PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Getting ready to install cams.
  2. HELP....6th Gear not engaging
  3. FYI ... AMS Engine Break In Procedure
  4. Evo9 fuel pump vs Walboro 255 data inside!
  5. I'm a compulsive ebay purchaser
  6. Forge WGA torn apart... suprise inside
  7. alky or n20??
  8. Helix 3" downpipe - false knock / pulling timing?
  9. boost problem
  10. Need your thoughts on somthing
  11. Center Diff is out??? Front wheels spin like crazy in launch! HELP!
  12. Lower IC pipe Problem HELP!
  13. HKS DLI Twin Power - fried both Coil Packs?!
  14. afr's
  15. 4.11 gear from galant gvr-4?
  16. VIII Turbo vs IX Turbo (data)
  17. ok heres my setup what should my whp be?
  18. Agency Power kit
  19. Guess My Hp!!!
  20. How much boost you running stock.? or close to stock
  21. Q's for anyone running 280's
  22. Boost Pressure??
  23. Buschur 3065 turbo makes 473whp
  24. Debate: Cams or Turbo upgrade first? (evo IX)
  25. Maxing out the stock turbo on pump - need your input on UICP & Stock Intake Box
  26. Injectors for 37r
  27. is this the right o2 housing from ebay
  28. Check It Out !!! Some Last Minute Advice Please !!! :)
  29. MBC Hose Size
  30. Nisei Licp Diameter?
  31. Skunk 2 CB exhaust
  32. Will the Forge bov hold boost on a GT35R?
  33. Whistling Throttle body
  34. Do I need a Walbro pump with just a TBE?
  35. Best valve springs-retainers for IX ?
  36. basic question, turbo upgrade on stock ecu flash....
  37. Dyno Numbers
  38. Plug Selection with Nitrous
  39. What injectors for 500 awhp Street car?
  40. o2 Housing/Downpipe install
  41. TIAL Vband turbo housings....
  42. what do you think of royal purple gear oil. its hard to get it in to gear!!
  43. do i need to tune by doing the following mods ??
  44. Can this piece be replaced? [PIC]
  45. clutch questions PLEASE HELP
  46. possible boost leak...
  47. Camshaft profiling..
  48. Want to get better dyno numbers without spending money?
  49. Max boost for a Evo IX with stock ecu???
  50. Silkolene?
  51. Measurements of removed internals
  52. IX owners: Who's toasted clutch already?
  53. Syncro shot??? help please
  54. Need help car died, won't start
  55. Flush the tranny at 2000 miles?? Diff too??
  56. how well respected is the WORKS brand??
  57. Help Before buying a 20 g Turbo.
  58. Mail In Flash
  59. Trans trouble already?????
  60. ECU Code Storage?
  61. Best cams for the money for Road Racing
  62. Intake Question
  63. turbo custom flange
  64. Need Wastegate Decision
  65. Why you MUST get a tune when you add a air intake to your Evo
  66. Buschur Exhuast testing - + 23 WHP (dyno sheet and Video!)
  67. HKS Downpipe on a IX
  68. Custom oilcooler setup and trans cooler..
  69. Rod Bolts-Upgrade or not to Upgrage?
  70. Tomei il thermostat eliminator or twin oil cooler setup?
  71. best clutch for the money?
  72. Exedy Cerametallic
  73. High EGT
  74. EVO IX Engine Gaskets.
  75. Clutch Position Interlock-ECU Pin / Wire
  76. Shearer 35R dyno results
  77. e10 (aka "gasohol") v/s Super Unleaded
  78. Fuel pump whine?
  79. Your thoughts on the Perrin Hoses
  80. just got my evo ix saturday,, 2nd gear grinds
  81. Diesel fuel inside the OEM lifters???
  82. What's limiting power on stock internals?
  83. Blouch Dominator 3.5 Data log lab dyno
  84. Anyone using JAMM lifters??
  85. Inertia of Exedy Twin Clutch Disks vs. Stock?
  86. I think I hear the death whine??? Not sure?
  87. revolver cams+stock ecu who has it i need help
  88. revolver cams=stock ecu who has it i need help
  89. act clutch broke after 20k miles
  90. Video - Clutch Tech interview with Fidanza
  91. If you have an HKS SSQV....READ it
  92. HKS Carbon Ti sound level? db?
  93. Whats missing from my 2.3 Stroker&20gLT Setup????
  94. May seem noobish, but a little bit of help is needed
  95. Anyone use an Infiniti TB w/ IAC motor on a evo?
  96. Best Intake Manifold and TB Combo
  97. Ralliart intercooler pipe installed
  98. stock turbo full boost at 5800RPM need help
  99. which set up for my evo ix
  100. AMS Stage 1
  101. TIlton Carbon on Carbon And Full Blown Fuel Top reviews with pics
  102. Not firing
  103. Questions concerning new o2 housing with downpipe/cat delete installed?
  104. Turbo is maxed out, why?
  105. Anyone running a Buschur Racing 20G-9LT Turbo on a 2.3
  106. Boost and Wastegate Issue's.
  107. HKS cam question
  108. gear ratio 5 speed
  109. F/S GSC 272 cams, int-exh, cheap, pics
  110. Titanium exhaust manifold......
  111. injector tips
  112. Snap rings
  113. 02 housing
  114. Help Needed! Please Help Meeee!
  115. Ported Stock Turbo Manifold Question
  116. What's the best air filter?
  117. Tranny? Clutch? Synchros? How to tell...
  118. 2.3 stroker (prolong life or shorten)
  119. Vibration on Acceleration
  120. Installing the MR Turbo
  121. 6th gear problem
  122. Exedy Twin Plate Clutch
  123. 2.3L GT40R Which Clutch/Parts to go with?
  124. Added a couple parts and a tune
  125. Broken Thermostat. frozen on C
  126. comp cams 280
  127. Forge MBC Users -how much psi increase per click?
  128. Anyone have a APS 3.5 TBE
  129. Transfer Case Blown :(
  130. Safe mods for Stage 1 tune?
  131. ACD Revisited
  132. valve spring compressure tool NEED ASAP NJ
  133. DIY catch can for stock engine bay
  134. Is it normal to smell the clutch on Breakin?
  135. is this an evo 8 lsd?? with pics
  136. ARC Intake - gains & sound
  137. Detailed write-up of walboro vs stock pump
  138. what whp will i make? EVO IX
  139. injen intake on ix
  140. need advice!!!
  141. MZ313376 from MitsubishiParts.net missing part number
  142. Who makes the best intercooler piping kits?
  143. lookin for AMS GT30R kit
  144. Help me find a 4.11 gear, please!
  145. Stk ECU, Power FC some moonshine and some power...
  146. shortblock question
  147. 6 spd upgrade
  148. Need Help!What are the safe temperatures for Water and Oil???
  149. Race Gas
  150. weird boost problem.
  151. Odd Smell/Gurgle, input needed
  152. My little project
  153. Doing Pistons and Rods in the car?
  154. Induction Pipe
  155. throttle body leaking bad. HELP ASAP
  156. 6 Puck vs Twin disk Carbon. Lockout
  157. how hard is it to change syncros
  158. stock gauge with aftermarket
  159. What's a good shifter?
  160. See if you can figure this one out, crazy boost problem. Help!
  161. radiator hose burning
  162. Safe boost
  163. Anyone had success with an aftermarket head gasket?
  164. This look legit???
  165. Battery Relocation Fuse Protection
  166. Forge BOV Backwards Install??
  167. How many miles on ur exedy twin?
  168. Spark Plugs
  169. GT 55 - pissing race
  170. Anybody know how to get ahold of TRE?
  171. Just received my Carrillo Rods and Ross Pistons
  172. Who has/knows/can locate the TIAL Cast SS Housings
  173. I blew up my td06h-20g turbo =( (pics)
  174. full bolton--ic helping any?
  175. Ams 23rr & E85
  176. Clutch install complete w/ reviews
  177. removing radiator hose
  178. Clutches
  179. greddy intercooler kit evo 9?
  180. ported head ???
  181. Where can I get stiff spring for Forge UNOS???
  182. Limit of Efficiency for Stock Evo IX Turbo in PSI
  183. Turbo noisier after LICP swap?
  184. Stalling problems...
  185. help with a cat back install
  186. Is a tune vital if I add a FMIC and LICP?
  187. How bad did I mess up my head?
  188. Advice on 02 housing...
  189. Evo Cranck
  190. Basic Bolt on help
  191. Just got my JunB.L exhaust system!!! 56k beware
  192. Evo Cranck
  193. LICP popped off, after i put it back on engine wont start
  194. After all the BS, finally I got some dyno #'s
  195. BOV UICP question?
  196. Which intake?
  197. just picked up a br500bb turbo kit on ebay with pics
  198. Evo losing juice
  199. developed a 5th gear grind today!!! help
  200. 50 trim turbo specs?
  201. Mobil tranny fluid?
  202. what settings?
  203. Wheres all these Cosi Cammed 9's @??
  204. Buschur Racing TBE
  205. new intercooler or just new upper and lower tubing.
  206. engine issues?
  207. Cam install: Assembly lube needed?
  208. how to tell what size turbo u have? help please
  209. ARP Head studs
  210. a/c line hose
  211. Help! HKS EVC on external wastegate setup!?!
  212. Is my Clutch going?
  213. Mods Safe to run Stock ECU
  214. buschur race ic install (pic)
  215. How to adjust boost according to weather?
  216. apexi s-afc II problem
  217. Brand New Hks Turbo Timer 110 Sipped
  218. Question about purchasing the green
  219. Shifting problems - Transmissions?
  220. best clutch....
  221. Injen intake and Uicp.
  222. Anyone has this coolant leak before?(pics)
  223. Time to replace the OEM knock sensor?
  224. Help with bad cylinder!!
  225. Does this look like a good deal? (eBay Clutch Cable)
  226. BR turbo outlet pipe & Forge WG, will it work?
  227. motor oil recommandation
  228. Head specification
  229. Best clutch for bolt ons?
  230. Cam Combinations "PRO’s and CON’s "
  231. Valve Question
  232. G-Reddy EBC + Dyno Flash vs Works Flash
  233. SlowBoy racing Turbo Kit 35r Who is runnig it?
  234. 24psi with TBE/filter and stock boost control
  235. Safe Charge Temp for 85F Ambient/Inlet
  236. gt35r/stock motor
  237. Evo 9 Tme 20g 10.5th
  238. I Have a Failsafe for My Meth Kit. What Else Can I Get to Monitor Everything?
  239. Ultimate Racing or Buschur TBE?
  240. How is the 20GLT at high altitude?
  241. Car binding on turns. Front diff???
  242. projected dyno numbers???
  243. RMR hood scoop
  244. Look inside
  245. Any1 know any vendors selling just gsc exhaust cam?
  246. out with the old, in with the new
  247. Overbore Limit.
  248. Intake help??
  249. Need help asap.. Oil in IC piping
  250. dp and rs-r ex-mag
