PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Anyone know what this noise is?
  2. Built Block recommendations
  3. What turbo to buy when you get used to 6766
  4. Official Blown Engine Thread
  5. 2.0, 2.1, 2.2 ?
  6. Stock evo 8 But have a evo 9 fp green turbo now
  7. Suggestion Turbo (Noob) | 05’ evo 8
  8. Buying parts for my engine - review
  9. Turbo options
  10. 500 miles into built engine burning oil
  11. 6 speed tranny after engine blown!
  12. Please help diagnose clutch/trans noise
  13. Advice on cams
  14. Fp green on stock block Evo 8
  15. Evo ix mr rear engine (dog bone) mount
  16. Clutch pedal pulsating
  17. Evo IX MR - Clutch problem
  18. Magnus V3 vs JMF Drag Billet Intake Manifold
  19. 4g64 Oil Squirters
  20. Boost, HP, & Longevity
  21. Need help with boost problems
  22. New J-pipe has no nipple
  23. Manley or OEM Crankshaft
  24. Rev Limiter is 10K Bad Idea?
  25. Oil squirters question
  26. Rear Diff Oil - Motul Gear 300 or Castrol Syntrax
  27. How do I loosen this 14mm on AC clutch?
  28. Catalytic converter -- stock or aftermarket?
  29. Engine Bogging Down.. AGAIN
  30. Couple questions... ETS 6466 kit install
  31. Engine ticking/vibration noise at 4500/5000 and above
  32. Tial QRJ Orientation
  33. Neep help!! Loosing power
  34. Mitsubishi outlander turbo rear diff. same as evo rs rear diff?
  35. STM Turbo Oil Drain Line
  36. Tilton Triple Clutch
  37. Start problem
  38. Wrist pins
  39. Evo 8 or Evo 9
  40. Stock camshafts for sale
  41. Stock intercooler for sale
  42. Stock blow off valve for sale
  43. Evo IX Another Busted Throw out Bearing and ACT clutch questions/decisions
  44. Another Busted Throw out Bearing and ACT clutch questions
  45. How to remove 4g63 crankshaft?
  46. Tick noise, thoughts?
  47. clutch do not engage right,
  48. New BR 2.3RPM Build No Start Tried Everything Need GURU !! lol
  49. transfer case on Evo IX
  50. ACT Monoloc wedge collar
  51. Need help choosin the next mods for hp gains
  52. Clunking noise on driver side
  53. Stock frame turbo water lines from ebay
  54. Clutch pedal stuck to the floor
  55. Evo 8 starter issues
  56. turbo tuff rods in 2.3L setup
  57. Damage caused by broken pieces of the plug that went into the valve and damaged it
  58. Can someone tell me where this bolts to?
  59. bov flutter/compressor surge?
  60. evo 9 goes lean as soon as i hit boost
  61. 5 speed into MR conversion kit 06 evo
  62. correct 4g64 block clarification
  63. Dry sump
  64. Clutch Slipping?
  65. WTB EVO 6 speed transmission
  66. Rear trans dogbone
  67. HELP: Cylinders getting to hot, weird fuel spread from rail
  68. Oil in the UICP - Help
  69. Can I use Tilton disc with qm 8 leg clutch
  70. 1-2 shift issue after car sat for 1 month
  71. Are cam gears NEEDED when installing Gsc S1s?
  72. Are injectors needed with these mods?
  73. A couple beginner questions about air/fuel ratios
  74. Rod Knock? Or Lifter // Valve Train Issue?
  75. Stock block turbo choice
  76. need turbo
  77. Apexi PowerFC MAP Sensor Problem
  78. Valve cover baffles with a catch can
  79. Question about throttle body/intake plenum/vacuum lines
  80. Ets cooler
  81. Oil in cylinder
  82. Evo ix boost pill location
  83. Evo 8 Wont Start When Warm
  84. 6mt wont go into third all of a sudden
  85. Drivetrain noise
  86. Hks -> k&n filter
  87. 500+HP daily clutch?
  88. Regular Lancer engine block in an evo8?
  89. Stock turbo/E70
  90. Compression numbers possible HG Issue??
  91. Vented VS. Sealed Catch Can Test, which is Better? Watch to find out!
  92. Reliabilty and Durablity of this build??
  93. Borg Warner S362 FMW + map Manifold
  94. Transfer case lsd its in Japanese
  95. Thinking about running either FP Red or Green w/ stock internals
  96. what cams for evo 6 tme
  97. CV boots cracking on otherwise perfect axles
  98. Stock 2005 EVO 8 Rough Idle
  99. cams problem
  100. cams problem
  101. cel insufficiet coolant temperature to enter close loop
  102. Need help cop kit problems
  103. rattle when driving
  104. Only 8 lbs of boost after racing
  105. Starting my Evo after 2 years, what needs to be done
  106. Looking for an engine builder to do my 2.3 stroker
  107. Same temperature, higher humidity. BIG TURBO
  108. Rebuilding exedy twin
  109. 2.1l long rod
  110. Rear wheel bearing seal *pic*
  111. Transmission Stud mounting bolts
  112. Turbo woes..
  113. DIY COP question after install
  114. Car bogging/jerking on boost
  115. Bov stuck open on idle!
  116. E85 Injector Question
  117. White smoke under hard acceleration
  118. White smoke under hard acceleration
  119. Boost Wont Come On Initially But Then Stays Strong
  120. Question about Torque Solution cam side motor mount
  121. camshaft sensor housing
  122. EVO 3 missing cylinder #2
  123. Evo 8 Water pump different? Or the Block? Need help!!!
  124. Evo IX MR (6-speed) Quartermaster HRB, need help
  125. Peculiar Timing Issue
  126. boost cut on high boost above 4500rpm
  127. Boost Leak Testing Help
  128. Advice requested
  129. FIC 1650cc injectors idling rich on 93 octane
  130. 3rd piston blown pics
  131. Carbonetics triple disk clutch issues. Please help
  132. 6466gen 2 issues
  133. 5-Speed walk through. quick vid
  134. evo 9; weird sound during testing
  135. Evo 3 gear rations and options
  136. Are GSC S1s a good choice?
  137. Adjustable Cam Gears for 272 Upgrade?
  138. Show me you oil catch can set up
  139. What cams are these?
  140. ABS question
  141. Simple Clutch Related Problem
  142. GSC S2 cams on stock bottom end?
  143. Building Head
  144. EFR7163 or 6758
  145. Any results on the efr8374 1.45?
  146. Rattle during acceleration
  147. FTO 1.8 on running on 1 cylinder
  148. What is proper grams reading for evo 8 MAF
  149. Question About PCV Valves
  150. timing help?
  151. Cosworth dual springs and Titanium retainers #28249
  152. Eagle 100mm Forged Crank vs 4G64 OEM Crank
  153. New clutch problem
  154. EVO4-9 block with VR4 head?
  155. engine bogging at full trottle
  156. Car going rich after driving?
  157. Over heating problem
  158. Lean AFR's, Break up WOT
  159. Differential/driveshaft clunk after Act 6 puck
  160. Fp Green 73htz spool time.
  161. MANLEY prone to cracking?
  162. Hallllpppp
  163. Borg Warner S369sx-e or GT4202r
  164. Evo 8 grinding in 3rd and sliding out of 4th after rebuild
  165. Evo IV crank pulley noise
  166. Half Throttle Hesitation/spark cut/?????
  167. Evo IX 5th-Gear Grind
  168. EVO Intermediate shafts
  169. Oem Valve Seals vs. Aftermarket?
  170. Which plug should I use? Anything I'm missing?
  171. Suggestions for Dual Gauge Pod above HVAC controls
  172. Milspec or buschur 65 mm throttle
  173. Wiseco HD2 Taiwan wristpins
  174. 87 oct. when tuned on 93
  175. Evo 8 iacv & idle question
  176. Rear Differential and suggestions on what to do. The saga continues.
  177. Oem Main studs vs. ARP main studs Problem
  178. Evo 8 BOV Stststst
  179. Lightweight Exhaust options Evo 8/9 cat back/Full?
  180. Running Larger Feed Line
  181. Bell housing full of fiber!
  182. Evo 8/9 Engine Failures
  183. head gasket leaking oil!
  184. Parts needed for Heads and Cams
  185. What clutch should I go with?!?!?!
  186. Evo 9 fuel efficiency issue
  187. cam angle sensor plate position!
  188. Estimate pricing?
  189. Evo 8 Buzz/rattle at 3500+ rpm?
  190. Feed lline bolt
  191. Forge type RS problem
  192. Evo 9 problems
  193. Anyone have a part number for the screws on the throttle plate?
  194. Excessive smoke with good compression and leak-down numbers
  195. timing belt tensioner pulley adjustment
  196. Rough Idle, Crazy AFR at idle, All good When AC is on
  197. Forge DV Leaking?
  198. ** Evo 8/9 Build w/ Video **
  199. 270-300kw evo 8 MR RS
  200. Airtrek Internals
  201. Opinions or Reviews on Rockauto axles for Evo 9
  202. overheating problem!
  203. What limits a bypass valves hp capacity?
  204. Slider/synchros?
  205. ACD Relocation Help
  206. HELP! VSS/p0500 mystery
  207. 2.1L 4G64 long rod ...
  208. Sportback GTS (AWD)
  209. low compression test
  210. TPS doesn't work, reads 0% on Evoscan
  211. Shifter base bushings, now no reverse lights?
  212. FP Zero OR Precision Turbo 6466
  213. Getting locked out of all gears need help
  214. Leak from Transfer case/drive shaft?
  215. Deck the surface or f it and finish it
  216. Block breather location?
  217. Meth+no IC vs IC
  218. Evo 8 rear differential ilquefying oil
  219. Help
  220. Twinscroll t3 manifold where to buy?
  221. strange misfire
  222. Evo 9 - Upgraded Exhaust Cam Only
  223. which turbo should I use on my 2.3 have an og green and an fp black
  224. Best intake and throttle body ???
  225. Borg Warner s200sxe (s257)
  226. 2.1L dipstick 4g63 or 4g64?
  227. different kind of vacuum lines
  228. evo x cant boost past 12 psi
  229. Vibration under load
  230. water pump adapter gasket for 2.1L help!
  231. 6 Leg to 8 Leg
  232. Exedy Twin Disc Jerking when slowing down and downshifting into 2nd
  233. Shifter
  234. What Oil and Oil Filter are you Running?
  235. Exhaust loudness list
  236. Can In-Gear Rev Hang Hinder Braking?
  237. Need some help on my evo 8
  238. Transmission grinding noise?
  239. Wavetrac Front LSD diff upgrade, is it worth it?
  240. noise identification help!
  241. Head Gasket; OEM vs aftemarket
  242. EVO 9 Leaking ACD pump
  243. Cam Gear cover bolt -- Help!
  244. Cv axle?
  245. What mods to achieve 350whp?
  246. How long to IKH24 plugs last
  247. Running rough on hot days.
  248. Evo Noise -- Turbo Shaft play?
  249. New 2.1L 4g63 build. Components?
  250. 98 eclipse swat turbo for evo9
