PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. Hks 7460 kai or non kai???
  2. Coolant came out of o2 dump?
  3. Enough fuel for 550whp?
  4. Purge tank
  5. Albins 3-6 speed cluster, any long term users?
  6. Evo 9 transmission to block dowel pins are preventing install
  7. Stock transmission gear HP limits?
  8. HKS GTIII-RS Turbo Specs/Information
  9. Knocking in the Rear?
  10. Best evo/4g63 machine shop?
  11. Interchangeable camshaft position sensors?
  12. Stock location turbo IC piping
  13. Engine Serial Number
  14. Stalling problem
  15. Evo 3 LHD conversion
  16. Map 2.0 block
  17. 100 cell cat + o2 dump? anyone try this?
  18. Clutch replacement - trusted shops midwest
  19. Problem with fuel
  20. Evo Build Thread with a slight issue.
  21. What should I know about operating a dyno if I want to rent time?
  22. Slave cylinder bleeding
  23. Another 4g64 timing questions.
  24. One Piece driveshafts (anyone make them anymore)
  25. Evo misfire/running on 2 cylinders
  26. Evo Tarmac Gravil snow light
  27. Evo IV No power to one coil while car is running
  28. Biggest twin scroll non forward facing turbo
  29. Tubular Headers and Thermal Protection
  30. What intake manifold shifts torque to the left the most?
  31. Need help identifying cams
  32. OEM fuel return fitting size?
  33. Fuel Issue
  34. Which clutch hmmm - I know another post
  35. Anyone willing to sell or know where to buy a 5 speed cable bracket???
  36. 4G63 Weight?
  37. Tomei oil scraper 4G64
  38. Evo 8/9 Skunk2 manifold
  39. Discovered my coolant reservoir empty a few days ago, blown head gasket?
  40. Loss of compression from one cylinder
  41. Identifying CBRD BBK turbo
  42. Evo 8 600Whp guide
  43. Transmission needing rebuild.. Thinking JacksTrans?
  44. Air filter suggestions??
  45. Need Vacuum line help with new turbo
  46. P0121 P0113 P0107 P0300 Codes popped up all at once
  47. Airtrek blocks
  48. Need help for Evo7 Ayc rear diff
  49. Head gasket help
  50. Exedy Triple SD vs Exedy Double HD
  51. Can’t Go Neutral During Decel
  52. turbo question? oem 9 or not?
  53. 2.3 or 2.2 build with stock ECU/OEM tune
  54. Rebuild cost
  55. Car is slow while ABS light not ON the dash
  56. Rattle from Rear at 2500RPM
  57. AFR Lean idle issues
  58. Evo 8 dies after for driving for 20min
  59. 2001 TME Evo6 transmission ratios. Are these correct ratios for this TME Evo6 ?
  60. Boost pressure help
  61. Whining noise coming from rear differential
  62. Precision 6466 shaft play after 2,500 miles?!?
  63. Evo VIII AIT (air intake temperature) sensor install
  64. Evo6 AYC diff VS plated LSD, your opinions please
  65. Evo 8 9.8t turbo charger upgrade options
  66. Evo 8 buddy club spec ii 264 cams anyone used them?
  67. AFR issues
  68. What is the 4.11 drive ratio?
  69. Upgraded Springs/Retainers w/ Stock Cams?
  70. Evo8 Running Extremely Rich
  71. To upgrade the turbo or not...that is the question
  72. Evo6 AYC diff, planetary gears side parts availability?
  73. Magnus Dry sump
  74. Is this a boost leak or normal? (video)
  75. ACD Relocation Wire Gauge?
  76. SCE Vulcan Cut Ring Head Gasket
  77. FP black Zero Boost.
  78. EVO 8 TPS question, pic attached..
  79. EGR Hoses popping off valve -Troubleshooting
  80. Need Help! EVO9 Crossmember Issue!
  81. EVO 3 Oil/Filter
  82. What cams best suit my 2.3l fp black setup.
  83. Evo 6 cv axle help!
  84. HKS 3037s turbo kit
  85. 10psi wastegate spring, but can only make 6psi
  86. Does a VTA BOV stay open on decel?
  87. Catch can fitting
  88. Catch can fitting
  89. Modified 4G64 timing cover
  90. Evo VI low rpm and idle whine
  91. New Hole
  92. Evo 7 AYC dif and acd tcase oil change and cluch pack replacement.
  93. Evo 8 boost leak throttlebody
  94. bigger oil pan
  95. Code P0507
  96. RossSport 2.2L stroker kit reviews ?
  97. 2.3L 6466 E85 blue smoke when you blip throttle at decel and at idle
  98. Oil leak
  99. best and cheapest mod I've done
  100. Turbo Lag / Engine Check Light
  101. Low Boost
  102. 03 Evo 8 5 speed noise/rattle
  103. Arlington Machining Oversize Headstud Washers
  104. Valve cover pressure - boost leak test
  105. Where to buy oem Evo 9 Catalytic Converter
  106. Non ACD Diff help
  107. Hardrace front engine mount cause more stress on gearbox?
  108. Evo 6-speed and 5-speed Driveshaft (Propeller shaft) Differences Question
  109. Map sensor install jdm evo 8
  110. Injector Seal Replacement
  111. Oil Pressure testing different oil filters (MD356000)
  112. JDM Evo 8 MR idle dip
  113. What injector adapter is needed
  114. Xr9569s
  115. Moroso oil pan with 100mm crank ?
  116. Running on 3 cylinders at wot.
  117. 20G upgrade
  118. FP3794 divided hotside?
  119. 6 speed output shaft diagram??
  120. Evo 9 Engine Build Advice/Tips
  121. Evo 9 downpipe without donut gasket
  122. 4G63 tools?
  123. New Evo owner, misfiring. Please help!
  124. Turbo inlet piping size
  125. EVO 3 short shifter?
  126. Defi Oil Pressure read constant 20PSI?!?!?!
  127. Can AYC rear diff be rebuilt?
  128. Mishimoto UICP - Questions
  129. 500 HP engine build
  130. Alternative Hydraulic Lifter from Hyundai/KIA
  131. No Start, No SES, No OBD2 data, No Fuel Prime
  132. ABS Light ON at acceleration and high speed and stay
  133. EVO 4 CN9A -Transfer Case
  134. evo 8 oem trigger problem
  135. Turning AYC rear diff to a mechanical LSD
  136. What to do next
  137. Idle issues - light coughing when idling
  138. 2003 Mitsubishi Lancer evolution stalls/won’t idle when warm.
  139. Sticky shifter after short throw install
  140. Evo 8/9 Catch Can/ACD Reservoir
  141. ID2600cc and stock ecu
  142. Evo 8 Northeast Indiana
  143. Help with these cams
  144. Evo 8 MR Blow By
  145. Evo 8 - 5 speed shifter cables
  146. Evo 9 head bolts
  147. [Video] Evo 6 - Ticking sound - cruising at high rpm before engaging turbo
  148. is 750 AWHP possible on a single 535 pump
  149. Cam help. Trying to revive this high mileage evo
  150. Shifter play
  151. Garrett E-turbo
  152. Which 100mm crank ?
  153. Locked in reverse My evo go’s in reverse when I’m neutral
  154. Finalizing the plans for my PCV / Catch-can / crank-case system
  155. Car blocks when trying to start driving
  156. oil pressure switch thread?
  157. 6 Blade billet wheel vs 7 blade billet wheel
  158. Will Evo7 motor fit with Evo 8 ECU and trans
  159. Uphill Problems?
  160. help..
  161. HKS 7460 idle issues
  162. Evo 8 Running like trash. Out of ideas
  163. Cruched bearing #2
  164. Evo 8/9 ACD Pump Rebuild/Replacement
  165. Grimspeed Boost Controller not responding?
  166. Buschur 2.0L LR or 2.3RPM???
  167. Evo 9 first start up
  168. F5M51 Transmission
  169. What Turbo set up for 2.3L street race Evo IX
  170. Compressor housing inlet size - Stock EVO 7
  171. Hard boost leak (with Video)
  172. Valve lapping
  173. EVO 6: Factory Bearing Sizing
  174. Camshaft options
  175. Weird whistling noise ,what is it?
  176. Evo 5: Cusco Twin Plate Clutch
  177. Water pump pulley
  178. Evo 8 engine swap
  179. Magnus mechanical pump advice
  180. How much turbo is too much turbo HPDE
  181. Sparktech cdi cop not working NEED HELP!!!!!!!
  182. Need some help, car keeps dying
  183. Final Drive selection with lr2.4 & gtx3582
  184. Skunk2 alpha rods
  185. G4js
  186. Anyone heard of an Albins 3rd 4th and 5th gear for their 6 speed?
  187. Need helping on my build, couldn’t decide on what to do.
  188. Tranny input shafts
  189. Looking towards the future. Turbo upgrade (RED) questions
  190. Valve guides leaking?
  191. Actuator Turbosmart
  192. question on efr size for 500kw
  193. Evo 3 rebuid
  194. Crankwalk Caused by Clutch?
  195. Help! P0201, 202, 203, 204
  196. How does this Piston, Rod and Crankshaft combination sound?
  197. Help deciding on what upgraded turbo to get
  198. Possible Blown Conrod - A Couple of questions
  199. Rebuilt head lifter tick issue
  200. Thoughts on my fuel system plan
  201. No reverse after repair of shift selector on transmission
  202. Change BOV Without Tune?
  203. What’s the pros and cons to switching t case
  204. Mysterious oil leak
  205. ACD EVO 8 FRONT WAVETRAC LSD AND Quaife ATB Helical LSD Center Diff
  206. Fuel Surge tank optoins
  207. Strange sputtering when shifting (somewhat urgent)
  208. Quiet whine in 3rd and 4th?
  209. Oil Pressure low when warmed up. could use some input please
  210. Set Bearing Clearances
  211. Wonky compression cylinder 3
  212. JDM evo 8 - stock tune ok with mods?
  213. Ebay muffler delete - anyone have?
  214. EVO 9 4G63 2.2L MIVEC - Turbo Selection
  215. Evo 8 Nitrous dragstrip Help.
  216. GTX3076R GEN 2 - Turbo question.
  217. Revel Tanabe Medallion Catback -- anyone tried it?
  218. rpm drops down with cold engine (drown)
  219. Iacv testing
  220. MR 6-Speed Upgrades?
  221. Evo 8 Running Lean
  222. Valves
  223. Short shifter to 6-speed manual
  224. 4.11 FD on 2.3 Stroker with FP Black
  225. Evo 6 Piston Oil Squirters
  226. Hiccup
  227. Mahle Piston Ring Gaps
  228. Someone double check my timing please.
  229. Gears wont grab!
  230. Exhaust missing bung ?
  231. Transmission fluid leak
  232. Blowing smoke on idle
  233. With porting skunk 2 intake manifold?
  234. Evo turns off while cruising
  235. HTA71 with 2.3 Stroker and FD bad mix?
  236. Evo 8 500WHP STOCK BLOCK GOAL!
  237. Coolant Temps
  238. Gearbox components
  239. Balance shaft removal
  240. Evo 7 push type clutch
  241. hood exit
  242. Blow off
  243. Nos Kit on somewhat stock evo 9
  244. Evo 8 engine teardown!!!
  245. Evo VII Rough Idle VIDEO & LOG
  246. TBE or Cat Back or ?
  247. Bearings!! ACL race or king PMAX
  248. MHI 18K vs Blouch Dominator XTR vs HKS GTIII RS
  249. ACD Pump #3520A077/MR580057 is discontinued
  250. Need helping with s90 throttle body
