PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Injectors - ID2200cc vs FIC2150cc
  2. Synapse or APS???
  3. stalling issues
  4. Another Idle Problem
  5. Urgent clutch question. Exedy Stage 1
  6. Questions regarding BBK Full Turbo
  7. Anyone has experience with Greddy Profec B Spec 2 boost controllers?
  8. Bov ?
  9. quick shift bog
  10. Buschur Turbine Housing (wastegate)
  11. Checkmate! Reichen's NEW EVO RECORD 237 MPH!!!
  12. NEED HELP!! My Tranny will not go into gear when my car is turned on.
  13. What Downpipe??
  14. Anyone here replace the Oil filter housing?
  15. odd clutch type noise
  16. Differences between Samco and Perrin Intake Tube
  17. Anybody running the buschur SD muffler
  18. HELP true boost problem!!!
  19. Shearer mani w/stock rad hose
  20. Head porting
  21. My ECU readiness story and my questions....
  22. What Mods should I do before installing new motor?
  23. Exhaust manifold/o2 heat shield on FP turbos
  24. My future Build "About T-Cases"
  25. Critique my build!
  26. Evo 9 output shaft help ASAP!!!!!!!
  27. What is the best rear diff fluid to use?
  28. Need opinion on tune problem
  29. Removing acd system and installing non acd transfer case
  30. Anyone Using These?
  31. Exedy Twin on 6-Speed = Sometimes Shifter Stuck in Reverse???
  32. LSD and ACD????
  33. Please help! Oil leak that has kept my car in the shop for weeks!
  34. HELP!! Wierd Revving issue
  35. Intake manifold/engine hanger bracket
  36. has nayone considered making tubular manifolds from
  37. Trying to replace stolen bolts
  38. Oil pressure question going from 10w-30 to 20w-50
  39. replaceing stock BOV
  40. Evo VIII exhaust valves
  41. Shearer’s combination of exhaust manifold & O2 housing
  42. Head leaking oil - need advice
  43. Clutch pedal adjustment help
  44. Yet Another Rough Idle
  45. Wierd and Dangerous Problem
  46. exhaust is leaking boost
  47. Exhaust Manifold suggestions
  48. Dynocom Dyno?
  49. evo 8 engine bay harness
  50. Need help with a fuel pump switch
  51. engine running cool
  52. Exedy Twin HD vs Power train Technology
  53. RPM's dipping
  54. AWD Motorsports Bastard Evo.. Beaten some more with HTA 82 now!!!!
  55. Opinions on rods and pistons?
  56. gates timing belt
  57. best timing belt
  58. about Shep Stage 2 block
  59. wheel bearing or t case?
  60. HeadGames is looking for your input...
  61. *Injectors Needed for Bolt_ONS*
  62. Any legitimate 4.11 final drive experiences?
  63. PTE 1200 fitment
  64. Yes i know its a weird request.. but need to make an evo8 NA.. Is it possible?
  65. Winter/soft tires seem to suck a few whp on the dyno
  66. Will Sard Regulator Rise Pressure?
  67. BISS screw adjustment
  68. SpoolinUp DIY COP Kit installed on Evo 8
  69. wideband says running rich at wot!!!
  70. Hows my flywheel? (pics)
  71. crank trigger wheel part number
  72. For those using Perrin Intake, what recirculating BOV fits best? It's tight!
  73. 22 psi Wastgate on stock turbo?
  74. Theory of mine why QM twin disc clutch have such low millage usage
  75. "Crushed" IX DV
  76. Need 2 measurements: turbo inlet, MAF
  77. Intake Manifold Question
  78. strange part-throttle bucking issue
  79. engine over heating
  80. Turbo Issue-- Butterfly Gasket?
  81. I *think* it's the TC death whine, but want to be sure before replacing it.
  82. peakboost manifold
  83. Injector size?
  84. Tick tick tick
  85. evo ix drain plug stripped oil pan question
  86. looking for some turbo options
  87. outlet pipe
  88. egr leak? rough idle and afr's
  89. Oil pump gear one tooth off from factory...wtf?
  90. raised boost throws CEL?
  91. intake piping keeps blowing off
  92. Upgrading turbo at 80k?
  93. stock block and head with Precision 6265 turbo
  94. Taking off crank bolt
  95. crushed ix dv
  96. Car Bucks While Doing Pull - Loss of Power - Other Issues
  97. Need help fast. oil fitting no more thread
  98. So what exactly am i looking at here :(
  99. AEM meth kit vs E-85 setup
  100. rear end sound!
  101. did I destroy a rod bearing?
  102. Normal Wastegate operation (Take 2)
  103. How to test crank/cam position sensor
  104. Maxing Out Stock Injectors!!!
  105. Pic of pedal stop PLEASE!!
  106. HELP! Evo left me standed on the side of the road...
  107. Titek vs Megan o2
  108. 60k Maintenance Nightmare
  109. Problem with Exedy Stage 2 Racing Clutch
  110. HELP! Evo left me standed on the side of the road...
  111. Perrin Intake w/ hard pipe?
  112. Is this supposed to happen....
  113. Getting ready to install cams
  114. 93 Evo engine problems! Please help!
  115. Car scared the crap out of me tonight...
  116. Help! Idle and Power Loss Issue
  117. Whiny Walbro 255
  118. overheatingevo 8 need help ideas
  119. Ceramic coating in CT?
  120. those of you that fixed your lifter tick..
  121. AMS F1 Intake Manifold
  122. Perrin Evo Lightened Crank Pulley???
  123. Amsoil Users for the T-case and Rear Diff
  124. enough fluid?
  125. Will a jdm diff fit in an usdm evo?
  126. bad fuel/ bad injector maybe=laggy start?
  127. fp 84mm on bbk
  128. damaged cam lobe pics inside
  129. Twin Disc Question
  130. Pedal stop question??
  131. 02 housing problem
  132. Left balance shaft incorrect timing mark
  133. Where did you get your gauge pod a-pillar?
  134. Should the TC drain plug have a magnet??
  135. Boost Flutter (Different but weird)
  136. MY 2.3 stroker FP red E85
  137. Spark Plug Wires
  138. Slow Boys 2.4 stroker Mivec
  139. Carbonetics clutch question
  140. Evo will not turn over or start, but runs fine
  141. 2.3 build problems (headgasket help)
  142. Three codes just came up....need help
  143. FpBlack Oil feed setup
  144. Clutch issues
  145. Crap idle, Lagg monster, Power loss HELP!!
  146. Exhaust leak
  147. Dealership Damaged Wedge Collar!!!
  148. Dealership Damaged Wedge Collar!!!
  149. Which turbo is better?
  150. S2 cams install now cold idle is horrible!!
  151. How rare are Shep Drivetrain failures?
  152. Good laugh..and how not to turbo
  153. Symptoms of a faulty IAC...
  154. Doing cams and timing belt
  155. stumbling at about 3k rpm?
  156. Titek O2
  157. Timing Belt Lose! Cams Skipped Timing! help
  158. URGENT Will an 03 - 04 ECU work in a 05
  159. Please help me identify this connector on the inlet manifold
  160. Whine coming from power steering pump... HELP!!!
  161. How much oil after Balance shaft removal?
  162. muse licp feedback
  163. question about tranny and tcase
  164. Exhaust valve sizes - HELP!
  165. GSC S1 or S2 on BBK stock block?
  166. XS T3/T4 Turbo Setup(56KDeath)
  167. David Buschur's BADBISH, new header.
  168. MR Drivetrain fluids suggestions?
  169. Looking for an ecu and have a question?
  170. ETS HTA3586 w/ 1.06 T3 Twin Scroll (Blue Wastegates)
  171. Clutch Suggestion
  172. 1st and 2nd are gone - IX w/ 16k miles - HELP!
  173. Help with exhaust manifold install...
  174. Built Head before Built Bottom end?
  175. car makes weird noise when letting out clutch
  176. Bolt on fp white
  177. Running a T3 Tubular manifold
  178. Evo 4 problem
  179. Hot IAC ... Really hot..
  180. My new set-up....(FP Black porn inside)
  181. Thermal Spacers, do they work?
  182. Valve clearance with FP5R!?
  183. AWD Motorsports " Bastard " Breaks Stock Ecu & Mivec Record.. 901whp / 640tq!!!
  184. Exedy Twin Questions?
  185. New full aluminum exhaust from downpipe back
  186. just got hta green tuned, stuck at 360/360
  187. HELP! bent shift fork?
  188. Ix turbo install questions/concerns
  189. megan exhaust manifold?
  190. Whats wrong here, I'm stumped, axle and/or suspension problems.
  191. Anyone with Competition Clutch twin experience?
  192. Evo IX Intake cam torque spec?
  193. O2 Housing ??
  194. Lauched now clucking when turning.
  195. Clutch Help
  196. Idle malfunction help
  197. Timing advance on the a 2.1 4G64
  198. 400wtq+
  199. Fuel cut, or something else?
  200. Spark plugs help
  201. new motor need help
  202. Coil Packs from N/T?
  203. Knock at idle?
  204. RPM jumps and goes down by 200 on WOT
  205. Evo won't start...found on road dead!
  206. Help!Clutch pedal was stuck to the floor and now can't go down.
  207. CNC head from HEADWAY PERFORMANCE
  208. oil leak from TC???
  209. Possible Rear end Problem
  210. fp black overboosting-25psi actuator
  211. Exhaust manifold nuts size and thread pattern
  212. What turbo?
  213. Shifting feels mushy after bushings
  214. 18psi WG or 25psi WG
  215. Part number help...
  216. Clutch ?
  217. My Evo caught the Toyota fever!
  218. Driveshaft out of alignment???? Possible?
  219. Setup.
  220. Quick vid of my car idling with fp5r cams
  221. Please Help ASAP!!! I'm going crazy!!!!
  222. Inside my AMS 2.0L after 15k miles
  223. New Turbo
  224. Highest whp for a 9.8 hotside powered evo with a stock block on pump gas?
  225. Transmission install tips
  226. is this HP right?
  227. stock clutch
  228. Finally starting my build
  229. Help!! Problems with Exedy
  230. 3rd gear grinds? Help me please!
  231. Clutch Pedal Problem...
  232. Evo 8 Transfer Case
  233. What Size Fuel Injectors?
  234. Timing belt noise?
  235. "hissing" sound and boost is down but no leaks
  236. request a part number urgently needed
  237. Broke trans (video
  238. alarm killed the battery store?
  239. A/C Evac & Recharge Questions
  240. HELP my tachometer is going insane but the car is running fine
  241. TiAL Q Install Help
  242. how do you set the cams to TDC?
  243. EVOX BOV on EVO 8?
  244. what clutch is better act or fidanza for 550 whp and 440 tq
  245. Did the Walbro pressure relief mod today
  246. Proper way to replace a rear main seal
  247. EVO IX - Borla Cat-Back Installed w/ Pics
  248. Evo IX engine into and Evo VIII?
  249. new water pump leaking
  250. yikes! need help here!
