- Just got my ETS Intercooler!!
- Twin HD max power?
- Where to place resonator?
- Anybody running close to 700 whp with drop in pistons and rods?
- MSD 75lb injectors
- Built head on stock block?
- Modified Balance Shaft
- Help - driveline noise
- a couple of clutch questions
- Help! Boost only w/ full throttle and above 4,500
- thread pattern for autometer egt gauge
- Boost levels for a fp red ?
- Clutch Not Disengaging?? Help please! Brand New AMS Exedy Twin Push Clutch!!
- Kelford IX Cams,Good or Not
- Muffler delete?
- Center dif just shat on me....
- Easier/ Cost effective??
- Greddy type rz
- Thinking of upping my boost on stock turbo.
- help me decide! FP RED or Twin-scroll hta
- Somethings really messed up about my car i dont know what...
- need to know evo 9 turbo coolant line part number
- BBK and FP Green HTA.....
- Thoughts on busted 2nd gear?
- Using rev-limiter instead of 2-step bad?
- LOUD ticking noise from front left wheel
- help
- Boost controller installation
- Buschur MBC Install
- Question about TTP Engineering ACT Clutch
- why 2.5" o2?
- Mod list. helppp!!!
- Tial BOV Springs, which one are you using in your 50mm or new "Q" Version??
- Fp red headstuds, and abuse or no headstuds !
- Check Engine/ Weird boost/ Low idle
- Stock Motor,what turbo?
- difference between mivec cams and non-mivec cams?
- need help please
- More issues....any input appreciated
- 2.3 stroker twinscroll turbo choices
- FP red what supporting mods ?
- quick injector install question
- New EVO 8 and 9 CNC Cylinder Heads APM Racing
- Size of BOV Recirc hose?
- The project..mild motor build pics
- 2nd gear pop out?
- Rebuilding Tcase?
- Greddy T67 25G Full turbo kit
- boost question....newb here
- How Long did your stock clutch last
- Tuning Help Needed to make smooth Idle with Cosw M2 Mivec
- Seriously? Another Cam gear sensor goes bad?
- Need Help!!! BOV question.
- Got a 3 hour drive to go to..safe?
- motor blew up!
- Crushing IX BOV
- Car turns off inbetween shifts
- need help with cel 172 and possible BBK hotside leak
- Help needed on BR turbo kit!!!!! (pics) inside, please help!
- Should i do a clutch upgrade advise please
- transmission / clutch question
- bbk or fp red?
- Jdm 6-speed mr..must come with diff in front?
- Problems with the walbro 255
- BBK full what do you guys think !
- Need Cometic head gasket pictures!
- Overboosting
- timing belt: to change or not to change... that is the question
- will a mishimoto intercooler add HP
- Possible Rod Knock
- Tanable dp and MAPerformace o2 housing questions...
- Weird Boost Leak
- I searched (I DID, I DID!!)
- Best pump gas turbo kit
- lots of mods, now what next
- o2 housings?
- this is a weird one need help please..
- I screwed up my FP HTA3582R compressor wheel...
- Swapping out Clutch , question w/ after TOB removal
- Clutch Problem
- Coolant Leak around Water Pump and Head.
- Need help head gasket
- Safe max rev limit on stock bottom end
- Thinking about upgrading turbo help !
- 35r oil feed line ?
- internal engine rattle?
- What to do next on the mod list ?
- Need help with COILS
- Exhaust Mani/O2 housing Q
- GT35R rebuild ?
- stupid question - will this work for capping off factory boost controller?
- Mitsu newb swapping IX engine. Quick question. Please help.
- Greddy Ti-C cat back come with a o2 plug?
- Clutch blew up at 8k RPM PICS INSIDE
- AMS Oil relocation line
- 2005 EVO 8 problems
- Stock MAP sensor wiring?
- What is the Max Boost for my mods on my IX MR?
- high vacume on boost gauge! 60, also no fuel pressure silanoid
- Clutch recommendations
- any info on maf box
- Flywheel weight??
- stock pistons on aftermarket rods
- Engine Internals, Setup.
- Annoying Issue with Car Pulling Timing.
- Clutch issues
- help with bc springs!!!
- Help!!! Drove w/out oil cap on!
- Stock IX plugs Lifetime on 30 PSI & race gas?
- Fidanza aluminum flywheel; resurface or replace friction plate?
- agency power 35r turbo kit owners!!
- Anyone try an AMK turbo manifold?
- HELP about springs an retainers!!
- URGENT: New Motor with all supporting mods will start up, but will NOT hold an idle!!
- Safety of the stock motor vs power.
- Oil Pressure 100+ PSI???
- Hard To Downshift. Please help.
- What is the best single disk clutch?
- Bad thermostat? Coolant Issue inside..
- Grinding in 3rd, 4th and 5th
- More Power with Bigger Injectors???
- Odd Clunking Noise
- Exedy Twin dragging?
- mishimoto vs. ebay
- Timing=blown bottom end??
- All IX owners w/Cosworth M2's
- Whistle noise when I am in boost
- TB Help!!!!! What did I do wrong?
- When Decelerating in 5th Gear
- Evo 9 cam questions, help!
- ams race balance shaft
- hard shifting?
- Blown Motor!!! Getting swapped!!!
- help, light thumping sound
- Worried about bent valve
- assembly lube question ... whats better ?
- about cams HELP!!
- 2.2L Stroker Owner's, Let Discuss Your Set-Ups
- Need some help with pistons
- samco coolant hoses quiestion evo 8 or 9
- Clutch dragging?? What is the cause?
- Ring Tension
- enging specs, ring gap and placement ...please help
- oil cooler....
- Slim Fan Zip Ties?
- Camshaft sensor query?
- exhaust sagging and sitting way too low...
- MAPerformance Ultimate Duty Rods
- Redline 75W90ns
- Execy twin Hd ?'s
- Vacumn Hoses
- help with clutch diagnosis
- Ported throttle body plate sealant
- Apexi N1 EXTI CBE
- greddy rs bov owners please help
- snapped stud in head
- egr block off purchase recommendations
- Blown freeze plug without blown head gasket?
- AFR Question :D
- Motor help!!!
- Rattling excedy twin plate
- Help, engine and rpm stuck
- need intercooler pipe solution!
- I know this has been beat into the ground but...
- Are there any good aftermarket exhausts that don't have an angled exit?
- Nisei LICP VS ETS LICP
- Help Boost leak
- 05 evo noise in 1st
- blitz intake induction cover? wat u think?
- ac problem
- stock balance shaft
- Drivetrain Question...
- Who sells FUEL RAIL that has the LARGEST inside diameter/fuel capacity???
- How Choose correct main / rod bearing size?
- Oil in charge pipes
- Best Rod Bearings ?
- spec/quartermaster TOB
- Forge DV or stock ?
- need advice on buying clutch
- new clutch/flywheel!! so many!! need help!
- meagan header
- Rolling resistance
- Engine Commpresion Test
- Cam Position Tool
- Help - Removal of rear O2 sensor and routing of WB wiring
- MAP Sensor Adapter?
- Can some one PLEASE look at the Injector Wires for me??
- Evo viii vs. Evo ix
- *Official* NILS Engine Rebuild Donation Poll
- Stock ix rods and bolts-how much power
- 02 dump and downpipe bolts
- internals for 35r??
- best bag for the buck
- worth it to re upgrade IC and LICP?
- Cant build over 24 PSI? help...
- fuel injectors
- Innovative 60-1 turbo repair?
- Car sounds like a go cart
- gt30 stock internals?
- CHRA parts swaps - putting the good parts from an 8 and 9 together
- Transmission acting up, help!
- POLL: ARP Head Stud Install
- Short shifter worth it?
- Where to send Cylinder Head for work?
- HKS gt30r manifold cracks
- not oem fluids in mexico
- Hotside Studs ?
- Tightening the pulley on the A/C condensor?
- what are stock 9 plugs
- Okada plasma coils VS HKS twin power??
- new setup, will these internals work together?
- will this downpipe fit my ix?
- Strange Walbro Whine after Track Day
- samco intake
- Full Rebuild - recommendations?
- Flywheel Clatter?
- Diagnostic tool to hook up to car for engine/car trouble shoot? Please help me guys!!
- Evo IX Vac question
- O2 Dump Questions
- Not getting full boost
- Straight pipe exhaust all the way
- Front o2 question!
- t bolt clamps - sizes - ams ic
- Evo locked up this weekend!
- What broke in my Tranny???
- Injectors...
- KU Engineering 70 mm Throttle body question
- Gummy shifter feel
- Weird 3rd gear shifting problem
- evo's not running
- Which turbo is most comparable to the hta3582??
- throw out bearing clutch help
- Any before and after pics of porting 02 housing?
- Heat Barrier Intake Manifold Gasket
- My Build idea...
- dejon mbc broken?
- When shifting into 2nd - seems to "lag"(not turbo) to apply power
- Perrin 4.5" Filter w/Vibrant MAF Adapter Help Please!
- Clutch Problem
- What is this noise i am hearing!?
- Kelford 272's or GSC S2's:Do I need springs if the block can't handle ovr 8000rpms
- Back pressure to Boost ratio???
- difference between 3/4 gear in evo 8 and 9
- HELP: Tranny Problems
- Head cleaning
- FP Red Road Course Evo's
- Twin Scroll ? T3
- Should i port my fp red 80mm turbo
- Cable Bushings, metal vs urethane
