- Safe EGT's on EVO
- Turbo oil line question
- RPM drop when boost at 15 psi
- Help! car will not start
- Question on Hyperground Cables
- oil cooler fitting size?
- High boost breakup
- help...
- Exhaust opinions.
- Buschur/SMC Alky Kit question
- CBRD- GT35R pics
- I blew up my turbo
- ACT Prolite Flywheel?
- 903 whp/624 ft lbs AND 460 whp/532 ft lbs Buschur Racing meets the Dynojet...
- Theoreticaly...
- My solution for Potential boom boom
- Does the stock fuel pump use a solid state relay?
- Heard a loud "thud" sound while powershifting 4th
- Custom made engine harness plugs needed.
- Wastegate size
- GT-42R? or leave alone?
- Single Flapper vs. Dual Flapper design 10.5 Hotside???
- Flywheel Bolts
- My ISP GT35R Turbo Kit
- Cam Gears!!!
- Is it tunning?
- Installing Buschur "RACE" FMIC... Have ?'s
- Transmission Differences?
- Spark plug recomendation?
- Calling all with aftermarket O2 housings
- 20G or 16G ?????
- GT30 Coolant Lines Question
- Custom Dyno tune or Custom Road street tune?
- No Boost
- knock sensor pigtail
- Data on various MY Blown Engines
- BR7ES or BPR7ES??
- Evo Died...
- Need a 6spd for a 04 Evo8
- Gt37r on the street
- turbo xs ?
- newbie evo 9 mr
- ATP's GT35R T4 flanged exhaust housings .
- Exedy Hyper Single gone at 4000 miles
- Broken Transfer Case?
- Who is running t3/t4
- Why do shop cars use mainly the 2.0L instead of a 2.3L in their race cars???
- I have a HKS CRBNTI for a is300...
- ams stage 1 and 2?
- Doing Buschur pistons/rodds/rings....few questions.
- So how long will a stroker live in a street driven car ?
- how to prime a brand new crate motor?
- GT35R Installed!!! OMG... So Much Fun!
- What is the quickest spooling turbo than can hold 25psi up to 10k rpm?
- Anyone have experiance running a Nitrous fogger on their FMIC?
- ATS Twin Carbon Plate Clutch
- low boost on my IX???
- Some One Tell Me What To Do
- agency ss cluth line on BR350 IX
- Problem with oil light
- Buschur Front mount Tune??
- Looking for a good downpipe for my 05 evo w/ a RS*R Exhaust
- Buying used cams
- Cams for MIVEC IX...
- Holding boost to redline
- APS intake?
- How much does mitsu charge for a 6 speed MR transmission?
- Building a 2.4L, any ideas?
- Warped Drive Shaft?!?!
- Boost leak test results
- cleaning buschur filter????
- need help info turbo
- Turbo Upgrade Poll
- how much more power would TD06-20g 8cm housing put out vs. stock turbo?
- so pissed off last night
- Type RS bov
- Anyone one using a Dump Tube?
- I know this is a dumb ? to ask, but I gotta ask!!!!
- cams?
- Maxford Turbo Manifold on the Dyno
- My new Evo IX, aftermarker BOV?
- i need help finding a turbo and bov
- Need Help With Wastegate Install!
- BR Stage 2 & Tuning
- 20G-9 + Koyo racing radiator + Forge WGA = need slim fan
- Bigger Intercooler opinions
- 911, need help - long
- Spun Bearings again????
- Engine problem
- BOV Question
- Blew engine today under extremely normal circumstances. not happy.EDITED
- boost leak?
- Buschur Race FMIC vs. Nisei vs. Injen Fmic
- IX 20 G from Buschur delivers at the track with a 11.3 @ 119
- RPMS raising
- Transfercase Fluid....Still Unanswered
- Turbo PSI?
- Forge RS setting at 22 psi?
- Where to run the oil feed line?
- Why did my EVO do this?
- which turbo/motor combo to go with HELP
- Altitude Dyno Comparison
- Very long post of deep thoughts from Smogrunner
- fuel cut?????? Help
- All Bov's?
- boost ?
- ill effects of useing a 4"-3" on turbo?
- Greddy bov not blowing off loud at all?
- Will a new tire kill your center differential?
- should i upgrade fuel line?
- How much more power can be had with these afrs?
- one for all you techies! :)
- Can you have 2 boost gauges?
- ticking noise once in a while
- Stock IX MR...Ticking at IDLE. WHY?
- question
- aftermarket boost control solenoid
- Finally...
- MR Tranny's! Any Grinding Issues?
- Why is car only doing 10lbs
- The SMART XEDE just got SMARTER
- question mr Buschur.
- Problems! Fan not working! and car overheating
- Whine Questions...... Anybody???
- anyone here pieced their own stroker kit?
- Worth upgrading the IX turbo to a 20g?
- GT35R teaser
- ambient temp and boost?
- Problems with Magnacore wires
- Injen intake...
- Do you need an MBC with a flash?
- Lets talk about short shifters....
- Error Code:P0136
- specs on the TD05 25G?
- Problem making boost... ??
- fuel pump?
- HELP w/ hallman mbc
- cam gears .HELP
- Engine Smell
- question about megan downpipe
- Evo IX mod list. What do you think.
- Very long post of thoughts from David Buschur.......
- Lower IC Hose Sizes?
- Service engine light
- The theory of Synthetic oil in New EVO
- Factory Boost Control Solenoid Pill
- I dont understand??
- fuel hose size?
- Boost and Redline question
- More issues.....
- weird whistling noise...
- intake hard pipes?
- 1st gear grind
- Call out to Buschur for a TD06 20G
- Are the hks 272/272 cams worth it?
- Shep Tranny
- From .70 to .60 comp housing
- Huge request
- IX Turbo
- Yet another check engine code!! Help please!!
- Not your normal exhaust question
- Omfg Help!!!
- New stock Evo 9 turbo for $599???
- Why does the boost taper off?
- Worst luck EVAR with wheel studs....Help please....
- OEM diverter valves?
- Boost leak
- What power does the HKS GD PRO clutch hold?
- Buschur Mbc problem
- Amsoil tranny oil is awsome
- max rpm's on stock bottom end
- Shes finally completed...for now
- intercooler
- who has 10.5 hotsides available?
- alky injection version2 smc,,,,NOT SPRAYING NO MORE...HELP?
- Need Advice please
- Boost falling with MBC?
- Cold Start Rattle
- Ebay fitment
- Anyone ships Diaqueen internationally?
- BLITZ vs GREDDY exhaust
- Can you install a APS 3.5'' (TBE) on a Evo IX and will you lose top end?
- Turboxs Downpipe with o2 bung??
- Home made MBC???
- Megan racing exhaust
- possible to get 310whp with buschurracing satge 0 evo 9 turbo
- Oil pressure guage install Best way to mount sender??
- Stock Wastegate Assembly?
- Annoying IX problems
- HKS SSQV redesign or fake?
- Questions after o2 housing install!!!!!!!!!!
- Just flashed by Sean Ivey
- Q: ECU wire & PLX M300 install
- what power steering fluid for evo?
- Anyone know how to crank the engine without starting the car??
- hks cf ti exhaust sits low
- Cam Gear Cover Issue
- cam gears???
- Stinky clutch....
- Where to Find V-Band in SoCal?
- Questions regarding CEL's
- throttle body
- Turbo kit install???
- Choice of Cams?
- Zacklee Clear Cam Gear Cover???
- How can I tell what cams I have?
- Possible Tranny problems...?
- BLITZ SBC iD vs. Hallman/forge MBC
- ecu question.
- Aftermarket BOV's
- 4G63 engine weight
- Documented 4G63 endurance
- went to the track todaywith my 05 (time slip inside)
- Tuned by Jestrtuning and TTP Engineering from Orlando!
- what next?
- Weird Boost Spike
- Cant get the metal sleeve out of the front motormount. HELP!!
- Vishnu/Axiom Feb 25th Dyno day results!
- 272 comp cams question
- quiet exhaust
- what other cars can you drop in a evo 8 03 engine in?
- Stock turbo evo8 fit on sr20dets???
- Got the IX baby... couple ?'s about TBE
- Need Opinion please
- Transmission oil leaks at driver side axle
- Runnin Too Lean
- DEFI BF boost Peaked @ 1.5 bar STock?
- Well, I F'd my car!!!
- choosing exhaust needs pics if you got um
- Peak Boost FMIC install and review..
- Best intake?
- Injen UICP and Forge RS BOV compatible? (W/ PICS)
- RPS twin carbon/carbon clutch
- Standard Internal Upgrades??
- Tranny question IX
- stumbling idle
- Where are the 9 20G Dyno Numbers?
- Evo 9 MR rear drive shafts vs. Evo 8 drive shafts
- high rpm's for 1/4 mile
- Head stud
- A real 20g on an evo....396awhp pump gas...stock IC
- Best Turbo Manifold
- help me with this ****y ass mainfold lol
- 4.11 Gear Option w/Shepp tranny
- Weird Sulphur smell
- Evo dies on me! Help me
- Exedy Twin Metallic Clutch Kit
- which Turbo Timer?
- evo 9 actuator vs evo 8 actuator
- AMS LICP Impressions
