- Ultimate Street Evo!!!
- lower boost with intake kit?
- My Dyno #'s with GT35R
- Stock vs Iridium spark plugs
- New clutch pictures: Ogura Carbon Clutch
- Not sure what's wrong
- stock wastegate/actuator cost?
- RPS vs CUSCO
- Boost Controller=CEL.......?
- ACT or RRE clutch.
- How long does it take to hit MAX PSI?
- Engine Smell after Turbo Kicks in
- Still...Boost is never constant...
- Impressions of RnR Racing Turbo Back with o2 Elim..by Jack Handy
- Anyone have previous exp. w TurboXS MBC?
- Need help??????
- Evo RS Front LSD Bolt Failure - FAQ & Repair
- how long will a twin plate clutch last for?
- WTB Apexi Power FC L-Jetro
- how much power can stock motor handle
- interesting comparison
- hks 264/264 installed
- cam gear timing is screwed
- Cam Gear Timing Wrong
- Ne1 - Will the Injen intake w upper i/c fit and 03 Evo
- Fuel cut question, need help/advice.
- want mod first EBC or Buschur Turbo Back?
- replace head gasket with new cam install?
- Megan intercoolers,....
- Leaking boost like crazy
- Revolver Cams ..
- Helix 3" turboback vs. Buschur Racing 3" turboback
- AVC-R Problem
- thougt u guys might enjoy this
- Perfect Power SMT Piggyback System
- duration & lift?
- boost problems
- Stalling problem when coming to a stop.
- Vishnu Stage 2 Dyno Sheets
- Best injectors....
- br440 w/ball bearing upgrade?
- This looks like a good deal...I think
- Resonated Test Pipe Feedback
- Strange Exhaust smell after upgrade...
- 272 jun cams on stock turbo/ecu?
- Installed Greddy Type-S BOV, have a question.
- HELP!!!!! what kind of oil filter.
- car lunging in 3rd?
- evo4 swap -->4g63T??
- Help! Major engine problem?
- about BOV
- Comm. w ELC & OEM Fuel Pump..... isnt it adequate?
- AEM or HKS Ignition Setup???
- Tuner says to upgrade fuel system, help!
- Broken MBC?
- Please post dynos of before/after stroker kit
- Where can I find non-USDM turbo parts?
- whining when accelerating
- How to install a Hallman Pro MBC?
- Cam Gear Installation/Newb
- RaceMax Hard Pipe kit
- Motec vs APEXI
- Cam Gear Installation (w/o cams)
- Launching your Exedy Twin
- Losing boost...
- My New Toy from Cusco!!
- Tuning with the HKS FCON V PRO ecu - 367 tq, 354 whp - pump gas, stock turbo
- CAI for a MAP Conversion Car?
- Stock EVO8 intercooler size
- MOD order to get to 350 whp
- Port stock turbo?
- X turbo vs Y turbo
- Quality silicone hose for great price
- Ogura Racing Carbon Clutch?
- arp bolts and studs worth upgrading?
- Which cams have the highest low end torque gain?
- Gears are hard to change...
- Anyone have the DC Sport 3" DP/Cat-delete combo installed?
- Excedy Hyper Single
- 10.5 Exhaust housing
- Innovative or Precision t3/t4
- HKS Electronic Idle Stabilizer (EIDS)
- A'pex Avc-r - V - Autometer
- Car almooostttt dying with Greddy Type-S
- Engine Mod Advice Needed
- Water/Alcohol Injection Thread
- for those of you who intalled a boost gauge.. i got a ?
- thinking bout cam gears need help
- boost ?
- 02 sensor mechanical fix
- P0300 Problems
- Stock BOV that bad?
- Who sells rings for stock pistons?
- WOW. Some tidbits.
- SSQV BOV Flutter after VTA
- MBC questions
- Ats Clutch
- HKS RS vs. Stock Airbox & More <My Observations>
- Perrin Test pipe
- Pruven Proformance round2!!
- Downpipe Tie bar clearance
- rough idle buschr stg4 br 440
- difference between HKS exhausts
- Question about exhaust systems
- Sound From Warlbro Pump
- who's using the lancershop bolt fpr?
- ? about wideband and AEM EMS
- Is this a good clamp for my BOV? ? ?
- Timing Control
- where to find oil/water delivery for garrett gt30r
- Choosing an EBC...
- Fimc
- What kind of BOV do U use w/cams?
- Anyone with Invidia or 5zigen exhaust...
- Anyone with Greddy Evo 2 exhaust?
- Dyno # are out..
- i need a good autox turbo
- Cam Gear Cover Removal?
- Intake Manifold
- Need opinions from AVCR owners..
- need help with what to buy
- humm, what to do, what to do...?
- Tranny Failure????
- whole lot of goodies to install
- electronic boost gauge
- Intercooler Spray Juice
- I think I have a boost leak...
- 1st gear....is this normal
- Point of Resonator in Exaust??
- Most Powerfull Exhaust
- MR valve causing stalling
- vishnu and HKS
- In-Car vac line for connecting Boost Gauge??
- Found an interesting test on intake manifolds.
- Capacity of stock injectors?
- Fuel
- Turbotrix and Dynoflash: The Verdict
- ticking in my valvetrain
- How many Hp will my car gain
- hks TT type 1 install help?
- Anyone want to trade HKS BOV for their RS intake?
- ***what do you guys recommend???***
- What Hp # should these mods do?
- Blowthrough MAF - Pix of the install and plug and play harness
- Slide Hammer, which one?
- AnyOne with KOYO radiator?
- Slim radiator fan
- clutch conversion question
- Apexi GT 3" Stainless Downpipe?
- Hks Hi-power Exaust Question
- Titanium Downpipe
- Boost gauge
- Hks Eids
- Part number for MR BOV
- knock meter at 256
- Evolution VIII MR EDITION (clutch)
- Magnaflow with BR TB?
- Buschur Racing Intercooler KIT with piping BEST OFFER
- maf sensor ?? + turbo
- Evo MR tranny rebuild...Who to go to?
- New turbo setup
- 16-17 vac reading
- Downpipe??
- Buschur Turbo-B VS Helix Turbo-B
- Whats The Best Turbo Back?
- How do I get my Turbo to hold consistent boost levels?
- Greedy BOV with HKS RS Kit Questions
- Quick CEL Question
- Help, Loud Whistling noise
- Forge Bov!
- Has anyone ever.......
- MBC question from a suby owner
- EBC wit no Limiter controll!
- Best Panel Filter?
- Evo step-by-step manual ?
- DAMNIT I made it 17256....
- Is there power to be gained on a stock car with just a MBC?
- Rev limit for stock motor?
- just put in twin disk Exedy
- Catless VS high flow cat
- My own setup
- can somebody explain this ????
- Rotor Warpage revisited...
- Just Put an ACT CLutch in
- Wideband suggestions..
- Any way to make clutch pedal higher off the floor?
- "Optimal" Fluid Combo !?!
- Dyno-flash or AfcII
- Semi sounding. have question?
- HKS cams, valvetrain tick?
- PLEASE HELP! STOCK IN & EX VALVE STEM INSTALL HEIGHT
- who re-builds gearboxes?
- need new clutch and looking for a flywheel
- dropping the clutch at 7k rpm
- 30,000 miles still stock clutch
- BOV leaking?????
- Gains: BR Stage 3 versus BR Stage 4+BR440
- Can someone show me where the DYI MBC intstall is?
- my new Borla Manifold just cracked
- Looking for Afc and harness new/used
- New direct replacement FMIC kits done...
- will Ultimate Racing hi-flow cat bolt to stock exhaust?
- anyone ever had an injector go bad?
- People who have destroyed their heads please read
- RRE No Name Clutch Kit
- are you sure the turbo only kicks in after 3k rpm?
- Evo MR Exhaust (buschur)
- Forge Motorsport Vented Blow Off Valve.
- High water/oil temps?
- Fq-340 vs. 05 Mr engine
- Need advice for some fuel man.
- Attn: People who have HKS Hi-Power Exhaust installed
- boost problems :(
- Buscher exhuast Question?
- major cel problems
- car missing/running too lean at idle. help!
- downpipe hanger bolts?
- Ats Clutch! Read Everybody!
- OEM clutches...
- Need FAQ help...
- ATT HKS 264 cam owners... Question
- Loud motorbikes make my idle stumble?!
- Apexi Intake Hardpiping?
- Buschur Upper Intercooler Pipe
- ive got an odd boost issue.
- XEDE or UTEC?
- broken clutch racing.... good story
- question about short shifters
- UR testpipe problem
- 80MM Delete pipe
- intercooler
- T3/T4 o2 eliminator 3" downpipe for evos
- SES Light came on anyone know what it could be?
- engine code problem
- HKS cam dowel pin hole dim and pin length HELP
- SSautochrome header and Titanium 10.5 16g review
- Turbo Trix Turbo Kit or GT35R? If you are Running either one?
- Check engine light affecting performance?
- So what can our engine take before it blows up?
- Stange Exhaust Fumes
- Weird sound coming from engine
- OBD II Scanner question
- Transfer Case!
- Jus got a HKS Carbon-Ti Catback
- What is all this talk about SS Clutch Line? Newbie
- HKS Hi-power....For those of u who have this
- broken driveshaft
- Which of these 2 mod paths seems the best to you and why? Will be ordering this week.
- Cusco/Exedy Twin-disk Engagement/Notchiness Problems
- thermal coating worth the money?
