PDA
View Full Version : Evo Engine / Turbo / Drivetrain
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251
  1. please help.in witch order are firing the cylinder when i oped the hood.
  2. Where can I get a QM Twin rebuild kit?
  3. Lifters help
  4. car is pissin me off !!
  5. building my 2.0L
  6. I just...
  7. Stainless Steel FAQ or WHY IS MY SS EXHAUST RUSTING?!?!
  8. Best Turbo for 600hp
  9. Verify cams..
  10. Suddenly Lean at WOT!
  11. Any new FP-BLK or BBK-XL info????
  12. Oil coming out my bov? need help?
  13. t3/t4 feed back
  14. COP with Dynatek CDI - yah or neh?
  15. Filling T-Case
  16. Compressor maps for FP Turbos (red/green)
  17. Tubular Manifold vs Catback
  18. Clutch Help!
  19. 5 bolt garrett O2 housings?
  20. Improving the Reliability of the 4g63
  21. evo 9 and 8 o2 sensors
  22. Hks 272?
  23. Tial wastegate
  24. O2 sensor help
  25. boost problem...
  26. ETS FMIC install thoughts (a few pics)
  27. Boost leak around TB
  28. Throttle Body "Drivability"...
  29. More PSI?
  30. bbk full vs sst
  31. Blue smoke after a boost leak test
  32. Evo gearbox rebuild. What wear is acceptable? several pics!
  33. ETS Intercooler Spacers - Help
  34. car makes a rattle when clutch isn't in
  35. EVO IX bov concern/issue
  36. Fidanza flywheel failure!!!
  37. turbo thinking about getting this..
  38. oil pump case Question
  39. A question for Dave Buschur about the Deluxe FMIC
  40. waste gate getting weak?
  41. Carbonetic Single??
  42. About Tran's Fulid HELP?!
  43. cleaning the head
  44. Mobil 1 FTL!
  45. Avid Motor mounts - Replace the sides with Stock?
  46. NEW PARTS!! See pics!
  47. Removing Injector Resistor
  48. engine builders i need help
  49. Boost Creep (not a usual BS thread)
  50. 9 trans in a 03
  51. Black Smoke
  52. Clutch
  53. Battery relocation question
  54. Please Help.. Need to identify what and where these go...
  55. Thinking of trying this
  56. Second Opinion: Radiator Issue
  57. LICP, which one????
  58. HKS 272 cams?
  59. head removal
  60. For the real mechanic
  61. acd reservoir???
  62. Driving issues.
  63. So.. My ACT clutch fell apart!!!!!
  64. shifting stick
  65. Larger T Case O Ring
  66. How many of you live with all 3 ACD lights?
  67. Opinions on FP red setup
  68. greddy ti or ets 3.5 inch exaust system
  69. missing / surging Evo 8
  70. How to test a Walbro 255 off the car
  71. when doing camshafts 272s
  72. Help Identify this FMIC
  73. Oil cooler help!
  74. Map performance ultimate rods
  75. Help with Avid motormounts
  76. need help!!! Stock ignition
  77. Can a vibrating crossthreaded EGT probe be causing knock?
  78. Grinding in second sometimes 3 PLEASE HELP!
  79. Front under panel
  80. Best 280 Cams
  81. Stock 10.5cm turbine housing divider cracking
  82. Worn Exedy twin disc
  83. OEM flywheel resurfacing - specs?
  84. What should be done first? (Head or Block)
  85. oil consumption? motor issues
  86. Crank Pulley Causing Knock
  87. AMS TBE Fitment Issue
  88. QM 7.25" V-Drive Service Parts(Clutch is slipping)
  89. New guy, I have some simple questions
  90. knocking noise from tranny
  91. P0401 CEL after missed shift/super high rev
  92. Which OEM oil filter should I use from now on?
  93. still having a problem- help
  94. Mitsu fluids or AMSoil for 30k
  95. diffrence between 8 and 9 turbo?
  96. Evo valve cover baffles
  97. Another cam question
  98. My evo is breaking up badly under wot help!
  99. Gearbox Or Clutch Problem, need advice
  100. ams Moustache Bar Eliminator
  101. 2.3l or 2.2l?
  102. Sparkplug cover with vents?
  103. Hks bov
  104. Turbo XS MBC???
  105. T.R.E. Stage 3 tranny, humming sound in 1st and 2nd gear?
  106. Greedy Counter weight and ebay short shifter combo?
  107. motor mounts
  108. need help choosing ignition system, plugs, and injectors
  109. AMS oil cooler on a MR?
  110. PITFA shifter issues...
  111. clutch flywheel combo???
  112. Anyone seen this sequential before?
  113. 'Short' UICP Kits
  114. hks exhaust problem?
  115. Smell of coolant inside the car? Also cooling issues?
  116. Re-Torque Head Studs?
  117. HTA35r or FP Red?
  118. boost 'flutter'
  119. 6 Speed vs. 5 Speed
  120. metal shavings in oil
  121. Custom moroso oil breather can (help with fittings)
  122. tranny....fluids
  123. Info and facts about the Wilson Manifolds D Rail for the Evolution
  124. Tuned on wrong spark plugs
  125. Need you help fellas PLEASE
  126. Stock battery and airbox UICP?
  127. 6 speed to 5 speed
  128. IX Block Carnage
  129. High hp, stock block, High milage
  130. Jun 272 Cam specs?
  131. Ams downpipe rubbing tc ?
  132. Help turbo oil leak
  133. Vent to air BOV question. Please help!
  134. One step colder for my 9 with red not sure which to get ?
  135. Evo IX Mivec and Cams question
  136. Hks rs....absolutely need tune?
  137. Internal Fuel Pressure Leak ?
  138. GT3567R....any info?
  139. Fuel injector clips evo 8
  140. Spec clutch problem
  141. What's the best FMIC??
  142. stock block weight ?
  143. Stepped Compressor Wheel
  144. turbo mag best exhaust results?
  145. Does something look shady here?
  146. One shaft - two turbos
  147. Injen pipe size
  148. Competition Clutch owners..
  149. coming to a biger turbo
  150. How much WHP can hks dli handle?
  151. Transmission Bolts
  152. Knock sound
  153. second gear notchy, feel like grinding when it cold - 6speed mr tranny
  154. About Exhaust Mani HELP!
  155. FP HTA3586 Not so sure???
  156. help request, my lazy Evo 8??
  157. boost controller question
  158. Will the FP Red work on the EVO 8
  159. Frequent Oil Changes Bad ...
  160. please help
  161. starter solenoid?
  162. which exhaust?
  163. Bad Boost Creep... After porting ss o2 housing...
  164. Boost Leak Test Problem
  165. bogging inbetween shifts...... why?
  166. Were to Start......Advice
  167. Boost leak test concerns...
  168. Fp red oil line help!!!
  169. HELP: Installing AMS Turboback
  170. tranny plug thread sizes
  171. engine fure keeps blowing
  172. Burning water. What to do?
  173. the chump is stumped
  174. ticking noise coming from engine bay somebody help please?
  175. Aftermarket Wastegae on 9 turbo
  176. Weird rattle when idling
  177. Very rough Idle with A/C on
  178. Car Broke AGAIN!!!
  179. High boost reliability for road racing
  180. is this really a helix downpipe
  181. 4G64 120K engine service
  182. Me and my wife installed then GSC 272 cams today :)
  183. fuel pump help!!!!
  184. Problem with the ACD
  185. What fluid should I be using for here?
  186. Throttle Body Shaft Seals
  187. When Are Springs/Retainers needed
  188. Turbo upgrade help
  189. Question on Boost Leak Test
  190. Transmission Installation
  191. Removing a mangled TOB
  192. ebay o2 housing wastegate port
  193. How to identify a TRUE IX turbo
  194. About BR FMIC
  195. front end noise ? Drivers side
  196. Mysterious Boost Leak Under Intake Manifold
  197. ACT CLUTCH not for me anymore!!
  198. Piston Rod install direction? Scat - Need help ASAP
  199. New turbo install, nasty smell
  200. Synapsis BOV Installed
  201. SpoolinUp COP installed
  202. Slightly Modded Boost Levels
  203. Oil leak after turbo swap!!! HELP
  204. Where does the AMS TBE stand in horsepower vs. noise and what's better???
  205. Transfer Case Problems Please Help
  206. Fuel pressure testing with the BR double pumper
  207. Apagan01 riddle me this.
  208. Mechanical issues diagnosis
  209. help: Clutch or Sychros??? or WTF is it???
  210. Exhaust housing?
  211. ralliart clutch kit
  212. EVO Tuners near cleveland???
  213. Will a Injector driver box help drivability on 1600cc inectors?
  214. Ways to hold boost at higher rpms
  215. Overhearing Issue
  216. Pic request: STD ams tbe tip with jdm rear
  217. Doing my clutch saturday, heres my checklist
  218. Fourth and fifth gear pull feels werid?
  219. Motor stumbles a bit after filling up...
  220. Noob: Are clutch release bearing & throwout bearing the same thing????
  221. Dealer quote for 30k service
  222. New Turbo, To Cam or Not to Cam? - That is the question
  223. Idle Problem and Throttle Lag
  224. spark plug gap, and power loss...
  225. Injector Placement Discussion
  226. guess the brand
  227. need help!! stage3 TC sheperd
  228. small hole in axel boot
  229. Anti sieze on hotside parts?
  230. Buschur Racing Solid Rear Diff Bushing
  231. half Radiator
  232. Need Fuel Pump Help
  233. stock 4G64 crank
  234. Seeking a Clutch.. Help
  235. Help me fix my Trust Ti-R exhaust please!!!
  236. High Compression Help
  237. 37R on stock motor?
  238. tial 50mm bov
  239. small trans problem, rebuild?
  240. Whats a used Cabonetics cc twin worth?
  241. Turbo Pressure and Engine Damage
  242. Help Diagnosing
  243. Decking the head
  244. MT-90 in MR 6 speed tranny?
  245. What is needed to put a viii turbo with a 10.5 hotside on a 9.8 car?
  246. 6sp shifter counter weights removal help
  247. Exedy Clip Pop Problem... does it affect the triple disk?
  248. New TC but ACD still on?
  249. FP white turbo what do you think
  250. GSC S1 vs. S2 vs. 272
