods on the evo
- 12.54 at 112mph in EVO VIII
- "Evolution" Valve Cover
- speed signal wire on ecu?
- Oil Temp vs Water Temp Gauges
- Exhaust question
- Any A-Pillar gauge pods out yet?
- filling intercooler spray fluid reservoir
- jic catback titanium exhaust
- Defi Boost Gauge
- Was the EVO 8 rushed?
- Bosst controler setting
- High-energy grounding cable kit
- Mines VX-ROM
- Cat deletion pipe.
- Which Intake set up do you prefer?
- Looking for a tunner
- How difficult to instal S-AFC on an Evo?
- open loop bov on evo
- Intake worries?
- APS Products
- Internals
- water sprayers?
- 4g64 Practical applcation for Evo?
- Any torque/HP curve graph for Evo8?
- HKS EVO Circle Earth ground system!!
- How close to emmisions?
- Carbon Fiber Wing again...please, read if you own a evo
- digital Boost A/F Ratio gage
- Evo 8 carbon fiber wing spotting(bubbling)
- gauges pillar and other
- EVO 8 Ecu diagram
- Looking for Ralliart Parts
- clunk noise when shifting to 2nd
- Anyone run toluene/xylene in their EVO?
- Evo VIII Short shifter...
- using a boost controller?
- Any thoughts on adding K&N filter??? Also, are we getting FQ300 upgrade
- Check your oil level...
- ECU wiring diagram
- exhaust clamps - matching metal
- turbo back....
- Intercooler sprayer question....
- performance parts for evo
- boost gauge
- electronic turbo?
- Intercooler Piping Kit
- octane boost
- evo noise
- Oil filter - is it same as '99 Eclipse???
- Oil Filter part numbers? 3rd party
- EVO 1-3 and EVO 4-7 intake port differences
- WTD: EVO 7 intake pics
- HKS Hi Power Exhaust
- Poor gas mileage
- Hyper Ground System...
- Boost controller HKS EVC V and Fuel cut?
- EVO8....crank walk??
- JDM immobilizer
- Boost controller for the Evo...
- Dyno results - Pruven Perf. Test pipe - SAFC and Boost contr - 275 wheel hp
