- Help on setting Apexi AVC-R
- Do your clutch chatters in the morning?
- apex AFC installation??
- SAFCII Wiring
- turbo xs standard boost controller
- troubles tuning emanage with the E-o1
- NY/NJ/CT...I need help ASAP
- hks gd max twin plate clutch
- Upsized Turbo
- Will this battery work?
- Installed Boost Gauge...Now
- autotronic ecus
- Electric vs Mechanical boost gauges...whats the difference??
- Manifold manufacture
- Works Reflash ECU and Vishnu Reflash
- What is the stock boost pressure of the 8
- Do boost controllers come with a replacement solenoid?
- XEDE or HKS EVC V and Apexi SAFC2
- Anyone ever think about putting a WRX boost gauge in your Evo?
- Noise in front endwhile driving
- Random Misfire in Cylinders code
- Can a SAFC read boost pressure?
- tranny making 'eeeeerrrrrr' noice
- Installed MBC, slight problem
- Will JDM Chip work on our US Evo?
- Timing belt tensioner tool ???'s
- dealer put in synthetic blen
- Humidity and temp...
- HKS Downpipe vs. RMR Downpipe
- Turn off that AC!
- Blown Motor
- Help Me Please!!!!!
- Ppl with HKS TT TYPE 0...QUICK HELP!!!
- New Exhaust Manifold
- type-s leak at idle
- Turbo swap - oil change needed?
- evo stock turbo?
- loud ticking at 2500 rpm
- clutch needed
- i rode the clutch
- Help on setting SAFC II
- Evo VIII Rear Spoiler Downforce?
- Evo 8 Aem Intake Installed
- Blue Boost Gauge
- Advice regarding EVO I problems
- How many times...
- EVO engine idle vibration
- problems on my evo
- Options for axle back exhaust
- Has anyone removed the under panel?
- HELP! Blitz DTT Turbo Timer installation instruction needed!!!
- Greddy turbo timer w/o harness
- S-AFC II vs XEDE vs Emanage
- Just had my boost/vac gauge installed....questions
- AMS and RMR compatability
- OOPS! Leaded gas??
- help w/ CEL
- EVO Compression Chamber
- Rigging the water spray to turn on at 80%TPS??
- Evo's been in the shop for 10 + days...
- I smell gas in my oil...
- SAFR about 500 RPMS off...help me
- If I were to buy an evo tomorrow(very possible) what new clutch?
- Getting Ready To Buy an EVO, STi forums scaring me
- Exhaust hitting Nut on rear end
- breakin for new pads and BOV questions
- Best performance set-up...
- Best Boost Controller...
- JUN Auto 272 cams for EVO 8
- Rear diff chatter
- Post when your Clutch took the dump...
- Buscher: Some questions....
- grounding kit supplies for cheap
- hks ssbov
- datalogging options?
- HELP!!! Any suggestions????
- Might be old news, but with the new talk about octane...
- Super Evo Dyno Thread - Post your pulls and discuss!
- installed mbc, hit 26lbs on accident, should i be worried?
- AFC power
- 5Zigen cat-back-anybody have one?
- Clutch Fix!
- Exhaust Sounds Comparison
- Will a T3/04e .63r fit on the evo?
- Gauges and normal readings
- RE: Aftermarket clutches and voided drivetrain warranty
- HELP: Turbo timer install
- greddy type-s bov problems.. fixed, now boosting 20lb to redline?!?
- Anybody loosing coolant?
- Which Exhaust?????
- evo 8 help
- How much power could the stock injectors take??
- Questions for Bushur...
- Constant power wire in radio harness
- Remove fuse to reset ecu?
- need a blow of valve, which one?
- Intercooler pipe coming loose?
- 700cc fuel injectors
- Where to get a high-flow cat?
- Rear Wiper motor burnt out
- Anyone have problems pumping gas?
- lots of mods being installed...
- Strange problem--car didn't move
- AFC tuning?
- problems with evo!
- Octane
- Some pipe is leaking unde the hood! Please help
- Forge Motorsports Recirc Valve
- boost conversion
- Changing engine and gear synthetic oil (neo vs redline)
- 5th Gear Grind
- Profec B Spec 2 Users?
- Drivers door wear
- Boost Gauge Ticking
- Evo fender well STICKY
- Boost gauge pod
- Free H.P.?
- Why is stock fuel pressure 43.5 psi?
- Who makes quality IC hardpiping that doesn't require changing anything else?
- Interfacing stock ECU
- Exhaust Tip Extender For HKS Muffler
- tanabe or magnaflow exhaust
- turbo xs mbc
- anybody changed downpipes
- Rev limiter
- Benefits of IC hardpiping?
- TurboXS-anyone got any inside info?
- Turbo Timer abd Auto Theft?
- EVO Cutting out when wet
- Increasing boost
- Forge Motorsports BOV
- Warranty Service Bulletin WB 2004-004
- weird pedal feel from the wipers
- I'm going with Buschur!!!
- AFC and Modifications
- Installed Custom Exhaust!!!!!!
- Bumper squeak
- Thinkin about installing Vishnu exhaust myself....
- apex power fc for Evo 8
- what kind of times can I expect...
- Rear Diff Fluid Change
- ecu reset
- Climate Control
- 19.5psi boost, psig or psia?
- Pruven Exhaust/RMR Intake
- Titanium Exhaust Recommendations
- What Tranny Fluid do you use?
- seat tech
- Grinding or is it just me?
- cheap exhaust..
- All about CBV's
- Will the Xede allow me to run a vent to atmosphere(bov)
- Octane boosters
- Turbo and injectors smaller on USDM vs JDM
- Driveshaft vibration - Rubbin UR Test pip
- WORKS - 93 flash + 3"UR TB
- evo 8 turbo upgrade
- What A/F ratio do i want??
- Apexi S-AFC2 question
- what clutch to get
- A/C Vent Not Working?
- Will a 3" cat-back fit on the stock cat?
- New TRIAL titanium exhaust
- Stroker Kits
- TT questions
- JDM spec Evo8 stupid newbie questions
- mystery HKS pipe on japanparts.com?
- Ralliart Air Filter ?
- Stock oil cooler size?
- KnockLink installation location
- Helllooooo & Turbo Presure !!!!
- Is the turbo on the Evo water cooled?
- clutch life on evo
- help! weird electrical problem!
- JIC exhaust came off while driving
- Need Power!
- Tranny Fluid?? What is this?
- Exhaust help!
- good reading on turbo charged engines? and direct me a little.
- octane boost
- AEM and Injen intakes.
- Forge BOV/VTA - which spring?
- Switched Back from MBC to Stock Config
- anyone got a Haward & Scott cat back yet?
- Blitz SBC ID question
- Twin Plate Clutch
- Vishnu Dumpback..
- Clutch Masters Stage 3 (installed)
- Intercooler Mist
- Is Vishnu Sig Series exhaust just a...
- how much boost
- Short throw shifter tips/comparison
- Help with axel back
- Loud clicking sound
- Help with coil wires
- New turbo kit and much more.....
- 2nd and 3rd. gear shift clunk?
- New Evo Rider's Questions
- JIC DP vs HKS DP
- Noob q: Removing cover under engine
- Damage to the Honeycomb on the MAF?
- boost problems
- ralliart or excedy clutch?
- Runs rough in a specific band
- best spark plugs
- What exhaust is emissions legal and will NOT trigger the CEL?
- HKS Clutch
- Part throttle, Full boost? Possible without Boost contoller?
- There Is A Recall "wiring Harness Corrosion"
- Car seems like it will stall when pumping gas
- Cat back and down pipe? Factory
- Base HP Vs Vishnu Stage 1
- about to pull the trigger on UR stg 1 +
- O2 dump
- US Evo front lsd
- Noise while turning
- Whats wrong with my EVO!!!!
- Downpipe or catback?
- APEXi or HKS?
- Should I go with a Cusco Twin Disk clutch with flywheel??
- Need Part #
- Evo bung
- Loud Spining Rattling Roise In Neutral
- Clutch care
- clutch restrictor
- factory option boost gauge
- Forge BOV problems fixed: port it!
- Idle
- Just installed Vishnu Stage I
- type S bov mod
- Grinding in 5th
- quest for COLD air (long)
- aftermarket tranny for evo
- Could I run mid-high 11's with just a K&N drop in filter as my intake set-up?
- What does the non-sig series Vishnu exhaust sound like?
- Evo Turbo Information
- Hole thru firewall for boost gauge
- Engine Management for Dummies...
- what clutch should i get?
- Does anyone ever see knock on the SAFC-II?
- Royal Purple - purple ice
- Ques on Sequential BOV's
- boost issue
- Help...Boost spikes
- Retard or Advance Timing?
- Exhaust Setup
- check transmission
- I have a clamped hose?
- Is this normal?
- Nitrous Express Front Mount Intercooler Chiller Kit
