- Having trouble with P0171 coming up about once a week?
- Help me diagnose my issue
- Price Check on Evo 8 Block
- Turbo options
- As of 2013: Kelford 272 or GSC S2s
- bluish smoke at morning starts
- 2.3 to 2.4 oil filter housing leak, need help
- T belt replacement
- P0420 code being thrown more often now
- New clutch for bbk full
- 5spd tranny help , 2-nd gear comes out
- P0456, fuel smell, passed smoke test, help!!
- P0403 & P0443, even after periphery modification
- Bad Compression Test, Now What?
- Tranny Overhaul..Spinning Races??
- evo clutch question
- Grimmspeed 3 port + AEM Truboost install help
- clutch noise/pedal stuck
- Boost leak around injectors
- Injector signal issue
- STM Catch Can Questions
- throttle body leak right below tps sensor
- test pipe vs high flow cat
- Evo VIII stuttering under load
- BOV question
- exterior WG flapper arm length?
- 5 speed into an MR info needed
- Problem with ATP's Garrett Ni-resist TS housing?
- help identifying turbo
- Double Pumper 12v Wiring
- Which Intercooler so I can fit a Cusco Powerbrace
- how to select the right cams?
- Oil pump gear leak (picture)
- Get me to 350 whp?
- Kinugawa 25G issues easily fixed?
- Cam removal (need help)
- QuarterMaster 8leg Street -- Amazing
- Alternative to HKS 272 exhaust cam?
- Comp 6262 or GTX3582
- get me to 450
- Quartermaster clunk after 300 miles?
- just curious question about cams
- Forward Facing owners chime in please ..
- Evo 9 Stock turbo O2 Dump
- Injectors spraying out e85!!! Please help!!
- Turbo Labs 25G Turbo Failed in less then 2 months!
- Evo 9 tranny
- Timing belt tensioner and idler leaking oil/grease?
- Difference between grimspeed ebc vs ebcs?!
- Ti Exhaust, for DD/Track-Day, yes or not?
- NEED help stalling issues!
- Evo ACD pump not even starting
- Clutch issues?
- 4.11 w/JDM 5th Gear, or keep 4.59 & stock 5th
- Transmission Rebuild kits
- Resurfacing a flywheel for the 2nd time
- parts question
- Bucking / hesitation issue - a lot worse when cold but warm too
- Peaking at lower boost ever since i installed my o2 dump and LICP
- next turbo up from gtx3582
- Any Idea What HTA Means?
- evo 8 boost
- ACD 4 error codes, next steps
- megan o2 housing
- Weird whistle noise coming from BOV (i think)
- Shifting issues: Hard to pull out of gear (or doesn't)
- ACD Won't Bleed
- How much hp can a stock evo IV engine handle?
- Looking to get a new exhaust, what do you recommend?
- The point of having a VCU if you install a LSD center diff? searched, frustrated newb
- 6466 v band question
- car wont start, stroker timing
- New radiator now blown water pump
- DIY Clutch - where to attach a hoist?
- 2.4LR what crank...
- Need good and relaible machine shop.
- Stubby Shaft tightening torque
- Evo 8 Boost Problem!?!
- evo 7/8/9 transfer case ring gear size
- head studs what do u guys prefer
- Wiseco piston question
- Introducing a New ACD Controller, ACDPro
- Spun rod bearing? Balance shaft bearing?
- How did coolant get here??
- Crank walk
- Kia Optima head swap
- FP Cast Race Manifold for the 4G63
- Speed density on stock 9 turbo?
- Throttle body plate
- 2005 evo rattle noise
- quick question about the radiator support
- Diagnose engine noise. Video inside
- replace mivec oil line?
- Throw out bearing rattle?
- speed density: vta vs recirc
- Just bought a 6466
- Bad Ignition Switch?
- AMS exhaust fitment issues on 05 Evo
- Evo 6 Vs Evo 9 Turbo
- How's my compressor looking?
- Serpentine tensioner knocks when engine/cams lope
- Manley springs - will they work with S2's ?
- Most reliable aftermarket Throttle Body?
- Comp clutch product decision:
- anyone knows what this line is for? fuel related
- Walbro 255 Fuel pump questions!?!
- Odd Clutch Issue
- clutch fork stop question
- Manual Steering Rack
- Normal for IAC to get super hot?
- Part number for PCV valve aluminium valve cover adapter
- question about over boosting
- Exedy twin rebuild plate positioning?
- Evo throttle body clean up
- twin sroll manifold with one wastegate solution ?
- half moons in throttle body.
- IX ACD computer and IX TB ??
- E8 cam position sensor problem
- Competition Clutch Twin Plate Evo 9
- cars running rich
- Shifter Cable Problem 6 Speed
- Id1300 injector scalings
- Torque Solution motor mount discoloration =(
- 4g64 Evo 8 Questions
- Boost controller
- CP9A Transmission
- Driving in 5th gear in low RPM & driving with ac on?
- overboosting with greddy profec e01
- tps setting
- Fp jb black
- Diaqueen SSTF (ATF) vs Super multi gear (MTF)
- AEM In-Tank Fuel Pumps
- Which wastegate is this ... ?
- Which UICP w/ STM Intake
- Rebuilt transfer case - how long to run in?
- Pte precision injectors
- Decent HP out of 100k+?
- How does a Turbo go bad?
- TPS adjustment - how to do without back probes?
- Another 4g69/63 piston question. need some help
- How to build a higher revving 2.3
- what fuel should i run?
- Thermal Siphoning, Could save your turbo.
- cams,retainers and valve question
- Anyone to measure the id of the Megan o2 housing?
- looking parts
- Crankwalk?! Seriously?!
- Looking to upgrade Turbo for Evo on E85
- Just finished compression testing on my Evo 8 with 103k miles.
- Evo 4 to 8 swap - Electrical problems
- Synapse Synchronic DV
- Tial 38 Mvs hook up?
- setup right?
- Exedy HD Tiwn Disc Clutch Noise
- Fp billet 7 blade vs garret gtx 11 blade compressor wheel? Which is better?
- Affordable oil lines for FP HTA3586R?
- head decked compression increase
- Time came for me to get a new clutch
- VIII Turbo Won't Boost Over 28psi
- Clutch problem...(when ac is turned on)
- bad timing belt tensioner?
- FP Red or FP Black for daily driver ( I do not want to build the motor)
- BBK install questions
- Quick question :)
- Evo xi mr
- Wtb 900-1000cc injectors, o2 housing, ported and coated manifold
- Anyone using these seem legit and price is right 2000cc INEJCTORS
- Blow off valve leak at half throttle
- Gates Belts?
- Fuel line
- Looking for an Evo V Ecu
- Valve cover fittings
- Clutch Sticking/Getting Hard... Any ideas?
- 100k mile Evo build $10k budget
- Amuse exhaust
- Amuse exhaust
- AMS F1 manifold worth it?
- EVO 4 AYC help needed
- Evo 4 clutch replacement
- exedy stage 4 triple disc clutch
- Rich idle, lean boosting problem
- No Reverse
- are these genuine Holset turbos ?
- Power FC and Launch Control
- Head Porting
- clutch issue
- opinions of t-case upgrade
- Motul 90 PA - Rear LSD
- Should I Purchase Buschur Ported Exhaust Manifold?
- Behive or Dual Valve Spring what is needed to rev to 8500-9000 RPM
- New Exeedy twin installed and now car jumps and shudders bad when I start moving.
- Bigger turbo, more HP, but slower track times - where to start?
- Backfire/misfire issue
- Lets talk wastegate springs and preload
- modification question
- Odd problem under boost
- Another ring gap question
- how to use stock feed as return?
- NKG Racing?
- HKS GTII turbo actuator replace?
- Check downpipe fitment: +acd + cat delete
- Clutch pedal adjustment for drag
- 02 housing question
- 5 speed into an mr. rear diff ratio needed
- Not boosting over 15psi. Need help troubleshooting.
- Boost lvl safe and normal ?
- Leakdown test results leaks out of exhaust ports
- Cobb Catback/Turboback for Evo 8
- 4th and Reverse Gear Grind?
- Loud rattle after cam install
- Strokers that have lasted 100k+ miles?
- CAM Setscrew and plate?
- possible bad wastegate?
- 6speed Shift linkage removal?
- Quartermaster 8Leg with 2nd Gen DSM Clutch Solenoid Mod - MUST HAVE
- Lifter tick?
- Evo 8 Idle Help ( Cosworth M2's )
- seized 2005 Evo 4g63 engine value
- DTC P0373. Please help.
- Idle issue
- Evo 9 BOV super loud?
- Oil from bov or somewhere else ?
- Retune needed?
- Sensor types and specs
- Manifold question
- ARE dry sump,anyone here using one ?
- Crank/Cam Sensor Codes
- stumped on ACD problem
- Lost compression in one cylinder
- High HP & torque guys: what do you torque flywheel bolts to?
- Jacks indestructible TCASE?
- what is the advantage of front facing turbo
- Comp stage 4 6-Puck chatters...!
- What pistons are better
- Stalls shifting from first to second
- Linked Intercooler Piping Clamps?
- ptw..big-end and main clearance
- Building a 2.3 stroker
- Misfire after shift under full boost
- To upgrade manley piston pins?
- Ets twin scroll what wastegate springs?
- Engine won't turn, even by hand
- Has anyone got their engine built by Jackson Auto Machine
- Evo 4 to 8 swap: no fuel/no ac fan
- decisions
- 2.0 Long rod vs 2.0 stock
- Evo 8/9 timing belt cover
- ACT Clutch for the 4G63?
- P0113 Issue need help
- Ground issue
