PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Evo engine builders: your opinions please
  2. Just wanna get some ideas on why my motor went.
  3. 2.1, 2.2, 2.3, 2.4 motors / strokers
  4. Crankshaft Oil leak ?
  5. mr oil temp reading normal?
  6. 2wd
  7. Aftermarket o2 housing doubt!
  8. Buschur Racing Dual Stage Boost Controller
  9. Cold car vibrations? fixes itself after warm up.
  10. Random Multiple Cylinder Misfire
  11. 3x same problem keeps occuring
  12. Gearbox and clutch acting up
  13. I just ordered a 2.1l shortblock?
  14. sbc id3 optional harness question
  15. Clutch/Flywheel recommendations
  16. Down on power with new engine
  17. New exhaust soon
  18. winter Project ''project 9'' by Evodan2004.
  19. for anyone that has crankcase pressure issues
  20. hks intake, tanabe turboback, tune ?
  21. tanabe exhaust?
  22. Wastegate
  23. Quick Quesion: Assembling the head.
  24. Please help with driveability
  25. where to buy wheel bearing/hub assy
  26. Seeing changes in my part throttle afr's??
  27. TurboXS downpipe w/stock dump
  28. Need some help please Transmission won't shift
  29. Acd lights. Need some help
  30. Adjustable shock/struts?
  31. stupid wastegate question....
  32. MAF gutting
  33. Very Persistant Transfer case leak:
  34. best way to install valve stem seals?
  35. Pte 6262
  36. Sound Clips of HTA Green?
  37. need help if the camshaft is right
  38. Air to Water on a drag car?
  39. Timing belt installation question
  40. UICP, stock air box
  41. Best turbo for my build up for 450whp on stock block and 93oct?
  42. Mishimoto Oil Cooler!?
  43. turbo for 2.3l
  44. Buschur Race for RR?
  45. Low vacuum idle upon cold start up
  46. The coolest Evo exhaust ever? Yup
  47. What size gap for plugs with spoolin up cop??
  48. Boost leak !!
  49. Hose Popped Off - Now Lacking Power
  50. Best deals on clutch/flywheel combo?
  51. What is the consequence for not Breaking In enough?
  52. stock turbo heat blanket
  53. Parting out my evo!
  54. My Evo V RS destroys clutch while doing NLTS
  55. Anybody have any experience with the fic bluemax 1680cc injectors.
  56. Just installed the Synaptic DV (evo IX)
  57. Garret releases the mid frame GTX turbo line :)
  58. Transfer box and rear diff CWP ratios
  59. Fuel pump (positive) power wire?
  60. motor/tranny mounts
  61. Autometer Water Temp line
  62. HKS Valve Spring Install
  63. "H" beam vs "I" beam rods
  64. best clutch for daily driver?
  65. Competition Clutch Twin Disc Clutch Kit - EVO 8/9 has anyone used this clutch?
  66. carbonetics lifespan?
  67. Anyone else Waiting for a FP Black ?
  68. non ACD t-case and rear diff
  69. Bracket for Drivers side LICP on EVO 8 Non-ACD is it the same as the IX
  70. Bosch 044
  71. Post your Synapse DV config and results
  72. Is this an Exedy Twin SD or HD?
  73. feedback on divided intercooler endtanks?
  74. AMS F1-I Intake Manifold
  75. Act 6 puck clutch life?????
  76. Oil Choice *SEARCHED*
  77. Looking for answers for what makes a turbo spool quickly.
  78. recommendations for cam install (valve springs)
  79. Are there any quiet twin discs?
  80. stock turbo set up. opinion on cams?
  81. Billet Output Shaft???
  82. new member with T-case issues 9 days after buying the car...
  83. White smoke
  84. update to a billet comprssor wheel
  85. Questions about the Greddy Ti-C catback
  86. Loud Snapping Noise: We have a problem.
  87. help please serpentine tensioner broke
  88. Boost change in cold weather
  89. E85 or 93 for road racing?
  90. serpentine tensioner broke
  91. Blew a seal on rear diff i think.
  92. Evo towed by conventional tow truck
  93. life expectancy outta the block ?
  94. Variable Vane Turbocharger??
  95. Possible Rear Differential Leak?
  96. Confused: Rear Diff/Mustache Bar Bushing Kits + Install Difficulty
  97. AMS underhood shifter bushing install question
  98. Force-Fed tests the HKS 7460 Turbo
  99. What Could this be from???
  100. 03 open diff bad in snow..
  101. Used Exedy Twin Question????
  102. drivetrain whining
  103. 05 gsr drivebility problems. stalling.
  104. whistleing sound when boost goes more than 10 psi
  105. Boomba tb to q45 adapter
  106. Identify these cams
  107. evo 8
  108. just when it got cold..
  109. RS LSD Mods?
  110. Flywheel inspection cover
  111. Tial QR to Q housing swap?
  112. Could this be the car that can take down sierra sierra?
  113. overheating problems
  114. DFW Service
  115. evo 9 shortblock used value ?
  116. Mobil 1?
  117. buschur intercooler kit / lower ic pipe fit 8 and 9
  118. Tial bov spring
  119. New turbo setup?
  120. transmissiin spline? help.
  121. 5 spd back to 6 spd?
  122. any results with a uprated 02 housing
  123. what is right for me.
  124. stock shortblock
  125. Need some advice on buying a new center diff.
  126. jerky off throttle
  127. Are these turbos going to be the new King?
  128. Fuel
  129. Valve Float
  130. Horrific Clutch Noise
  131. Transmission gears on my 06 evo
  132. JIC Exhaust Opinion
  133. Boost Issue
  134. evo 9 springs!
  135. using aftermarket valve springs with stock retainers
  136. porting Intake Manifold
  137. HELP!! Weird ACD/AYC problem
  138. Need Help Using stock pressure plate with upgraded disc
  139. What's your opinion on cams with stock turbo?
  140. switching to standalone ems and fuel pump relay?
  141. Magnus IM Tb bolt partern
  142. Solidify for more protection :p
  143. Part Number Request.. pleasee
  144. Perrin Intake w/ 84mm turbo housing
  145. Compressor surge
  146. FIC 750 opinion/exp.
  147. FP GREEN #'s on stock everything?93/no meth
  148. whos running an ex wg on an FP turbo?
  149. Full-Race / BorgWarner EFR
  150. Repercussions of Large injectors?
  151. knife edge build.
  152. 2.0 build, need advice por favor
  153. new clutch...whining noise
  154. Bossting much?
  155. 1100rpm stumble, plz help!
  156. Over Sized Valves Some Questions
  157. Transfer case death whine ?
  158. Best Coolant Brand?
  159. How much Knock is ok?
  160. 2.4 block flywheel problem
  161. Can you reuse valve seals?
  162. Is reliability a possibility?
  163. Clutch on it way out
  164. Blown turbo??
  165. OOFASTLINEOO,GOBLIN BUILD coming together....
  166. WTF is with this cylinder??!!
  167. new motor clutch turbo weird problems help please
  168. walbro pressure reliefs????
  169. ac clutch malfunction? evo undriveable
  170. Difference between 3rd gear and 4th gear pull on dyno??
  171. Cam Pulley Off Timing
  172. AMS Upper Intercooler Pipe and Mini-Battery Review.
  173. all the 2.4L block owners!
  174. FP Green Oil Selection
  175. 4G63 Hesitating on Acceleration
  176. what year galant motor?
  177. ACD unit fried?
  178. EVOKID03 OFFICIAL Black Beast Build Thread!
  179. Evo 8 - Camshaft Position Sensor (CPS)
  180. mixing and matching clutch and pressure plate's???
  181. Calabrating aem wideband??
  182. The All New ETS PT6765 Twin Scroll Turbo Kit!
  183. is this bad?
  184. Throw out bearing?
  185. What year stock turbo picture is this?
  186. Beginning of evo 8(injector question)
  187. Another stock block bites the dust...
  188. Evo 6 heavy duty clutch slipping HELP!!
  189. People with FP black or Reds!
  190. M&W Sequential Ignition Multiplexer
  191. FP 18 psi vs. 25 psi wastegate actuator
  192. would you ever?
  193. Recirculating BOV question....
  194. need help with intake manifold
  195. two three stroker oil suggestions
  196. What's the difference between a regular and 100% synthetic oil filter?
  197. Ams balance shaft kit
  198. Cam Identification marks
  199. Fpred Max HP on a Mustang Dyno
  200. Exedy Triple Cerametallic Upgrade??
  201. Belt Tensioner & Water Pump Pully Problem
  202. My New FP BLACK Set Up
  203. RWD converison gearbox
  204. Bending turbo compressor fins
  205. Question about Lifters
  206. Tial QR bov Spring ?
  207. What is the little piece on the crank called?
  208. Thumping sound coming from right front wheel
  209. goal: 120mph traps. turbo?
  210. Best clutch for 450whp?
  211. Mangled TOB
  212. exhaust studs help
  213. what cams would be best?
  214. Question on Manley piston ring gap?????
  215. Do you guys like the power train twin disk clutch?
  216. How much Boost can a stock block hold?
  217. pullin the motor
  218. HKS Super Turbo Exhaust
  219. adjusted clutch -> won't start
  220. Transmision Advice?
  221. Boost threshold:
  222. Will a 37R exhaust housing fit a 35R?
  223. Help with camshaft Identification
  224. AEM Tru Boost. Im confused!!
  225. defi gauges questions
  226. Boomba TPS Adjustment issues
  227. Crankshaft Check Bolts??!?
  228. Redline MT-85 transmission fluid
  229. rebuild?
  230. REM ISF on a built trans? Real world experience/proven benefits?
  231. 2.1 destroked or 2.4 stroker?
  232. Who's Experienced a Valve Spring Failure
  233. Exhaust leak... Buschur port. o2, bolted to AMS downpipe.
  234. What is this Short Throw I've recieved? (evo 9)
  235. Hobbs switch for twin in-tank pump setups.
  236. What turbo uses the TD06H turbine wheel?
  237. 4g64 with 2.0 water pump adaptation !!!HELP!!!
  238. Clutch Fork Stop adjustment
  239. Need some feedback urgently!!!!!
  240. Starting Vehicle without a Clutch Pedal.
  241. DP and HFC Cat Install Issues
  242. FP Green Install
  243. Rear diff noise
  244. Rods for 2.3 Stroker
  245. Is it normal?
  246. advice needed on main bearings evo 9
  247. Problem with A/f keep changing
  248. 2.5or3" intercooler pipes
  249. Borg Warner EFR - Info on Full-Race.com
  250. Problem with excessive boost after swapping WGA
