PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 [199] 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Jun Cams/valvetrain vs HKS Cams/valvetrain
  2. Boost issue!?
  3. just got 280 hks cams
  4. Need to beat my friend...what should I get
  5. Geo@EvoStore :thumbup:
  6. UK Turbo Dynamics "Turbo Upgrade" - 450bhp EVO IX
  7. mobil 1 synthetic 75w90 for t-case?
  8. NOS as first mod?
  9. Anyone using Fidenza Cam Gears, what cover are you using?
  10. stock fan CFM
  11. Weird Boost Issues....Help?
  12. flash without sending ECU?
  13. Results of my self-tuned HKS EVC 5 EBC
  14. 5th gear grind, HELP???
  15. Useing RalliArt Diff from TRE...
  16. New SFI ISP/ATi spec damper....
  17. Help with HFC
  18. RMR Intake Replacement Filter
  19. problem with wastegate(maybe)
  20. Trying out different sparkplugs
  21. keep blowing engine fuses
  22. re: idle problem
  23. 10.5 Hotside, Tubular Exhuast Mani and O2 Housing Install Pics
  24. fidanze or prestreet flywheel for ACT clutch?
  25. Rally OZ VS. Ralliart
  26. Checking crank sensor function?!? Arrrrghh!
  27. Apexi AVC-R Settings
  28. Buschur TBE w/ Diff Muffler
  29. Intercooler where to go ??
  30. Happy with your cams?
  31. could i have damaged valvesprings or retainers?
  32. Need Help Choosing UPPER IC PIPE ! ! !
  33. Owen turbo kit
  34. which exhaust?
  35. Downpipe Bolts Coming Loose!???!
  36. Car Hurtin!
  37. Short shifter for my MR .. PLEASE!
  38. about b.o.v's
  39. NO cat CEL fix. anyone tried this?
  40. Two kinds of Synchromesh?
  41. Pics please of BR500 turbo kit installled
  42. hp loss at high altitudes
  43. Buschur flash??
  44. Apexi GT Exhaust Questions, need help?
  45. Question for those using nitrous
  46. Is there a point for bypass/bov?
  47. Fuse keeps blowing can't figure out why?!?
  48. Exhaust and downpipe suggestions?
  49. BOV Help
  50. Vibrations after alky install
  51. DynoJet correction factor for temperature conditions
  52. Compression on an evo.
  53. what should i do ???????CAMS
  54. Buschur tuned 35R w/methanol...and a jack russell
  55. Spark plugs when and who?
  56. GT30R on a stroker
  57. Question about install of Buschur 3" TBE
  58. SFP turbo kit
  59. quick exhaust question!
  60. greddy turbo kit #s
  61. greddy turbo timer question..
  62. Motor mounts
  63. When the clutch starts to go...
  64. So this is Launch control/NLS?
  65. Quick Question
  66. Funny story, we don't sell "offroad pipes" anymore!
  67. Anyone running 280i/272e Cam Combo
  68. Greddy Evo2/SPS
  69. FANTASTIC!!! My 272's!!!!!!!
  70. Leaking Transfercase/Transmission seal
  71. Why does whole car shake in 1st gear?
  72. New stock clutch, a few questions
  73. Clutch, BOV, And Exhaust ??????
  74. Exedy disk replacement
  75. Need help with my BOV.
  76. Stock MAF Capabilities
  77. Spark plug fouling help
  78. I Want 11's!
  79. Any Suggestions On Before Install Tomorrow....
  80. nology hot wire ??
  81. switching bov
  82. 272 or 280's with dynoflash?
  83. Stock Boost Guage
  84. Transfer case is Diff?
  85. Where can i find just lower ic pipes?
  86. expensive sounds
  87. Anyone using the EVO 8 HKS Intercooler Kit?
  88. Alkohol Flash-running w/out alcohol
  89. Great Comparison Video of MR vs GSR vs. Sti
  90. Would you go with these upgrades?
  91. Full boost @ what RPM?
  92. torque spec on crossmember????
  93. Which replacement filter?
  94. Broke again
  95. Installed my HKS EVC 5 EBC PSI model
  96. People with HKS ssqv recirculated
  97. Cracked Valve Cover....
  98. Anyone interested in some track time with some other EVO's? (IE. VIR in Va)
  99. ****evo Mr Exhaust/02housing Question***
  100. evo fq 400 on TV now! (9pm chicago)
  101. problem after clutch install
  102. best intake for your money!!!
  103. 250whp tuned, low results?
  104. Ok did pressure test, possible problem with mbc
  105. Getting 272s do i need supporting mods?
  106. how much power?
  107. installed megan manifold have leaks
  108. Heard Something Pop/ Break...
  109. JDM MR BOV error
  110. Injen Intake Owners
  111. Dynojet/ET/MPH Comparison numbers
  112. cams and fuel pump question -
  113. ECU and HKS EVC probs...
  114. Squeek at high RPM's -- HELP!
  115. race gas???
  116. Where to buy Quaife?
  117. Bad Dyno GT35R
  118. Buschur Racing's new EVO, runs a couple of 10's.
  119. Disconnected waste gate line, got 30 PSI!!!!
  120. trany rattle noise, please advise !!!
  121. Injen intake damage
  122. White hotside
  123. My evo is boostin early with Hallman manual boost controller
  124. Synchro problem or not ???
  125. Anyone totalled out an MR yet?
  126. Fp 3065
  127. Tanabe catback owners?
  128. Engine R&R Tips WANTED
  129. Nisei FMIC
  130. Castrol GTX for 1st service
  131. Misfiring after 4k rpm!!
  132. Should change name to smoked.....clutch!!
  133. Flex Joint....necessary?
  134. Is 23lbs of boost safe for me?
  135. How much power you think?
  136. sell me on plug type and gap
  137. Lighter flywheel throwing CEL?
  138. What can be done to improve acceleration? (gearing wise)
  139. TRE tranny
  140. Suddenly im rich
  141. ACT clutch with flywheel?
  142. Difference In Power Using DIff mixes with an alky kit
  143. help!! idleing issues
  144. 20G turbo upgrade from Buschur Racing.
  145. Just bought my new EVO 6.5 RS TME Turbo
  146. Clutch Adjustment & TOB
  147. Looking for high flow cat to fit in OEM exhaust system
  148. 25g
  149. Motor Oil
  150. Throttle Body Size????
  151. Can anyone recommend a magnetic oil drain plug?
  152. Borla catback?
  153. ACT Clutch Question
  154. Penzoil Syncomesh Destroying my Tranz
  155. Spark Plug Suggestions?
  156. what exactly this does
  157. how much boost can a stock evo 8 turbo produce
  158. 4th gear syncro issue's and questions!
  159. exhaust question?
  160. ACT clutch & syncros!!
  161. which 3" DOWNPIPE has the best fitment?
  162. combustion chamber volume?
  163. Turbo inlet size
  164. Porting stock turbo
  165. Kinda bling, but...
  166. Black wax type substance
  167. Again same problem
  168. exhaust...(read first)
  169. Options: TME Turbo or Cam Gears with Cams?
  170. could my problems be a bad o2 sensor?
  171. megan R o2 compared to stock?
  172. Turbo XS Bypass Valve problem.
  173. boost guage needle vibrates bad
  174. upgraded FMIC worth it in cold climate?
  175. Looking for a better fitting DP and catback
  176. 1g 4g63 t-3 flange manifold
  177. oil catch cans.
  178. 0300 code caused by transmission harmonics?
  179. Jestr tuned
  180. exhaust leak or brake squeal?
  181. is my clutch going out?????
  182. Added Hallman Pro MBC & a boost gauge = WOW!
  183. installed 3" test-pipe and 3" JIC Spartan Catback...wow...car much faster!
  184. EGT probe snapped off... [Pictures]
  185. help! fitting for oil cooler hoses?
  186. Prototype Bolt-On Turbo Testing
  187. Hks Eids
  188. Is it normal for boost to increase by 2 PSI with DP and TP?
  189. Looking for input on radiators Koyo/PWR/ARC....
  190. putting a perrin crank pulley hurt my motor??
  191. How to blow up a clutch 101
  192. !! Lots of oil in catch can !!
  193. Blitz DD BOV Problems
  194. Need help please!
  195. Retarded timing (Literally) and spoolup
  196. Tial 44m Wastegate Springs
  197. for those running ARC intake
  198. How would you spend 1000 dollars ...??
  199. What next?
  200. Is this the best way to spend this money?
  201. Porting the Forced Performance !0.5T
  202. 10.5 housing wastegate question
  203. Installed bigger IC, now boost decreases?
  204. Pounding the White Rabbit
  205. turbo xs fmic
  206. intercooler piping question
  207. Greddy Type S & Possible Boost Leak
  208. 21G turbo news?
  209. 264s vs 272s
  210. Turbo Information
  211. P0300 Stuttering, retard timing
  212. have a question
  213. Invidia G200 Ti??
  214. When to change spark plugs
  215. problems with my car need some advice
  216. Buschurs "view" on cam gears
  217. Downpipe gasket set
  218. nx co2 spray
  219. WasteGate restrictor pill
  220. Fumoto valve
  221. Anyone know what this is <see pics>
  222. Buschur exhaust Question
  223. Max PSI Recommended?
  224. I need a no flutter recirc BOV - need suggestions
  225. Evolution Drivetrain for Dummies
  226. Flywheel resurfacing
  227. turbo advice needed!!!!
  228. Do cam gears alter power or adjust idle?
  229. Is 1.59 bar (23psi) safe on my car...
  230. Help Needed in Ferrea Product
  231. Driving without a tune?
  232. Apex'i Active Tail Silencer (ATS)
  233. HELP!!!...car wont start
  234. Link to PLX wideband/680cc injectors for sell in classifieds
  235. WOW ! 558 AWHP 454 awtq on stock motor (cams and headbolts) and 94 octane w/meth.
  236. HKS RS intake: once again, notable power gains
  237. Porting the 10.5T Questions
  238. Former Honda Civic Guys help!!
  239. EVO 6 TME Vs 10.5 Hotside???
  240. Help Please! i need an answer!
  241. Running to rich?
  242. japan and blow off valves
  243. Resonators: Louvered or no?
  244. BGsyncroshift works good!!
  245. tranny question noise
  246. BR standard intercooler upgrade
  247. please help, my DIY gone wrong
  248. My AC is no longer cold anymore
  249. What size injectors?
  250. bearings
