PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Twin turbo EVO???
  2. Header question
  3. CEL Problem
  4. Lancer EVO wanted for showroom floor at SEMA show in Las Vegas
  5. Has anybody in or near TN done a clutch?
  6. Hissing Turbo?
  7. New Intake - Your Opinions
  8. Advice me on exhaust buy
  9. Fuel System Revisited...(for roadracing)
  10. my short Injen Intake and IC review on the install...
  11. HKS FCD std or K3?
  12. what causes overboosting ?
  13. for those of you w/ the HKS DP and Cat-back
  14. P0139 code - need some help
  15. HKS GT 3037S Turbo kit
  16. Who said Evo 1st gear was too short?
  17. Twin Scroll Vs. Standard Scroll
  18. Wategates
  19. Cat Back system. Worthwhile?
  20. Harsh engaging clutch.
  21. Which BOV WONT stall the car at idle...
  22. A better valve guide
  23. Pro Turbo Kits
  24. 444whp /BR500 turbo
  25. Help!!! Can't get the P0300 flash!
  26. Rear Oxygen Sensor
  27. For those with the Turbo Smart E boost...
  28. question i cant find the answer to on here about SS clutch line bleeding
  29. Turbo Trix reflashing the BR500
  30. Need Help With MBC on GSR
  31. Standalone Ecu
  32. Ever Welded the center Diff. gears I.E. in a GSX, What about the EVO?
  33. Is it a synchro?
  34. How to disable boost fuel cut ?
  35. ECU pulls timing when RICH??
  36. Throw out bearing ?
  37. car running richer in 3rd/4th gear than 2nd gear?
  38. Just received Hyperflow FMIC
  39. Are there any how to's for the clutch
  40. HKS cams
  41. Cant find the nipple
  42. How much play in turbine shaft is too much?
  43. 550 Awhp
  44. Shifter Base Bushing Install
  45. 2005 center diff. in a 2003
  46. clutch install help
  47. RNR racing-where are you
  48. What's the best short-throw shifter?
  49. Releasing Throw Out Bearing
  50. Brake/Clutch fluid resevoir top off
  51. Vendors: I need an HKS 272 exhaust cam
  52. Exedy Single or ACT 2100
  53. WORKS vs TOMEI
  54. problems with FORGED BOV ?? just me??
  55. Ebay Exhaust Manifold
  56. Low vibration when turning at low speeds..
  57. garrett gt60r
  58. how far after the turbo do most people install 02?
  59. Need best pricing on ACT clutch!!!
  60. Estimated reflash WHP gain with these mods...
  61. Anyone Use RalliArt Dual clutch??
  62. Anyone have the APS Intake?
  63. Question about exhaust
  64. Need help with MBC Install
  65. Vibration Spitting CEL Light?
  66. Boost/VAC at Idle - is this normal?
  67. Installing HKS SAFR
  68. turbo trix ecu flashes??
  69. Lumpy idle after fuel pump and grounding kit? (HKS 264/272)
  70. Boost control solanoid (soleniod?)
  71. Ok I have a little problem
  72. I have a problem!!
  73. WTF my car is bone stock and still have problems WTF!!
  74. AVC-r wont hold steady boost?
  75. Burnt Clutch BAD last night.
  76. How hard is it to hook up the Greddy Type S BOV?
  77. Installing Greddy Oil Block
  78. wideband installed. running rich as hell (9.6)
  79. Buschur Intake Manifold Install
  80. AMS Intercooler testing
  81. how much are the Mitsu. Spark plugs?
  82. Boost problem at track, but not on regular roads!
  83. i hate my evo....may get m3
  84. 350 at the wheels....
  85. Helix 02 housing
  86. Best Intake for the EVO
  87. Help! my evo is broken.
  88. Got my 1st mod done!
  89. suggestions for 400-450 whp
  90. Installing my ARP head studs
  91. car stalling
  92. NEW! Buschur Racing Evo 8 Blower Kit!
  93. Got my car tuned @ Turbo Trix
  94. Pruven FMIC question regarding upper intercooler piping
  95. good news........bad news.........
  96. Using a boost controller to hold boost until redline
  97. NOt another clutch question!
  98. Wideband O2 Sensor
  99. Exedy Twin Clutch Questions.+.AWSOME Website for Parts!
  100. Greddy Warning Boost Gauge Acting Wierd
  101. Evo throttle body same as 1G or 2G?
  102. Buschur Racing Air Filter Kit Install?
  103. For those with the Walbro 255 lph Fuel pump...
  104. 165 Forward, 0 Reverse Help
  105. Clutches.....
  106. 350 horse @ wheels: observations...
  107. WTB Sheet Metal Intake for Evo
  108. Bonez SS braided and coated clutch lines
  109. buschur turbo kits compared to ams turbo kits..
  110. Cam gear settings with larger turbo?
  111. which should i get?
  112. S-AFC and 272 Cams
  113. Turbosmart E-Boost?
  114. Cleaning Monster Sport Filter
  115. where to find fuel rail fitting?
  116. Cutom IC pipe pics
  117. Is there an adjustment for the evo clutch.
  118. Helix Turbo-back dyno's???
  119. How to detect BC install?
  120. turboback vs. catback
  121. Evo Spark Plugs
  122. What do you think about this??
  123. No Knock ????
  124. Shift Linkage Problem
  125. Greddy Turbo Timer install help
  126. Ball Bearing Turbo Conversions
  127. People with the APS turbo back I have a few questions?
  128. hks cams
  129. Mods & fuel efficiency (mpg)
  130. Instant 12whp In 5 Minutes
  131. HKS BOV flange query
  132. DSM Injectors = EVO Injectors?
  133. What's the best intercooler?
  134. shifting problems
  135. More MR valves!
  136. royal purple
  137. Which Mbc?
  138. If you've changed your own injectors -- please help
  139. Able to hold more boost with toluene????
  140. Random Misfire 0300: Dealership reflash available...
  141. Do headers make a difference??
  142. Major drivetrain problems...not my rear diff.
  143. Engine F****d up bad
  144. Anybody using a Palmone for diagnostic?
  145. Cat back diameter and TQ.
  146. Tubular VS Stock manifold
  147. Question about pistons and rods.
  148. P0120 Ecu Code
  149. Coolant Leak, anybody else?
  150. Ralliart Thermostat
  151. BR440 questions
  152. Hallman Pro boost controllers and evolution kit question
  153. 9.8t titanium turbos vs 10.5, what is this?
  154. Put fuel pump in, but they sent me the wrong install kit
  155. Throttle cable slack, CHECK IT!
  156. O2 Housing Explained
  157. Do the Tomei 260/260 pro-cams idle smooth??
  158. EVO-8 on EVO-6.5TME
  159. For those with MBC's...
  160. Evo running like #$%^
  161. Innovate LM-1
  162. 1st gear grind at 1800 rpm's
  163. clutch kit or clutch disk???
  164. In need of the torque specs on the main bolts for an EVO 8
  165. Tips for fuel management
  166. The HKS CORPORATE response to the HKS SSQ BOV
  167. mappable ecus for evo 1 to 3
  168. So what mph is 8600+rpms in 5th gear??
  169. question
  170. need advise - Knock Noise
  171. NX intercooler chiller, any input?
  172. APEX'i Induction Box...??
  173. Buscher downpipe question?
  174. Question about Engine Oil?
  175. Custom IC pipes
  176. Vibrating sound from tranny???
  177. HELP!! Clutch Install Questions
  178. Irridium plugs available around the corner...
  179. Help! Clutch Problem
  180. HOW TO: get rid of stinky Check Engine Light (test pipe) (HFlowC)
  181. !! 5th Gear Synchro TSB FOUND !!!!!
  182. Intake pipe, of any kind?
  183. Full Intercooler piping around $300
  184. Is This A Cold Plug ?
  185. 91 octane - 420 whp
  186. Hey whats everyones Vacuum level at idle?
  187. Gains from Greddy Ti?
  188. K&N drop in Vs. RMR intake filter
  189. I want BOV but not lumpy idle - possible?
  190. 606 Whp!!!!!!!!!!!!!!!!!!!!!!!! [MERGED]
  191. STAGE 1 FROM RMR 320 AWHP....IT'S THAT POSSIBLE?>>>
  192. Who has plug and play o2 sim?
  193. Speed Source Intake Kit
  194. Solid lifter adjusting solution
  195. Urgent help please
  196. rnr exhaust manifold
  197. Sticking MBC?
  198. Accufab throttle body linkage solution
  199. Octane RON of your gas?
  200. hks 272i/264e
  201. something wrong with my engine or tranny???
  202. EVO III BIG 16g
  203. Problem after exhaust install
  204. 4G64 or 2.3l Stroker
  205. Running rich in-between shifts
  206. ATI super damper?
  207. gas issue!! (HELP)
  208. projected reliability of the 4g63 at 350-400whp?
  209. Upgraded intercoolers that can be used with the stock airbox?
  210. Opinions on AEM intake?
  211. Fuel Pump - Can you replace it when the tank is full?
  212. MIVEC on a Evo (has anyone tried)
  213. grindin durin down shift from 2nd to 1st
  214. Best Internals
  215. Knock limit?
  216. Having problem with injector clips
  217. Stock Boost Control problems?
  218. Turbotrix Turbo Kit !!
  219. My Second upgrade Perrin Exhaust System
  220. Ralliart Exhaust
  221. Is the UR Blowthrough MAF worth $650?
  222. Will an EVO 7 AYC Diff work on an EVO 8?
  223. im not sure if this is normal???
  224. Question about stock MAF sensor
  225. metal in oil
  226. what do i tell the dealer? (help)
  227. Which is a better clutch-ACT or Clutch Masters
  228. any aftermarket transfer cases/trannys options?
  229. Need measurement!
  230. How much would the HKS SSQV take?
  231. What is the loudest BOV?
  232. Stock Fmic Peak
  233. having major drivetrain problems
  234. Help, oil leak..but where?
  235. Apexi N1 catback..Anyone has it?
  236. HELP! I need a cable identified
  237. Anyone have any experience running open header??
  238. Just ordered the Walbro 255 HP fuel pump, the 342 model
  239. Fluttering with turbo xs RFL BOV ???
  240. Please Help Out a Feelow EVO Owner!!!!!
  241. DSM Diverter valve best mod yet!
  242. Where to get an Adjustable FPR?
  243. Turbo pipe, Throttle bpdy pipe....
  244. Higher injectors without tuning ok?
  245. radiator
  246. Stock BOV vs HKS SSQV?
  247. Best catback for the money?
  248. profec e-01 install? Pictures?
  249. Cusco Heatshield Group Buy?
  250. Power Enterprise Timing Belt Noise
