- HELP!! Broke something not sure what it is ? Pics included !!
- Rocker arm fell off!!?
- ETS Short Route Complete Intercooler Piping Kit (Evo 8/9) Recirculation Pipe?
- Enginebuilding
- question ondifferent types of fp hta 3582r
- Bad boost leak around throttle body - HELP PLEASE
- ETS Spark Plug Covers Available Again?! - Details Inside!
- Is the head plug for DSMs the same for the evo?
- Could really use some opinions!
- Intake Manifold styles / Searching for old AMS Article about intake manifolds
- EVO 7 5 seed different to 8 and 9?
- Hks dli 2 REPALCEMENT exchange HELP help PLEASE!!!
- my first 2006 exo 9 se
- Best/most useful defi gauges for the money?!?
- Small cam but big lift.
- evo 8 wont go into 4th gear????
- When to upgrade stock intercooler?
- Strange oil leak! Help!
- HKS GTII 7460 w/o oil restrictor?
- early mitsubishi 3000gt rear diff on a evo 8 help
- Boost Control.
- Mivec modification, and results on stock bottom end.
- ETS short route w Honda battery mod
- Any ideas what cams these are?
- Maybe burning coolant? How hard to replace head gasket?
- need to know what turbo is this !! GT30 or GT35 pics Inside !!
- ETS Single Scroll 6266 Kit
- Horsepower on pump.
- Clutch or something else?
- JDM Evo 8 Blowoff valve problems
- OEM 7-bolt 4G64 100mm crank part number?
- Og green rebuildable to hta?
- ACD warning light: only fault code 34
- Replace what else along with clutch/flywheel? BEST PRICE ON PARTS...
- Piston Dome Dish and Compression Ratio
- t-case leak
- Tranny noise on cold start
- precision turbo size???
- For those who have a built engine video inside...
- Evo 8 MR Enclosed Air Box and Intake Options
- Oil cooler size
- DSM Turbo Set Up Question
- Thick black sludge issue?
- Transmission Problems..3rd Gear Grind
- Some kind of surge noise?
- chatter/rattle noise at 3000-3300rpm
- Evo 7 box 5 speed.
- Extreme Turbo Systems - GTX3076R T4 Twin Scroll Turbo Kit
- cant get 4th gear in
- evo 8 lower boost levels when hot
- oil pressure at cyl. head
- 6 speed 3rd/4th fork snapped... pics inside
- standard valve springs on tomei 11.5mm lift cams?
- How to replace oil cooler with AN fittings? Evo III
- Oil on spark plug threads
- Turbo Question.
- Quick question!
- Internal vs External Wastegate?
- Invidia Downpipe with Buschur Cat/Catback
- Oil from v-band area on turbo
- grinding noise ?? help..
- FIC1050 data sheet
- Hals oil cap
- Looking for best pricing on BW/BEP Turbos
- gear whine ?
- Air to water intercooler
- sooner spooling turbo?
- Bad Axle?
- Evo 9 Headgasket to 8 engine
- Shredding serpentine belts
- High idle after clutch install
- For those with dumps
- Low Boost / High Knock for 1 day only...
- old school 3065 bushur kit options for turbo change
- HELP: Car goes lean when second fuel pump comes on
- How long does it take to burn exhaust valves
- Walbro 450 e85
- Transmission issues.. could use some advice.
- Double pumper identification help
- Urgent! Need help asap please!!!
- anyone have the Buschur double magnaflow tbe exhaust setup with a review or sound cli
- Camshafts on stock frame turbos with larger exhaust cams.
- What intake/exhaust valves do you hight hp guys use!!??
- con-Rods and pistons (manufacturer?)
- boost sputters under WOT
- Rear Diff Leak.... Where is it coming from
- HeadGames cylinder head porn...
- Problems !! evo 7 engine ???
- Exedy Stage 2 Results
- Steel locks with titanium retainers?
- Are EVO transmission gears shot peened from the factory?
- need turbo experts advice
- main's oil clearance
- rear differential help needed
- BR front crossmember bar help!!!
- What could this be? Compressor surge?
- Electrical and HID issues
- Voltage oscillation/drop during WOT pulls…… V swings between 13.8 to 12.3V
- Lightweight Flywheel / Crank Damper Tech
- Two engines burnt up in three weeks. I could really use all of your inputs PLEASE
- No power to ecu
- Throttle hang issue at high RPMs
- Peakboost Top Mount GT3576
- Funny oil on oil cap
- Clutch 600 pounds
- Tensioner pulley...same part??
- What turbo do I have? Help please
- Spool and Power difference 6262 .63 vs. .82
- Keep Current Cams or Upgrade
- engine bearing problem
- Evo 8 transmission leak from driver's side
- Tial 44mm WG leaking during boost leak test.
- Greddy profec b 2 not controlling the wastegate
- machining a 4G for 1/2in studs
- oil question for 2.1
- CXRACING 11 Gauge Stock Frame Tubular Manifold
- 02 housing upgrade
- Buying an exhaust manifold but on a budget suggestions?
- No boost control
- idle problems
- What point do I need a dry sump oil system for my evo 9?
- Kiggly vs duals
- Non ACD transfer case housing
- Attn: All buschur racing 2.3 rpm motor owners w/gt3586 or larger turbos.!.!.!
- Bled lifters, Intake cam may have jumped a tooth. Opinions please!
- Comp twin disc question
- What's the difference between a V3 evo engine and a T3 engine????
- Ok everyone needing help again on my engine swap the new engine is in. Urgent please
- Re-sized combustion chambers to 87mm on a 9 head and a Kia head. Pics inside.
- Pros/cons of having ACD on hight HP Evo questions?
- video on how to change the front diff in your evo 8
- Price check on 4g63 block
- Need help on boring my block!
- Bell housing broke from clutch fork
- Cars making a loud noise when trying to take off
- Kelford cams ?
- Just pulled my motor
- rpms "slip" from 3500-4000. clutch? electronics? something else?
- Evo 9 stock turbo whines
- Check valve on 300+ fuel pumps
- rear diff side bearing
- Differance Between Turbos
- Hawker Genesis
- ACT Clutch Screeching
- Can I run an ACD Transfer Case in my Non ACD EVO 8 GSR
- Need help on how to properly resize combustion chamber to 87mm.
- Direct swap dual ball bearing?
- Hallman boost controller with an fittings. What is the pros of this?
- anyone usin Tomei 270 with 11.5mm lift
- Short shifters ..
- hard to shift side-to-side
- VII stock bottom end's
- hopefully my only retarded question on this forum.
- Radiator Life
- Opinions on Rads?
- front mount issue!
- Car shut off going dow highway...stalled
- How does this happen???
- video on how to change clutch in a evo 8
- is tuning a must after a cam install!?
- Mystery broken ball bearing found in oil pan
- Evo 5 & Evo 7 Transmission difference
- Base Map
- flushing my treansmission fluid
- 500 whp + MAF = how pressure drop in the intake pipe?
- Intake Pipeing
- does anyone know what thread pitch to make my own fill tool for transfer case?
- evo9 turbo or bs?
- whine while in boost, possible turbo shaft play?
- Visual difference between Exedy Twin HD and SD
- help identifying bolts
- Feed back on Okada Projects Plasma Direct coils ?
- Possible to just keep ix gears besides 4th ??
- Evo 9 acd motor burned
- Lifter Tick? Stock BOV Flutter?
- winterizing question
- What is a new FP Red worth?
- 2.2l help.
- evo engine failure - *video*
- Mystery Head and Valvetrain Identification!
- Poor cold start, EDM 4G63
- MBC Boost Levels Winter vs Summer
- ACD relay
- wanted 3000gt rear diff side mounts to fit a evo 8
- Evo 9 Turbo vs Tomei m7960
- Clutch good for 450-500tq?
- The craziest thing happened...
- Sheepey manifolds??
- Idle won't fall between gear shifts
- motor lift brackets. HELP!
- Clutch fork pivot arm
- Exedy Triple Disc
- clutch kit question
- How much HP without head studs?
- Pte6262
- Motor blown? broken spark plug
- Exedy stage 1 HD clutch first impressions/short term review
- Leaking Tomei M7960
- Anyone swap out a Full-Race 35R to EWG EFR? Swap the 35R out for which EFR turbo?
- stm 4" intake
- EVO 9 Rough Idle
- lower front control arm
- Huge evo 8 leak
- good aftermarket Manifold with EWG flange....
- Noise, sounds like something is loose..
- Another "what turbo should I get"
- Fp green turbo upgrade help
- 2.1L Timing Question
- ac delete help
- What's the best 20g turbo?
- What gear ratios should I use?!
- transfer case whine
- OBX Direct Bolt On Turbo anyone?
- noisy clutch? sounds like a dragging caliper?
- Tomei Oil Pan Baffle Plate work on a4G64?
- Injen Intercooler Piping Install Issues
- Vacuum flutter from bad lifter?
- catback question
- Should I buy HKS hipower 3in exhaust, 3in downpipe, & 3in perrin test pipe for 300!?
- 1200cc and single walbro 255 on E85?
- Just wanted thoughts on new clutch... ACT
- Evo IX Studdering
- Bolts ons for FP Black Tune
- Spec Clutch SERIOUS ISSUES
- I have a pretty much stock evo8 and want to go e85! HELP
- Burning oil on throttle lift, oil in turbo inlet
- Car can't high boost and cuts Rpm
- E85 in tank while stored or retune on 93 necessary??!!
- Slight puff of smoke
- engine life
- Connecting Rod HELP!!
- HELP to Diagnose Rod Bearings, plz.
- SPAL FAL MISHIMOTO EBAY fans?
- Cylinder Head inspection w/ Pics, Opinions requested!
- engine wont start
- 4g64 head gasket recommendations
- Review of engine build, Detroit region
- evo advice
- Big turbo help!
- No 3rd/4th Gear in Evo 8 Transmission
- BBK-3B Turbo
- Weir performance 16 plate max grip lsd kit review
- disappointed in my injen intercooler pipes
- Forge mbc/grimspeed
- Shifting into first and reverse while stationary
- 2005 evo 8 tranny into a 2003 evo 8 transfer case
- Best turbo for 3k RPM full boost spool??
- Help I need to replace the discs for my ams Push Style Triple Carbon HD Clutch Kit.
- Fp Black ???
- How to video: Diff removal
