- haha who wants to hear something funny???
- Hi-flo Cats directional or no?
- Boosting too low
- anyone with the new megan racing manifold?
- Boost level problem
- Boost taper
- Boost readings all over the board.....
- Dyno'd The Evo for the first time
- 600+whp, Road Racer ?
- Problem with nology / new spark plugs
- Need advice finishing Buschur Stage 4/BR440 setup
- MR Transfer Case.
- HELP:T-case Replaced, Now Rough Shifting??
- Buschur Stage 1
- Retainer/valve spring group buy lost two people...
- Where can I find Magnacore Wires
- Tbar clamps for stock IC piping
- rnr Turbo kit question
- JDM EVO VII titanium turbo upgrade?
- miss with H2O/Alcohol Injection
- EVO Clutch Review in Turbo Magizine
- Buschur Stg4 + Methanol (dynosheets)
- AEM Intake and Turbosmart BOV
- Greddy Profec B spec II Questions....
- Apexi n1 VS Greddy Ti
- New Headgasket prep process?
- Lets Talk Flywheels
- EBC can't hold boost!?
- cali people help.
- Helix Downpipe Question
- HELP HELP removing t case Evo 8
- Help! Asap
- My "Performance Coatings" DNP manifold
- Oil return line on BB turbo...
- NEW FMIC Questions
- Would anyone be interested in a shift lever extension?
- Pic of Evo 8 rods
- Max boost on stock turbo w/race gas
- ok seriously...what's the deal with lightened pulleys?
- The official removing emissions thread...
- quest for 350whp?
- Clutch job how much did U pay?
- is this fuel cut?
- More Boost Spike Talk
- Question regarding Oil Temp/Pressure install.
- Nitrous
- MY poor poor clutch is it time ? =/ hep meh
- Plug-n-Play O2 sim ???
- Buddy Club 264/272 Cams
- Where to buy Polished Unorthodox Racing Intercooler piping???
- ACT street disc is on back order
- GSC Power Division Cams - Installed and turning!!
- Where can I buy an EGR blockoff plate?
- Evo 6speed trany recall in uk
- Has anyone upgraded their fuel lines?
- Boost spike with Profec B-Spec - Broke?
- How much oil in the turbo return line.
- dynoflash question
- would u thermo wrap?
- Poll: AEM EMS users: Do you use EMS boost control?
- TME install questions
- Evo VIII Drivetrain Diagram...
- Building up engine so I took some pictures of the process...
- Mandrel bent tubing for intakes, etc.
- 05 ECU Flashed in Illinois?
- Magnecor Spark Plug Wires
- Ported Stock o2 housing--VS--Helix o2 housing
- What Mod(s) Next?
- Evo 8 driveline issue
- APS blow off valve
- Flaw in Alcohol Kits?
- Evomoto Cam Install Tutorial?
- Royal Purple SAE 90
- Planning some upgrades, advices and opinions needed
- Flywheels...
- Ok big turbo guys..I want some advise
- (10w30) motor oil comparison
- carbon deposits on pistons & valves
- Forge Valve help...
- Mines parts?
- EVO 8 Transmission rebuild questions
- Who's installed rod bolts?
- Oil TemP Gauge and Greddy oil block adapter
- where can I get the a power steering belt?URGENT!!
- ATP Stage 3 Turbo kit for EVO 8
- Poll: PO300 code. ignore it and drive or get a new car?
- EVO 8 MR downpipes
- Dynoflash with Works cams
- happy with G-Tech Pro RR?
- Ultimate Racing Exhaust
- TPR Magazine Evo MR Downpipes Shootout!!!
- How do I get 25psi on the stock ecu?!?
- EVO internals.
- best high temp coating option for turbo manifold?
- alky vs race gas
- I've got a Greddy Profec B should i keep it
- Kemco ocatne 130
- 5th gear grind, Tranny clunking
- Smelling clutch during shifts
- to anyone who has changed lower IC pipe
- Who makes/supplies final gears?
- how much whp gain on mbc only
- Arp Head Studs
- khs carbon ti exhaust
- my transmission feels hard to shift
- Indentify this broken part for me.
- HKS 280 deg. Evo dynoed @ 335 hp / 344 tq.
- Simple Question (Walboro)
- Cam Install Help!!!
- LPI turboback
- stock turbo in to ball bearing/titanium blade?
- evo4 rear diffs
- Just got Back from the Dyno
- Tunning decision which and why ?
- What are all these turbos?
- 393 hp, 406 tq, stock turbo, stock ecu
- HKS 264s making noise?
- Anyone running revolver cams with valvetrain?
- 1G BOV and venting
- GT35R - Happy or not?
- 3 part tranny question
- Is this a sign of Knocking? Latest Data logged from PocketLogger
- Idling oil pressure
- Fidanza Cam gear question
- 3071r,3037r,3076r, and gt35r dyno graphs!!!
- Autometer Guage Problems - Customer Support
- By the numbers: Max boost levels w/ ARP head studs 91 oct, 100, etc.
- would you get alcohol injection?
- Transfer case question (and problems)
- Downpipes for the Evo MR
- adding TBE affect gas mileage?
- Which gauge is more important, fuel or oil pressure?
- Dry Sump System Is Needed Evo Vi
- Pix of Team D Motorsports built MR on Injen.com
- changed tranny, whine still there?
- My evo grinds in 2nd gear somtimes...
- Whistle/Howlign from FMIC
- Downpipe?
- Anyone use NEO 10w30 motor oil
- Fuel pump require new injectors?
- thinking bout gettin cams should i do it all?
- Power Trip
- HKS billet Crank english instructions
- head swap -- how difficult?
- would this 35r fit?
- Oil coming out from exhaust manifold?? (HELP!!!)
- Any Evo owners using a "Turbo Scrambler"...?
- HKS 280 Cam video (idle)
- New Stock Turbo Record !!!!! 407hp 427tq!!!! update! 418 and 439 now
- Dyno Tested HKS 280's W/graph
- Question on separating TC from Tranny
- Just bought an Intercooler
- Act Clutch but says exedy?
- 20G Owners???
- Building Motor
- LPI catback exhaust
- Does anybody know anything about South FL Performance Turbo Kits?
- stock bottom record?
- Clutch for MR
- O2 housing porting?
- Where to order gear oil pump from
- EIDS making idle worse!
- anyone boosting 22 psi or higher on stock turbo?
- RnR Slip Fit Exhaust questions
- Help on EGT install
- Do I need to upgrade fuel pump if full exhaustm, injen intake?
- I think we all should get an Oil catch can.
- Intercooler upgrade Q's
- RnR Carbon Ti Sound Clip?
- Leak at the exhaust manifold...?
- Can I use a mini battery?
- Nos
- How's the Helix IC pipe kit???
- T-Sports Flat Shift
- Does anyone know?....
- NEED Pistons (Wiseco..CP)
- Evo8 engine and drive train q's(not a neb)
- RS04 TC compare to GSR TC
- MBC equpped: 5th gear WOT sputter
- Exhaust Manifold
- serpentine belt
- Anyone done a piston/rod swap? How much?
- 05 TC i think for my 03?
- Helix DP touching oil pan?
- Sun Automobile Cyberspeed Hyperground And Hypervoltage
- Bushur Turbo
- Dyno'd HKS 264's w/ graph
- 412tq & 395hp STOCK Turbo and Intercooler
- magnacore wires
- Has anyone used Toda cam gears?
- ECU Error code
- Well im having some problems deciding...need help.
- sell hks catback?
- Hallman MBC dropping 1-2 psi near redline, normal?
- Fidanza or HKS cam gears?
- BR 3" Downpipe (help please)
- 2.4L stroket kit labor work
- Stroker kit parts.
- 05 GSR & RS owners Please help.
- TOMEI and G-FORCE
- catalytic converter
- Where to look for a new sequential gearbox ?
- Check out my engine bay
- My Evo is Stalling...Please Help!!!!!
- need clutch setup help
- BAD Front Differential
- Stock Boost Spiking
- Magnus intake manifold question...
- buschur or ultimate racing tbe?
- Exedy twin metalic convertable to carbon?
- HKS SSQ BOV Adjustment???
- Transfer case gone, replace clutch?
- weapon r engine tampener
- Buschur "Evo8 Camshaft Install Timing Belt Kit"???
- Someone help ..is this a major problem whats wrong??
- Upgraded Throttle Body...
- Is This Clutch Any Better
- BR Stage 2 Shots
- odd, no boost taper, car is stock
- LICP diameter
- why doesn't my car start??!!
- Where Do I drill my CF Heatshield PICS included
- Buschur Standard IC Installed
- Running off of front wheels only
- Help with AEM UEGO Wideband Gauge
- Need tach signal wire for JDM Evo 8
- Why is my clutch slipping?
- just installed a 10.5 hotside on my 04.
- MBC Question
- Turbotimer F'ing up coilpacks?
- Where to buy code reader?
- HKS Hi-Power
- ACT MB7-HDSS Street clutch or stock clutch?
- How dangerous is this?
- 1G DSM BOV & 1G Forge BOV
- clutch and warrenty is it worth it?
- Need your opinion ACT Clutch
- Going soup to nutz on my Evo8 - heavy on the nutz!
- hit fuel cut???
- which is the best turbo back
- Car pullin while in nuetral?
- Buschur Racing Axle Back (Sound Clip)
- normal operating temp on EGT guage?
- Coolant problem....help!
- T bolt clamp measurements for IC piping?
- Having Problems After Walbro Fuel pump installed
- Manual boost controller problem
- ? about turbo xs intercooler
- HKS GD Max Question
- Perrin Short Throw Shifter
