PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. How do I get a bbk full turbo?
  2. 9.8 vs 10.5
  3. Turbo Rebuilders?
  4. help with hardwiring walbro
  5. timing belt ?
  6. Part Throttle Issues. Any help?
  7. Car running lean.
  8. Intake pipe, JM fab or Samco
  9. evo9 block with evo8 head
  10. Synchronic BOV Install
  11. Wheel bearing replacement?
  12. Stock '03 is going to AMS for a dyno tune.. Did I forget any of the bang4buck mods?..
  13. Exhaust Leak in the Head? HELP
  14. Speed sensor, bad idle???
  15. Best Tuner Shop in ARIZONA?
  16. Evo 8 Longblock Weight..
  17. FP give info on the new HTA green, we pump people need it
  18. What companies make intake manifold gaskets?
  19. Evo IX trans manual
  20. need radiator
  21. strange noise....helpppp
  22. how to tell
  23. 3'' HKS hi power exhaust
  24. 1,2,3, and 4th gear synchro's and sliders...is that supposed to look like that?
  25. Subframe studs broke?
  26. Engine build finally complete, yeah.
  27. Wheel bearing or front axle?
  28. how to tighten timing belt tensioner pulley?
  29. Full-Race Twinscroll 35R + AMS 2.3L + GBR Race Team Build = FAT powerband
  30. Car dying with new walbro 255
  31. Clutch rattles on Deceleration?
  32. What kind of gains?
  33. Head work
  34. Reason for the new FP oil line for EVO's
  35. Cam upgrade
  36. First time replacing clutch...
  37. whats wrong with my evo?
  38. need help fast
  39. Control Module for ACD
  40. tcase fluid change help
  41. Trouble bleeding clutch
  42. Quaife ABT Differential Front
  43. Coolant flow rate for Evo VIII/IX turbo?
  44. Best way to access bottom of condenser fan - Help!
  45. Project Buschur double Magnaflow Quiet Exhaust
  46. Resonator
  47. dc sports downpipe questions
  48. lagging? or what
  49. trying to find out what cams??
  50. modded evo no start at times
  51. evo 6 speed and gt3240?
  52. K&n drop in or cone filter ??????
  53. Building the CT9A 4g63 Evo Engine by TTP-Engineering
  54. Evo 9 6 speed??
  55. cuttin out
  56. 02 housing which one for 06 mr ?
  57. ignition wont unlock
  58. mystery problem! help diagnose
  59. advice needed: something dropped in valve port
  60. whp number questions after a tune on 05 rs
  61. AMS 2.3 Stroker sounds like a desiel...
  62. Fuel system
  63. Anyone have a PTE billet 6765 in stock?
  64. P0300 on my IX - 33k
  65. Can a Timing belt effect compression?
  66. Building a better/mongrel turbo at guv-ment cheese prices...
  67. OEM Pins
  68. What the heck is this pipe?
  69. What are these parts? Removed from 06 IX
  70. 8 turbo to 9 turbo HELP!!!
  71. Milky Oil in Catch Can
  72. iac troubleshooting in my idle freak evo
  73. Car running on 3 cilinders, urgent help please
  74. ACT 6 Puck?
  75. Will a MAF from a 96 3000GT VR4 work on an EVO IX
  76. Exhaust Manifold XS Power VS. Megan???
  77. Can the EPM O2 Housing fit with the ETS V2 LICP??
  78. Strange Tranny Noise after Clutch Install
  79. Catch Can Help
  80. Loose Injectors
  81. Lower vacuum after switching to a different BOV?
  82. How reliable is the 2.3 vs a 2.0
  83. It does this?
  84. best turbo
  85. Urgent: Car dies when clutch is engaged
  86. Defi boost gauge in IX MR - question
  87. Will the HKS suction intake fit 3" or 4" turbo inlets?
  88. any good shops in CHI area
  89. anyone making power on a stock catalytic converter
  90. Serpentine Belt Tensioning: How?
  91. Clutch chatter more so now then before
  92. BBK Owners: Anyone running an upgraded WGA?
  93. Hks mbc?
  94. Robert @ Forced Performance
  95. Help vacuum problem
  96. Max boost for AVC-R
  97. Thermostat question
  98. Opinion on a flywheel
  99. question about oem tranny, tcase, rear diff fluid
  100. SPEC Twin Clutch for 2003s?
  101. Whoops! (Timing Belt)
  102. oh my CAT!
  103. "Upgrade" from Injen LICP
  104. Is the Mini battery strong enough in the Northern States?
  105. ACT pressure plate help
  106. Outlet Pipe
  107. TCASE pulled for the 3rd time, all seals replaced..STILL LEAKING....WTF!! (PICS)
  108. ETS front mount intercooler
  109. turbotrix busts out an 8
  110. CBRD radiator with slim fan owners, question about fan wires
  111. AMS 4G63 Race Balance Shaft Eliminator Kit
  112. 7 RS front LSD?
  113. OMG My engine!?
  114. ACT, you suck
  115. cracked exhaust manifold
  116. New Radiator being built: NEED Aeroquip, Goodyear Radiator hoses....where can I buy??
  117. FP 25psi Wastegate, Spike?
  118. innovative lc-1 help plz~!
  119. HTA3076R installed... can I safetly boost to 13psi?
  120. boomba inline manual boost controller
  121. Does anyone have an ARC oil catch can installed in their car? Please help.
  122. Spark Plug Ceramic Broke Off
  123. HELP! fuel pressure sensor leaking
  124. Boost spike after turbo, TBE and O2 Housing?
  125. Oil treatments??
  126. K&n intake or drope in not sure which?
  127. HKS twin plate clutch
  128. Greddy type S BOV top nipple
  129. Help, over oiled K&N air filter!
  130. Evo 3, Cracked Ring Lands - Need Pistons
  131. idle
  132. brian crower springs and retainers
  133. Rattling coming from my engine
  134. I'm getting tire of my evo......
  135. brakes when you have aftermarket cams?
  136. Funky smell after replacing wedge clip??
  137. What Tranney Fluid do you use?
  138. Starter go bad?
  139. For same price - AMS 3.6" vs ETS 4.0" IC
  140. Tuned stock MAF pipe vs Tuned 3" MAF pipe?
  141. ACD Problem!
  142. Will myu running HKS 280s on my 05 EVO VIII cause a CEL on the stock ECU?
  143. Can anyone reach TRE for me?
  144. To wrap or not to wrap?
  145. Stock Rear o2 Sensor. WHERE DOES IT GO
  146. Stalling turbo
  147. Coolant temp gauge?? goin crazy
  148. Pinout on harness that connects to the fuel pump
  149. whats are these for? (relays?)
  150. Signifigance of 15psi stock 8 turbo?
  151. Phelonic Thermal Intake Gasket??
  152. Boost / throttle problem
  153. oil pump walked in housing
  154. VIII going to green
  155. rear diff going bad?
  156. snapped a headstud...
  157. Where are the AMSoil dealers?
  158. Looking for Wavy Rings/Washers for Exedy twin mod, anyone have them?
  159. evo 8 bellhousing bolt pattern?
  160. I need an o2 housing
  161. Managing boost pressure -- issues and options
  162. what do i need to do to fit a evo 8 turbo onto my 95 gsx?
  163. Help finding partnr on seal.
  164. Clutch failure , act MB7-XTG6
  165. Turbo gasket question. help, quick question
  166. injectors
  167. boost leak test questions
  168. Fuel Guage ??
  169. Help with wiring in a evo 8
  170. Rear diff noise
  171. Timing belt rubs on the crank sensor blade?
  172. rpm's reving in gear
  173. removing stock turbo manifold?
  174. Ebay Intercoolers and piping
  175. upper I/C pipe P!$$!n6 me off!!!!
  176. mystery: drivetrain vibration! suggestions?
  177. Evo IX Idle Issues, Overseas HELP!
  178. What would you guys do?
  179. HKS 272 and 280 Exhaust cam lift
  180. Denso fuel Injectors leaking
  181. Professional and experience input needed. FPred vs. 50-trim.
  182. Knock Sensor Location ?
  183. No power to fuel pump and I think the rel
  184. MDC Install
  185. Hallman MBC doesnt hold?
  186. weird noise at 4500 rpm
  187. Timing issues
  188. gaskets?
  189. tanny problems
  190. only have 10psi anyony know wats wrong
  191. hey guys need advice on cams
  192. TB Idle screw air leak
  193. Crankshaft K1 or OEM ???
  194. turboXS tbe install/ problems with brace
  195. Mod Advice: MAP 38mm MVS O2 Eliminator Downpipe w/FP Red
  196. Help: Melting Catalytic Converters and More!!
  197. Car starting issues. Engine flooding maybe?
  198. Shep trans/ F 4.3
  199. Anyone watch their IAT's?
  200. AMS 1000 HP Fuel System installed and now fuel pump wont turn on, what could it be
  201. EVO OBD-II Code List
  202. Lightest Exhaust
  203. Safe to rebuild Exedy twin HD
  204. oil leak dripping onto downpipe
  205. clutch gets stuck..
  206. Need your help! Please!
  207. Coolant - What Are You Using?
  208. New FMIC worth the money???
  209. If you have a Turbo Kit & A drivers side fan this thread is for you
  210. gt35r t3 or t4
  211. People with Buschur UICP and intercooler. What size T-bolt clamps???
  212. Exedy twin disk issue
  213. FPred tried to eat my honeycomb
  214. Help Question: Evo ACD lights all on. Wheel speed sensor??
  215. Modifed stock intake manifold
  216. Help identify these evo 8 cams!
  217. Help...Forward O2 Sensor removal/replacement
  218. turbo temp
  219. Cel p0137
  220. Service Engine Soon with AEM?
  221. Stock Turbo, Max PSI/Boost?
  222. Anyone using the Dejon Intake tube for Evo
  223. Cam question
  224. Do I need a fuel pump?
  225. camgear question
  226. stutter at wot?
  227. Are the VIII & IX head gaskets the same?
  228. how to read Check Engine Light
  229. Upgrading help
  230. Boost control question.
  231. Profec B spec II High Boost
  232. TOB clicking when clutch ingaged
  233. evo 8 turbo full bolt ons
  234. power steering gone during a curve
  235. Buscher Boost Controler
  236. Converting to Speed Density on stock IX turbo
  237. Simple break down of what comes stock on evo's.
  238. help needed quick
  239. HKS MIVEC 272/272 Cams, but what about 272/280???
  240. what is the iacv do when it accuates???
  241. 20G compressor upgrade
  242. Exedy clutch upgrade or not ????
  243. Help: Dont have Oem Flywheel bolts (What do i use)??
  244. --- FP Green 73HTA ---
  245. AVCR boost memory
  246. megan test pipe/ stock exhaust
  247. New Exedy Twin Pressure Plate design
  248. wut hp on 2.3 stock turbo?
  249. Need help wiring through fire wall.
  250. Lower IC pipe question, NEW one, I think...
