- ? about Forge RS Bov ?
- Shifter prbblems...help!
- is my shop scamming me?
- Plastic 8DV to Metal 9DV problems.
- What clutch is this??
- Some E85 tunes
- uego sensor location? and egr CEL light code????
- Which is the best intake for dual rails?
- tranny rebuild?
- What flywheel is this? Pic inside
- Those running AEM intake, is it for 03-05 VIII or the IX also.
- BR DOUBLE PUMPER INSTALLED, now FUEL gauge doesnt work. help.
- JDM, TRE Front LSD, install got some questions
- Samco Intercooler Piping
- HKS RS + Apexi Power intake = Questions
- bogging issue
- Help Can not get the output shafts out of the tcase!
- Getting FP Red tuned
- waste gate pressure?
- VCU... how to test of tell if faulty?
- evo 9 20g
- Can't find source of fwd evo, nothing looks broken
- BR DOUBLE PUMPER question.
- Perrin FMIC Fitment
- Spark plug issue
- mbc pressure source diferences...
- Evo VIII stall and drops rpm, my evo is one turtle!
- QUARTERMASTER users i need your info/experience here
- help ,,,
- 780cc Injector Question
- To replace, or not to replace? Rear main seal...
- Fp Red Turbo
- Fp Red Turbo
- Does this look like every other hotside? porting pic inside.
- Engine Overboost
- Dominick Irragi owners? Any HO Alternator Owners chime in!
- Aem Pencil Coil
- 2.0L build
- GT3582r And Ecuflash
- 2.4L Twin Scroll HTA turbo setup
- Lost crush washer :(
- Wierd Boost issue
- Who has broken a center diff here? (in the tranny)
- Place to buy anti fouler
- Ku Engineering Intake Mani, Does It Works?
- Cams Cams Cams Kelford vs BF
- Low voltage causing mis-fire?
- ideas on starting a build
- UICP - Help
- Weird noise when in 5th in cold weather
- hks spec-r exhaust
- Help Head Removal
- Custom lenght long rods?
- 1000cc injectors on stock ECU?
- Finnaly fixed!
- Bad 2.2l combination
- Caution! Bench racing inside...
- Lube your shifter bushings!
- 2.3L, here i come
- sputter under ft acceleration
- Warranty after a warranty
- Hard getting into gear downshifting?
- Headgasket, 8/9...Does it matter?
- massive sputtering (i've searched)
- overkill?
- HKS Downpipe problems
- question about intakes on my evo
- New Twinscroll T4 turbo from Garrett -- GT3788R?
- pcv and ccv question
- What brands should i use?
- EIP Racing Evo9 on E85 = 500.4whp & 407.6wtq *Mustang Dyno*
- HKS GD Clutch PRO for Evo ix 6MT
- Stock BOV and Aftermarket?
- When is it right to upgrade BOV?
- 3" Downpipe and Test Pipe w/ Stock exhaust??
- Transfer Case replacement
- Vacuum schematic
- Walbro Overheating......Can someone help
- Spark plug suggestions for E85 and 30psi
- lost motor
- power steering pump difference E8
- help me build a better car this time around...
- Stock Flywheel? Or aftermarket?
- Confused: Fuel question?!
- Should i port the tb and intake manifold
- 4G63 Engine build, need help
- Which LICP to get?
- Installed Milspec seals on my BR 65mm T-body, and reinstalled on EVO..
- Which clutch is best??
- brand new clutch and flywheel chatter
- mr short shift
- Misfire Issues :(
- Stock evo ix cam lift(asap please)
- Ac??
- Kelford TX272's
- Exhaust Manifold Cleanup and Heat Shield
- Good or bad
- Exhaust Cutouts?
- Possible boost creep
- Fuel pump hickup!!
- PCV Valve Rattling/Ticking or Tapping noise
- problems w. passenger output shaft to T-Case fittings
- Stock BOV Sound Question!!
- Which Injectors?
- AMS Moustache Bar Eliminator
- HELP.... I have a Problem
- grinding noise when starting
- starter probs
- How to block off UICP?
- Rear diff questions..
- Act Xtreme
- differential pump failure... advise needed
- High revving issue need advice
- Tcase problem, no whine, grainy on decel
- TPS issue, possibly weather/temp related?
- rear o2 sensor help
- Ticking only at idle
- Return oil line leak
- Mini-battery took a dump, will wet cell work?
- Unofficial Poll: E85 vs Meth Injection
- Defi Egt Probe problem *HELP*
- TC Whine... Maybe?
- New to the turbo and Evo game
- rre no name clutch
- 9 turbo vs 8(10.5) hotside
- determining b.o.v type
- Met Mr. Wheel hop yesterday...
- Evo 8 + Mivec
- need HELP, 2 days to decide pistons and rods
- Trans coming out, few ?s
- help severe knockout
- Exhaust = boost leak?
- Just looking for advice
- New water pump leaky :( copper spray ok?
- Fp35r Hta
- greddy type s help
- Air Filter Shootout test
- 05 SSL Motor Noises
- Boost creep help
- aem twinfire with COP setup... Is ANYONE running this without issues?
- Need help with G35 turbo....
- cam installation vibration
- Belt Routing for AC Delete
- Strange clicking in engine bay under load??
- Spy Vs. Spy article Dan Bajalis and Jake Montgomery Drag Mitsubishis
- Getting Tuned Tomorrow
- crank pulley, will it work?
- Engine Hesitation
- swapped in diff turbo, NO BOOST!!! HELP!
- Center Diff, how to inspect and change?
- P0171 code--- caused by cam gear install?
- 2005 o2 sensor correct part number help
- Stack Dash Display Systems [Street Legal]
- Spark Plug Question
- fp red specs
- Where is the font diff?
- Boost cut/ Fuel Cut??
- !MAF shrinkage at its best!
- could someone please post a picture of the back fill-hole diff. bolt. (thanks)
- Clutch Adjustment?
- Quick question on a Boost Leak
- Red conversion wait time?
- Found some time to work on my own car! New Intake, etc.
- When is an Adjustable FPR needed
- Pure Tuning Intake Manifold Testing (Magnus vs OE)
- B.O.V question
- anyone out there running a BW s362
- Which BOV to use APS dual vent or another?
- APS intake inlet size, and replacement filter
- rough idle on cold days?
- Turbo ID help needed (pics inside)
- What makes a reliable high power Evo?
- I'm faster than a jet!!
- 2wd evo.. wtf happened?
- intake manifold shootout
- Possible for exhaust leak to sound like a boost leak???
- Built head...suggestions please
- High Idle Issue, what can it be?
- o2 sensor???
- GT30 Turbo Upgrade + Cams Question
- Grinding noise? maybe pulley?
- just lost 1st and 2nd gear
- intercooler temp gauge
- AWD Motorsports RS.. 743whp / 575tq on E-85.. Precision 6262 Turbo!!
- DYNO HTA88 26psi e85 gas
- what disk goes on first on exedy tiwn disk
- acd reprogammable ecu
- Anyone using new version 2 of Titek O2 housing?
- engine rebuilding tools
- Zeitronix narrowband help
- Why are people still upgrading to injectors under 1000cc?
- What Turbo is this??
- ETS exhaust
- Help... Ignition Problems...
- boost cut
- Help with fuel cut problem
- fp green to fp red
- 2.0L, Cosworth head, stock turbo, cams
- GT3076r on stock engine
- Weird clutch noise
- Hta86
- Aftermarket FMIC install tips?
- sluggish and to much boost
- GT35 What do you think....
- transmission problems
- Crap dyno numbers-car won't hold boost
- Pics of Buschur double pumper installed please
- Isamu RX6 turbo & Garrett GT3582r
- Evolution Tuning Basics
- stock manifold vs aftermarket...?
- PPI LICP installed (pics)
- Fp Red: What's your barometer drop above 7k rpm and what intake are you using
- Cant get into any gear
- Clutch grind/creak/rub???
- Aggressive Cams for MIVEC? Evo IX
- How much will it help
- Borg Warner s258
- Buschur O2 Housing Fitment Question
- cosworth head build (pics)
- STM *** New Product release***
- BUschur Stage 3 long block Full race 4088r ...Kansai
- Rear LSD axle problem
- how much can i get?
- Knocking engine help LONG!
- FP Red or 30r?
- Deciding on cams for my mild setup...headstuds?
- Rubbing noise in engine area?
- evo 8 and 9 ignition
- boost creep
- greddy type rs???????
- Any way to clear( DTC's) CEL without removing battery power?
- Reducing drivetrain lash
- I need help!!!
- How Much PSI the Stock Int ...
- best way to clean lifters..??
- Helix Down Pipe Question
- What spark plugs to go with?
- Cosworth piston issue... photos inside
- thoughts on the fidanza 3.2 clutch
- need a new radiator
- Cyclinder Misfire. Help
- revolver 264s vs kelford 272s
- Testing new Wavetrac front Diff...
- Need Trans Suggestions
- just installed FP red. have some q's
- Which 02 Housings fit with AMS downpipe?
- Who's running 1600cc inj on the street?
- Evo Ix Dyno #
- evo Rs transfercase overfilled... by +16oz
- Pics of your boost controller
