PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. stock frame turbo replacement suggestions
  2. Transfer case died hard!
  3. TRE SPOOL in the rear diff?
  4. horsepower on ACT street clutch
  5. What catalitic convertor
  6. What's the recommended oil pressure for a track car?
  7. RS transmission. HELP
  8. Car wont turn over after injector adjusting?
  9. Feels sluggish - or is it my imagination?
  10. Stock catback on built evo Q's
  11. front driveshaft noise evo iv
  12. Identifying what year my motor is
  13. Cleaned Maf / Throttle Body -- Car won't start
  14. Spark Plug Questions
  15. 4th gear lockout high rpm
  16. Stock Location Plastic Fuel Tank
  17. Evo 9 Head convert onto Evo 5. Pls Advise
  18. Evo8 timing belt changes
  19. How do you take the hot side off the evo 8 turbo
  20. what is a good boost controller
  21. name these cams.
  22. Sanity check: evo ix timing
  23. Oil Pressure problem!!
  24. Help please! Evo broke down this morning
  25. Turbo choice...LR2.4 for track days
  26. Evo 8 oil pressure problem
  27. Evo 8 oil pressure problem
  28. stock head gasket on .40 over pistons?
  29. metal on metal grinding noise in reverse
  30. Turbo Heat Shield Re-Paint and Re-Finish
  31. Suddenly Throttle Sky Rocket during Idling
  32. Evo 9 Gsc s1 cams?
  33. O2 dump or S2 cams
  34. Cylinder head CC volume?
  35. Front Axle install tips
  36. a/c with ff turbo
  37. Calling Ontario Evo Owners
  38. Car runs rich after battery is recharged.
  39. Exhaust leak at catback, help!
  40. What part is this---Evo IX mivec cam
  41. Rebuilding evo 8 TDO5HR turbo with TDO5H turbine/compressor wheel, questions.
  42. Car goes very rich totally randomly...?
  43. Getting EVO 8 head ported
  44. Calculating Compression Ratio
  45. Evo poly exhaust hangers 4,5,6 ?
  46. ARP studs/nuts with Full Race OE manifold
  47. Need help with trans
  48. My Evo 3 needs a little of your help.
  49. Evo 8 Spark Plug Change
  50. misfire after rebuild
  51. fix it, sell it, or...? ...just stupid me?
  52. EF turbo vs owen
  53. New Transmission won't shift
  54. GSC S1 or GSC S2
  55. Weird clutch engagement problem. I'm stumped!
  56. Blown head gasket when boost leak testing
  57. Rev hang, idle issues, knocking and all that fun
  58. Stock FPR pressure issue
  59. Vacuum line off turbo outlet
  60. ACD lights - strange intermittent issue? (CT9A)
  61. Low boost. Need help
  62. Help with longer intake manifold studs for the head
  63. GSC R2 Cams results?
  64. Overheating in 1/4 mile!!
  65. Compound turbo 2.4l torque Build
  66. who has the most miles on a quarter master 8 leg
  67. catch tank screw up my AFRs
  68. fullblown radiator reviews
  69. EBCS ECU tuning ?
  70. Weird Boost?
  71. pte 5252
  72. car overheating---Cracked head or headgasket
  73. helllllp info for a noob
  74. Is it a bad iac????
  75. boost issue
  76. Team Rip (T.R.E.) still in business???
  77. Help rattling after cam install
  78. FP black on stock injectors??
  79. P1021 headache
  80. cost installing new cams
  81. Evo 9 - P0335/0340 Help
  82. PCV Fail.... B.L.T 5psi~
  83. Do I need a catchcan and if so, which one????
  84. 2.4l build help , need confirmation on timing!
  85. got a newb question. need help with clutch fork, video inside
  86. 03 evo whining niose
  87. Overheating w/ tubular manifold and half rad
  88. Advice
  89. m2 performance exhaust
  90. Ticking from intake timing pulley??
  91. What does backpressure do to a motor?
  92. Buschur Down Pipe
  93. Hoping to be some quick help
  94. DEAD PEDAL Question!
  95. HELP!!! why wont my evo hold steady boost?!?!
  96. strange problem
  97. Radiator top cracked -- replacement options?
  98. EVO 6 Noobie Questions...
  99. fuel pump not working!
  100. Smoking from Air Filter while cranking
  101. extreme psi level 0 front axles
  102. titanium retainers
  103. MAP oil feed line - wrong adapter?
  104. A hole in my TC!
  105. high rpm shift issue
  106. help idle problem
  107. Titanium exhaust?
  108. Still P0401...Exercised all known fixes
  109. Anybody running a stock frame gt3076r?
  110. keep getting lock out of gear with new clutch
  111. Help understanding MFI Circuit Diagram for grounding issue.
  112. car leaning and bucking..need help!
  113. Air leaking from valve cover vent port area
  114. I got a clutch Question(on Exedy triple)
  115. Need some ideas on why I'm spooling slowly
  116. Car Shaking Bad at low RPMs - Is it the Cams? or the Tune?
  117. Clutch Fork Rod Help
  118. Black gunk in head and exhaust manifold
  119. Evo 9 Engine Quizz
  120. Advise on light modofication
  121. Building a motor
  122. Install help/tips for Competition Clutch push to pull conversion
  123. WAS just about done with my installs....
  124. Evo 8 Major Loss of Power
  125. Suddenly knocking - causes?
  126. need some help identifying a plug...
  127. Hardblocking and Aluminum rods
  128. FS Tomei Expreme Ti JDM
  129. Need Help with Fuel Setup 800WHP
  130. For Sale Turbosmart EVO 9 xs intercooler
  131. Competition clutch throwout bearing.
  132. Keep your balance shafts
  133. V-band manifolds leaking?
  134. 4g64 timing help!
  135. Wheel bearings
  136. 7 bolt crank ok for EVO build???
  137. Max power/boost on 9RS V2 (01571 - Revised Mag Compressor Wheel) Turbo
  138. Injector Stuck?
  139. Compression test results from my Evo 9
  140. GTX30 comp wheel into GT30
  141. ACT 6 puck clutch
  142. how to preload wg actuator
  143. Metallic Rattling Sound
  144. Evo 8 front case/oil pump gasket on evo 3?
  145. CEL P0202 and P0302 Cylinder two missing
  146. Brand new ETS coupler blew up
  147. Clutch job, Things to replace?
  148. boost leak test, gurgling in oil pan
  149. Anything to worry about double pumper sitting for a while?
  150. whats this tapping noise?
  151. Gasket or no gasket on lifter oil bridge?
  152. wastegate actuator install
  153. Shift Linkage went out?
  154. What to expect upgrading to r2s
  155. Oil pump gasket?
  156. turbo oil return line gasket
  157. Piston Rings
  158. HKS 272 Cams
  159. Valve Spring and Retainer Updrade?
  160. HELP!! Running rich and I don't know why!
  161. Small engine oil leak, unknown origin. Pic inside
  162. Drivetrain Whine with Rear Diff Busings
  163. bolt on set up. need help
  164. AYC/ACD fluid change question?
  165. Suggestions on why car cuts off doing boost
  166. Having PO300 code issues
  167. GTX3071 vs HTA3071...Still not yet?
  168. ACT clutch - problems after first launch
  169. AEM V1 1320 PTE 1200CC help.
  170. AYC fluid question?
  171. Shep trans stage 2 - 5 speed
  172. Precision BB and oil line filter
  173. Pure 91 octane vs. 93 with ethanol
  174. New mods Please Help
  175. Oil light flicker
  176. EVO missing on #1 and #3 cylinders only running on 2 cylinders
  177. I need a downpipe that will bolt to a Buschur catback
  178. MAP Stock Framed Turbo Identification
  179. Data Match Technology: flow matching and latency value info from Fuel Injector Clinic
  180. Evo 9 driveshaft for evo 8
  181. What fuel pump can I use
  182. Which Manley Turbo Tuff I-beams for 4G63 100mm stroker?
  183. balance shaft elimanation help!
  184. 600 whp 2.0L piston/ rod combo?
  185. stripped exhaust manifold stud/nut
  186. 2.3 stoker build
  187. Evo 6 Idle Problem
  188. Need input
  189. Clutch Clip / Clutch Adjustment
  190. bad lifter?
  191. Hard pull in 1st gear, backfires now won't start
  192. Vertical FMIC
  193. Is this normal?
  194. Looking for a stroker motor
  195. Lookinf for Info on upgrading stock lifters..
  196. Stock Evo 9 making 412 whp on E85 w/ ONLY 1100cc inj ????
  197. Need help. Installing clutch. Fork position???
  198. Electrical HELP ASAP
  199. Swooshing/ whirring noise at engagement on new act clutch (vids)
  200. Aftermarket rods on stock pistons
  201. MIVEC question
  202. Hit a weird bump now lean idle
  203. Questions about the dreadful PO300 code?
  204. Weird sound from Manifold? i guess!! ( Video Included )
  205. poncam type r 270 cams
  206. Bad ball bearing fp black????
  207. Buschur Baffled Modified OEM Oil Pan Question
  208. o2 Housing bolts fall out?
  209. 4g64 head seal prep
  210. O2 dump louder at idle/cruise
  211. Where can i get a Transfer Case?
  212. Blown Front Diff
  213. Twin scroll V-band Manifold makers
  214. e85 users chime in
  215. 37r turbo oil feed line size from head
  216. Need suggestion on a clutch
  217. Need downpipe/Cobb access port/Intercooler
  218. Evo 8 Engine with Evo 4 flywheel
  219. Really Stupid question about turbo and manifold
  220. Is this retarded using an GSC2 Intake cam with a Kelford 272 Exhaust
  221. ATP 3071 Turbo - Bent turbine fins
  222. To Tune or Not to Tune???
  223. torque solutions rear diff bushings help
  224. What goes on this threaded hole on block behind oil pump cover?pics inside
  225. no vacuum? rough idle
  226. clutch engagement point fluctuates with temp?
  227. dailey driver clutch
  228. Weird noise....Drivetrain?
  229. Leaking Synapse Bov
  230. new tomei turbo setup... need help
  231. T3 vs tial vband
  232. Is this repairable?
  233. Good quality/sound?
  234. Name this Manifold!
  235. Information on Supertech Dual Valve Springs
  236. Turbo Install Q's
  237. Oil Seal - ACD Transfer Box
  238. 4G64 posible problems
  239. Power steering pump wobble.
  240. GSC Power Division R2 Cams
  241. manifold
  242. S1 vs S2 re spool(VIII)
  243. CBRD new 6/6 compressor wheels vs old 5/5 wheels. Feedback?
  244. Evo IV modding help
  245. Changing BOV from circulation to Atmosphere ?!!
  246. precision turbo question
  247. Stage 1 MAPerformance Shortblock 2.0
  248. RS LSD in 03 Evo 8 tc?
  249. HELP! Broken driveshaft carrier bolt
  250. new install help!
