- #4 cylinder not firing??!!
- EGT probe in DP?
- Do Intercooler Changing Give Some Extra Horsepower ?
- DP/catback combo advice needed
- Just Installed APS 3" turboback
- Blitz NUR Spec R Catback Exhaust
- Bov?
- Buschur MBC
- Any results from a full race kit?
- In search of Beefier Xfer Case
- Failed OEM BOV?
- New clutch....New flywheel?????
- RnR installed my CarbonTi TBE!
- Terrible Idle, Please help me :)
- Easiest way to replace small o-ring between Tcase and tranny
- Hey guys..a little help with my evo?
- GT30R: Please post your experiences...
- What Type of Tune To Go With???
- Help Dyno Sheets Inside
- Vishnu Stg1+ vs Buschur Stg 3/4
- Need Help, Turbo is not doin' well, i think...
- APS Piggyback
- Flex Pipe
- Help throwing a CEL P0300 and P0420
- Ok to leave O2 sensor dangling?
- JUN 264 cam timing
- Boost chase
- TurboXS RFL-Ti pics
- Plug and Play "Chipping, ECU"
- Buschur 3" SCCA catback w/ Magnaflow
- changing downpipe....maybe
- Can I buy only clutch disk for exedy Hyper Single Kit?
- Sound opinions rgd BOV sounds
- another clutch question? exedy stage 2
- SAFC tune and boost question
- Where to get act clutch?
- 255lph feul pump other than walbro
- 1st Time DYNO run today :)
- Mmmmm, precious.... (BWW)
- Are there any TSB's---->
- FS- Greddy type RS bov, with flange
- Stalling @ idle, only with AC running ...
- Is RnR Racing open today?
- CEL comes on ...
- Could we use mickey thompson "street radials"?
- Tired of searching.. Clutch Options opinions.
- Not much sound out of my Greddy Type S BOV
- AMSoils Anyone???
- tranny/engine ticking/cluttering noise help!
- 415whp GT3076r on pump gas
- Turning the stock flywheel ?!?!
- smoke?
- New noise appeared last night.
- Wet IC from BOV?
- Does the AMS Intercooler need s retune?
- Part # for factory boost solenoid?
- Oh Noes!
- Anybody from alabama have stock cat willing to trade tbe
- Works axleback muffler review
- Anyone connect HELIX to Stock AIRBOX?
- possible fuel pressure issue
- 6000rpm engine knock in second gear. Help, please?
- Installed HKS 272s today
- Problem with Profec B spec 2
- gforce 5pt harness doesnt fit right w/o bar
- I need some info on the 10.5 hotside
- vishnu adjustable cam gears
- Need HELP Asap w/boost not being held....
- Help
- how does the fq400's tranny hold up?
- RNR turbo install
- buschur cone filter vs. generic cone filter
- 21G turbo from Buschur???Whats this???
- vishnu adjustable cams..
- installing Greddy S BOV
- HKS SSQ questions
- spiral baffles!
- Boost leak?
- clutch install
- HKS>exhaust/downpipe/intake 05 GSR
- Porting, Benefits worth the work?
- Question about camshafts?
- bled lifters now even louder ticking?
- Drivetrain noise during deceleration...
- Car failed emmissions
- Idling and Stalliing Need Help
- BOV leak
- lifter question
- Need Engine block please help....
- Look what I got! 11's here I come.
- Where to buy pregapped BPR8ES & BPR7ES??
- MR Transmisson Grinds
- AEM vs. GM map sensors?
- Who's got a built bottom end?
- If you installed a Buschur Slip Fit Turboback....
- How much of a weak point is the 2003 differentials?
- Reviews on XS engineering power pack
- cam install question???
- Greddy TI...Who has it?
- ALL RECALLS FOR 2003 EVO's
- Engine Build... need General Info
- trans t.s.b.
- trany fluids to use.
- Ppl w/ Greddy Type-S...question...
- Peak boost for 2005 Evos??
- dyno tuned at gruppe-s today
- R&R of transfer case?
- Evo 7
- Anyone Have Sound Clip Of Greddy Evo2 Catback
- good boost gauge
- Simple idle question.
- Best Clutch...???
- BPR7IEX, stock heat range or one step colder???
- Quieting down Helix exhaust
- Buschur Stg4 Cars w/Alcohol
- mbc, can it be disconnected
- Bov?
- BOV + Buschur Upper Intercooler Pipe
- does anyone have this problem?
- need help
- cryo2 systems
- low end tq/hp
- Having issues shifting from 1st to 2nd
- Power from the HI-Power???
- Nitrous
- Has anyone dynoed before & after with equal-length header??
- EXTREMELY annoying rattling nooise from engine bay FOUND!
- help me choose a setup
- RPS Carbon Carbon
- Any Pulley Updates?
- FINALLY got my exhaust
- used cams
- Considering class-act lawsuit against Mitsubishi
- Cali Smog Test w/cams
- Bad Gas = Blown Piston
- Reversed stock bypass valve
- 05 comp. housing price!!!!!
- Blitz Dual Drive (DD) Blow-Off Valve
- Walbro Help!!!
- BOV weird question
- Help identifying turbo......
- car "burps" during WOT
- ignition help....
- what boost w/ 100 octane fuel?
- walbro fuel pump loud or no?
- Help choosing a downpipe...
- Common torque settings...
- clunk noise from front end of car
- Buschur's 11.2 @ 124mph..
- Installed my new turbo with pics
- steel vs. stainless steel
- Will BR500 work with Godspeed DP?
- How often to change out fluids in differential, transfer case and transmission?
- What makes the evo 7 and evo 8 gearboxes different?
- Install after DP and 02 housing
- Weapon*R engine damper fix
- Dealership Impass
- Evo Engine question
- Buschur 3" downpipe question
- Problems with the clutch :(
- Turbo Wheel Size?
- boost spike help
- Another exhaust question but different.
- Best Boost Controllers? Mbc Or Ebc?
- Gears go in hard when driving fast..why?
- TITANIUM CON ROD CLEARANCE MEASURED AT 0,085 mm ?
- going to install cams without tune
- overboost cel
- Improved Power AND Fuel Economy
- GSC 272 and 264
- hks bov intake plug
- Anyone with a GT3076R
- Act 6 Puck Sound Video Inside
- Need help boost problems!
- Evo Clutch install
- Just installed my Buschur deluxe FMIC kit
- RNR 50 Trim Turbo Upgrade
- Can you adjust the MAF (VAF) ??
- ACT 6 PUCK Installed
- Help on Spark Plug and Compression number ...
- Anyone use the GFB Hybrid Bov yet???
- Ralliart Group N Motor Mounts
- PSI Problems
- Notchy third gear?
- Port the stock O2 Housing
- EXEDY flywheel bolt size
- Installed some mods. All i can say is WOW!!
- dynoflash for mods but took mods off now running weird
- Can someone explain this? (bigger turbo gain at same boost)
- Boost leak or BOV leaking????
- Mild overboost...and now NO boost!
- Apexi Turbo timer problem ..................
- Torque Specs please !!!! so i can finish putting my clutch in !!!! please
- Finally got a chance to install.....(sorry 56k-ers)
- My 10.5 Hotside Install & How-To
- Ticking noise when cold!?
- Pocketlogger vs Wideband
- Help, missing boost
- RPM jump
- Clutch Replacement, Location California
- effect of magnaflow cat + resonator
- Hallman Manual Boost Controller Choices??
- HKS DP Resonation question.....
- Will these fit on 2005 MR?
- how much hp / torque will i gain ?
- convince me to get a EBC over a MBC
- a/f ratio after downpipe and o2 housing?
- Profec B spec II troubleshooting/problems
- Q/idea about BR WI kit install?
- Worth installing 02 housing?
- HKS 264i/264e...HP???
- Highest EGT
- Smoke
- AMS Stage 3
- What psi do you have your FPR set at?
- Blew my engine, please help!!!
- Buddy Club 264/272 cams installed
- P-0420 with Helix HF Cat
- INTAKE: HKS rasing suction or ARC indution box
- Flash for 04 RS
- HAs anyone had their Ignition coil pop out a bit while driving?
- Wastegate Actuator Question
- Walbro's DAMN annoying....
- Team RIP
- ATP Turbo Upgrade
- intake options with aem ems w/o maf!!
- Question about APS 3.5 TBE
- Coil pack problem.....help please!!
- turboback and catback exhaust difference?
- RPS Single disc street clutch feedback?
- Has anyone experienced this stalling issue...
- P0300: What is your Evo's MFG year?
- What throw out bearing should i use with a exedy twin disc carbon clutch.
- Intercooler H2O Sprayer Dash Light (out)
- I want another stock clutch
- What engine how-tos are people looking for?
- Apexi Induction Box and Other Filters?
- Cel ???
- GSC 272in\264ex w/Cam gears
- ARC box or Apexi power intake/aluminum box?
- Quaife LSD In! Huge Thanks to Mike & Tony @ Road Race Engineering!
- HKS cam shafts
- Most incredible, fantastic gains from this mod
- I think I have the lowest cammed evo ever!?!?
- Turbo Headaches
- Electronic whine coming from under the car
- Temp guage
- Ok, whats louder?
- Question for tuners
