- Evo Oil leak any ideas recently had rebuild
- Kaaz & Redline Light Weight S.Proof T.Case Mixture?
- gsc s1 idle for evo 8
- What do you think of BC V/Springs & T/Retainers?
- used core upgrade or new core upgrade?
- Deployed & can't look @ my Evo 9-HELP!-Short shifter ?s
- front motor mount causing lockout
- anyone know diameter tial flange
- Stripped Egr Bolt...sort of...not totally F'd
- Tcase Fluid Color
- FP Red (84mm) users get in here plz...
- 5 speed to 6 speed transmission case swap
- 2nd gear Issue
- Tune after rebuild need??
- Transmission Grinding Issues
- Engine Oil Pressure Warning
- Boost!
- Limit Power?
- cop wiring diagram
- time for a new turbo
- AEM Boost Solenoid clicking *Vid inside*
- CBRD double thick, half width Radiator-
- CBRD- more custom...well... stuff ;)
- Camshaft seal part number
- High compression inner rings!
- notchy third gear
- High pitch whistle noise?
- What is this? (picture)
- What causes roller rocker arms to break?
- Hallman MBC Issue.. Cant turn boost down
- Check out these pics and tell me what you think!
- ECU - Which to Pick???
- JAM/OEM lifter question
- 12psi but NOT an installation issue
- Precision 4274 2.0L evo...
- Nuke Performance blow off valve?
- New build need help car not running correctly w/mivec
- hta 3586 hot side questions.
- need help
- Idea for cooling down intake temps, TB coolant auxiliary cooler?
- Fp black fuel chose???
- 4g64 2.2 LR DESTROKER PISTONS for 94stroke + 88mm crank + Extra Long Rods)
- JAM Stage 2 head
- New & reviewed 2011?
- 2g MAS with evo 560cc injectors???
- Trans broke?
- Car Stuttering. Please help.
- Very Sick Evo IV Help!!!
- vta 02 dump and aem wideband
- threw sparks under car during launch
- Rear diff drain plug washer size?
- Stock intercooler
- Need a sparktech harness (COP) evo VIII
- Custom Turbo Kit For Tobz Performance - Huge Bottom Mount!
- Wierd Evo ogging and Smoking Problem
- P0401 CEL - EGR insufficient flow
- Just received my FP BLACK!! but now OIL DILEMMA
- O2 dump with stock exhaust?
- GSC S2 on back order?
- Boosting to 14psi in first and second gear... And then...
- Standard Garrett 37R upgrade options...
- Launch help!
- What symptoms would a stuck lifter have?
- Fp5r cams scratch
- Synapse on an Evo IV?
- turbo squeal problem (HELP)
- Clutch pedal click
- Please help:Intake manifold!
- Oddball Troubleshooting Q&A
- Front diff
- Intake Snorkle Test by Boosted Tuning
- Stripped stud on fuel pump housing.
- Stock fuel regulator or adjustable???
- No barb on stock IX turbo?
- clutch install complete!! one thing different in how to..
- Need help!!! Car wont start
- Injen Intake/IC kit installed now my BOV is quieter WTF!!
- Baffling the stock oil pan for better oil pressure...
- Low vacumn, rough idle on new built motor
- Voltage Problem
- evo rear diff
- Can i higher boost after a thicker H/Gasket?
- Manley turbo tuff question
- Car cranks, starts, but won't idle and dies immediately
- E85 fuel system questions
- Strange boost issue
- Evo IV Clutch Options
- Evo IV Overboosting?
- Evo IV BOV problem
- setup from a pro? any help ???'s
- Competition clutch pull to push sytem???
- break boosting
- MOD order with specific budget+list+GOAL
- Cylinder head porn from HeadGames...
- Please Help!!
- swapping 9/8 turbo
- ACL bearing
- Exedy twin carbon/carbon rebuild Q?
- Stock evo 8 fuel pump?
- best forged pistons for Lancer Evo 6.??
- D Buschurs 02 housing pics available ?
- clutch master fx300 problem
- Quartermaster Twin Disc, Flywheel resurface?
- Locked new motor on start up
- 86HTA vs GT35R,spool?
- Crazy loud ACT 6 puck unsprung clutch noise, please help
- 272 kelford cams degree!??
- non-lopey cams
- buschur cast manifold 3065 hotside upgrade available??
- cel help
- WARNING - if you have a double pumper please read
- is this a good choice? ebay 02 housing LINK
- Looking for "no chatter" 400hp daily driver clutch
- As far as ic piping goes...
- Balancing Belt
- what turbo/other advice for road racing?
- Rear diff ???
- question on act..
- FP Black & Wastegate actuator?
- Couple questions on Transfercase
- Look what came in the mail today!
- Surge Tank Setup...
- evo MR 4th gear grind. Fix with synchromesh??
- Gas leak on FB double pump.
- EVO 8 too many problems
- Boost Leak from HELL!.. where the F*** is it
- Engine Bay Noise: "Tick" Coming from a pump (I think...)
- Catastrophic Failure
- NEED AMS 4G63 Honing plate barrow/rent for school build
- upgrade to walbro 255?
- Please help - Troubleshooot muffler sound!
- oil squirter
- Injectors not turning off during decel + tps problems
- Life Expectancy of Your Stock Turbo
- walbro 255's limit?
- CBRD & EVODAN- custom stuff ;) Finished!
- EVO 11.5 Hotside, anybody try it?
- Anybody else have a "Gear Turning noise" when you rev?
- HKS SSQ BOV Recirc Question
- Swapping Turbine housing on gt3071r
- Help in identifying a vibration
- Oil pissing out of transfer case after install!!
- Drivetrain removal method
- HKS GT II turbo OR The AMS GT950R
- Hotside comparison
- Boost Leaking Through Turbo Oil Lines?
- what turbo to run
- 498whp ( FP red & Meth )
- My 2003 Evo Build.
- Eagle 2.3 build issue
- Car wont start
- Rebuilding my Evo IX
- changing fluids
- anyone ever heard of this?
- Question if ICS has gone bad
- short Shifter with a very tall selector?
- identify this turbo?
- Engine overspeed by downshift
- evo 4 shaking
- HKS dry sump system - has anyone got any photos of it fitted
- Would this exhaust setup match up?
- P0365 CEL Expert Advice Needed
- Spark Plugs too cold or ok?
- No oil pressure after replacing oil pump.
- Idle Issue/Stalling with Defroster/AC
- E85+1050s
- replacing BOV?
- Tomei Evo IX Pro 270 Cams Tested.. +20whp & +40tq!!!
- Missfire all the time! HELP
- Metal Gasket between motor&Trans
- running no cam sensors
- 4g63 bottom block bearings
- Built 2.0 firing on three cylinders?
- Gearbox start to have sound...What is happening???
- New "Batmowheel" turbo from BULLSEYE POWER
- Help compression test results: 150-160-145-170
- 2.4 started and ran, now no start.
- 2.4 started and ran, now wont start.
- Installing Motor/Tranny question.
- stupid question or not....I want to know
- Oil PSI Question
- Only firing on three cylinders?
- tial exhaust housing, 0.82 or 1.02/3
- New setup won't start, help?
- TPS check/adjustment
- Low Z injectors
- Du i need to run in for new valvesprings, retainers, lifters & turbo?
- Quartermaster Question
- good clutch
- Do I have a valve sticking, lifter loose, faulty injector? Tapping around the head
- how much power u think i am gonna lay down?
- thoughts on these internals!?
- evo 9 acd transfer case dissasembly
- downpipe dilemma... used or new?
- what is the max boost level on a stock turbo with the factory tune?
- Why always seems lack of power everytime moving from 1st gear???
- cosworth m2 or gsc s2
- Changed cams and fixed vacuum leak....Need a retune?
- HFC Cat cell count information - A little exhaust flow calculation
- Straight pipes... Pics and questions
- competition twin disk
- so if your goal was 500whp.....
- How long will stock rubber intake pipe suffice?
- Review my sparkplugs!!!
- going to upgrade my intercooler from stock...quick ?
- Tomei's manifold
- possible problems with vta o2 dump housing?
- Evo VIII, Cam Advice and Link to Shiv's Cosworth M2 VS M3 Dyno comparison
- Link Please: to Shiv's Cosworth M2 VS M3 cam test
- Lower ic pipe blow off?
- Cold start issues
- help
- Evo 5 Fuel press, Oil Press and Oil temp
- Uh oh!
- Boost Leak Question/ Car Problems
- Forward Facing Turbo On Daily Driven..
- New Intank Pump That Out Flows Bosch044
- Cracked Crankshaft
- Need Help Finding A New Exhaust Manifold
- 5 spd-6 spd bell housing interchangeable?
- Starter Motor Diagnosis?
- What kind of rear differential for 06 IX GSR with 650-700 WHP
- P.E.A on intake? (pic)
- WG actuator selection: 17psi vs 22psi
- Coolant over flowing
- Clutch tob is pisssssiiiing me offff!!!
- read on compressor efficiency
- messed up spark plug...what happened?
- How important is to use a Oil Inlet Filter for GT30R Turbo?
- Drilling MAP sensor flange to OEM sizes
- everything shakes !!!!
- weird noise when turning and accelerating
- cams for a built motor
- Should I go C.O.P or NOT?
- IX Turbo Turbine Wheel Differences
- Clutch Problem?
- Evo 8 will not idle on its own!
- Manual Anti-Lag Modification???
- Can Evo 4~8 use Air Trek block?
- Oil bypass bolt
- HTA3586 .82 to 1.06 T3 Single Scroll
- Tried my friends clutch aaaand now I kinda hate mine.
- dual tial q spring function???
- Coolant Temperature rising and peaking high
- notchy shifting, hard to get into 5th gear.
- Evo 9 tranny
- 3rd and 4th gear trouble
- 6262 vs 6265 turbo ?
- those with evo engine building/teardown experience opinions on this Headgasket
