- 4g63 trans options
- ARP studs question
- Hks 264/272
- GM 3-port with External Wastegate
- Keep an eye on your spark plugs.
- evo 9 wastegate restrictor pill?
- Car won't go into gear.
- Is my boost controller setting correct (Pro-Fec B II)?
- Boosting issues help!
- Build your own coil on plug system
- I am smelling gas
- Kelford 280 vs BF272?
- Massive boost leak?
- What to do with spare engine that spun a rod?
- Fan hitting stock UICP/hose after radiator install
- Quartermaster Twin Rebuild.
- epm o2 dump question?help!
- Injector question (size/set up)
- WTB HKS cams
- Losing Cooliant, does that mean blown head gasket
- Evo 9 after new clutch install 1st gear lockout. Help!
- Tomei Slow spool up? HELP!!!!
- how much can the tranny hold and beefing it up?
- Timing Belt too tight...
- Just a little...AMS Performance Porn (Fuel Setup)
- GSC Beehive Valve Springs - Suit JDM Evo 7?
- evo 6 speed switch to 5speed trade
- Evo 9 20G
- Boost guage reading too high?
- Combustion Chamber damage, need opinions
- Rear Clunking Noise
- which are the best fluids for tranny,tcase,diff,for evo IX?
- Stock Internals. Max out WHP.
- Has anybody welded a universal muffler into their catbacks/mid-pipes?
- What oil in new rebuid motor witl new FP Black
- exedy twin clutch HD problem
- Help me identify this sound!
- Anyone have the clutchmasters fx 300? any good or bad reviews?
- need help choosing clutch?
- FF turbo kits, what air filter are u using?
- Help me decide on exhaust for my evo 8.
- HKS Oil Cooler Thermostat
- Front end noise
- Shot Peening gears
- Fastest spooling Turbo on a 2.0
- Time to change timing belt
- question regarding vaccuum??
- Evo IX MR transmission 6pd.
- older bosch injectors or never ID/fic high impediancy injectors ?
- slipping problem BUT!not from clutch...
- Upgraded turbo, IM, TB now missfires/floods
- maft questions
- Weird noise...clutch problem?
- How to put on exhaust valve stem
- hoses
- tune or no tune???
- Should the clutch discs be staggered or inline on an exedy triple??? Help
- Tired of Searching - What Part is this?!
- BOV to recirculate or not
- Evo 9 turbo fake or not
- Mechanical gauges...
- Twin Disc Non Sprung - proper downshifting
- 5th synchro upgrade?
- front o2 sensor
- More power out of the evo 8.
- Is there a Plug & Play 2.3L Crankshaft for Evo?
- FPBlack/Boost issue...need help!!!
- AFR jumps lean when maintaining speed around 80MPH
- What is this part?
- Pipe size for hallman pro
- Is Exedy tob's on the same list of junk aftermarket tob's?
- slim fan
- Tuner !!
- Boost Control Soleniod Capped off??!?
- Competition Clutch stage 3 review...till death!
- Compression test 180 across the board.
- car runs crappy for 10 min then fixes itself
- Is this "Serious"?
- Exedy stage 2 HD issues
- Installing stm clutchline.
- Stroker Problems evo9
- Which turbo kit would be best?
- Help identify these valve springs!
- FP71HTA installed today
- Weird issues with the car today... need opinions
- Lower Intercooler Pipe setup for FP Black?
- is single walbro enough
- HKS Hi Power midpipe>test pipe gasket size?
- FP/BBK/Buschur 04 RS (new pics of cold air intake, etc.)
- zip ties for catch can hoses?
- Short block replacement
- knock on evo ix.
- reccomended BOV?
- UPDATE: Downpipe disconnected from Exhaust manifold
- Fujitsubo RM01a
- Exedy vs act
- ets stock battery uicp and apexi induction box fitment
- DC Sports Cat-Back tip fell off??
- built motor oem headgasket
- While driving all power turns off!
- Cocktail for IX?
- Car wont go into gear
- FP Black on stock block owners, please chime in!
- low oil pressure problem help!!
- Help with 2.0L Build
- weird clutch noise!!! any suggestions???
- Rod to cylinder wall clearance
- Post your Exhaust db using phone & free app
- Transmission or Clutch?? help
- Oil and power steering coolers
- best/safe boost without a tune?
- average life of an exedy clutch
- 35r open wastegate
- Clutch help
- What route to go?
- Awhp estimate
- only 14 psi wtf?
- Video... How bad would you say this turbo is
- FP Black Shaft Play
- 4K-9K RPM Power Band.
- Exhaust Wrap & Wideband
- An intake that works with stock turbo and upgraded turbo?
- Weird Engine Noise SOS! VIDEO INSIDE
- Differences between Samco intake vs Aem?
- Anyone know the difference in the Exedy triples? SR and HR
- 2.0 to 2.3 build
- Hesitation when warming up
- 2.1L Build
- Anyone runnin a catchcan setup straight to the can only?
- Anyone running 6765 in Twinscroll T4 yet?
- New Fuel Pump Not Working
- Head trouble
- Clutch Stop, make sure you adjust it periodically!
- Evo 8 help.
- SD conversion questions. please help!
- 700whp clutch?
- fuel economy
- Heater Core Removed, hose help
- 1-2-3 pull with my TS HTA3076
- Manifold Design Idea
- 96 Evo Transfer case
- Transmission help, just rebuilt now no 5 or rev
- Piston stop tool in #1 or 2 cylinder?
- Block back from machine shop. Need opinions.
- RS-R Oil Optimizer
- GSC S1 cams & type of oil??
- Weird missfire
- benefit of TC-SST?
- Eneos Oil, Worth it or NOT??
- oem transmission problems! 6spd IX
- Newly rebuilt drivetrain noisy as hell..
- honeycomb on front of MAF???
- Uninstalling AMS GT35R, what VIII or IX parts am I gonna need?
- evo 9 spark plug choices which ones?
- flutter or surge on stock 9 bov
- Quest for quiet high flow exhaust
- quesions about my 2.4 build
- A Warning about ACT clutches to eveyone
- Engine mods = better mileage?
- need help with my 2.4 build
- 4th gear problem!
- Need a tune to drive car safely?
- Evo BOV
- speed density setup - what bov are you running
- Here we go again, quiet cat-back clarification needed.
- NEED ASAP LONGER 5th GEAR!!!
- help wit hks bov
- Ticking noise
- What else to replace while installing exedy twin?
- Valve cover gasket
- Rpm in 6th gear at 60mph
- Help diagnose/repair my ACD/AYC
- o2 housing gasket options....?
- HTA Green hotside question
- Clutchmasters FX 300 vs. ACT hdss or xtss?
- 40Rand 1/4 mile results
- NEED HELP FOR P1870 and P0420
- Can Evo 4 5 6 Use 6.5 TME Center Differential???
- it didnt go boom atleast!
- help identifying injectors?
- "Gone V8 hunting...be back in 8 seconds" 2011 picture and new build thread
- Which type of muffler dampens sound more, packed type or baffle type?
- Clutch Options
- Installing an exedy twin disk rebuild?
- Catch Can(Is this worth the money)
- Evo IX MR or SE/RS due to tranny?
- Benefit from just DP and TP?
- 35R Exhaust question..
- Putting an Evo 9 Turbo on an Evo 8
- LSD Transfer Case in a nonLSD EVO
- Transfer Case Swap cost
- gt45r turbo
- GSC stage 2 on stock turbo?
- Porcelin broke off spark plug cylinder 4! Anyone know the cause? input welcome.
- Help! What Part is this? I need one!
- idle issue
- Evo 9 Transmission Parts...Where???
- where has the "lope" gone to
- Rebuilt tranny popping out of gears.
- Debating on changing my cams...
- boost controller help
- Evo 9 Piston Ring Orientation
- fp red help
- e brake and battery light on!!! Please Help!!
- 3 acd lights are on, dealer say its my bad speed sensor?
- p0401 (EGR insufficient flow code) All options exhausted
- ROSS Pistons/Rings
- Bullseye s259et
- Tcase oil seals?
- Fp turbo vs GT35r series
- Head Gasket Choice
- boost cut due to cold weather?
- Hydrolocked my built 2.0L ... pics inside
- Help with exedy clutch
- BOV Issue or What?
- Any Increase with Only Downpipe and stock Exhaust??
- Did it blow up??
- Will actuator fit
- Motor lifting points...?
- best headgaskets for 4g64evo
- hpw much load should I see
- Car Wants to turn over then dies... Help!!!
- Inner tie rod?
- Leaking fuel injector?
- What would be the cause.. help plz..
- evo 7 diff problems (HELP)
- Exhaust manifold or stock manifold ported???
- Anyone run a LIPP O2 housing here?
- Need help after clutch install
- Cold vs Hot vs Wet compression #'s
- mini battery question
- fp5r cams in a daily 2.3
- Question reg: Cosworth intake and intercooler pipes
- Long rod vs standard rod
- What injectors to get.
- Adapter Flange from Evo to T3 Frame Question
- Transmission Modification???
- Perrin silicone intake with ETS stock route piping?
- Cannot find 6th!!!
- Oil Stabilizers?
- opinions on 6 spd when did yours break
- Buschur spec JE Pistons install position
- Timimg Belt install.
- HKS GTII 7460R Track Results and Review
- New Product Introduction
