PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 [135] 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Does removed airbox cover simulate cone filter noise?
  2. Fox lake ported head
  3. Transfor case seals
  4. help with idle and iac motor
  5. HTA upgrade + TB/Intake Mani Ported
  6. HKS 272 w/o Springs or Headstuds
  7. Pulley/Belt Noise during Cold Starts at 10K miles???
  8. Why AMS recommends Race balance shafts
  9. aftermarked oil cooler lines and fittings
  10. Quick PTE 880 question
  11. gt4080rl 2.3l or 2.0
  12. PLEASE HELP URGENT!! I need to know if I need a diff spring in my EWG 38mm Tial????
  13. 300 miles later oil is down to bottom of dip stick wtf???
  14. Squeaking noise during deceleration???
  15. 35r
  16. My clutch
  17. cam install
  18. Built trans issue. Experience Needed!
  19. Groden Aluminum Rods a must for serious power....Take 2!
  20. forced performance Evo VIII install kit
  21. rev limit
  22. need help
  23. installing cams help
  24. Upper Intercooler Pipe
  25. HKS light action clutch
  26. Cosworth 2.2 stroker
  27. Getting A Green
  28. Need suggestions
  29. Trace amounts of oil in the airbox? :(
  30. Exhaust Back Pressure Measurements?
  31. how much boost can a stock evo handle?
  32. oil pan RTV. what do u use?
  33. replacing clutch
  34. How much boost can a stock evo 8 can handle?
  35. BC SS Valves
  36. fuel pump??
  37. 50trim to a 35R? worth it.. or not
  38. RPM's UP
  39. Twin scroll Question
  40. Belt Tensioners needed with cam install?
  41. Forge EVO15 BOV/DV Issue?
  42. How heavy is the Tilton twin disc....
  43. Issue w/ turbo!
  44. Cams for EVO 8; keeping stock turbo.
  45. Buschur inline MBC; change lines?
  46. The Best Turbo Kit for my Evo 8
  47. EVO 9 TME (Magnesium) turbo Questions
  48. Question about Beatrush prop bushings
  49. Greddy Type S Spring..
  50. meth injection
  51. Which spark plugs should I get?
  52. shortest route piping
  53. help with valve springs and retainers...
  54. Cam Gears
  55. max out stock turbo's support mods? or upgrade to green?
  56. Need Help!
  57. Anyone Know Precision Ver. Of gt3082r?
  58. Clean MAF while car running?
  59. GSC vs. BR272 vs. JUN
  60. Dash rattle with Ralliart mounts
  61. Buschur Front Motor Mount Installed!
  62. Random Clutch Noises?
  63. Eagle 2.0L Evo VIII & IX Rotating Assembly
  64. Clutch Install Help!
  65. P0446 - Evap Emission Control System Vent Circuit Malf
  66. Need some help
  67. i need stroker kit recommendation
  68. Wow what a difference
  69. best turbo for the price?
  70. eBay Evo 9 IX Exhaust Install?
  71. Problem with injectors
  72. dumb question.. but still a question
  73. I Need Oil retun Kit for t3/t4???
  74. Twin charging (again)
  75. Low RPM Stutter / Stuttering
  76. Test Pipe
  77. Question about Exedy Twin Disk Clutch Engaugement
  78. When is a FP regulator needed?
  79. mikronite??
  80. Broken Engine Help!
  81. Cosworth Cams
  82. defi water temp install
  83. Hey Guys, EVO Noob here but pretty sure this isnt right, emergency question
  84. turbo problem
  85. PCV system
  86. Stage II Stock Turbo IX with Aquamist 464 TQ 416 WHP !
  87. Who makes a solid engine mount?
  88. Tranny noise...
  89. Anybody use SuperTech Pistons before?
  90. tanabe Blue G
  91. Where To Set My Cam Gears
  92. Calling out torque monsters...
  93. turbo conversion???
  94. Ivey Tuned Customers Please Chime In!!!
  95. O2 housing, manifold, licp, uicp = How much gain?
  96. Apexi N1
  97. Freeze Plug Size
  98. Do I need to switch my MBC install for my new turbo setup?? Please help me!!
  99. HKS GT3037S or HKS GT2835?
  100. Possible slipping clutch?
  101. When to get a FP regulator?
  102. Oil Cloud on decel. HELP!
  103. mivec head
  104. HELP Car not starting.
  105. new downpipe clearence issue
  106. revs don't come back to idle
  107. Mitsu turbo output range...links
  108. 1st post to share my ride
  109. stock spark plugs or 1 step colder
  110. Best season to tune???
  111. My EVO is running again, with pictures!
  112. Buschur Dual stage MBC
  113. Manifold Question
  114. weird overheating issue
  115. Bolt-ons for 350 whp?
  116. Who has succesfully replaced rodbolts from below?
  117. Recommended Code Reader?
  118. exhaust cam only
  119. Should I change my timing belt at 25K?
  120. EX POWER INC EVO 8 mani/downpipe. Any good?
  121. The Metal DV gonna be able to hang?
  122. Hks Evc Vi??
  123. valve covers?
  124. MBC Installation Procedure
  125. The Perfect / Ideal WHP Number for Road Track Racing
  126. Avid Motor Mounts
  127. I need a Quaife LSD ASAP:)
  128. Shifter linkage issues, need help ASAP
  129. Just received my Evo Green!
  130. New Clutch Recommedation
  131. Quick MBC Install Questions
  132. Thoughts on the XS Engineering 272 Cams
  133. recommended spark plug gap
  134. Has anyone tried this t3 manifold/downpipe off eBay?
  135. Quest for no lag Turbo IX
  136. clutch question, probably pretty stupid one too...
  137. evo 5 engine?
  138. aftermarket radiator worth it?
  139. where do it?
  140. tranny going?
  141. Shep Trans just came in
  142. BR2.0L or BR2.3L??
  143. Silky Smooth & Solid
  144. Speedo problem
  145. Code 300 evoix
  146. Intake/exhaust porting...hp increase???
  147. rnr down pipe
  148. What to do next? full bolt on Evo 9 SE
  149. How much lag on this turbo??
  150. big problems
  151. Installed Oil Cooler Fan: Pics Inside. Cost:$94 Benefit:10-15 degree drop
  152. Inside of a Buschur Racing engine with lots of abuse
  153. what could be causing my P0234
  154. Transmission Oil
  155. Misfire at 20PSI on 04 8
  156. "System Too Lean" Error (P0171)
  157. My catch can results...
  158. 5th gear grind
  159. Tranny noise under deceleration
  160. Cutout anti creep/spool proof?
  161. Full-Race Hypertune Intake Manifold Dyno Chart!?!
  162. which would you choose....
  163. Evo IX- Mivec cam swap for HTA35R
  164. IX ecu versions
  165. Need 35R turbo exhaust housing-- recommendations / support
  166. ok so i ordered cams and cam gears
  167. question, possibly boost leak?
  168. How much did it cost you to have your head gasket replaced?
  169. Boost Control with tune
  170. shifting blocks
  171. nisei hard pipe kit
  172. maf wiring?
  173. HKS DLI fixed misfire but P0300 still appears sometimes....
  174. o2 housing question
  175. built blocks AMS, B/R, JAM.. Who to go with and why
  176. Cam Gears? What brand do you use?
  177. PWR Intercooler ?
  178. very loud noises/vibrations coming from engine bay after service work
  179. Tuning Gains?
  180. Issue with my new turbo kit (driveability/stuttering, bov??): PLEASE HELP!!!! )
  181. Oil Temp Question
  182. Exhaust Brands
  183. Exhaust Volumes
  184. Getting Tuned by Turbo Trix this week
  185. Look what I can Do!
  186. who makes a UICP that uses the stock diverter valve??
  187. Which Turbo Is this...
  188. Buschur intake pipe users, what way is your pipe installed?
  189. Buschur HO Fuel Pumps
  190. What t4 turbo will spool good and make great power??
  191. Is it possible to Standardize Dyno Tests? Such as Starting RPM, AVG whp/wtq
  192. evo stock turbo and power?
  193. 280 & 272 cams what is the dif ?
  194. Alky kit w/o solenoid valve - bad idea...
  195. Why Buschur and AMS don't do twin-scroll T3 kits?
  196. Mitsu tech Motor assy guide?
  197. Royal Purple
  198. how many miles have you guys put on your built 2.0 motors or built stroker motors?
  199. JM Fabrications Intake Manifold
  200. K&N drop in filter or AMS Cone Style K&N Filter and Adapter
  201. Please help me identify this turbo.
  202. Big difference between 2.75 and 3" dp?
  203. KW variant 3 + Dynoflash Custom tune = Smiles!
  204. replaced spark plugs annndddd what the crap...
  205. ignition blade voltage regulator
  206. Almost lost my motor today
  207. Mr. Buschur: HTA 35R with .63 hotside instead of .82?
  208. Spark Plug issue.
  209. stock intercooler upperpipe problem...
  210. wastegate adjustment
  211. Turbo Problems (I think)
  212. 1st and 2nd gear gone?
  213. Anyone out there w/ a bone stock 8 dyno graph?
  214. Ported Cyl. Head Pics
  215. Need Help FAST!!!
  216. Meth injection (how much to you use a month?)
  217. wastegate actuator problems maybe?
  218. Trouble with new turbosmart dual port
  219. HKS 280, E85, Buschur TBE idle video
  220. ACL Main Bearing Part#?
  221. My Compression Pressure Test! Comments?
  222. meth or aem ems?
  223. quick tcase flush question
  224. just bought a used BR MBC..What size vacuum hose do i need to install??
  225. Anyone come across this engine noise?
  226. Need Pic of vacuum lines to Intake Manifold
  227. BC 272/272 Idle video
  228. AMS2.3RR vs BR2.3L vs BR2.0L
  229. Air Intake Help
  230. christmas came a lil late (t3 twin scroll gt35r)
  231. 750cc Injectors Large Enough for 30R Big Turbo?
  232. Exedy Twin Disc
  233. 02 housing bolt size
  234. 02 housing bolt size
  235. Exedy Triple Oh my
  236. T-Case whine, what does it mean?
  237. Question.. regarding making of the Greddy Type-S BOV
  238. Noise in 3rd 4th and 5th under gas
  239. Might have a resolution to my issue.
  240. Help! Probs with shifter?What is it?!?
  241. what about this turbo?
  242. BOV advice needed
  243. power steering fluid
  244. Mahley pistons
  245. Big Issue Need All Engine Builders Input Please!
  246. Noise from cone filter
  247. 264/272 vs 272/272
  248. Typhoon intake??read before you flame..I did search..
  249. What does stock muffler internals look like vs. Magnaflow? Magnaflow Model Questions
  250. IX compression numbers
