- 4G63 Ali Block (UK)
- Question About Valve Cover Breather Filter Install
- turbo vaccume question..blown turbo!
- Feed back regarding CAM gears for CT9A issues? (HKS or Tomei?
- Evo 9 Bogging / Hesitation under Boost
- Towing Evo with transmission out?
- 4G63 head
- evo 8 axles from other year evos
- Brand new Evo 8 9.8t engine
- ECU triggered relay for 2nd pump
- Fuel Pump Wires Extremely Hot
- Turbo Blanket, pros/cons
- Anybody have any experience with Thermal?
- cc clutch failure!
- Jun 264 or 272 for my needs?
- Can I safely put cams on my evo?
- Holset HX40: Single Scroll T3 BEP .70 A/R housing VS 19cm Twin Scroll T4 Housing
- rear axle inner cv joint question
- Low boost, loud engine noise!
- what's the deal with my oil?
- Boost response
- Tensioner Bearing?
- odyssey PC680 problems
- 03 evo 8 engine build
- Cam position sensor?
- Does evos really need a aftermarket Fluidampr on a 550hp+ cars
- Low compression reading in 1 cylinder
- Car idling at 500rpm, shaking, vibrating. Sounding like its going to stall.
- Balance Shaft Elimination Questions
- Exhaust leak suspect manifold
- Propshaft Length
- Advice on 3 inch Cut out or Full Exhaust
- oil press. 12 psi
- Will an evo 4 valve cover fit on an evo 8?
- 4.3 Final drive
- Upgrades for Gt3582r
- Evo gsr cams vs GT-A
- Fp red ss housing price
- 1st to 2nd gear change problems
- Has anyone ever used the Okada projects plasma COP kit?
- GSC S2 versus GSC S3 for 2.4L MIVEC (none LR)
- AYC/ACD-relay not getting signal
- Wtb: Hks gtii 7460
- Evo 7 Conrod and piston Replacement
- Best cams for stock valve springs
- time for a new clutch
- Aaaaaa what the hell is this?
- Clutch disengagement issue
- At what point do you need to drill the valve cover for venting?
- I need help with HKS camshaft
- Tomei 280 Pro Cams - Evo 4-8 - Timing Settings
- evo 8/9 driveshaft measurements
- busting up high RPM
- Evo 6 Plazmaman Spec R Kit
- car misfires at high RPM
- Garrett Air/Water intercooler from AMS?
- ACT HD Street vs. Helix organic
- Evo 8 Rough idle
- Weird boost problem. Help appreciated
- Balancing the motor with the clutch
- mods for E85 plz help
- I think its a boost leak?
- Need help Evo 7 conrod replacement
- Engine trouble
- Evo 9 turbo install help
- evo 9 HKS cams question?
- FP green vs FP green 73hta
- Exedy twin to tripple question
- Blow motor build in process
- 4g63 smoking from breathers (blow by)
- Need help to fix log end blogging
- Milky oil but full on coolant. Rough idle. Vid inside
- HKS Cam Gears/ Timing issues
- OEM v.s Rebuilt Drivetrain
- To rebuild or not??
- What happened here too much rev or poor detonation?
- Shift linkage cable problem HELP
- Evo IX 6 Spd Manual Transmission serive manual
- Need Help! Upgrade Evo 9 Drivetrain System.
- Weird Issues after EGR delete...
- Hydraulic release bearing for Competition Twin?
- Letting You In On The Secret.... Face-Platted Transmission
- How did this engine even run?
- Help bleeding ACD
- GSC S2 cams on stock evo 6
- engine build tips?
- Should I run this block?
- URGENT! Fuel injectors difference
- Opinions on valvesprings GSC or Kiggly...
- O2 housing work with Ultimate Racing 3" downpipe
- Downpipe setup for FP's new SS housing. What are you using?
- 2.1L water pump adapter plate help!
- best turbo for e85 and stock block
- HKS 272 stock turbo e85 question
- I need help.
- Car bucking on/off throttle.
- quatermaster twin judder
- Boost gauge reading
- Checking to see if my bottom end has been built
- High Idle After Warm-Up.
- FPR evo VIII
- ACD tcase to 8 shell?
- Question about a anti-lag system. Not pops and bangs!
- ACD Failure Just Coincidence?
- HELP! Flashing back the ACD??
- trial mvr44 what spring/springs to use
- Intake Port Dynamic Pressure - High Speed Data on Kiggly Racing Drag car
- My 7 seems to go to jelly under heavy acceleration in corners. AYC issues?
- help ! What is the best recirculating bov ?
- Evo IX 2.4 cam noise?
- Building motor 2.0
- Low compression in cylinder 1 & 2
- Vband or Twin Scroll manifold
- mapperformance downpipe?
- Balance shaft inspection hole breather
- evo 8 wga on FP red?
- Gsc s2's vs s3's w/fp red
- Evo fuel/boost cut...? Need help
- Fuel Pump Questions
- Loud exhaust?
- 4g64 help
- Evo bolt ons?
- usdm evo ix + jdm engine swap
- Help me identify this Forward Facing Manifold
- 4g64 Question: What oil pan setup?
- Thermostat problem maybe
- Evo 8 missing sounds like a Subaru. Need help!!
- Noisy Gates Timing belt - Evo 8
- dual 255's or single 450 walbro
- oil cooler question
- Need some modding advice
- timing belt tensioner question...
- Fp red not barley spooling.
- Front wheels spin while lifted and in gear
- Transfer case
- Solid Street/Strip Turbo for New Build?!
- Fuel Pressure Regulater
- My compression test results
- idenify this turbo?????
- Worth the upgrade to 71HTA CHRA from stock 9 turbo??
- Why is front engine mount incorrect size??
- Engine Ticking Sound HELP!!!
- Installing DS front axle seal. Tips and advice needed.
- Planning for Next Steps... Lookin for some opinions
- discussion about the oem heat/sound deadner
- Car won't start.
- anyone know where I can the inside of valve cover cleaned?!!
- Precision 6466 Boost creep
- Intake manifold for MY setup?
- PST CF 1pc drive shaft installed - 700hp/510tq
- Evo 8 Rattling from Head/Valve Cover Area During Idle and Decleration
- another turbo id
- blown Fp black?
- precision pw46 or. tial MVR v44 wastegate
- will an evo 7 valve cover work on an evo 8?
- PCV Valve Variations?
- Failing walboro 392 external?
- My build.... Your opinions
- 1.25" vs 1.5" exhaust manifold comparsion test
- Solid side diff supports without mustache bar
- Evo 8 Rich Problem at WOT
- S3's too big for EF3?
- Compression test results
- Transfer Case clunk
- Evo 8 w/ 4g64 2.4L block
- Is 20g upgrade different for evo 8/9?
- Evo 8/9 Sheepey V-Band Turbo kit (link)
- Exhaust Header Gurus - Need advice - Pic attached.
- manley vs oem crankshaft question,..
- 06 Evo won't rev help?
- Balance Shaft Install
- Oil Pan Cleanup
- map h11 headstuds
- twin 450, 6an aeroquip lines, fuelab FPR and ID1300 OVERKILL for my setup?? 550hp E85
- Evo 8 block question
- Turbine housing outlet
- Having issues with engine load
- Hobbs Switch
- cam timing and its relation to lifter noise
- 'Rs' rear diff, do I still need a pump for the acd?
- Need some catch can advice
- Loud sound when getting into boost
- 05 MR axle seal.
- Rrm head
- please help me guys, questions about clutch
- Boost leak at IACV
- gsc s3 cams compatable with supertech?
- Evo 9 parts
- exhaust size comparrison, big hp
- What else do I need to install this FP red?
- loud drivetrain noises
- 76 mm turbo elbow and downpipe..
- Engine Re-Build Options
- dirtball 2.3 build
- Car dies when MAF sensor is plugged in
- Waste gate problem
- How to tell if a turbo is BB or JB
- install gsc valve springs and retainers with head OFF the car?
- half radiator + DBB turbo fitment?
- EVO V hwy cruising at 3.2-3.2 RPM!.
- Questions Regarding Blowby, and ECU information
- Subframe trimming for tranny installs
- Combustion chaimber is copper color and spark plugs too car isnt spooling up too
- Tomei Arms Compressor o'ring
- Need help with Agency Power Shifter Bushing install.
- E85 Base Tuning 1200PTE AEM
- Evo 8 Turbo to 20G 10.5 Conversion
- ceramic disc for oem clutch ?
- Evo 7 with HKS FCON and Horrible 80MM throttle body want to go to stock ECU HELP
- weird boost sound
- new location for pulling vacuum on pcv side
- QM Twin not engaging..
- Exedy Twin HD too much clutch for 450-550ft-lb?
- Fp zero vs pte 6262
- Flywheel removal help
- Is my motor toast?
- Are my std IX (fq-340) cams an upgrade for any other models
- Aftermarket o2 housing with stock turbo worth it?
- 2006 evo ix rs weird ratte/grumble noise when building boost
- Pic request: Shift linkage.
- Fuel Pressure Dropping - New Pump, Reg. etc.
- Head Gasket
- New exhaust manifold a bit 'lippy'?
- Crank no start? Please help me someone!
- DC Sports Downpipe flange issue
- Best Exhaust Cut Out Option
- P0125 won't go away
- 2.4 and 6266 Question. .
- EVO 8/9 rear diff housing unusual # stamped on outside; seems incorrect!?
- Notchy shifting after new clutch ruining my fun..Any advice?
- Sudden vibration under a load.
- Taking care of my friends evo, need adivce.
- Throw out bearing recommendation.
- Engine loss of power after shift (any gear)
- Camshafts for evo 8
- Camshaft for EVO IX
- Oem clutch chatter?
- 404whp intake, tbe, meth inj what's next??
- 4g69 crank vs 4g64
- Clutch was slipping, now it's not.
- Replaced bushings still have same problem. Whats next?
- Reviews of arashi 20g turbo?
- Td06 20g for 400whp?
- Precision 6262 with 272 hks cams?
- How safe is aem meth injection?
- 2.4L Question - Need help ASAP
- Syncrotech Carbon Syncros Review
- Buschur Racing's Clutchless Four Speed project for sale
- Carrillo H beams vs turbo tuff I beams
- change in throttle hang after sustained WOT pulls
