- Interesting main bearing damage
- mini battery gone bad after dying once?
- New clutch installed car moves by it self
- Details for porting Stock manifold and turbo
- Can you align the steering wheel yourself?
- Turbo trade
- Air inlet tube?
- couplers
- Boost went up mysteriously from 26psi to 30psi!
- Quick wierd dipstick question
- acceptable driveshaft play ?
- leaking valve cover
- Interested in a high output Alternator?
- Speed density or no...
- which arp head bolts for lancer evo 8
- competiton clutch ?
- Tomei Exhaust Manifold
- Evo building
- Engine builders step in: Clearances!
- What type of PTE to get for my goal??
- Greddy Turbine Outlet (O2 Housing)
- Valvetrain rattle - chatter - noise after cam install around 2k rpm and greater
- 450-500awhp opinions
- Which head bolts MAP vs ARP?
- Switching from thick oil to thinner oil?
- Fp red rebuild myself good or bad idea
- evo 8 air fuel ratio question...
- Transmission Issues! Help
- How much power will my setup make ?
- Tial Q owners
- APS BOV leak!
- ignition issue-please help
- transfer case whine
- aluminum rods in 4g64 questions
- How loud is the Trust Ti-R really?
- New setup needs new clutch
- Does the Evo 8 use two O2 sensors?
- Screetching from Front Drivers side tire.
- 3rd gear grinding after Clutch and Flywheel install.
- oil leak issue
- Gruppe s flywheel
- Re-Install Factory Air Intake Duct, Box, and Filter
- How to plug piston oil squirter holes.
- Injector seals leaking?
- next engine build maybe?
- Identifying Cams
- boost problem..need help plz!
- need some help.....
- Are these GSC S2 cams newer or older ones. EVO8 cams? Pics INSIDE
- Maintenance opinions during clutch replacement
- ACD pump temporarily disconnected, okay to drive?
- 1000 cc
- Act Streetlite Flywheel= better times at the dragstrip?
- 400 tq problems? Looking for 410/400
- evo8 with evo 9 turbo without tune?
- Evo 8/9 oil filter housing question????
- new member, questions on upgrades
- 2G Eclipse 2.4L block in Evo?
- diff and transfer case preloads
- New Holley Fuel Pump - 600+ LPH
- Egr delete by tapping hole in head
- ARP vs. OEM Flywheel bolts
- Coolant spraying Windshield
- AN Fuel Line Help
- exedy twin. stabbing evo tranny first-timer
- Broken oil filter threads!
- BBK-Full Bites the Dust!
- Clutch upgrade?
- 2 different stock throttle bodies...
- Question???? Turbo fp hybrid
- how long you have over 500 whp on stock block?
- Daily Driver with forward facing turbo setup any issues or problems?
- New AEM 50-1000 320 lph fuel pump
- Weird Cam idle
- Exedy twin-plate clutch or ACT hdg6
- Drop in pistons advice
- 600WHP Goal help
- Does the Act clutch kit Need/Bring a retaining clip?
- Need Advice, Cylinder One Leaning Out
- Wire Identification Question
- I'm about to go redyno. How far should i push my stock engine
- Timing belt let go what now?
- Opinions on cosworth cams?
- 400WHP mods need you to check the list
- Missing link 304hp/300tq bolton 05 evo
- What is that main seal called that goes behind the flywheel?
- Do you need to remove the Flywheel pins in order to get it resurfaced?
- What is the most whp made on a 2.4L with 100mm crank?
- Just installed GSC S1 in Evo 9 MIVEC
- Get my ix to 400whp!
- Need help identifying clutch
- Transmission Fluid Change Metal Pieces Not Shavings
- Evo 9 and 8 use same diff?
- Evo 7 Major Blowup - With awesome Pictures
- my evo 8 wont pass 16psi!!help!!
- evo 8 with evo 9 turbo and mods need injector size
- Catback muffler hanger broken
- Help Identify these Cams
- new turbo time, help me chose!
- carbonetics rear lsd/mixing 2part motul 1part redline heavy shock proof diff fluid.
- Trans and VCU TC dimensions for retrofit
- what's yoyr vacuum reading with S2 cams ?
- Tanabe Medalion Touring & Apexi WS2 Exhaust user's PLEASE Chime in!
- Exhaust Manifold Stud Holes Stripped
- Grimmspeed 3 port EBCS wire question
- Buddy club cams Evo 8
- Help! Evo dying out
- Building my Motor for 2.3. Need recommendations!
- Any easy way of removing flywheel?
- Turbo Color
- 4G63 block from N/A
- ETS Titanium Piping Kit For Evo 8/9 - Short Route!
- Exploded view of the evo 8 & 9 transfer case.
- os giken rebuild
- Recommended intake manifold gaskets?
- New Fywheel & now i need a retune? Hu?
- Hallman mbc or the grimmspeed boost solenoid?
- Rust in intake piping?
- cosworth 272/272
- Stock frame BB conversions?
- Clutch Restrictor Pill? Slave cylinder
- Evo 8: JUN 272 vs S2, if cost was no issue
- Best balance shaft eliminator kit ?
- Running out of fuel from the DW pump, whats next for me?
- 2.0 156mm Setup or 2.3 Stroker
- Bad fpr or fuel pump.
- Evo 8 engine trouble
- need info on setting transfer box and diff preloads
- another ebay 70mm throttle body question
- Ef3 vs Fp BB red on 93
- act xtss w/ HDR6 questions w/ 73hta or Gt35r
- Most miles out of Exedy SD Twin
- IX Clutch Master Cylinder --- SUPPORT BRACKET Available ?
- Evo 8 sounds like a subaru.
- Homebrew Double Pumper
- Fp red wastegate actuator
- Looking for insight. Sparkles in oil
- How do I repair this busted driveshaft seal?
- Opinion needed on this failure, if possible....
- Idle and dies HELP
- Torn Between Turbos :(. Please Advise...
- Which rods for my 2L build?
- Should I get a re-tune with OEM IC?
- What clutch to buy
- EPM O2 dump gasket
- Low/Poor idle and stalling when cold.
- CP9A driveshaft
- Evo 8 death whine?
- Has anyone ever had the Driver side axle and input shaft to the transmission come out
- couple ?'s about running BBK Full
- Having a problem holding boost
- Car dies when I come to a stop. HTA86, built 2.0, exedy triple. E85
- Slow crank after battery relocation
- Clunking Under Braking - Transmission Related?
- how to ID a rear diff?
- Evo 8 alternator
- Any plastic cover under your front end?
- Race Balance Shafts AMS vs. GSC
- What Fuel pump should I use on Street with ethanol
- Evo IX MR - 6-speed shifter kit?
- td05 16g to T3 housing?
- DTCs going crazy on my car!!!!
- TransferCase Failure
- Evo 4-9 Engine Swap question
- Question about 6262 running on low boost.
- Perrin Foam Intake Filter Falling apart
- Issue I have never seen...
- HKS 272 cams?
- Test Pipe or Bad cat? Evo 8
- transmission carnage. Is it salvagable?
- Need to know what these are for. came with Tranny. pics inside
- Still Whining
- Quick Thermal Tape ?
- Spark plugs, what you running???
- Run car NA
- Rotten egg smell!
- Engine Setup
- Hard vibration in only 5th gear?!?! Suggestions?
- Balance shaft preference
- Clutch Dragging and Lock Out - FX300
- Help - Unknown tube loose...
- Exhaust hangar help
- Zero mile engine oil change sked.
- quick question
- ETS 4" intercooler on stock turbo
- Exhaust question.
- 4g64 Cam gear Cover
- Building my Block Need Advice
- XS Power intercoolers???
- How many of you are running stock rods with over 400bhp??
- Is there much difference between the HKS 7460R KAI & an 80 series?
- EVO IX MR 6 speed
- Engine Blew
- Squeaking and sticky clutch?
- Best Fluids For Hot/Dry Climate? Need Help ASAP Please!
- What mod to do next? opinions please....
- Car Runs Too Cold
- Forward Facing turbo downpipes
- evo 6 running problems any help is helpful
- KAPS release 6 Speed sequential for Evo
- Relocated oil cooler / upgraded cooler + lines
- boost guage vacuum line split
- best clutch for >700$
- 03 Evo GSR "notchy" tranny
- What to check for a motor that has been sitting?
- Zero compression after one month of being garaged!
- Need some help Ticking while Reving
- 4 bolt downpipe?
- I need some help
- Oil pressure after engine rebuild
- Transmission removal
- Clutch diagnosis question
- OK guys i need some help on diagnosing my car
- Evo 8 w/EF3...approx hp and et?????????
- black powder like material in the coolant reservoir?
- Exedy Twin City Takeoffs
- New Guy, Noob Question :(
- Air Intake? Which one
- How to measure a throttle body, ie 65mm
- Clutch Issue??
- Continuos Knocks from 2500~5000 RPM?
- 2nd gear lockout.. is it synchro?
- Help with Maintenance info?
- compression and leak down test - need advice
- Exhaust help needed!!!
- What ACT Clutch to purchase?
- brand new motor smoking
- kelford or GSC camshafts ?
- 2 core vs 3 core radiator for evo8
- Rear Diff fluid level
- Did DIY Clutch, have a problem now!
- Click-clack noise: please HELP
- Which is the best turbo setup to help me hit around 750 whp
- SuperTech valve stem seals leaking?
- evo 4 rear diff options
- Less Boost Pressure after Exhaust Mani Install
- Solenoid Help - K5T43583 vs K5T43988
- 4g64 manley h beam clearancing
- Boost source for 3 port
- Please Help! Problem with bolts that hold turbo to mani
- Issue with GSC Retainer
- TB Job: Crankshaft Pulley Holder?
- FP green questions
- HKS 65mm downpipe?
- Torque spec's for trans case
- i have a down pipe question
- What is the problem?
- What's wrong? TOB? Pressure plate?
- $1500 dollar mod list. Advice needed
- Shim between wave clip for exedy twin and tob??
