PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. shep tranny..exedy clutch help
  2. C6 ZO6 vs FP RED?
  3. Defi / AEM UEGO
  4. Do i have to use Platinum Plugs????
  5. Valve Springs Choices!!
  6. Cobb turbo back, Good or Bad?
  7. My Thoughts on Short Shifters and Gear Grind
  8. 6 Speed Evo 9 Drain and Fill plugs
  9. Fp Green hot side options
  10. I want cams that sound like this...
  11. New Tomei ARMS turbo kit
  12. A few parts..
  13. Edelbrock 75mm TB with Ford IAC questions
  14. help with new exhaust!!
  15. Loud bang big problems
  16. springs and retainer help?
  17. throttle bodies
  18. Wilson Manifolds Billet Runner intake manifold
  19. MBC install gone wrong?!
  20. Drop in Pistons+Rods: BS Removal?
  21. Rattling MIVEC - Help!
  22. how to Confirm Clutch wear/replacement
  23. Coolant temp problem. :(
  24. Turbo compressor wheel question
  25. Transmission concern
  26. 4G64 w/ MIVEC Head, What head gasket?
  27. How can I improve my Evo 9 gas mileage?
  28. Need a hobbs switch?
  29. Drop in Pistons+Rods: BS Removal?
  30. Worth Going HTA?
  31. Trany problem please help
  32. spitting grey smoke....help!!!
  33. Is my boost guage inaccurate?
  34. Video: Dsm/evo shootout..
  35. Antifreeze...
  36. AWD Motorsports FP Red Evo IX on Pump.. 446hp!!
  37. Need Help!!!
  38. Part install questions
  39. Part install questions
  40. car wont go in gear
  41. Power steering fluid question
  42. Found a little suprise while doing a clutch job...
  43. Info for Clutch install/replacement for 9MR
  44. greddy ti silencer
  45. 496hp on 93 octane pump fuel and ??? with VP C-16...
  46. problems shifting in to reverse.
  47. Cam/idle Question
  48. Twinscroll + HTA
  49. Labor hrs for Head studs, Cams, & Spring/Retainer Install
  50. 35r with HKS racing suction intake
  51. A few questions about driving with a bad o2 sensor
  52. tubular manifold
  53. removing egr and other junk.... need some help
  54. Installed BR 65mm t-body, ported IM, and EGR blockoff... now some ??'s
  55. a few questions about high boost on stock turbo
  56. 20g on an Evo 8!?
  57. need help
  58. Water in engine
  59. Vendor with the best price on Exedy twin hd
  60. Is it possible to dyno my evo fwd only?
  61. Desperately need help
  62. HTA35r Dyno Results: 635hp 545trq pump w/ meth
  63. Rough Idle
  64. Just installed my HKS Camshaft and Cam Gears... Need help
  65. Balance shaft
  66. Switched to Amsoil
  67. which springs and retainers? revolver cams
  68. MBC Problem
  69. stock exhaust manifold???
  70. how to make your ix spd smooth?
  71. egr cel problem
  72. boost leak at fuel injector
  73. Water Return Hose Leaking !
  74. How bad is this??
  75. Stock Sport Meter Kit Question
  76. Perrin high flow cat - Don't waste your money
  77. Cams for Stock Turbo EVO 9
  78. What Manifold 02 and DP??
  79. Just curious where my car stands with its power?
  80. cam degree
  81. Rattle from Megan DP
  82. Spark plug condition
  83. Can anyone identify this J-pipe?
  84. Profec B Spec II setting question
  85. couple intake ideas, need input.
  86. Whining Noise only in 1st goes away when clutch engaged.
  87. Megan DP
  88. Car wont start
  89. Oil report
  90. Engine pull thread or write up?
  91. 6 speed motor/5 speed motor differences?
  92. Does the 04 RS have a center diff???
  93. Apexi RX-6 Turbo Manifold
  94. Help, Ackward popping/clunking noise
  95. HELP. Wont go passed 1500rpms
  96. help car cutting out!
  97. cv joint going out?
  98. Strange miss at idle when fans kick on
  99. noise coming from front driver side axle???
  100. Drivetrain Problems...
  101. Slowboy t3 flange ss manifold, does it work?
  102. Evo GREEN for $625!
  103. Max psi using Greddy profec B spec 2 boost controller?
  104. new fujita intercooler kit?
  105. to port or not to port my FP green
  106. Who thinks this would be the ultimate cam test?
  107. 2g dsm crank same as ours?
  108. Oil Pan Removal Question
  109. to port or not to port my FP green
  110. cams decisions decisions
  111. evo 9 turbo
  112. Change 6 speed gearbox to 5 speed?
  113. Who can make a recirculated dump pipe for 38mm Wstgt?Best price
  114. Who's Manifold??
  115. Putting a T61 turbo on the Evo
  116. Cutting honeycomb out of stock MAF???
  117. Bad Clutch. Help.
  118. fp green
  119. Wastegate Adjustment
  120. Forged Wastegate VS FP Wastegate
  121. just did timing belt, vibration
  122. IX Turbo Installed on VIII Impressions...
  123. Whining, but definitely not the usual TC whine
  124. EVO 9 turbo issue
  125. valvoline 75w-90 gear oil?
  126. swap front lsd into 03 evo 8 trans??
  127. Tell me about your Stock turbo setups (also green and red setups)
  128. Noobie question........ what is a Knock?
  129. Looking for a fitting
  130. Witch size block for hta37
  131. ACD fluid
  132. clutch install help please, fast!
  133. Overheating some help please
  134. driveshaft
  135. Exedy Triple Disk Picutures
  136. BF 272 Cam Specs
  137. Shop/ tranny work
  138. Evo 8 Compression Test
  139. Thoughts on buying used turbos?
  140. 30k service?
  141. What's the best valves $$ can buy?
  142. Car moving at neutral gear position
  143. tranny problem help....
  144. Spark Blow out.
  145. What exhaust is this?
  146. is that safe?????
  147. Clutch engagement changing randomly
  148. TD06 / T67- 25G review
  149. TM works Individual Coil Pack
  150. HELP!!!! Code p0069
  151. Evo IX cams: Kelford 272 vs. Cosworth M2
  152. ACT clutch slipping? (videos inside)
  153. False knock, stock ecu, built motor
  154. How to tell TME 6.5 Turbo?
  155. Video/Sound clip request of HKS SSQV reric
  156. Help w/ motor issue
  157. can't boost over 28psi help help
  158. Fp Green Vs 3076 Kit
  159. small filter robbing power?
  160. Turbo doesn't spool high anymore
  161. How should I break in my engine?!
  162. HKS EVC 6....english manual?
  163. how to get 30lbs out stock turbo
  164. ? for those who have removed the OEM EVO 8 intake manifold...
  165. Valve Cover
  166. reverse block
  167. which cams hks 272 or gsc s1
  168. xtd clutch???
  169. A good 91oct setup for my IX MR
  170. Do I have my bov on backwards?
  171. Took throttle body off and i think the TPS out of adustment
  172. O2 Sensor answer!
  173. Need Help from Mitsubishi Technician Please!
  174. Motor work?
  175. Buying used injectors... Good or bad?
  176. Evo8 And Evo9 turbo Difference?
  177. JDM ALS valve
  178. Where is the rear o2 sensor on a 2003 Evo 8 located?
  179. All-New Precision Billet 3562R!
  180. evo 8 exhaust help
  181. Many "maps" in Evo9
  182. new to the evo world
  183. Anyone know if Avid billet mounts are lighter than stock?
  184. best way to get another 50 whp for price
  185. Which Trans Fluid?
  186. Lose of Power after 4500 RPM 350HP Peak
  187. 6spd tranny
  188. transmission
  189. 03 evo still getting p0300 code
  190. Evo 9 w/an evo 8 turbo
  191. air filter
  192. rpm's stay high during clutch in/neutral
  193. Manifold question...
  194. intake recirculating bov plug
  195. clutch break-in
  196. shaft vibration help
  197. Clutch Problem
  198. Tubular Manifold Question
  199. Green vs. Red
  200. Problem installing Buschur under hood shifter bushings
  201. cosworth m3 cams
  202. Stevo8's most recent build.
  203. rev ,question
  204. DSM/EVO Shootout Video !!!
  205. help to get bare block
  206. Wiseco pistons in 2.3 stroker
  207. Stock Cat
  208. Cams for a 9?
  209. evo 8 with fp green alchy boost tapering???
  210. strange noises
  211. Engine stuttered on hwy, then CEL.
  212. ACD Issue? Please Help!
  213. **ams Engineering Update** Wet Sump Oil Pan
  214. Water to Air Intercooler
  215. Works O2 or Titek O2 housing?
  216. Anyone Running FP RED YET?
  217. Exedy Twin Vs Quartermaster Twin Vs Fidanza 3.2
  218. GT 4088R - Set up (advice)
  219. Single vs Dual Valve Springs/Valvetrain wear
  220. What clutch to buy??
  221. FP Red Question???
  222. HELP! something went BOOM
  223. clutch choices, decisions decisions.
  224. compression problems??
  225. Mellon Tuning/RaceVideoForums coverage of the 2008 Buschur Evo DSM shootout
  226. Exhaust heat shield replacement bolt?
  227. Powerflex insert vs. Agency Power full billet side motor mount
  228. Test pipe or High flow cat...what are you running?
  229. AMS 2.3rr and Cosworth 2.2 short block
  230. Cam/valve cover questions
  231. Replacement O2 Sensor
  232. Is there any exhaust out there that is quieter than stock and still free flowing?
  233. Help me find my boost problem (vid inside) HELP
  234. AC took a dive...HELP
  235. Where to find a starter?...
  236. any reviews/opinions on this fuel pump
  237. Should I get headstuds or can I wait?
  238. Where did you get your Walbro?
  239. Install my 02 dump this weekend.....
  240. is it safe to run untuned?
  241. Apexi Power Fc D Jetro intake manifold question
  242. diaqueen on other cars?
  243. What's wrong with my car? PLEASE HELP
  244. Need Help Please!
  245. Spot for one more gauge
  246. Battery getting ready to die?
  247. Oil Cooler Thermostat.
  248. would that can cause any damage?
  249. boosting too high?
  250. Smooth shifting?
