PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 [184] 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Descriptions of O2 sensors?
  2. still have this d**n cuttoff problem @ 6k rpm in 3rd gear!!!!!!!!
  3. Is my auto i/c spray working?
  4. To anyone with a RNR 35r kit....
  5. MBC off? Is there a point?
  6. Dyno result by Türkish evo
  7. apexi gt spec clip
  8. help !!! gfb bov exploded
  9. What tools for a catback install?
  10. Need some help asap!!!
  11. intercooler pipe blew at 21psi!!!
  12. 2 O2 sensors broken after 6000 miles
  13. AHHHHHHHHHH..almost
  14. Front radiator fan in Evos without A/C?
  15. short shifter
  16. aftermarket oil coolers
  17. running lean?
  18. Whats wrong with my CLUTCH?? >=T
  19. RSR downpipe fit IX?
  20. peak boost
  21. Another whp wondering thread.
  22. What Else To Do
  23. Alky/Meth Injection
  24. cam for ix
  25. Slave and master cylinders
  26. New evo what should i buy first?
  27. 35R Installed Need Help!
  28. New Buschur Catback vs HKS Hi-Power
  29. Anyone got headwork done from buschur racing?
  30. Cam Gears adjustment
  31. AMS TBE vs Turbo XS TBE
  32. thinking of switching up dealers
  33. Roll Cage is finally in
  34. Ordered a buschur 440 turbo kit!
  35. Unicorns
  36. Anyone else done this?
  37. Manifold gains
  38. Shifter install tip, saves money :)
  39. It's a Warrtalon Xmas in Colorado!
  40. EXEDY stage 1 clutch/ACT Streetlite Review
  41. Just got Tunned from TT!!!
  42. BG synchromesh vs. pennzoil sychromesh
  43. Exedy Clutch
  44. Need help install aem wideband uego gauge
  45. boost question
  46. Transmission Problems
  47. where to buy cheapest hks exh 272 cam?
  48. question about manifolds...
  49. Does the bumper really have to be removed???
  50. new gaskets??
  51. HELP!!!!!!!!Can I remove the back O2 sensor?
  52. Fourth gear "draging" in MR 6 speed
  53. front lsd?
  54. Cam gears torque
  55. Question on Clutch Install
  56. What next?
  57. Oil pump failure's on 2003 Evo's Seems to be happening more.....
  58. Water Spray Control on 2006 US EVO
  59. Nylon Tubing OK in the Engine Compartment?
  60. Clutch install Question in a 2005 Evo?????
  61. Hopefuly i told him right...
  62. hey davidbuschur i got a question...
  63. Here we go again(stupid friend)
  64. Do I need to run an O2 sensor?
  65. HKS 264 vs 272
  66. What's with Buschur Racing's dyno....with dyno sheet of RS.
  67. Little bit of big turbo testing on the stock 2.0
  68. stock engine, upgraded turbo?
  69. pros and cons on knife edging the crank?
  70. oil pump upgrades? anybody?
  71. I want to blow up my engine!!! (Edited)
  72. fic 850 lag timing
  73. Quick cam gear ?
  74. PO325 CEL code after 2.3L Stroker install
  75. Full Race Manifold
  76. Wastegate Actuator question
  77. 10.5+o2 housing+Ams Custom flash
  78. Quaife Center Differential?
  79. fuel injectors
  80. Need Real Racers for Product Testing
  81. Exedy Clutch Question
  82. evo questions
  83. Exhaust vid: 2.4 Stroker, hks 280s, AEM ems, GT35R
  84. best place to get a 10.5 hotside
  85. DIY 10.5 / Exhaust Manf. Porting
  86. APS Intercooler
  87. Boost spikes
  88. Fuel system upgrade+cams?
  89. SMC Alcohol Injection
  90. Oil cleaner ruined oil pump?
  91. wierd rattle NOT something loose
  92. Can all EVO VIII downpipe fit EVO IX ??
  93. Buschur Racing Black EVO back on the dyno........again.
  94. cam gears and 280's
  95. Best Drop In Air Filter for EVO (Poll)
  96. question
  97. Double chirps after Forge MBC install
  98. Question on Helix intercooler hard pipes
  99. will a 8 ss clutch line fit a 9?
  100. hks cams need help
  101. Blown Timing Belt...Need Advice
  102. Best GT35R kit for the money
  103. Your Experience Changing TC Fluid.
  104. Need help with my EVO IX!!!
  105. What boost controllers use a a 12volt high/lowboost input. making alky failsafe
  106. HELP! engine trouble
  107. What Are Some Good Aftermarket Igniton Wires?
  108. Injector with 20g-9 and alky
  109. Q for people w/ biggie fuel pumps
  110. What size injectors...
  111. clutch stuck engaged!
  112. Clutch problems please help
  113. Why did you choose you FMIC?
  114. smaller battery affect spark?
  115. Evo 9 stainless steel clutch line?
  116. Building Derek's 4G63 (video)
  117. Need Advice Please
  118. UICP and BOV question
  119. 05 MR dyno results
  120. 264/280 camgears setting
  121. Quick BOV Question, PLZ Help?!?!
  122. Where do I put my gear oil in?
  123. Has anyone tried 264/264 comp cams?
  124. New SRT-bag slaying weapon....
  125. How much oil does your baby burn?
  126. LICP for Evo 9
  127. Quicker Boosting Turbo than Stock?
  128. IXs with Exhaust Cam and gears?
  129. INSTALLED 264's?& IDLES LIKE 280!?? & GETTING FUEL CUT!??WTF?
  130. very hard shifting into reverse gear
  131. Engine Torque Dampeners?
  132. gains from downpipe??
  133. Someone PLEASE help me!!!
  134. ok i need more help
  135. Car won't go into gear!
  136. Stock Fuel Rail Question
  137. Pics of engine build up (lots of pictures)
  138. Turbo XS intercooler....
  139. What happened???
  140. ECU tach output EVO9 for shift light?
  141. Installed LICP, checked for leaks, no power gain?
  142. 10.5 hotside ?
  143. best spark plugs with 35r?
  144. Kansai air box + aftermarket filter without tune
  145. How long do EVO stock spark plugs last?
  146. Clutch restrictor
  147. Stewart Warner > Defi-D
  148. Pennzoil Synchromesh=5th gear grind NO MORE!
  149. Wallbro started whining noise. Is it bad?
  150. My throwout berring is stuck...
  151. Do your hose clamps pop off often?
  152. Vacuum/Boost Line/Hose/Tubing - Replacement Options
  153. IX GSR & B&M Short Throw
  154. weird noise after camshaft install
  155. Tools to change valvesprings?
  156. JDM EVO IX Tested & Tuned
  157. upgrade clutch???
  158. 5th Gear Question???
  159. HELP!!!!!!!!!!!how many is EVO 8'S normal OIL PRESSURE???
  160. Tried everything and still can't launch
  161. Best shift point with upgraded ex/int
  162. desparate... need help a.s.a.p.
  163. Do evo 8 cold air intakes fit on the IX's?
  164. Best MBC
  165. A case for a "GT35RS" ?
  166. cracked transfer case
  167. Any last words of Advice for somone doing a clutch job on jackstands???
  168. need some advice?
  169. Wanted.. greddy r/s vented adaptor.
  170. Stock 05 MR BOV
  171. lets see how much AWHP will these mods get me
  172. Those with the gt35. i have a ?
  173. Is something wrong with my tranny?
  174. Cosworth Camshafts
  175. Grinding Noise in 5th gear
  176. Buschur Racing teams up with Warrtalon....
  177. in your opinions is this a good start (05 gsr)
  178. was up
  179. custom intake sizes
  180. car cuts off during WOP
  181. Oil Pressure gage not working - Need Help
  182. Forge RS BOV Mounting
  183. 05+br turbo back?
  184. Aftermarket O2 Housing with 80mm Turboback...
  185. Sputtering.......different than others
  186. VTA Cause Intercooler Leak/Come Off?
  187. 40whp from revolver cams?
  188. Coolant smell but no coolant loss??
  189. Aeromotive Pump Questions - Electrical
  190. question about stock 05 turbo?
  191. AFR question (Help)
  192. Dynoflash part question
  193. FMIC question
  194. New Evo Owner... What YA thInk
  195. Evo IX Turbo vs VIII Turbo
  196. will this solve my slipping problem
  197. Anyone with specific details on APS BOV settings??
  198. Need some specs on 680cc...
  199. Buying EVO
  200. cams to choose from...help plz
  201. Evo pistons???
  202. Stock BOV or Aftermarket?
  203. I need help deciding what to do
  204. Hard Intercooler Piping
  205. this is fpr EVO OWNERS W? HKS 272 cam shafts only
  206. wastegate and turbo support
  207. help!!! I spun a bearing and have 7 grand to blow on it
  208. Intercooler piping.
  209. Buschurs AEM Boost controller
  210. Got the car tuned at EIP and...
  211. cross threaded a turbo bolt...
  212. Are you happy with your Forge Products?
  213. VIII 10.5 w/ alky or IX Turbo
  214. Transmission temperature?
  215. Ti/Al 20g-9(-5) ?
  216. Is it the MIVEC or Turbo????
  217. Turbo back Exahust?
  218. Problem with throttle response
  219. Im having serious bov problems
  220. how do I know if my oil pump is broken?
  221. Anyone have experience w/ Exedy Stage 1 Clutch?
  222. My own evo project
  223. Prove my friend wrong
  224. Problem with throttle response
  225. Ams and Buschur injectors question?
  226. Anyone changed their spark plugs on their IX?
  227. T04S ar.70 ported shroud.. where ?
  228. anyone using ultimate racing stage 2?
  229. Anyone seen this malfunction before?
  230. Quick disconnect cat/test pipe?
  231. stupid question on alky settings
  232. WARNING Do NOT use OBX Products!!!!
  233. ACT carbon/carbon clutch
  234. help me choose my next mod
  235. some worry here, might buy 03' evo 8
  236. Quick Question about SBC I-color... Boost controller
  237. Any IX's with big turbo?
  238. Any IX's with big turbo?
  239. downpipe w/heat tape?
  240. Cylinders 2-3 won't fire
  241. Diverter Valves... Max PSI
  242. Modulation Question...
  243. DC Stainless Downpipe W/Cat Delete
  244. UNOS Boost spiking: Please HELP
  245. DSM vs EVO Cam gears
  246. Affects of wider intercooler piping?
  247. DNP or Full-race ex manifold
  248. Buschur Stage 1: w/ Test pipe- How much WHP for 2003 Evo 8 stock?
  249. intake manifolds....
  250. clutch problem
