- Buyers remorse.. need help with air filter/intake
- would an evo ix turbo really be worth the money for me?
- main girdle and block question
- AMS 35R downpipe solutions.....
- CBR coils and harness and MSD DIS 2
- 2.3 fp black with mr tranny
- Don't bleed the clutch with a motive power bleeder.
- car stutters when turning on?
- ACT Xtreme/Street Disk
- AMS Cam Side Motor Mount
- Vibration at 5th gear
- Which filter to use on my intake HKS suction of K&N
- Is spraying meth on the 2 step safe??
- SES flash Not WOT
- Nice week! NOT
- Not the way I wanted to end my day....
- Quick clutch question
- Stock Fans Question
- Did a compression test.. wtf
- e85/93 pump related question
- denso 1000cc or fic 1100cc injectors?
- Head Stud swap...
- Proper Crank Angle Sensor Signal?
- special tool for timing belt
- 5MT, 5th gear issue
- Which Clutch Kit Recommended???
- rear motor/roll mount bracket FML!!!
- Wastegate Stuck?
- Evo VIII 5 Speed to MR 6 Speed Swap? Can it be done?
- Comp Hsg R&R
- My evo from chump to champ by MDR Performance
- What downpipes are similar to the AMS???
- 03 Evo 8 - Overheating issue.
- d tuned?
- 2.3 build?
- 05 Evolution 8.5 MR
- installing output shafts
- Changing your spark plug
- blow off valve OPEN while idleling...
- 05 mr 6spd tranny 82k, clutch fork broke off!!!(pix)
- Transfer Case Fluid.. Quick question !!!!!!!!
- Evovin is back! (TurboTrix Racing)
- boost leak
- Synapse BPV: Placement w/ Injen Intake
- Got rid of my o2 sensor check light finally....
- Ticking from where the Cam angle sensor is at?
- Swapping Turbos Help
- cleaning intercooler
- Battery/Aternator Problem!? Dont know what to do
- Run an upper timing cover
- bcs question? has anyone tried this?
- help with built evo 8 running lean on acceleration
- Lots of noise after cam install
- Strange boost issue 06 mr
- psi on stock....
- Hallman MBC Boost Source
- intake mani
- PT6235 Street/Strip Pump 93 Yes or No
- runner volume?
- Evo VIII stock, should I imitate turbo timer?
- should i use obx manifold for a red?
- RC 1000's vs PTE 1000's
- FP Black 25 PSI
- turbo noise?
- Stage 2 Transfer Case Rebuild
- Switching to SD, what intake?
- ACL or Clevite Rod Bearings???
- Power steering coolers?
- Need some advice
- Tranny sound weird
- Advice for new clutch, ACT2600 blew after 63,000miles!
- Vivid Racing's review Exedy stage 1 clutch and flywheel, Agency Power bushings
- can i drive on ethanol e85/e70 with 1050cc and walbro 255
- Evo 8 and 9 clutch compatibility
- Unsteady boost?
- RS and Evo 8 tranny
- Summer Project: FP Black 93 pump only
- shep transmission owners come inside..
- 500whp on E85
- Will I be able to make 500hp..???
- need help, vehicle cuts out
- noise in the transmission
- fuel rail or fpr??????????
- fuel pump...
- Car won't start! Need some help.
- Ets licp~
- Stock Exhaust Manifold: BR vs. MAP vs. PPI
- anyone know size of small TC o-rings
- ETS Stock Replacement Twin Scroll Manifold With Twin 38mm TiAL Wastegates
- throw out bearing question
- Need help maxing out my stock IX turbo - advice on what to do next!?
- Build a motor or buy a built motor. 20, 2.3, 2.4. Engine builders please read
- transfercase o-ring is a magician
- Need input what is the best head gasket when boosting 2.3 bar?
- pte 5557r
- Head/Shortblock Question
- help!!!
- Dyno dynamics dyno 1.1 conversion to dynojet.
- FP Red to FP Black
- Problem someone please help!
- Tune up parts
- Ported Head
- Engine ceramic coatings question
- Best size intake for 35r?
- How Many Teeth Till BANG!! lol
- Which RECIRCULATING O2 Housing Produces the Most WHP between the Older/Newer Units?
- Power Enterprise Air Force Turbo
- LICP and turbo outlet ???
- weirdest problem ever...
- boost leak test
- IC piping clamp.
- Drivers Front Axle Length
- Fuel pressure regs
- Anybody have issues with fic 1450 injectors on stock evo ecu, with cold start up idle
- oil on BOV
- fp hta rebuild
- best exhaust manifold???
- Turned Crank Theory..Controled Test
- Another quiet exhaust project (BluEVOIX and beyond)
- Stock BOV
- Chirping in the Rear
- Which hydraulic TOB?
- wastegate troubles
- Exedy triple clutch Overhaul kit
- How Do I build a 2.1L
- Aem tru boost...... Whats ur thoughts on it???
- Drewdq's SBR 2.4/FP Black Build
- Best Intake Manifold!?
- FIC 2150cc OVERKILL?
- Major Revision & Updates to Synchronic SB001 BOV
- tial mv-r wastegate water cooled
- Forced Performance Finally Releases the HTA3794.. 900+whp Capable T3!!!
- Well, 159k and it finally happened...
- Strange One For You - Clutch Problem
- Help to figure out where to connect boost pipe...
- Intercooler color...?
- Poly Shifter cable bushings... any failures?
- Breaking- up
- transmission problem.
- How many quarts of oil
- injector help
- Evo 8 compression problem.
- Preventative transfer case rebuild?
- Unorthodox Lightwight Pulley
- 80mm fp red intake options help
- CBRD radiator and fan
- CRC fuel system cleaner, is it safe?
- is it the axles or Tcase?? w/pics
- Injector Wire Help!
- why is my grimmspeed ebcs so loud?
- fixing codes P0113 and P2228
- Any one know a install kit only for a gt35r
- i was stupid....re used flywheel/PP....new clutch
- evo 8 10.5 to evo 9 turbo??
- Anyone running octane on demand? 2nd fuel tank?
- aberdeen area
- What bov to run with fp green hta?
- Intercoolers (evo4-9): weight's?, temps in/out, hp gain vs stock??
- Oil cooler line gasket size?
- turbo flutter
- valve springs to use with comp cams?
- Flame away.....
- 4g63 block or 4g64 not sure
- Question about PCV Valve connection to valve cover
- Thread Pitch for Clutch Line
- built tranny question
- MR pops out of 2nd??
- LC-1 Very Lean Readings
- Random miss at 2,000rpms!?
- sigh. a/c problems.
- Trans Dilema on Evo VI TME
- billet 6765 surging when brake boosting?
- anyone running DeatschWerks 1600cc Inj with e-85?
- boost pulsing with HKS EVC IV
- long shot turbo question
- So you have Meth Injection.. Are your pistons also cracked??
- Sent my Exhaust Manifold to Buschur for Porting & Jet Coating BUT....
- fp red invidia o2 housing
- fp red turbo on my evo9rs
- ATL Fuel Cell Options
- single Knock/pop noise at low rpm take off
- Exedy Twin HD Pressure Plate
- Acree's MAP 2.4L FP Black Build
- Ill effects of Dirty/Rusty Gas Tank on EVO?
- FP Black intake options
- bottom end parts what do I need???
- Most hp on stock viii turbo????
- help! evo 6.5 t case problems!
- Precision turbos
- HKS or Forge RS
- springs and retainers??
- Kelford 272 Vs. 280
- Any 600+ Evos run a Turbosmart E-Boost2?
- Car breaks up intermittantly
- Car Just Died at 6k and Heres Why (Check This Out)
- HTA Green Boost Spiking :( Anyone else got this problem?
- turbo opinions
- trans issues/questions
- After-market ignition system.
- Performance in Hot Humid Weather
- thermostat housing gasket
- weird noise
- Best Intake with TBE??
- passing emissions
- Startup issues??? HELP
- Exedy Twin HD Pops out of Reverse
- clutchmasters fx400
- epm o2 dump confusion
- Loud Bang, -10 to 15 PSI. Help needed
- Samco Vacuum Hoses
- Stroker kit
- Apparently throttle body vacuum leak. Help Please!
- evo 9 uicp suggestions
- exhaust gasket may have went out
- Evap, egr, emission and cel
- Turbo Storage
- What belongs here....some hlep
- PS fluid leak diagnosis?
- HKS timing belt with 2.1L motor
- hta86 with cast manifold
- Big idle problem? Need help
- 4.11 gearing
- Quick question about forge actuator
- many problems....car wants to stall when using clutch in traffic and reverse
- What Size Is The Stock Turbo Inlet?
- Need some advice for my build.
- Whos has ACL Race bearings in Stock??
- e85 or meth ??
- hks twin plate clutch, opinion's
- Data results with some mixed parts.....
- Check Engine light after engine swap
- Small leak, ACD breather issue?
- custom intake shield/air guide
- ams f1-i manifold Questions can any1 help?
- Replaced PS pump now I have no PS at all
- Well freeze plug blew out of the block again...
- ETS LP2 LICP w/ Buschur Street FMIC?
- changin cams for 272 kelford?
- Fidanza Bad Customer Support!!!
- 02 Dump Question
- Clutch master cylinder leaking.
- Abnormal Engine Load?
- Diagnostic Help Please
- i searched already, transmission/clutch issue exedy twin hd
- who offers the best porting for a fp black as far as hp goes?
- Need help fast
- Is it worth porting an fp black turbo? If so what sort of gains have you seen?
- One for the turbo tech's which turbo's for compound please.
- Evo 5/6 radiator in and 8?
- BR billet rear diff supports, improved.
