- Can I run open downpipe?
- 4 bolt to 5 bolt turbo hotside difference's?
- exhaust manifold question
- intercooler sprayers
- How long did you ACT last?
- What Clutch Should I Get?
- How far will meth take me on stock injectors?
- Best forge pistons for IX with stock ECU?
- New lightweight parts and safety items on their way...
- FP Green - Which Cam Combo is best suited for this turbo.
- crank walk?
- oil line from valve cover to intake arm.
- Anyone dyno the TITEK o2 housing
- Car sputters when cold?
- Hydraulic vs solid lifters
- Evo 5 CP9A/// What parts are compatible???
- gsc 272/272 vs gsc s1
- Where can I buy those factory style hose insulations?
- Perrin shifter help........
- Grinding issues
- Issue with above 20PSI
- Real quick, 780cc or 880cc for 50 trim/100% meth on stock ECU?
- No boost! help!!!
- Act just isntalled BIG PROBLEM...!!!
- where to get a green from
- something weird..can anyone help?
- Throwing codes after putting stock ECU back in...
- cant figure this out
- Pressure Test
- What Next??
- Green Numbers from today.....Thanks CFT!!
- Syncros
- quick fidanza cam gear question
- looking for cheap fmic and cams 03 evo 8
- Help! Cant get tranny in!
- Advice!!! clutch issue with Exedy twin
- Real Quality......
- 400 whp possible?
- no O2... less turbo? Need help please
- New MEGAN downpipe version just released!
- Cluth pedal vibration at 2500 RPMs
- Hallman MBC or Forge MBC
- Best Clutch.... For about 600 whp.
- ally rods, anyone using them???
- Any news on new Turbos?
- Any1 having issues with Exedy clutch?
- Aps Twin Vent?
- Will this manifold work with a green?
- Clutch adjustment???
- Exedy TD wear question...
- New Evo...NEED HELP
- I just got a "complete" turbo kit, or did?
- Jun Evo 8 Cam Specs???
- Does BR still sell ported 10.5 housings?
- Buddy Club Racing Spec Condenser???
- smoking on idle....
- Bigger Turbo
- What boost are you running on IX's with pump?
- Which vendors use the Garrett Core for their Intercoolers?
- Question
- Engine Compression Thread, what are your numbers?
- Greddy Ti-C exhaust fitting issue???
- Tial bov spring alternative
- Limp Mode
- clutch replacement (to use stock flywheel???)
- boost pressure problem
- S-Max intercoolers ? CO2 internally chilled
- Having problems after ATS Twin CF Cutch install
- Full Built Motors Buschur?
- Help! Gearbox problem!
- Put on catback and MBC!
- Not your typical TT harness question
- a/c compressor connector
- Snow Performance Meth Install Help
- smell something burnt everytime i hit boost
- wtf!! evo stuck in gear??
- So lets see some DIY-ers UICP
- crushing the stock diverter valve
- Can Exedy twin SD be rebuilt?
- whats wrong with a 35r on pump
- Clutch Pedal Stuck
- Cams in, engine bad, please help
- Another turbo and injector question...and yes, I did a search
- EVC problem
- Finally got back on the dyno
- COMPLETED!: TWIN FUEL CELL SYSTEM! (pics + vids)
- BIG HP EVO'S-Wheels & Tire Choices
- Has anyone?
- Perrin test pipe (cat delete) with stock down pipe and exhaust
- Some problems with the Zeitronix ZAVT
- 11 sec with stock internals Evo 3.
- help help help!!! - hose keeps popping off
- Which turos fit my car?
- FPRed turbo for Evo???
- LSD, evo 1, 2 or 3 not sure
- Quaife Front LSD Installed
- Tomei pro 270's vs Revolvers built 2.0 35r
- BC 280 Cams...No lopey idle?
- transmission power flow diagram?
- Clutch Pedal Adjustment Problem
- Is the EVO throwout bearing the same one used on STI's?
- how much psi
- How tune for better idle with more aggressive cams?
- Silencer
- HELP! Turbosmart EBoost 2
- Can I achieve 400 whp on pump with an evo green?
- Help, just had a brain fart
- Upgrading to Evo 9 turbo...worth it?
- Denso Iridium Spark Plugs...help?
- NB plug question
- Problems With New Motor/turbo/dual In Tank Pump Setup???
- Low boosting problem..
- Anyone consider (or using) a vaccum disribution block?
- What engine for a 37R
- Evo Green
- Any one with the Tanabe Concept G Blue TBE???
- Stroker kit 2.3 or 2.4?
- Alternative to Garrett turbo maybe????
- Head Gasket??
- Samco IC inlet/outlet (PN#?)
- Any word on Tial DV?
- Look what I got at my door today
- P0442 help??
- evo 8 with AEM EMS running 24psi boost question
- Timing Belt Question
- CAS sensor questions....
- When installing an EBC
- Speedometer not working
- My EVO is sick
- Need HELP with boosting problem
- Any one have a Greddy Ti-C Exhaust? Need to know Ti Vs Ti-C
- E85 and emmisions?
- Stock EVO Fuel pump inside 1G Eclipse?
- So who does BUILD the top cars..??
- RnR GT40R turbo kit
- Buschur Racing GT45 turbo kit.
- Dyno numbers... 35R fell short?
- Can i transfer Evo6.5 gears into my 6 speeder Evo8?
- HKS SSQV Adjustment
- Ideal place to shift based on this graph?
- just in.....GT4094R
- sean ivey=savage
- looking to make 400whp
- 35r or 60-1 for pump gas?
- High rpm sputter
- Buschur Racing 3" DP Review
- Weird whining noise at 3500 rpm :(
- buschur fmic failure
- How mans trans/x-fer/diff changes can I get out of the oem fluid jugs?
- Boost Leak????
- 2006 EVO IX.....still having boost issues!!!
- Problem with idling
- modified bumper needed for nisei intercooler?
- head gasket size
- fp evo green turbo serial number
- Need my IX turbo repaired
- Apr Head Studs
- Fynetune completes 500+ AWHP on Pump Gas (93)
- Clutch disc question?? ACT
- 450whp intercooler??
- Car sputter!
- New Evolution 9 Cam Released by Buddy Club
- How much stability does a roll cag offer???
- V2 272 Helix cams
- Evo I-iii Bov
- APS coold air intake
- Sequential turboing an Evo?????
- evo 9 lsd fit into 2003 evo 8?
- searcing TRE upgrades?
- ACD transfer: noob question
- Shep Trans "Ultimate Ratio" Gear box Review
- Greddy trust front mount on ebay?
- e-85 and meth?
- Can AnyBody Tell Me the Problem??!!
- bov question
- Exedy Twin HD Cerametallic is this one? Owners READ!!!
- Nitrous!!
- Evo Flywheel
- whats the ideal afr ?
- Boost trouble!!!
- loud exhaust
- nisei ic pipe help need quick response
- Extreme Turbo Systems – Behind the Scenes- Turbo Kit Mock Up
- Exedy Twin HD question
- fp green turbo arriving this week!
- which mod between these two - Evo IX
- Installed an Exedy Twin and now RPM hang issue
- Well..... she finally went 10's!
- Car sputtering when trying to make a turn?
- Dyno in NC?
- could a bov recirculation bung too close to the compressor side cause a problem?
- Bov setting
- Buschur Music
- scraping sound...
- blown engine on e-85 600 miles......
- Weird engine noise
- Mounting sensors for oil temp and oil pressure - remotely?
- Powerband of Strokers
- question about replacing 02 housing and downpipe
- VOTE please - e-mail/mail in flash POLL
- spark plug problem
- Any vendors sell these?
- Extended clutch rod: Whats the REAL truth behind it?
- next mod? Anything left thats cost efficient/ bang for buck?
- Street Disc vs. Puck Disc
- Naive about your cam gear cover? READ THIS
- BLown Turbo?
- lost boost / Greddy Profec B-Spec II
- Greddy TI-C Catback rear bumper shields ?
- Forge MBC vs. remove stock pill and ecu controlled boost
- BOV Mount location
- Forge MBC with TIAL EWG help
- Safe Boost
- Advise needed - tubo back exhaust purchasing
- Fuel pressure line for nitrous
- mitsubishi drivetrain warranty question(back axle)
- AEM Tru Boost
- 156.92 (mph) reasons why Buschur Racing is the best !
- Highest Hp Stock Ecu Is Here
- Head Studs The Right Way
- Front Motor Mount vs. All Motor Mounts
- missing At 6000 rpm
- mods for low 12's or high 11's
- Modification advise needed
- what w/g actuator = fp-grn/20g-lt?
- is my mbc bad??
- jdm bov
- Lifters
- pulled the head, got a question bout the cyl. walls
- Is this BOV a P.O.S.???
- Fuel cut at 4.5k with engine light
- Brian Crower 280's Dyno #'s!
- evo tranny
- fpevo green ordering
- 06 MR tranny fill/drain hole?????
- BOV Flutter
- So was i due for a drivetrain flush and fill?
- Please Help
- fuel pump needed?
- what does everyone tune with?
- Dyno #'s SAE vs. STD what's the difference?
- Miss shift/Grind
- Interesting oil performance article:
- piston upgrade?or not?
- Help!!!!!!!
- GREEN 20G-LT Maxed out Record HP #'S
- gains from a test pipe? any issues with CELs?
- 2.5in IC piping
- Engine Torque Damper Brand ?
- Spark Plug Installation
