- People who use meth, what kind?
- Which Hallman MBC?
- Maitenance question
- Drivetrain noise
- HELP, 5th synchros grinding
- [B]the rabbit has landed....and it is good.[/B]
- Stock Springs & Retainers vs Crower
- a noobish question.. sorry but..
- Boost problem fix!!!!
- Need urgent help with boost controller *removal*
- grey smoke
- Variable Area Turbine Nozzle on Turbochargers
- manual dual boost controllers
- which clutch:read this thread fools!
- act clutch install
- Buschur GT3076R turbo kit ?
- TopSpeed Evo Destroy's Tranny!!
- boosting around 24psi????
- Spark plug heat
- New upgrade path, need some help.
- anyone gone from Greddy Ti to HKS?
- target set on 500WHP
- External Wastegare welded on stock cast manifold and a few out questions
- need help for my friends Evo!!
- water injection on stock turbo
- invidia exhaust
- tubular header question
- Spark plug gapping
- skunk2 cams?
- clutch isses/questions
- No EVO.....No Help from buschur..
- clutch+flywheel combinations?
- Front O2 CEL?!? any fixes
- Best budjet clutch
- Anyone have the APS cold air intake?
- Tranny Help
- anyone using royal purple
- weird problems!
- FS: HKS BOV with Upper IC and HKS RS
- no dyno numbers from Full-Race?
- HELP! A/F jumping up and down
- Exhaust to intake port pressure ratios
- Warning Hks Cam Gears
- Does 04 have same problems as 03
- Tranny HOT
- FPR altering on stock evo?
- 3" NO brand name work???!!!
- Bad BOV or Boost Leak????
- 3" two bolt exhaust gaskets
- question about knock sensor causing car to stall
- changing exhaust manifold... gaskets?
- need re-tune after FMIC?
- input on boost problem
- PeakBoost A-spec fmic
- ??? Hallman MBC ???
- Cam choice?
- Can PO300 be fixed with HKS DLI-2 or C.O.P.?
- Calculating o2 Voltage to AFR
- Hallman Leaking....
- Best CAI??
- EXHAUST!!!! questions
- Exhaust gaskets??
- How is the six-speed gearbox on the MR compared to the normal Evo's five-speed?(more)
- Intercooler's compare(Ams and Buschur)
- Ignition Issues w/Nitrous
- Buschur Race Chip Install??
- Every upgrade on my car except PULLEYS
- Downpipe with or without flex piece?
- Aps Bov ?
- 400awhp??
- Valvesprings/retainers
- Forge Motorsport Aux. Racing Fuel Tank
- RS*R GTII Exhaust
- Cams Some finnal answers plz
- HELP! Couple concerns....
- Strange turbo problem
- UPDATE on my GSC cams please read
- Help,02 Housing Bolts?
- smc alky kit hardware
- Installing MBC tonight.
- Passing CA smog test with upgraded cams
- Alky w/o AEM?
- GSC cams with cracks
- Best turbo kit/turbo for solid 500whp w/meth?
- Jump on the twin charge wagon....
- Odd noise coming from my clutch...i think?
- RS*R sound clip!!!
- Boost decrease
- 300 HO @ Wheels possible w/Stock Turbo/91 Octane?
- My first Impressions of the NEW exedy Heavy duty Twin plate!!
- whats this knob do?
- New Part!!!
- What next?
- Ingalls Engine Torque Damper
- 2nd to 3rd high rpm shift (smelling clutch)
- Independent Oil study...
- Ebc
- compressor/turbine matching
- Shifter Setup?
- Manual Boost or not?
- Manifold to turbo Gasket for stock twin scroll.
- Narrowband O2 values vs. A/F ratios
- Possible Boost Leak after HKS Intake install
- BIG Shout-Out to Nick @ Buschur Racing
- Solid Lifters for the EVO
- How to sovle the problems with VTA BOV?
- what gauge should I get next?
- stock turbo efficiency map
- CAI opinion
- Something a MBC can't do
- alky kit questions?????
- Help with Cams!
- mods help
- Opinions on turbo upgrade
- Full race turbo kit...
- SAFC question
- Who builds the best engines?
- what catback is quieter than stock other than JIC??!
- Buschur ported OE manifold vs. header
- Problem with my MBC
- Help out the guys at Car and Driver....
- HKS 272/272 and gears without any type of engine management.
- Ticking noise from 5-10mph only?! help please
- ARC catch can...and catch cans in general?
- 2nd Gear Synchro Problem
- Best Spark Plugs - Big Turbo, Big Boost?
- Boost problem Please Help!!!!
- Is the 02 housing worth changing?
- Help me pick what to do to 'er next!
- JUST HI FLOW CAT, no downpipe, WORK??
- HKS 280 with stock retainers and valve springs can rev 8k?
- EGT probe breaking?!!!!
- which air/fuel gauge you recommend?
- Question Reguarding the RnR manifold or any SS manifold and EGT................
- First oil change?
- Apex'i Air box question...
- Forced Performance White Rabit
- Helis IC Pipes, Boost problem!!
- dumped exaughst
- High Flow Cat and Downpipe...
- GT3071 vs. GT3076???
- Cusco Twin Vs. Exedy Twin
- Acd Lights????
- weird sound from tranny area
- downpipe w/ stock cat PROBLEM?!!?
- Walbro Fuel pump help!!!!!!!
- greddy 20g turbo pics inside
- downpipe with EGT probe?
- Looking for a new clutch..
- maf no good????????
- My plans, please criticize
- Buschur Racing customer breaks our own records!
- issues with my nitrous system......
- FMIC's, exhausts, dyno knowledge & alky kits.
- ACT clutch - poll on problems
- people running nitrous...
- GSC cams valve tick
- defi d-gauge reading correctly
- SS manifolds Cracking.....What causes them to break?
- Whats wrong with my clutch?
- Fuel Question...
- 264/272/280 Cams which one should I use
- Replaced Plugs now po300 code
- AMS 3" tb *VS* APS 3.5" tb
- JDM Mr bov
- something wrong with my MBC?
- Stupid Question!
- Greddy Type RS Blow Off Valve BOV review
- Buschur Loer Intercooler pipe install??
- 1G DSM ignition coil and power transistor
- Question about GREDDY PROFEC B SPEC 2 installation
- Dyno results
- 301.6 whp dyno Mustang 05 MR
- Down pipe problems?
- What about a smaller intercooler?
- Calling all AVC-R pro's. Need help.
- best investment a downpipe or an intake???
- First gear not hitting 19...help?
- Looking for Compressor Maps for the Following Turbos.................................
- Boost q's..help
- Anyone using TOLUENE as booster?
- trying to find
- High revs after Clutch Install
- any flaws in my simple mod plan???
- 20G with Alky?
- My ACT story (not good) - please read
- GT42R vs GT35R
- PSI/bar setting for stock turbo
- From MBC to XEDE
- Loss of mid-range after BOV install??
- Velocity of gas going thru the upper IC piping
- New parts coming my way...
- running rich
- bolt size question (downpipe -> o2 housing) (x-post)
- BPR8EIX or BR8EIX?
- 2pc Under-hood Stiff Bushings Kit
- carbon clutch options?
- Transmission Oil Question for my MR
- **boost Fuel Cut Question**
- Need DP Feedback
- RnR PLease HELP! Wastegate problem!
- Fall/Winter Seazon Tires
- Car loss of power
- 3" Downpipes that reuse stock donut gasket...AND FIT '05
- Exedy or ACT, why 1k difference?
- cam differences...
- 2005 and CAI
- stroker?
- help needed:weird starting problem
- clutch pedal button
- GREDDY Type RS Bov Flutter
- Forge BOV: Type RS Kit or just Recirc?
- Need Urgent Help !! ??
- Ceramic coated pistons...
- exedy carbon slipping?
- DC SPORT or RSR DOWNPIPE FOR 05, MR?
- Intake Cam Theory
- want more power....options..
- AMS exhaust?
- What is that rattle!!
- help with cam install(cam angle sensor)
- Installed buschur intercooler/hallman pro Need help....
- headbolts required? for 380-400whp?
- Radiators: Which is worth the money?
- finally moding. FuQ miTsU!
- Installed FJO WB02 in stock clock**pics**
- turbo
- 2.2L vs. 2.3L Stroker Kits
- To XEDE or To DynoFlash?
- How to get Exedy twin plate to work right
- I'd like your opinion on turbo selection.
- Who using the Forge BOV Type RS Valve Kit
- Aftermarket Ignition coils.
- front output shaft seal pn's?
- is the oil cooler on the evo.. temp controlled?
- quick question on mods to reflash ratio (if i make an sense)
- EVO Overheating....
- HeadGaskets....OEM Vs All
- Simple Clutch Question
- Forge Wastegate actuator?
- Diaqueen clarification
- Redline water wetter ???????
- question about 20g turbo
- what's the best engine coolant?
- exhaust leak?!? help
- more tranny install woes...any advice?
- Oil leak after HS install????
- tubo kit
- atpGT3071R turbo kit
