PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 [121] 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Just installed BR MBC, boost spikes at onset then tapers back just like stock??
  2. Exhaust system for track use only
  3. Best Cam Gears On an 8 ....???
  4. PCV Valve Relocation
  5. Boost leak test issue
  6. I'll be looking at this VIII tomorrow A.M., what should I look for?
  7. How much power 650 injectors are good for?
  8. Some tech insight wanted... Subie guy running a 35R
  9. Solution for Peakboost FTW manifold and radiator hose
  10. Who needs cams 440hp?
  11. Possible 03 Evo engine broken....help
  12. Exedy Problem
  13. Your thoughts about this combo on cams....
  14. Where can I find a stock evo 9 turbo compressor housing???
  15. Question about the ACT Xtreme CLutch Kit?
  16. High Boost on 93 or equivalent - Why it works?
  17. A little of this, a little of that....500+ pump again
  18. AMS GT850R Pump Gas!!
  19. Radiator Coolant Leak From Top.
  20. Sorry just another 500+ pump gas and 600 race gas EVO
  21. Acd Button
  22. CBRD TS, vertical, fun stuff...
  23. Is My Oil Supposed To Be This Dark?!
  24. What are the signs of a bad alternator?
  25. Clutch issue
  26. HTA 35 to HTA 37
  27. WTB: Complete Evo 8 2.3 short Block
  28. opinions on the K&N drop in filter
  29. FP 4r's & EvoGreen
  30. exedy twin problem
  31. Exedy stage 2, 15,000 miles, 60 drag passes
  32. Fuel Pump Question
  33. hard start problem...help!
  34. how to add awd oil in the back trunk help please!
  35. Those who paid up for a real turbo, opinions?
  36. HDTTP Clutch
  37. HELP!!! EVO Stalling out then locking up while driving
  38. Help!! Evo8 Wont Start!
  39. boost controller
  40. boost controller
  41. Very weird situation tonight please look
  42. I need help!!!
  43. Weapon-R Intake Technology
  44. DV Flutter: Synchronic BOV perspective
  45. NEW WAY TO CHILL YOUR INTERCOOLER! Anyone hear of S-Max??
  46. clutch questions
  47. loss in power after LICP?
  48. Should I run Mobil1 synthetic High Mileage?
  49. All ready for Pinks with new faster spooling and more powerful Gt37 turbo
  50. Mike Reichen thru the 200 mph barrier
  51. I can't pressurize my piping to do a boost leak test.
  52. Need advise on E3.46 plugs
  53. which injectors
  54. air/fuel ratio reading
  55. help! need advise from you guys
  56. HKS vs Greddy Turbo Timer
  57. plastic piece behind camgears
  58. Greddy Turbo Timer Problem Need Help
  59. Intake cam position sensor bust...
  60. IX with HTA35R spark plugs?
  61. HTA 35 or 850r?
  62. Boost control for 24+ psi?
  63. Finished install of HKS Inlet Manifold
  64. help with fuel set up please
  65. GT3076R Downpipe
  66. Timing Belt?
  67. exhaust manifold pipes id
  68. Need help please
  69. Oil pan crack.
  70. More datalog goodness
  71. Fujita Air Intake + Upper and Lower Intercooler Pipes
  72. Who needs a clutch anyways???
  73. Need info on NGK LFR6A-11 for evo 9...
  74. Fuel efficiency
  75. Engine Problems
  76. Mobil 1 Extended?
  77. FP Exhaust Manifold Vs Stock ported Manifold
  78. Kelford 272s or Cossie M2s?
  79. exedy stage 1 or ACT for DD only.
  80. Fp Mani ?
  81. Top End Power
  82. Big Turbo, Little Motor
  83. Automatic transmission for Evo VIII
  84. ? about installing BR ported intake manfold and 65mm t-body?
  85. i melted a coil pack!?
  86. Does Greddy S BOV, Increase Power ???
  87. Apxi Turbo Timer question (car wont stay running)
  88. Strange wideband behavior
  89. quick question
  90. Boost Problem Help!!!
  91. Misfire...Help
  92. How do I know if I have a front LSD
  93. Anyone know what this could be?
  94. o2 bung for trust ti-r
  95. O2 Simulator??
  96. T-Case and rear diff oil
  97. OPINIONS evo reliability
  98. So in goes the HKS 3037s kit
  99. Vid of Definately blown T-case
  100. Cam Gears?????
  101. Good Head
  102. Problems shifting from 3rd to 4th?
  103. Does to small of a wastegate spring, cause the EWG to open early?
  104. High HP MR's
  105. Battery reading 13.8volts??
  106. Press in clutch - car dies....bad clutch master?
  107. Problem with tran need some help.....
  108. Parts for evo I, II, III ?¿? PLEASE ?¿?
  109. Clutch Access Hole Plug
  110. Choosing a turbo kit
  111. Evo 9 Front diff pooched?
  112. URGENT - PPIHC car blows TC and needs a new one ASAP!
  113. windsplitter/intercooler upgrade
  114. AEM truboost install - boost pressure source?
  115. Egr Valvle location
  116. will this bolt up?
  117. Is my clutch shot?
  118. go external Wastegate or not??
  119. Turbo/Build Question
  120. Video of (TC) Transfer Case noise.......
  121. TSB question
  122. car jerks and flutters any help
  123. Where can i get a fp green?
  124. anyone have any exp with a john shep rebuild?
  125. High load issue with normal boost
  126. Cosworth M2 Review.
  127. cam choice
  128. tc/tranny issue?
  129. Need help on part name!
  130. swapping evo 9 1st gear into evo 8 trans
  131. What valves to buy? Help
  132. Weird Clicking/Popping When Taking Off
  133. Where to purchase replacement battery to the Bushur mini Battery?
  134. help!!! rough idle and other things!
  135. Tranny Fluid Change
  136. I need some pics of the iac valve
  137. wideband sensor placement on QTP downpipe
  138. GSC S2 idle
  139. EVO Red pump gas/race gas dyno numbers.
  140. HTA35R: Tubular vs. Cast Mani on Pump and Alky
  141. Boost leak
  142. 30k service cost
  143. My evo issue #3,089,982
  144. colder spark plugs
  145. Found damage in my head- is it a problem
  146. full engine build
  147. Evo 8 Probelms
  148. guessing game
  149. FP RED, White And Green Shootout
  150. Clutch pedal vibrates? TO?
  151. MAF translator Install... (evo 9 pin out)
  152. What size is the stock alternator?
  153. Anyone tried these 02 sensor replacements...
  154. Front end click noise when turning?
  155. ic pipe question
  156. ABS light-How to reset?
  157. a/c problems - can anyone help
  158. Poilishing Bearing surfaces during motor build
  159. Replacing Stock clutch @ 79k, resurface flywheel?
  160. coolant help
  161. Throttle Body Seals?
  162. Need Suggestions: Rebuild!!
  163. 6 speed strength
  164. Getting a "tune" - what to expect?
  165. full engine build help
  166. Whistle/whine under boost
  167. No Boost After Install!
  168. Injector size for E-85
  169. Need Help making decision on New CLutch
  170. FP Green Questions
  171. 2.3L build
  172. Intercooler Question
  173. stalling in neutral with a/c on only
  174. Oil cooler lines- Direction of oil travel
  175. Modified factory oil pan????
  176. Accusump install? - 2 motors blown in 1 month
  177. 2.3 stroker vs 2.0 - GT3076 vs HTA35r
  178. 1st Shakedown on PT 6765 Turbo - 9.80 @ 138.9 mph !
  179. EVO VIII power "cutting out" in higher gears
  180. Short shifter vs upgrading the bushings to the stock shifter
  181. exhaust
  182. clutch problem
  183. Ecu Ralliart Evo Ix
  184. Evo 8 Cam Gears
  185. gear popping out
  186. Disabed O2 sensor for test pipe?
  187. when is it time to upgrade stock injectors?
  188. Stick with my HTA35R or keep it simple?
  189. Funny noise @ high boost?
  190. Turbo Back Exhaust with test pipe question
  191. weird sound
  192. car pulls harder with AC on...
  193. Please help a noob
  194. Snapped a cam bolt today while installing HKS 280's....
  195. pls help...exhaust manifold on evo 9
  196. Question about ported manifold and 10.5 Hotside?
  197. first engine mods??
  198. Exedy High Grip Wear Carbon D Clutch Coming
  199. scheming new upgrades BIG POWER take a look
  200. Need advice
  201. Car suddenly will not build boost at a stop
  202. Bolt On Turbo Line Up
  203. Okada Projects' Plasma Direct coils
  204. Do I need to have Injector driver for 1600cc? (37R w double pumper)
  205. Real Problim Car not cranking up
  206. Hallman mbc and Tial Wastegate connections
  207. Driveshaft making noise
  208. Don't want to loose the evo...
  209. Video Request: HKS RS intake, with stock bov/turbo.
  210. 10.72 @ 129 Red Turbo
  211. Ingition issue, maybe knocking or missfiring
  212. Anyone have their accessory belt pop off?!!
  213. Walbro 255 and fuel filter
  214. Stock MR boost gauge inaccuracy?
  215. Easy to use clutch?
  216. hks 280??
  217. Sound Clip for FUJITSUBO SUPER TI exhaust anyone?!??
  218. HKS 272 or GSC S2
  219. Ticking sound
  220. PTE 56 trim to 3076r
  221. ebay turbo back exhaust
  222. hks intercoolar help
  223. 1g bov VS 9 bov
  224. Coolant Reservoir Help
  225. Exedy Stage 1 Racing Clutch
  226. Cam question?
  227. Connecting rod bearings question
  228. FPwhite + Evo 9 + 91oct
  229. evo viii compresson housing swap
  230. 23 psi on untuned EVO IX ok?
  231. Where to get an FP Green or similar in stock
  232. ceramic coating in nj
  233. QTP downpipe with electirc cutout and buschur exhaust fitment
  234. something is wrong
  235. what filter?
  236. Apexi intake w/ Induction Box what hard pipe?
  237. time for a bigger intercooler
  238. best bov, APS twin vent?
  239. replacement oil temp gauge
  240. Dyno question
  241. Clutch not release at high rpm, or something else?
  242. HKS racing suction intake.. thoughts?
  243. And Now for the Mother of All TS T3 Housings
  244. Blown Turbo
  245. Did Someone say ETS 6262
  246. evo 8 trouble
  247. Any experience with this cat-back??
  248. Transmission Problem?
  249. oil return line gasket question..
  250. HELP! problem with my evo. new to site
