PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 [214] 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Anyone with the ACT 2100 PP & 6-Puck Racing Disk???
  2. Excellent customer service
  3. want to buy used S-AFC 2
  4. Turbulence
  5. Running Rich?
  6. Best intake for the 05's?
  7. bigger turbo=higher rpm reving?
  8. VENDORS: Any 264's in stock?
  9. need some possible ideas to figure problem
  10. CRX and 4g63
  11. Hey people need help
  12. installed walbro fuel pump.
  13. cheap tranny
  14. Exhaust Reccomendations for my Specifications (yes i searched!)
  15. 5th gear grind is back 1 month after the dealer fixed it!!!
  16. Help! Is my rear diff locking up???
  17. difficult to get into 3rd gear!
  18. Rebuild an Exedy Twin Plate, or buy a new ACT
  19. MR Injectors - 560cc or bigger?
  20. Neutral Clutch Engage=Creep Forward
  21. leaking transmission, help!
  22. Anyone Throw/Break a Connecting Rod on their EVO8 yet?
  23. AMS Lower IC Pipe- worth it?
  24. Tuner for road racing in Los Angeles area?
  25. Walbro 255 lph Fuel Pump Question
  26. ATS clutch not engaging?
  27. Low Boost.....pls help.
  28. UR Test Pipe, 2.5" or 3 "??
  29. Hallman MBC installed, very happy
  30. Invidia Downpipe..help!
  31. Big difference between Hi-Flow & Straight Pipe?
  32. Is an aftermarket O2 housing worth it?
  33. Exhaust Help
  34. 24psi. What gap for plugs?
  35. Whining noise...pulling timing???
  36. Mileage after cam install?
  37. HKS 272 cams. Do I need springs?
  38. Relocating the MAF Sensor to Upper Intake piping?
  39. WTB: HKS 272/272 cam set ASAP!!
  40. Gearbox making weird noise
  41. Look what I came home to today!!
  42. Recall about syncros from Mitsubishi.....
  43. question on condition of spark plug
  44. Drychargers?
  45. Are built engines reliable?
  46. Megan Racing Downpipe
  47. can you mess up the clutch by jacking the car up in the wrong place?
  48. Hallman MBC and Dynoflash!!!
  49. Something is wrong but what?
  50. Question about MBC
  51. Fuel Pump LPH !
  52. Helix (or other) outlet pipe
  53. List of turbo upgrade kits
  54. Regarding 10.5 hotside
  55. Mods Setup Question
  56. 3071 or 3037?
  57. What would you choose?
  58. Help Me Pick Exhaust Asap!!!!!
  59. Anyone using this Megan Racing setup??
  60. Buschur with different exhaust
  61. Is there a short shifter for the MR yet?
  62. drivetrain noise???
  63. What Turbo Am I Looking For?
  64. Please Help
  65. post up pics of your engine bay ( upgraded turbo )
  66. Very strong exhaust smell at WOT
  67. ECU reflash or SAFC and boost controller?
  68. HKS GT2835 turbo
  69. 512hp on pump gas with IHI RX6 turbo?
  70. ss clutch line on an EVO MR
  71. Big Problems???
  72. My evo's boggin a little
  73. evo 7 owners pls HELP!
  74. Ikeya Formula Sequential Shifter
  75. Question for Boost Adjustability out of ECU Only...
  76. compressor surge or normal or what?
  77. Boost guage
  78. Exedy Twin Disc
  79. UR TestPipe with CEL??
  80. Anyone using the ATP 3037?
  81. fq-320 turbo vs VI tm ti turbo
  82. Oil smoke?
  83. HKS Intercooler Piping???
  84. GFB Bov Help
  85. Exhaust Questions, please advise.
  86. Stock Boost Ok?
  87. intake and tbe, but no reflash
  88. where you stall egt and boost guage?
  89. boost
  90. Turbo question...AMS maybe??
  91. ATP GT3071R HP and BOOST?
  92. Defi Control Unit
  93. service engine soon = loss of performance
  94. Intake flutter noise...help pls
  95. 1500$ Clutch Opinons
  96. ECU Flashes
  97. Test pipe wont fit!
  98. Loud Shrieking At 30 Mph And Above
  99. Clutch dilema...help!!!
  100. need some help on hallman mbc pro rx evo
  101. How do you get 2 different ecu's to work in 1 evo?
  102. Hallman Pro Evo RX install plan
  103. Boost spike to 24psi?
  104. Pics of a Thermal Exaust
  105. My Evo's dead :( (electrical problem)
  106. ??What Upper-IC Piping is this??
  107. APS Intake Questions
  108. Helix 3" SS Downpipe on Ebay
  109. Another clutch question
  110. ?CAI or no CAI?
  111. Megan Vs Helix Turboback
  112. HELP Service Engine Soon Light
  113. compressor discharge tube pics?
  114. HKS BOV on Buschur Pipe
  115. Aftermarket or Factory Cruise Control?
  116. Shifting problems with Evo 8
  117. bushur afc or flash
  118. Exhaust resonator question
  119. Anyone else having problems after Exedy Single installed?
  120. All opinions needed, click here
  121. Battery...not mini but..
  122. Some evos' are stronger??
  123. Mirage engine swap to 4g63
  124. HKS Grounding Kit missing gold piece...
  125. FQ-400 turbo
  126. Best Turboback system?
  127. Problem w/ UR testpipe & SES light
  128. Looking for Tomei 270 Procams specs sheet...
  129. Need opinions on my exhaust and chassis setup
  130. Downpipes known to clear TC on '05's
  131. Tomei exhaust maniford?
  132. Pardon my ignorance, but...
  133. Exhaust question?
  134. Tomei exhaust maniford?
  135. Thermal R&D Catback for EVO 8
  136. MBC now or later???
  137. Cut pipe at taper? Need advise!
  138. What 4G64 crank is best for stoker?
  139. Built Motor needed ASAP
  140. Vendors Please help - OEM Spark plugs
  141. Does the '05 10.5t fit with the '03 compressor?
  142. p0108
  143. Is an Oil Catch Can worth getting?
  144. Looking for HKS 272 camspec sheet
  145. Spark Plug Non-Fouler and Greddy Ti exhaust
  146. Which pistons would you choose?
  147. Clutch Problem
  148. need help!
  149. ?s about APS CAI and Reflash
  150. VERY cold starting with a buschur mini battery!!
  151. Better handling?
  152. So people know what downpipe is better
  153. whats the whp gain for this ?
  154. Vac Lines without MBC
  155. HKS 3037s
  156. idle wont drop on MR
  157. long term MR recirc valve
  158. need help troubleshooting transmission problem
  159. Ralliart cat back sound
  160. will any synthetic motor oil work?
  161. boost PSI to BAR converter
  162. HKS Panel Filter, anyone have it?
  163. how to?
  164. what cams should i run with a gt-35r setup??
  165. Perrin o2 Sim installed still CEL...
  166. Oil Crush Washer: Is this Ok?
  167. How to lower boost?
  168. Cold weather and boost controller, help needed
  169. Review of Muellerized RS
  170. Does anyone know approx. how much a Team RIP tranny build is ???
  171. Stock turbo size?
  172. MSD 6A Ignition or AEM ignition
  173. Low rpms jerky...
  174. Turbo is cutting, is this why?
  175. Just switched from test pipe to highflow...
  176. Just installed MBC, is this normal
  177. low boost
  178. Question about fuel cut
  179. Question for two-wheel dyno tuners
  180. NO turbo spool
  181. Need help please
  182. Buschur racing downpipe question
  183. Tomei Cams Setting?
  184. Best cam gear setting for 264/264
  185. Vibration in 5th gear
  186. P304 CEL 4th Cylinder Misfire
  187. Second time slave cylinder line broke
  188. just ordered walbro 255 lph fuel pump
  189. before and after HKS 272/272..DYNO
  190. Engine Codes Pulled, What to do?
  191. First mods?
  192. twin scroll compressor map anyone???
  193. Stock boost
  194. Water/Alcohol injection is a waste
  195. 1Gen gsx trany vs evo trany
  196. Unofficial 2.4 Blocks Thread
  197. '05 MR clutch line and restrictor
  198. Boost and Octane
  199. O2 Housing w/o ecu tuning ?
  200. Xmas presents...did i go wrong??
  201. Cam noise help!
  202. boost gauge readings / numbers
  203. 3 inch QUIET turbo back exhaust
  204. Helix exhaust
  205. my first performance mod
  206. Need advice on Cam Gears
  207. Polling interest- GM Maf Translator Conversion
  208. Best bolt on turbo or hot side
  209. AMS DP w/RMR Lower Brace
  210. My thoughts on the Megan Racing O2 Housing
  211. Questions for CO EVO owners
  212. looking to buy a stroker motor ready to go
  213. Interesting test for K&N filter users...
  214. Black intercoolers...
  215. Exhaust Help!
  216. been in a GT35R and 3037 Evo?
  217. AHHH!! Studs from turbo broke!!
  218. new greddy type-s sound?
  219. Buying a GT30R kit but have a few ?'s...
  220. stock intercooler ?
  221. poll: greddy type s - two stock springs or single spring mod
  222. Aluminum roof in the '04 RS?
  223. HKS Type1 TT or Greddy TT?
  224. Stuck in traffic on a hill, now a weird burning smell.
  225. Need a real answer on transmision oil
  226. Something is wrong with my EVO! Help!
  227. Best price for '04 Evo RS Transfer Case
  228. vacuum line???
  229. help with boost guage
  230. AEM EMS vs. HKS F-Con Pro V
  231. DO NOT ATTEMPT..fuel pump
  232. Greddy Part Needed
  233. how much????
  234. Whoops too much boost? 23psi!
  235. APS BOV worth the $$$???
  236. Which aftermarket recirculating valve is the loudest?
  237. Few Question..SS Mod Quiet BOV, Noise when Shift...
  238. Help please
  239. What 3" DP and 3" Hi-Flow Cat for HKS Hi-Power 3"
  240. ECU plus question
  241. MBC Install Help Needed
  242. HKS RS intake, How to install?
  243. 450 bhp Lancer Evo Turbo Kit
  244. HELP!!! i smell antifreeze!!!
  245. Stock Air Intake
  246. Managing Upgraded Fuel System on 4G63
  247. Where are ams lower i/c install pics & dyno chart?
  248. Does a after market intake manifold helps?
  249. why does my car run better at 16 psi??
  250. which dp will fit the Greddy Ti exhaust
