- What next for the IX
- J&S safeguard
- Clutch blew up, need a little input.
- Cams and afcII
- do i have a problem.
- nos question
- Added noise from Fidanza flywheel??
- 12V ignition on power source?
- Apexi Noir Evo Cat-Back
- ATTN To those who have shipped out ecus to be flashed
- TC problem or bad wheel bearing?
- Help me diagnose this oil leak?
- EVO 8 Problem Please Help!!!! Bogging down
- Got a CEL today...HELP!
- when does the IX turbo lose efficiency
- Anyone know the correct thread size for the taps on the head??
- Bolted up a 20g-9.....untuned !!
- Once again HELP! Engine Problems
- boost gauge fluttering???
- Greddy SP2 Pics
- Drivetrain noise...
- Thanx to TT
- which clutch
- gt3076r and plug gaps
- I know I know ...Im a newb but....
- Tilton from a honda, Will it fit in an evo 9?
- EVO IX - HKS Exhaust Cam?
- stock turbo and 11s??
- Replacing Helix catback with?
- Quick question:Sun Auto Cyber Products
- Stock IX FMIC core?
- Redline Heavy Duty Shockproof candy
- detonation, need new pistons
- SBR GT35R dyno results
- Forgot the washer on the rear diff drain plug... bad?
- oil lines leak - oil cooler
- SPEC clutches really this bad????
- how much damage did I just do?
- To GT35R or FP3065 ???? choices, decisions....
- 20G 9 ti wheel
- ACD Overfill ?
- apexi noir vs rsr ex mag
- Driving impressions: BR Race FMIC on Stock 05 Turbo
- Dynoe'd my 03 EVO! Am I about right?
- Cant find o2 housing on ebay
- really cool washing machine!!
- Brand new EVO IX, 1100 miles, strange problem
- need help, I was sent 264, 280 hks camshaft ?
- 264/280 cams??
- Engine misfire
- Cat or not to cat
- CEL question
- 20G Turbocharger
- Brake fluid concern !
- WTB: stock turbo from a EVO 7 or 8
- spark plugs
- QTP First Evo 8 Down Pipe/Cut Out!
- any one use Trufilter oil filter
- got questions on gauges
- US Only Oil Filters? What gives?
- Finishing up cam install and...
- Gsc 264/274's are bigger injectors needed?
- To 35R or not To
- Review: WORKS Axle-back muffler "Videos"
- Throttle seems to Stick..
- Mivec question?
- MBC problem continured
- 1.2mm Head Gasket + Head Stud Kit
- Maybe my next mod path
- exhaust flange
- 1st Dyno attempt ever for me.
- WTB stock evo 8 turbo manifold
- Cosworth head repost
- Is my clutch slipping?
- Turbo
- Decibel testing on different exhausts and combinations....
- In the market for an 02 housing +10.5 hotside
- what manifold should i do??
- How to clean oil residue in Turbo inlet
- Turbo xs fmic dyno gains?
- Cosworth cam info...
- Issue with timer harness and not happy with Lancershop customer service!
- Installed some part on a friends Evo
- Do I have Headstuds?!?
- help me continue my mods!!!
- 05 transfercase
- I'm tired of my coffee can exhaust - Alternatives?
- Bushur Exhaust Question
- Head Flow Data Comparison
- Turbo XS D-tec EBC
- type s
- Another clutch question
- what kind of turbo is on the f400
- Trans/ TC fluid Chaos
- replacing stock manifold with aftermarket???
- Greasing the APS BOV?
- EVO 9 and Upgraded Turbos
- anyone run a shearer 50 trim?
- Clutch gave out today.....
- Maf Problem Help
- Monster Sports Parts Debut
- Timing Belt Change Question....
- Fujitsubo RM01A....NOT 3" Through Out
- in ref to sticky - stock evo track day?
- turboXS HPMBC
- MBC is being a douche bag
- Cam Gears
- Anyone install a low profile fan? - Instructions?
- T case fluid change
- Engine/Boost problem.....
- DEI exhaust wrap
- Trans. Fluid Alternatives
- my IX on 100octane daily
- Gearbox or Differential
- Align hone with ARP Mains??
- Tales of my EBAY O2 housing
- IC pipe leak and BOV question
- yet another turbo recomendation needed
- User-Tunable ACD Controller for 05-06 EVO? Anyone Interested?
- MBC problem
- front mount swap. look here.
- anyone know about flywheels???
- MBC or Greddy Profec B spec 2?????
- Looking for catback...
- Injectors
- White Rabbit Peak PSI Flow?
- best power for the money cams?
- Boost lower then normal....
- Malibujack's Mechanical Engine Porn
- another whining noise thread.....
- Piper 290 Drag Race cams??
- Electrical Problem 1st day..
- Just dynoed my ams gt3076 kit
- Rear Axle WHP Capacity
- any one use Clutch Masters stage 3
- Turbo Back Exhaust = Less boost
- Hks Ssqv
- Stock MAF testing: Is it really restrictive?
- Trans or Tcase
- alchy or ams intercooler
- This is how my Full-Race turbo kit install went today......
- which clutch??
- Will this Work???
- Gauges
- just for fun, how much hp after turbo install estamate
- Removing lower IC piping....
- street tuned the GT35R
- shorter 5th gear for '03?
- TURBO! I can't decide which one...
- Throttle Body Spacer??
- EBC and HKS RS intake combination
- Intercooler piping and intake ???
- Weird noise when downshifting???
- CEL code question...
- Need a AEM map ASAP (35r,1000cc,5bar)
- Help on Clutches, love to hear from AMS, Buschur, Turbo Trix, and Auto-Xers
- HKS cam question
- greddy ebc
- anyone using the carbon fibre driveshaft as yet?
- DC Downpipe Problem?
- WORKS clutch line problem???
- Clutch Slipping Solutions?
- Does the stock wg arm need to be adjusted for high boost?
- Its that time...
- Boost after Dynoflash
- thought i should share
- are my cams causing these codes to be thrown???
- IX 5 speed much better than VIII 5 speed?
- Where can I buy an O2 sensor including connectors? Need help!
- Clutch Help!!!!
- Clutch chatter on new clutch?!?!
- smc alky kit questions
- what would be faster?
- 05 VIII Going under the knife this weekend...
- Will this intercooler work??
- Agency Power Turbo Kit - DYNO RUN VIDEO
- Breaking in a Stroker Motor
- Evo IX Compression test
- Best/Easiest way to measure fuel pressure?
- Intercooler pipes
- CEL code after mods/tuning
- 20G-5 vs. 20G-6 wheels and compressor surge
- Engine RPM's
- **VID** My HKS 280's cams idling on my 05 EVO 8
- is my clutch ok?
- for you people w/ ebay style O2 housings
- 3076R hotside, .63 or .82 ?
- Evo IX Gearbox
- Will $5K get you into the 10's in a IX?
- someone please explain heatsoak
- 2.3l + what turbo?
- TurboSmart E-Boost2 Boost controller
- Which intercoolers work with the oem sprayer?
- How much Hp for AMSGT-35R
- FWD Evo??
- Ignition Problems
- Dyno graphs...topspeed tuned
- Anybody using AEM's twin fire ignition module?
- fluid leak =[
- Looking for Intercooler
- Is the shifter different between an 03 vs 06?
- Test Pipe Gasket HELP HELP
- my 280 cams idling before tune - video
- Cosworth Cams
- New Buschur Racing 3" V-Band Turboback Exhaust
- Greddy T-67 Kit
- Parts
- 02 housing question
- Detonation, What's it all about?
- Bosch 044 vs. Aeromotive A1000 or Eliminator vs. Magna Fuel ProTuner MP-4302?
- fuel pressure problem
- Should I upgrade Intercooler????
- revolver cams vs Hks 280 cams
- How to grease Forge MBC?
- questions
- with or without?
- Just got AMS flashed
- So Confused ... Turbo Question
- Timing Belt Problem, Please Help!
- PO171 & PO134
- wait for flash?
- Ignition Troubles
- Engine revving for no reason
- David and the Buschur crew, Thanks for helping the kids.
- Anyone running AEM Twin Fire?
- Does anyone try this product already?
- My Buschur Racing RACE FMIC arrived....all damaged!!! Pics Inside!
- defi egt install help.
- boost on a GT35R???
- FMIC: stock vs Rnr vs Buschur race
- Have i gone to far?
- New Problem when it rains. HELP!!!
- Stupid Oil Question
- Rod failures and Test drives?
- feul pump
- someone please explain air fuel ratio
- Crank Sensor! Help needed
- Zeitronix freezing
- Where is the best place to tap into for oil to feed the turbo???
- which clutch/flywheel would you recommend for my daily driver
- Possible solution to ticking lifters...
- Wastegate actuator adjustment and the lower heatshield
- Part Throttle Boost Issues.
- Greddy Type-S self made recirc Kit?
- boost help
- Fuel Cut Help Please!
- Dip switch settings on smc meth kit?
- Where to get Evo IX turbo
- differential lockup ratio
- Helix IC Pipe Sound
