PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Turbo swap
  2. engine trouble (electric)
  3. Custom clutch place in CA?
  4. Missfire at WOT?
  5. VRSF 4" intercooler is on and here's my review
  6. New motor, lean idle (18.0)
  7. ARP headstuds 1x1 torque sequance
  8. Wavey clip retainer on throw out bearing
  9. Aeromotive 340 E85 failure..
  10. 25g Kinugawa install
  11. Autocross turbo selection
  12. Smoking at > 1/2 throttle & low compression - rebuild time?
  13. Evo Crankshaft Compatibility
  14. Vacuum to vent crankcase?
  15. Difference between exedy triple sr and hr
  16. 4g64 Block Power Steering Brackets
  17. Intake Manifold Caps
  18. STM aluminum cat-back
  19. car leans out at 1/2 tank
  20. Leaking in some engine pipe ?!! PIC included
  21. Red line oil into VCU tcase + Wavetrac
  22. Boost
  23. Mivec line fitting sizes needed
  24. Evo engine oil experiment: Would you run this oil?
  25. while cleaning up my cylinder head found these in combustion chambers, is it ok?
  26. Differentiating clutch vs. trans issue?
  27. 4 or 6 puck!
  28. Installed A new fuel pump... No Start??
  29. top end gasket kit
  30. Turbo Oil Return Line Leak
  31. Need Driveshaft!
  32. Clutch disk Help
  33. Front o2 sensor connector
  34. Exedy clutch disk Depth.
  35. MIVEC wiring harness help, how to test OCS (solenoid) at harness?
  36. ACT Pressure Plate HELP!
  37. Opinions on Crower rods (not brian crower)
  38. car broke down. found this afterwards.
  39. EVO 8 vs 9 rings
  40. Low Compression
  41. Car going lean after about 5 pulls...
  42. Weird Drivetrain issue?Guru's pls help
  43. dual tune info needed
  44. 6k rpm rumble
  45. AEM Dry Flow? Stock MAF
  46. Weird leak and weird smell
  47. Installed mbc, boost wont go over 12psi
  48. Smallest 3xmm wastegate?
  49. Turbo List
  50. Evo IX Bad Idling (Fluctuate, Engine Die, Stall, Etc) Progress
  51. Identify cams?(purple paint,CWC4604)
  52. of cams and timing
  53. Fuel system question
  54. Evo IX Cams
  55. Help, power loss
  56. GSC Zero-Tick Lifters - My Experience
  57. Cold Exhaust Runner Cylinder 1
  58. How do you identify cams? are these S3's?
  59. Exedy triple disc thickness
  60. GSC S2 Mivec cams with stock retainers?
  61. how to adjust new clutch properly ?
  62. full blown fuel filter
  63. Balance shaft removal in car questions..
  64. Buschur 3/4" Width Fluidyne Radiator Kit ***GROUP BUY***
  65. 400 Walbro pump install
  66. Well, this is frickin' lovely
  67. Cam decision help
  68. stock internals HP and torque limit?
  69. PCV question
  70. Transmission Problems
  71. Best clutch flywheel for my power/budget.
  72. vgt turbo
  73. ACT street clutch
  74. transfer case help!!!
  75. ams f1 intake with stock tb flange or 75mm tb flange?
  76. Engine keeps cutting out!!!!
  77. Oil Leak-Oil found in Intake Manifold...Help
  78. Help ID what valves I have in my IX head.
  79. tcase for 6 speed transmission evo 9 ???
  80. Fuel on top of pistons?
  81. Switching to summer oil
  82. Comp stage 2 for 27psi and 520 Wheel NM torque?
  83. STM catback + MAP O2 eliminator?
  84. compression test results, need advice
  85. GSC R2's with Supertech duel valvetrain is a NO GO
  86. Output shaft put in wrong side
  87. clutch for sub 400 hp
  88. Fuel regulator?
  89. Can I sell this clutch used?
  90. fork stopper on oem clutch ?
  91. the reason behind my sudden fuel pressure problem
  92. Power expectations...hard to search specifics
  93. Weird leak, and stutter.
  94. Starting over
  95. Logging turbo back pressure
  96. Custom COP setup 10/15 fuse
  97. Extremely weird clutch problem
  98. Help: Anyone recognizes this cams?
  99. Evo 4 transfer case, can it be modified?
  100. Evo 8 Thermostat Diameter Size
  101. Where to buy EVO 9 RS JDM 5th GEAR
  102. Whats my evo 8 head worth?
  103. LSD/6 MT/AYC oils recommendation
  104. is it safe to port to 70?
  105. Quarter Master Break-in miles??
  106. Act clutch issue
  107. I have replaced everything..... But still...
  108. how to 9000 rpm??
  109. Skipping or Missing
  110. Transfercase leak
  111. magnus V4 i/m
  112. evo 8 tomei 280's
  113. oil cooler delete
  114. fp black on forge or fp 25 gate.
  115. new start up
  116. evo 8 or 9 gasket
  117. Tial wastegate spring question
  118. Hta 3794r , applications ?
  119. Master/Slave cylinder rebuild kits?
  120. QM 8 LEG Install
  121. SO since there are no cobb access ports for evo8 & i wanna go catless downpipe?
  122. Fullblown 70mm TB - TPS adjustment
  123. Blow off valve making high pitch whistling
  124. Bent Crankshaft - Would this cause any problems??
  125. Clutch pedal vibrations and then no clutch
  126. Trans/Clutch Issue? Help!
  127. Car stutters when going WOT!....Stock ECU/SD on 93 Oct
  128. Steering wheel hard to turn on my evo ix
  129. Valve leaks/cause of "lack of timing"?
  130. Quick question about GSC R2 cams and valve springs.
  131. oil leak after motor install
  132. Clutch slipping but not during full load pull- Please Help!!!
  133. Need Help - Recurring Low Oil Pressure Light
  134. Camshafts recommendations?
  135. Walbro 400 lph failed
  136. fuel lines and fittings
  137. Looking for tuners advice
  138. Unstable Idle
  139. Engine Oil recommendation
  140. Cold idle issues
  141. Anyone use Rev X
  142. fuel system swap
  143. Evo 7 GTA Turbo/Cams Help.
  144. My almost successful 20g with Billet wheel Build
  145. in need of pigtails for id1000 injectors
  146. Shifter base bushing kit
  147. Oil pump??
  148. Lockout at low RPM
  149. Evo IX weird sound after new clutch installed
  150. Front 02 Sensor Normal Voltage Range?
  151. Abs delete with ACD Evo ix
  152. 90mm Throttle Body choices
  153. What 4g64 engines fit a evo 8 head. Make, Model, Year of 4g64 LR2.4
  154. Tial Q vs QR for SD
  155. OEM Clutch Brand?
  156. P2228: Does anyone have the answer???
  157. TB help
  158. stock ecu online flash tune
  159. Ticking noise 3000+ rpms
  160. What is the type of cam and crank pattern used on Evo ix ?
  161. Exhaust Camshaft position sensor issue
  162. Wheel bearing size for DSS rear leve 5 axles
  163. What Caused This? Diag Help Needed
  164. Mivec cam angle sensor help?
  165. Hta3586 vs 6466
  166. Gapless rings
  167. Looking for an ACD Controller beta tester
  168. O2 Housing install question.
  169. I got some new toys;)
  170. Advice/impressions
  171. 2.0L build, need advise.
  172. Transmission issue, and/or transfer case?
  173. Need help identifying what HKS exhaust cam i have,
  174. Need help identifying what HKS exhaust cam i have,
  175. Maybe failed T-case bearing??
  176. Airtrek turbo appears to be boosting 16psi from stock?
  177. Fp5r/fp11 combo
  178. Camshaft broke
  179. Gsc s2r cams w/ buschur head
  180. GSC S3 and stock motor?
  181. Another ACT clutch question
  182. TOB issue to extreme
  183. EVO Torque sequence
  184. compressor surge?????
  185. How much power will i make?!
  186. cel question
  187. Downpipe/O2 opinions- Titek vs Tomei
  188. Guys help me ID this cams before I install them!
  189. How to build a 4G64 for an EVO 8/9
  190. AWD debunked and no better than FWD..
  191. Precision in/out V-band clamps
  192. Evo Rocker Arms - What's the deal?
  193. Shep Trans Tranny fluid
  194. Help me pick a 2.3
  195. Do I need to get tuned?
  196. Stock springs and retainers
  197. Overboost with open wastegate
  198. Energy Suspension master kit question
  199. 2.1 build, need advise!
  200. PPI extreme port vs oem manifold pics
  201. Cam help??
  202. Cold start, car tend to move itself
  203. setting up a magnus V-5
  204. Where is this sound coming from?
  205. Troubleshooting: Dead, sticking, soft Clutch Pedal
  206. Stm square catch can
  207. Act Clutch
  208. CBRD BIG O2 housing/downpipe vs Map recirc wastegate eliminator
  209. What are my options for a center diff
  210. Spraying intercooler with any fluids to cool down
  211. J Pipe Question
  212. Need some advice on my situation.
  213. Curt Brown Intake Manifold Pics
  214. Arp L19 head stud install
  215. Quality vacuum caps needed!
  216. 8mr qauife front diff install question
  217. EVO IX Turbo...Convert to Ball Bearing.
  218. New clutch, Car jerky, Need quick fix
  219. HELP! My o2 sensor is wrecking my tune or something.
  220. 2.4 headgasket question
  221. 10.0afr @ cruise PLEASE HELP
  222. No good...
  223. Whoops...how do i fix this? Fuel Pump GURUS help!
  224. Springs and retainers
  225. Axle Rebuild Anyone
  226. Koyo 1/2 radiator reviews?
  227. gt3076r vs hta3076r
  228. Noob clutch break in ?
  229. Throwing around 2.4L options
  230. MIVEC broken, where to start?
  231. Ams race core bumper cut?
  232. what oils to run: First startup *break-in*
  233. Needing Feed back on knock sensor question
  234. Correct headgasket for 2.4 Mivec, 650-800whp
  235. New shortblock/ what mileage do you...
  236. TD06SL2-20G evo 8 fitment?
  237. Blue Printed Transmission W5M51
  238. head gasket
  239. XEDE = Obsolete?
  240. Someone please help w/ lsd question!!
  241. Have questions for us?
  242. Name that part!
  243. What bearings?
  244. Optimal NLTS limit
  245. Turbo opinions please
  246. tranny/tcase
  247. Boost help.
  248. MAF to SD Conversion Advise Required
  249. fuel pump ?
  250. Evo 9 wastegate actuator?
