PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Can it be done? Using 2 more stock coils so theres a total of 4?
  2. newb question
  3. Another problem, for a broke college student...
  4. Dual fuel pump wiring question
  5. Boost leak at intake manifold
  6. spark plug gap spec and procedure question!
  7. Differential combination
  8. Brand New Clutch Sticking?!?!?!?! HELP
  9. MAGNUS Stroker kit feedback needed.
  10. evo 8 to evo 9 maf
  11. gt35r vs 6265 (help)
  12. Quaife or Wavetrac?
  13. EPM o2 dump installed. what next?
  14. Clutch or trans mount vibration
  15. Help ideintify these rods
  16. p0401 code issue advice
  17. help my clutch wont come back up......
  18. Cosworth dual valve springs/retainers
  19. evo9 motor problem
  20. Can anybody tell me what this is and how to call it??
  21. After stroking my Engine
  22. What fuel pressure regulator to get
  23. stock evo throttle body size
  24. Over Bore
  25. 2nd gear grind (I searched)
  26. Difference in 03-05 coil packs and 04-06 ??
  27. Norris Designs - Supercharged & Turbocharged kit!
  28. Full-Race TS35r - whats the answer??
  29. De stroking 4G64 to 2.2 or 2.3 LT
  30. FIC 2150cc?
  31. how do i bleed my clutch?
  32. what do 880cc injectors max out at??
  33. why no Garret ff kits?
  34. missing at idle and wants to die when heater or ac is turned on
  35. Turning boost down?
  36. Alternator help
  37. arp head studs torque
  38. Catch Can Locations
  39. IX MR drain plug question
  40. Buschur Racing SD Turboback
  41. Idleing issue
  42. Need help oil leak from block/head
  43. recirculated valve=crazy buckle+leak?
  44. just rebuilt and cant get it to start. help!
  45. Are Evo 8/9 diffs the same?
  46. stock connecting rod questions
  47. Acd fluid leaking through axle seal?!?!
  48. "low speed" radiator fan system not working
  49. Boost/turbo problem please help
  50. hks t04z vs pt6262
  51. what next
  52. evo 8 external dump
  53. Rattling & Increased Exhaust Noise After 60K Maint - Included Timing Belt Change
  54. 2.5" VS 3" IC piping
  55. list of Problems. HELP!
  56. Dump tube broke from wastegate
  57. Forced Performance Turbos - Compressor Cover Leak Notice
  58. Hows Does Evo 9 Mivec work?
  59. Picture of the transmission internals
  60. 1st gear part number
  61. Came up with a quick fix for SSQV users
  62. Spark plugs
  63. JDM MR DV on Gruppe-S for $300?
  64. Will a 35R bolt to the stock manifold??
  65. Question...
  66. Questions about the 4088r
  67. Time to change spark plugs... AGAIN?
  68. Can spark plugs cause knock?
  69. What do you think, 2.2 + FP Green HTA
  70. Best tubular manifold...
  71. any opinions on the atp gt35r/.82ar kit..
  72. 4G63T - Titanium internals available?
  73. Raising the rev limiter...???
  74. Clutch or something BROKE!!!
  75. excessive amount of smoke from exhaust
  76. CAR blowing white smoke
  77. Helping~~~!! hard to shift after changing the clutch and fixing the transmission leak
  78. Stock injectors?
  79. IX bov w/ a 35r?
  80. FP Red external dump o2 housing vs recirculating
  81. Castrol Edge vs Mobil 1
  82. Clutch problem!!
  83. boost leak question
  84. New setup to beat my brothers 08' ZO6
  85. MY current setup...what would you change?
  86. DIY Idea: Making a LICP bracket for those without one...
  87. will be safe to still boosting the car without a tune??
  88. Turbo with 91 octane
  89. New HTA 35 R- SV Turbo From Owen Development
  90. car Start,Idle, Dies!
  91. Best Comp Ratio for 2.4l
  92. Honda OEM filter on EVO?
  93. ACT 6 Puck Sprung vs Exdey Twin Disk
  94. help! cant get it to start
  95. Balance shaft delete and low load knock?
  96. Difference between Buschur Deluxe and Street Core
  97. fidanza cam gears!!!wtf?
  98. Evo 8 with ACT HDSS clutch
  99. Evo 8 Turbo life?
  100. exhaust noise
  101. nisei licp installed
  102. GSC S1 cam on Evo 7
  103. What's changed from stock (pic)
  104. '05 RS ACD TCase same as IX ACD Tcase?
  105. Lots of oil in my coolant......
  106. How many miles last your triple clutch???
  107. Best rods for street car/weekend warrior?
  108. Rear wheel bearing part# and replacement ?
  109. carbonetics twin clutch?'s
  110. DA-31 Fuel Pump
  111. Max Boost AMS GT35r?
  112. Tranny question
  113. ACD pump rebuilding
  114. Amsoil Users...
  115. Spark plug issues and help on EVO 8
  116. Any dyno testing on ported i/m and ex mani?
  117. oil pressure sending unit
  118. POLL: FP Red or BBK
  119. What Clutch are you running(no twin disks)
  120. Motorsports Shifter????? for my evo.
  121. porting head
  122. Can't shift into any gear
  123. major power loss (maybe drivetrain related)
  124. Boost leak effect wastegate? CEL : P0243
  125. fp black on pump vs fp red on pump
  126. rebuild
  127. Ported shroud housing.. is it needed on a 2.4lt??
  128. atp housing
  129. Front diff went out...possibly tc as well?
  130. HKS hypower exhaust
  131. Super Stiff Shifting
  132. Greddy EBC will not control boost
  133. I want a bigger turbo
  134. Which clutch to pick?
  135. crank dampner wobbling
  136. Lug nuts that fit both wheels
  137. best location for external wastegate?
  138. Starting trouble !!! Pls. help
  139. Big clutch and thrust problem,HELP
  140. Something let go tonight! Need help!
  141. My custom catch tank with pcv breather (photos)
  142. 2.1 motor w Aluminum rods Drag and DD. How many miles you have now?
  143. 4g64 flywheel bolt issue
  144. Evo Engine Tick Help. watch sound clip
  145. evo 9 FP red/other turbos or ETS 50 trim turbo kit
  146. Transfercase leaking?
  147. AMS F1 vs Magnus V5
  148. Possible to drill/tap thermostat housing?
  149. question about stock turbo 9
  150. ECU Harness Replacement Questions
  151. 4g64 boys chime in!!!!
  152. Is this even possible?
  153. Quick question for you guys
  154. Low oil pressure? Bad pump or bad bearings.
  155. crank sensor
  156. clutch noise
  157. Blaq ops progressive double pumper
  158. TTech 600 bolt-on turbo released
  159. Injectors Needed?
  160. Boost Spikes 0.5 Bar on Off throttle
  161. fuel pressure guage help?
  162. Rattling W/ New Downpipe Install
  163. Help plz , few issues !
  164. Fuel pressure reg mounting position
  165. **Mivec CAMS**
  166. FP Black going on my Dyno Queen
  167. Purpose of 2 Speed Fuel Pump
  168. Any word on FP Black up grade for a Evo 9 turbo??
  169. crankshaft
  170. blown head with head studs possible?
  171. chirping ac belt after replacing old chirping belt with new one
  172. Does anyone have an electric exhaust cut out setup, that does not leak when closed?
  173. Before I pull it apart, is there anything missing?
  174. kelford 280's in a stock motor....
  175. No more blown freeze plugs on water pump
  176. Air Intake / Intercooler Piping Upgrade
  177. Defi EGT probe thread pitch vs. Zeitronix EGT thread pitch
  178. FP red questions
  179. Clutch master twin disc, disc replacement
  180. Garrett Turbo Exhaust Bolts help (looking for safetywire bolts)
  181. which radiator
  182. How much power will my setup make [Mega Merge]
  183. Trans Scraping Noise
  184. Got my FP red in today and.....
  185. Oil leak after clutch install...
  186. CBRD turbo... good spool up?
  187. What wastegate will fit a Greddy T67 25g kit?
  188. Shuddering when turning from a stop
  189. evo 8 vs 9 gearset ratio
  190. My Kelford 272 install
  191. 9/10sec sec Guys w Exedy Twin that converted to Triple...Do you like it?
  192. Forge Splitter BOV vs. APS Dual Vent BOV vs. TurboSmart Dual-Port BOV. Suggestions???
  193. Exedy Twin HD Install Tips?
  194. Recirculating BOV help
  195. Need help.
  196. Transfer Case
  197. HKS DLI troubleshooting
  198. Garrett GTR-X Billet Turbo
  199. hard ass rev limiter?
  200. 28psi on BBK Full without upgraded actuator
  201. clutch help
  202. Where to find longer-than-stock 14mm bolts for lower arm bars?
  203. Early EVO Christmas
  204. Cam Sensor Housing same for the IX? Part # for the intake cam gear for the IX?
  205. sheptrans questions and part questions
  206. Is an intercooler really needed at this point?
  207. Machinists please look here.. flywheel question
  208. My car goes pop pop... breaking up.
  209. 25psi Wastegate on 30psi
  210. MR clutch install/TOB & fork issue
  211. Any experience w blox filter?
  212. Any concern using a Cosworth HG on a STD bore?
  213. OBD2 and EPA off road?
  214. Intake Pipe Question
  215. Insight needed for FP Red
  216. Insight needed for FP Red
  217. Cam timing E6
  218. Which Retainers for the Valve Springs?
  219. help with direction to mod my Evo 9 - Long thread FYI
  220. HKS EVC 6 Problem
  221. Running lean all of a sudden?? How so?
  222. Hard to shift question...
  223. clutch pedal dropping to the floor after EVO sits overnight???
  224. oil pressure sender thread size?
  225. Best 280 cams!?
  226. carbon fiber intercooler piping???
  227. fp-red vs t3 kit
  228. Need HFC to generate 350-400whp without problems.
  229. Precision 880cc Inj. How much whp?
  230. Torn between 4g63 2.3l or 4g64 2.4l
  231. Evo X AYC in an Evo IX
  232. When oil pump leak!
  233. Short shift kit for a 2005 6SPEED MR
  234. hks super sequential
  235. Clutch gone at 16k- Need recommendations
  236. amsoil tranny and t-case
  237. quick trans oil question
  238. Starter Problem. Please Help!!
  239. Alternator help needed!
  240. My quartermaster took a dump
  241. AMS HTA35r Installed!
  242. Removing oil filter housing....
  243. AMS F-1 Manifold
  244. Part throttle miss-stutter-misfire @ 3000 rpm when under almost no load 3rd 4th gear
  245. where to get bullettype comp. wheel nut?
  246. Lower Stock Boost
  247. MAP QuarterMaster twin plate Clutch
  248. Best Clutch for E85/Buschur FS635/2.3L car
  249. Top Mount Setups
  250. Comp surging again
