- Apexi down pipe
- Pennzoil Synchromesh Question
- Norris Designs Header
- Stock Turbo question
- Help i have a problem
- Best price on Cusco twin Disc?
- Gfb Bov
- Resonated Test Pipes
- HKS type R intercooler
- Need Greddy type-s advice please
- Upgraded transfer case?
- Twin-Turbo? Possblie
- Reliable Tuner
- Knock reading 160-200 when driving it on a 98 degree weather
- BR Lower Piping Warning
- did anyone have a problem with hks bov vta?
- Thos with AEM cam gears, 5 bolt design
- Front LSD in My Evo ?
- Redline Oils
- Water Inj. VS Water/Alcohol Inj
- BR Stage 4 w/EMS times update..
- Anyone using Clutchmasters clutch?
- First mods
- New timing belt?does anyone replace it when they get new cams?
- Shifter Bushings and Boost Gauge install how-to
- Knowing when to switch to standalone EMS
- boost gauge install
- turbo gauge
- What size is the stock Exhaust?
- What is the best way to modify an EVO8 for power and relaiblity
- Can the SBC-ID be used as a Boost gauge only?
- How long will a ACT Clutch with street disk last?
- Stroker Rev Question
- What is the best bang for the buck....???
- Greddy Profec B install help
- New member needs help in northern nj....
- running lean or rich?
- good aftermarket clutch??
- Turbo XS RFL Ti review/fitment question
- 2G rods and pistons in Evo??
- Best Single Disc Clutch?
- Help! Cam install, timing belt slipped
- stock turbo/10.5 housing install?
- Modified Engine Reliability on a Roadcourse
- Quick question of P0300
- Whp?
- A test on the intercooler sprayer and how effective it is.
- DC Sports Exhaust?
- AMS 3076R kitt
- NX N-tercooler Kits...whos got em?
- 272's And Gears
- Misfiring like Crazy!!
- Cheapest place to get an exedy twin plate?
- Vishnu/ATP 3037 Turbo Kit Review
- Which downpipe?
- for the 264/264 cam owners
- safe boost with my fuel setup.
- BR MBC Mounting Locations
- My new clutch in LA
- No more 4th gear Grind!!!
- Sti 2.5 Vs Evo!!!!battle Is Not Over!
- Help a Noob out! Please
- injen intake with upper I/C pipe review
- Flames
- APS Dual Vent BOV
- My Greddy Type-S Experience
- Best way to connect oil catch-can
- Evo Meltdown!?!?!?
- trim & a/r's for br500?
- Auto Moto Sport stage 2 kit.
- First attempt at head work.
- tranny mounts?
- Cam Q's
- My evo's boost.....
- Lancershop Downpipe
- How do I run VTA?
- Bushchur Racing Stg.4 with Br580 turbo kit hp #'s?
- Quad Throttle Body
- hollowing cams
- help car won't start
- Finished installing BR FMIC. Wierd noise
- MR BOV question
- Bolt On Mod Listings (No Tuning) - help!
- Samco hose impressions
- FNG here!
- injectors
- BR Lower intercooler pipe mess up
- Stalling with 3 inch downpipe?
- Ultimate Racings Turbo.
- oil pressure & EGT reading
- Exhaust Manifold Thread
- Titanium Turbine?
- Looking for 3inch or bigger dp plus o2 housing that tapers to fit stock cat.
- evo 8 blown big end!!
- EVO 8 crank and rods
- Greddy Ti Catback exhaust and downpipe
- Apexi S-AFC II settings
- Quietest exaust
- Aps
- grounding kits, does that stuff work?
- BR lower IC piping
- Help with BR FMIC
- Drivetrain fluid help!!!!!!!!!! Pennzoil or BG
- engine block
- What brand gearlube to use in Trans. Transfer and F & R diffs
- Problem starting after install
- Any info on the BLITZ NUR SPEC exhaust?
- Al Friedman is the man
- crower rods?
- Are sodium filled valves worth the price difference?
- Question about HKS exhaust
- Had Hallman Pro MBC Installed
- clutch grab..
- stock fuel pressure? ... need help fast
- Boost taper at high rpm?? Is my BOV leaking?
- TC oil drain question?
- HKS Hi power exhaust, 2.5 or 3 inch?
- anyone here heard of OGURA twin plate clutch?
- Sputtering under hard acceleration in 4th & 5th............
- Trans axel fluid
- Who has pics of AMS Turbo Kit installed?
- Forge recir. bov which spring to ...
- Can you hit 400 whp w/out....
- greddy type-s do i need a flange
- Shelf life of gear oil?
- stalling problem - can't get into 2nd and 4th
- ECU for '04 Evo VIII RS
- Tomei Procams...Anyone????
- Installing HKS Cams
- APEXI N1 muffler owners
- Bearings for Eagle rods in EVO8?
- ACD ECU upgrade for Evo VIII?
- stock air filter - new vs 15,000 miles
- vacum?
- Thanks Sfp And Buschur Racing
- Please Help!! Car is taking a crap!!
- 21 psi falling fast to 19 on stock turbo and heads
- New Boost Controller... Need Expertise
- "Darkhorse" Garibaldi Imagineering billet fuel cell skeleton[MERGED]
- test pipe and muffler delete
- Ruff Idle!! what's going on!
- Pistons To Hold 550+whp
- Who has knowledgable info on mr bov?
- Linkage Diagram
- Next modification?(Need some help)
- Just ordered Kartboy Shifter linkage and base amoeba bushings
- HELP!!! Whistling Noise!!
- Turbo XS exhaust
- Factory boost solenoid line to maf pipe?
- B&B TB rattles
- Anyone make a Intake for the stock box
- SunAuto Hyper Voltage Type MR installed
- Install of Defi B Oil Pressure
- Cusco twin disk owners
- With a HKS RS intake do
- greddy intercooler piping kit
- Installed my ground system, help!
- exhaust gasket question
- Random tech cat question
- Vishnu Exhaust Owners - Anyone actually
- Cams, richen or lean?
- The TXS DTEC!!!
- breakin? please help me
- possible to fix this downpipe?
- Boost leak after 5000rpm
- o2 simulator
- Advice Please in IC!!!!!!!!!!!
- T78 too big?
- Before I cut the vac line for the boost gauge
- Steering Shaft problems Please look at picture............!!!
- Ikeya Formula Sequential Shifter
- air/fuel ratio question
- Piper Vs Works Cams
- Is a JDM Evo VII engine, turbo, manifold different from USDM VIII?
- I want this ....
- Turbo Timer + Aftermarket Alarm = No Fun Plz Help!
- Pennzoil Synchromesh too thin, or is it SS clutch line, or do i need bushings?
- Installed the Injen SRI last night
- Any HKS 274 int / 264 exh cars out there?
- Fuel Cut on SAFC2 Settings
- weird whistle noise while accelerating??
- problem w/ evo and Stealth Fx BOV.... I have a turkey?
- need tuning help
- Need bearings !!!
- SPEC 3 Clutch?
- please read, a head gasket question
- clutch pedal
- Review of my Fujitsubo Rm-o1A
- Buschur upper intercooler pipe with apexi intake and box
- clutches
- tuning at idle
- Cat back Dyno graph
- Simple question
- How do you know if you have bad M.A.F.
- Air intake, better fuel efficiency?
- Do i have a exhaust leak still?
- Is this RMR's equivalent of the HKS RS intake?
- Help! Ralliart Spark Plug code
- Need advice from some tuners: How long...
- 2nd - 3rd gear high rpm lockout?
- Fuel Leak??
- diff and tranny fluids, when should u change them
- WTF is wrong w/ my RNR Carbon/Ti TBE???
- I need some tips!
- Please help, my evo is.....
- Bushur turbo back installed - review
- What else needed with Boost Control?
- help with ARC induction box
- what else should i get....
- High flow cat...$50.00??
- stock manifold fit on dsm?
- blitz sbc-id owners.....
- Need help from fellow evo owner
- Question for Defi D Boost Gauge owners....
- Need pics of a specific location from a nearly stock Evo VIII
- Help - Oil chand disaster
- max hp for stock bottom end/hp for NA evo engine
- Anyone have a pic of inid eof transmission?
- NO2 or CO2?
- Evo 7 rear diff
- metal hitting metal noise
- XS Engineering FMIC
- Turbo Fluttering?
- Pump Gas Power
- Oil Strips On Hks Rs Filter????????
- 3ed gear clink noise? any ideas?
- Oil pressure out of control/need help
- EBC air hose routing
- Cusco VRS Excedy Twin
- HKS SSQ BOV + AEM Short Ram Intake
- HKS MANIFOLD & GT EXTENSION KIT
- Is it a "knock"?
- new cams without new rocker arms?
- greddy bov flange is it needed
- went over redline...
- ACT Clutch installed...WOW!!
- Sloppy Driveline and really bad de accel noise..... Help?!?!?
- 5 sp. vs. 6 sp.
- EGT and oil press guages
- Stock injector size?
- Sam's(gofast87) EVO 8 build-up
- turboback w/no boost controller
- Boost Controller
- Xylene
- RS front LSD interchangable?
- A Question about Titanium Exhausts
- Exhaust Silencer
- Pics of billet battery box I just finished
- Piper Rally cams - G-Tech Plots
- Looking for an exhaust system...
