- Clutch? issues
- Injectors..
- Can coilovers damage hubs?
- ......just finished clutch install and car wont shift into first?......plz help
- santa pod disaster please help
- arp 1x1 install question
- which tb to use on my setup?
- Wiring HKS DLI into 300M Coils... Need Diagram
- Fpred on higher mileage evo?
- wanted
- aem uego gauge suddenly shut off!!??? WHY???
- lower boost with BR Deluxe intercooler
- PTE6262/FP3582 vs GT3582R
- Bad shuttering and jerking from a stop with Quartermaster
- Torque Solution bolts?
- Help! Engine vibration and noise after 60K job
- help! car has bad idle!!
- Will GT35R turbine housing fit a GT30R?
- Shifter suddenly sluggish
- P0125 and rough idle after tune
- 88mm K1 crankshaft 2.0 liter build. need some advice
- Redline Lightweight Shockproof Gear Oil safe for T-Case?
- problems with start up and idle?
- coolant leaking out of side of block
- Questions about tuning?
- identifying denso injectors
- EvoTK FP Black Build
- Ebay silicone couplers, experiences?
- Lookin for a new clutch
- Need Help: Oil Hole on Block
- Inline Aeromotive 1000 fuel pump system setup (PICS)
- hesitation/bogging, rough idle, cold only
- Help! Grinding metal on metal sound after changing clutch.
- What would you do next?
- turbo problems
- Ignition: COP w/HKS DLI?
- turbo swap gone bad
- evo 6 radiator
- Safe Boost Level Question
- Full Blown dbl pumper
- Gearbox and LSD confusion
- New to Evos, looking to make mine fast - Need some help with what to get?
- Evosick2332 Complete Build thread!!
- New Forward facing STM Manifold
- 60k service
- Compression ratio and pressure:
- Buschur Down pipe
- Injector sizing on E85 w/FP Black
- Turbo oil return line leaking
- Keep your eyes and ears open before your big dyno day...
- Anyone running a lightweight push fan for the A/C?
- aem uego output voltage problem
- p0300 nightmare
- Anyone running pte 5857 and 6057 (reviews please)
- royal purple 75w-90 ok for transmision, and turbo sounds different after new clutch?
- Will the fp black boost creep with a jm fab o2 dump?
- What else do I need to install FPBlack for MAX PWR on 93
- T3 vs T4 1.06 twinscroll housings, any power/response difference?
- need help on deciding on which cams to get..
- 65 Tb Gasket
- Slow Boost on a BBK Full ???
- whats best foR US evo VIII FRONT OPEN DIFF OR LSD?
- Anyone else have this issue? ETS intercooler pipes.
- WOW!! I just paid $355 for an evo green...
- exedy stage 2 clutch question!!!!
- Clutch Pedal Problem
- Good 500whp single plate Clutch
- Blow off vavle question?
- No 6th gear after clutch install?
- BW s362 vs PTE 6262
- Interchangeable Gears
- Best Rear LSD upgrade
- Big problem, need help with rear LSD
- Stage 2 transfer case
- GM 3 port/boost pill question
- Retorque stock head bolts?
- No crank...
- engine lost power at track..car cut off
- Service life of a Walbro pump?
- clutch master cylinder?
- is it worth the money?
- HELP!!!! Clutch gone or Tranny gone?
- Blown headgasket or something else?
- How to read precision injectors
- car is breaking up, need some quick advice.
- need help quick. sparkplugs
- Installed my FP Black yesterday - pics inside!
- Plugs, coils, fuel pump, or injectors??
- ??? on main bearings
- Lubrilon Permanent Engine Protection?
- i need help about this trubo ...( pic)..
- no power to the fuel pump
- Just installed IX turbo - rich idle
- Help. Turbo pulling oil up from the oil pan?
- quick release hose clamps
- Slight clunk coming from engine bay?
- Megan exhaust manifold?
- Car on idle but no fuel coming out in the return line. Is this normal?
- timing issues continued?? i'm guessing bad ecu
- comtic evo 8 gasket on evo 9???
- Cams 180 out
- Hole in my stock intake manifold wtf..
- evo 9 block in evo 8 ???
- Maxed IDC?
- precision injectors...
- Evo 6 TME fuel cut when on 1/4 tank fuel?
- 35r Turbo question
- Please help! intake/bov pipe hoses?
- clutch shot - massive slipping on way home very hot
- Quick Responses Please!
- OEM Headgasket
- Where to buy Exedy Hyper Single clutch rebuild kit
- Clutch choices...too many!
- Interesting find, 2004 Hyundai Sonata Ignition coils
- Axle shaft? what the hell is this called?!?! (pics inside)
- smokin evo 8
- Results for a B/W S300SX3?
- WTF is wrong with my car? F-ing throttle is hanging...
- wastegate actuator
- bad ecu? bad coils??
- EVOLUTION III @ Mellon Tuning Race Car Project
- EVOLUTION VI RS2 @ Mellon Tuning Project
- Nicks LR 2.4 FP Black Build
- Single loud click noise
- Anybody know what clutch kit is MBD088U
- Need Evo 6 GSR turbo details and 9 upgrade info .
- timing issues under load
- how to adjust cam gears
- Idle and Boost problems ( Videos )
- why would you run a HKS 264 intake cam?
- service engine light
- Cons to running too large of an injector?
- Overboosting... cant find the problem
- hks turbo timer not working
- Any gains or benefit from a vented/catch can setup?
- Hard starting after car sits!!
- NEED HELP!!! I've got no oil pressure!!
- Turbo bolts
- 2 different maps ??
- 60k maintence
- Valvoline VR1 20w-50 Race Oil?
- idel problems
- Q: Can you... Evo 8 Transmission in FWD format only?
- Can Fouled Plugs cause Knock?
- Very weird problem (knock even with no boost)
- At 208,564 miles my timing belt snapped!!
- Can I reuse these spark plugs?
- Strange Noise/Vibration
- Lifter Tick. Lol
- best time for oil change?
- help no one will tune my car !!!!
- Walbro fuel pump question!!!!!
- rattle from engine bay while in boost
- atp 3071r with stock internal
- Exedy Twin doesnt want to release when downshifting?
- Misfires when cold
- Pin hole in turbo oil return tube
- Manley Crankshaft question
- Oil Temp Sending unit
- Need some opinions on turbo choice
- exhaust manifold stud broke!help
- Transfer Case dissassembly
- ? for those running revolover cams...
- DNP T4 Manifold Fitment
- Boost leak test ? thoughts on the issue?
- Difference between std. EVO and MR BOV??
- can't boost more than 1.3 bar on 25psi wastegate
- Replacing gaskets when doing turbo swap
- Tha Dark Knight Evo 8.5 Project
- FP Black EVO, 1320 built, 4ws tuned
- FP Black/Red question
- Quick engine swap question.
- What fluid for the ACD
- Looking for professional and experienced opinions on FP green or red for track car
- How audible is the ACD Pump?
- Camshaft Choice for FP Red, FP Green HTA
- Transmission Problem Expert help please!!!
- coolant temp goes from 192 to 206....why?
- Please help! my car wont start..
- Evo 8 Transmission Fluid Metal
- Help?
- engine blown pics of culprit
- Emission Q: Test Pipe
- fuel tank in trunk
- Bonjo Bolt Master Slave Cylinder
- How Many People Have Blown thier Engine using a FAILSAFE METH KIT?
- Drivetrain Help
- Oil pressure light flickers rolling from dead stop
- Secret to removing starter???
- ACD is messed up
- Clutch install Help!
- BBK XL vs FP Black
- 04 and 05 gear ratio the same???
- AMS Push style twin slipping need triple upgrade??
- Help Needed IACV
- What is your experience with stock 9 gearbox misshifting issues please?
- Gsc s2 - do they all say kelford on them
- Project Valve Technology Muffler
- head gasket problem? LOGS INSIDE
- Need help diagnosing problem, bogging
- intercooler sprayer needed?
- custom dp question
- T case went out
- Modifying valve cover with AN fittings
- idle problem
- Another death whine question.
- Check Engine Light
- Dropped a keeper
- Need a 2.4 block specialist!!
- 02 housing
- Does mitsu sell just the transfer case housing?
- Exedy Twin or Exedy Tripple ?
- EGR Hose Gone... Size?
- Serious and Weird issue, HELP!!
- is this clutch any good?
- ams balance shaft delete
- NEW build new opinions!!
- Engine builders what you think about extra Clearance rod bearings?
- Evolution VI Project @ MellonTuning
- My Evo Build....
- Can i get some opinions on my transmition situation
- head studs necessary if.....
- oil pick up tube for fp install??
- Stock EVO 8 Injectors "vs" RC Injectors
- Retuned from stock, seems to lag power
- Well there's your problem right there! Blown ACT clutch disk inside.
- TC, or Tranny problems please help diagnose
- when to go with a 3.5" exhaust
- I broke 4th gear....
- Homemade "Boost-A-Pump", has anyone made one!?
- Vid of MAP O2 Eliminator + 3" Straight Pipe
- HKS 280 vs. Kelford 272? Answers!!
- How much voltage should the injectors be getting?
- Transmissin Help
- need some help
- Quick question about clutch/transmission
- banjo bolt issue with fp red turbo
- car overheats under boost...
- Rod bearing clearance?
- Who All Overheats With Slim Fan and Tubular Header?
- what intercooler piping will work with my setup?
- FP Red w/ ETS FMIC
- turbo fitment questions
- tcase/driveline failure
- 280cams+valves, retainers or go with 272s and stock???
- Megan racing VS OEM ported and coat manifold
- Need help asap..suppose to tune in am
- 3" Titek mod?
- Crank Pulley bolt?
- oil pump pully has resistance when turned?
