- Apexi Power Intake+ HKS RS Induction+ Evo9
- is 80mm test pipe needed for my 80mm greddy turboback exhaust?
- OH BOY! No Good!
- EvoM FYI: ported throttle bodies shouldn't leak or whistle...
- 2.3 Power Goals
- Urgent help needed
- 3+" intercooler piping
- wideband help ??
- Question about idler pulley
- Buschur Racing Coil on plug ignition
- Piston Comparison
- 10,000 mile oil changes?!?
- Water out of exhaust?
- Tial Bov spring?
- Buschur COP pictures.
- Exedy Twin Smell?
- evo 9, 57 trim or 35r
- Tuning e-85
- Manley 300M Alloy Connecting rods
- E-85 tune
- Oil pressure after built
- Stock Injector Size (IX)? And Fitment Question (VR4)?
- Buscher O2 Housing offerings on website confuse me...
- All ACD lights on
- Clunky shifting solved by launching?
- DC3 Oil Catch can
- 30k Maintance
- Turbo install questions
- Buschur Guys: Wideband bung position
- REBUILD: Exedy for the 3rd time or ACT MB7-HDSD?
- 4G63 Turbo List (DSM Guys)
- Magnus Aluminum Intake Manifold or Aquamist Hfs5
- Would Greddy EVO 2 TBE dp fit on an IX?
- Exedy Twin Disc for daily driving?
- Just adjusted clutch.. and question
- Jet coated ex mani
- Need some help
- Rear Differential noise
- What stroker kit is the best?
- P0171=help!
- ABS Module EVO X RS
- Air filter max hp
- TRE Stage 2 Tranny Amazing
- Help!!!
- What Spark Plugs would be best?
- Transmission Cooler
- Fuel Injectors Question!
- Has anyone used a BMC CDA intake?
- Crank walk
- Skunk2 cams 1st look
- exhaust leak prevention question
- XSPower fmic questions.
- changing dump - from above?
- Need Fast Help EVO 9 MR (MAF)
- Getting tuned this weekend ?
- Air flow meter???
- Evo Engine to a lancer???
- ACD Pump Sensor?
- T-case removal
- Different sized tires
- it wont start? NEED HELP PLZ!
- idle problem..please help
- 5 to 6 speed conversion........
- new exedy twin
- weird...car won't start?
- Code scanner
- Help me cobble together my exhaust...
- Better Throttle Response FREE MOD
- question for ppl that have the epm dump
- Karking rebuilt transfercase?
- how do you know if it's going bad.
- Evo 3 1st & 5th gear oem part numbers.
- High flow cat vs. Test pipe
- Cam choices for track car and 2.3 stroker?
- Need some advice
- injectors shut off under certain load(pulse width 0), help!
- Gas like oil in catch can
- Fuel Injectors
- AWD Motorsports Evo RS Makes History!! 8.98@156mph!!!
- car not starting now please help
- P0420 And Emissions Testing
- T04Z Exhaust Manifold
- best cams
- Reviews on PLX devices
- What is this???
- Will a 2.4 in a evo with a a built trans with evo 8 3,4,5 gears with a 3.73 rear dif
- exhaust question
- 02 dump!!!
- is a double pumper necessary(500 whp on pump gt35r)
- After 2.5yrs car is running!!
- Is there a 3inch hks turboback exhaust system?
- Injen VS Fujita F5 Intake
- ? about ultimate racing test pipe
- No balance shaft Oil pressure at startup?
- What do I need to switch between 2 maps on a stock ECU?
- What again do I need to pull 9500rpm?
- The new Intercooler (Core Anyway)
- K1 crankshafts?
- 10.5 hot side
- Tanabe Medalion Concept G Blue Turbo Back Exhaust for Evo 8 & 9!
- AWD Motorsports RS.. 784whp / 600tq.. 6262 Turbo.. E85!!!
- Fluctuating boost?
- The corect way of engine break in process?
- engine cuts at WOT
- car wont idle
- Compression check - normal?
- Car won't start in cold weather
- bushur cop vs spark tech
- 02 Housing Dump Gasket
- Injectors needed?
- Evo WG
- No Tensioner Tool! NEED HELP!
- Aluminum rods
- B.O.V Question
- WORKS or BMC Drop-In filter?
- Clutch Question Exedy vs Cusco
- lets hear your short shifter reviews.
- leaky valve guides on built heads common
- Weird Misfire ~3K - Both coil packs...?
- Question about TBE
- Mishimoto Intercooler.. Yes or No
- coolant lines for my HTA86..
- Magnus Cast + 8000cc = You tell me!!!!
- Is it normal if an injector looks different?
- Overheating
- billet crank options
- GT4094R Spool up
- Tapping tubular mainfold
- Can someone clarify this for me please?
- ACT HDSS - Poor Shifting When Cold Normal?
- Need help Smoke from exhaust after new parts install
- Can anyone help?
- ok...air fuel problem
- Walbro Fuel Pump Mode #
- third clutch just went out. ideas?
- FP4R cams sound!
- tubing for boost gauge
- what caused my motor to blow
- FP Red Flow Rate
- What is this NOISE i hear???
- cusco front power brace vs intercooler
- transfer case problems
- downpipe help?
- Radiator fans are dead, anyone used the Mishimoto fan shrouds yet?
- Very strange boost issue
- evo 8 hks vs kelford 272
- Vacuum line routing
- Interesting SSAutochrome read...
- drivetrain help
- megan racing downpipe for 05
- Cams vs Cams specs
- Gt35r Tuning ?
- FPRED vs CBRD BBK
- somethings wrong and i dont know whatt
- How much boost?
- Stroking the spare shortblock... turbo suggestions?
- hks 2.0 ams gt37r
- Need to rebuild a stock turbo...sorta...any good shops?
- boost creappp????
- 438whp/471wtq Stock Turbo
- EPM DUMP installed
- Any benefit to reving over 8500?
- Tanabe louravated style resonator?
- Strange noise after Exedy twin HD after install
- HELP! Contiously fouling #4 plug (pics inside)
- Kinsler EVO intake manifold....rad
- cam shafts
- FP Red Turbo
- 2.3L Build?
- oil light comes on at idle.
- ignition system
- MAP Integrated O2 Housing
- Safe to heatwrap an HPC coated manifold?
- Voltage stabilizer and COP CDI ignition
- for those of you using act clutches.. quick question.
- Crack exhaust manifold = lean fuel?
- ***Need advice with problem I ran into installing exhaust***
- exhaust manifold help!!!
- Weird ticking
- Beatrush and QTP
- my gt35r evo (pics inside)
- new clutch...
- Bushur TBE vs. Cobb TBE
- Tuned for 93 but can only find 92...
- It this a real Full-Race manifold??? Will it fit T3?
- The official 6-speed failure thread
- winter build time
- massive sputring .
- fuelcut like reaction
- hand/parking brake effects when moving
- anyone go GT30R to GT30R HTA??
- FP Red on Evo X set up Help
- What to do next?
- eBay Intercooler PICTURES?
- Why so much hate for the Injen SRI+ piping?
- injen intake noise????
- EVO IX SE - All 3 traction lights stuck on after driving? Something wrong?
- ?? for parting out the motor people
- little problem..
- Magnus Cast Intake Manifold Fuel Injector Issue
- fpred turbo oil return pipe gasket
- Heat Reflective Tape "Gold vs. Silver"
- another o2 sensor question, but different.
- advice needed for boost controller?
- Removing head - can the turbo stay
- Freeze Plug pop out!!!!! Its still runs fine after put back. What could this be?
- best clutch for 6-speed?
- What InterCooler To Buy?
- P0303 code and car runs like poopoo
- 4G63 Internals
- evo gone wrong
- Car won't start in winter
- help plz
- lookin to put out hp numbers
- Pulse Sparkplugs
- gizzmo boost controller
- quick BISS question??
- Need new clutch, debating PRICE v. NECESSITY
- Update and Thanks from Indy Evo
- Whining sound when driving
- Which Clutch?!?!
- OBX intercooler
- what setup do you recommend, n°1 or n°2
- help air is comming out of valve cover when i do boost leak test
- Advantage of WG Dump (Vent to Atmosphere)?
- Trickle Charger for Bushcur Mini-Battery?
- How to make an evo 8 block work in an evo 9 with a mivec head
- what should i do with a blown transfer case?
- Misfire with CDI COP system..
- JMFab o2 Dump
- advice if i should buy an intercooler now..
- exhaust leak from my hotside help!!!!
- Which of the three BOVs is best JDM VIII, IX, or X
- Coupler???
- IX Drivetrain w/ Tre Rear Diff vs. X's S-AWC
- Ported TB?
- color coordinated engine bearings???
- IX Drivetrain w/ Tre Rear Diff vs. S-AWC
- ACL Rod/Main Bearings Extra Oil Clearance?
- Anyone ever blown a brand new turbo?
- Gasket Questions....
- how to replace prop seal
- Carbonetic twin questions??
- Some photos of my 2.3L build
- Will it take the punishment??
- Compression ratio opinion need your input
- evo 8 dipstick blowing out
- loud pop in 5th at 4.5k or 5k rpm
